Hi all,
I'm looking at adding to my very small 30k Thousand Sons force, but want to build units that will be usable in both systems, with appropriate load outs (effectively building a new 40k TS army!). I'm looking for inspiration on a range of things that could be used in both systems, either single models, or unit load outs - if you have any ideas, please share!
Heresy/40k
5 veterans with rotor cannon = 5 rubrics with soulreaper
Flamer support squad = rubrics with warpflamers
Scarab occult = direct use as Sekhmet
Sorcerers on disk = jetbikes?
Predator, rhino, land raiders = use as-is.
Hellbrute = castraferrum dread - would anyone object to a contemptor being used as a hellbrute?
Characters = their 30k equivalent
Tzaangor enlightened = ruinstorm Daemon harriers/cavalry?
Edited by Xenith
https://bolterandchainsword.com/topic/388261-cross-compatible-units-for-30k40k/
You don't say if you prefer to use 30k minis, but assuming you do:
  • Terminators:  Use Sekhmet, although you may lose some options ( Soulreaper Cannon, ML launcher)
  • Sorcerers on disk: AFAIK there's sorcerers with jump packs in the Legacy PDFs? You could also put a 30k sorcerer on a disk and play it as using a JP (look a the cover of Fury of Magnus!)
  • Hellbrutes: I think their lore doesn't specify the pattern they're based on, so both castraferrum and contemptors should be fine with the proper loadout
  • 2 weeks later...
Register a new account
Sign in
