templargdt Posted July 26 Share Posted July 26 Hey, im thinking about putting a techmarine with some desloators in an impulsor. I read the rules and I sont see if I can repair the impulsor with the techmarine on board or not. Help? Link to comment https://bolterandchainsword.com/topic/388295-techmarine-in-impulsor/ Share on other sites More sharing options...
Solution kabaakaba Posted July 26 Solution Share Posted July 26 His rule clearly said within 3". When he embarked he is outside battlefield and cannot be within 3". So you need disembark first. 1 Back to top Link to comment https://bolterandchainsword.com/topic/388295-techmarine-in-impulsor/#findComment-6180678 Share on other sites More sharing options...
Karhedron Posted July 26 Share Posted July 26 (edited) Desolators are not a great unit to put in an Impulsor because they have two separate weapons. The Firing Deck rules for the vehicles like the Impulsor are as follows (emphasis mine): Quote Firing Deck ‘x’: Each time this TRANSPORT shoots, select one weapon (excluding weapons with the [ONE SHOT] ability) from up to ‘x’ models embarked within it whose units have not shot this phase; this TRANSPORT counts as being equipped with those weapons as well. Until the end of the phase, those selected models’ units are not eligible to shoot. This means that Desolators in an Impulsor can only fire one weapon, not both. Hellblasters or Infernus Marines are probably a better choice if you want a shooty Impulsor although most people use them to stage melee units. Edited July 26 by Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/388295-techmarine-in-impulsor/#findComment-6180687 Share on other sites More sharing options...
templargdt Posted July 26 Author Share Posted July 26 2 hours ago, kabaakaba said: His rule clearly said within 3". When he embarked he is outside battlefield and cannot be within 3". So you need disembark first. Thanks! Where does it say that guys in a transport are off the battlefield? Link to comment https://bolterandchainsword.com/topic/388295-techmarine-in-impulsor/#findComment-6180694 Share on other sites More sharing options...
kabaakaba Posted July 26 Share Posted July 26 (edited) 16 minutes ago, templargdt said: Thanks! Where does it say that guys in a transport are off the battlefield? 18.02 last paragraph. Quote When a unit embarks, the active player removes that unit from the battlefield and places it to one side – it is now embarked within that TRANSPORT and is not on the battlefield. Edited July 26 by kabaakaba 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/388295-techmarine-in-impulsor/#findComment-6180696 Share on other sites More sharing options...
