Shadow Talons - part one - Verdantia
Go to solution Solved by Adeptekon,
Many years ago, when I first started getting into Warhammer, my daughter thought it was cool and wanted to be a part of it too, but didn't like the girl stories.  I said I'd come up with something for her.  Six years later, I've finished the prequel and she has well and truely moved on...  Anyways.  The Shadow Talons is in two parts, this is the first.  It starts in M25 and is suppose to be around the culture of the home world that seeds the culture of the Shadow Talons.  There's a few canon challenges, especially in part two, but I've tried to find the gaps and weave things through.  Keen to get your opinions, let me know where I've pushed to far or have completely busted canon.  If I've done it right, it should be here as an ePub download.
Shadow Talons - 1 - Verdantia.epub
Edit: The attachment hasn't worked for some, so have pasted the text here.
Edited by Shadowtracks
link to fiction text in this chat.
https://bolterandchainsword.com/topic/388323-shadow-talons-part-one-verdantia/
  • Solution
Like copy and paste the text of the attachment into your post here. That way people can read it without having to open an attachment. As you can see it was unavailable for kabaakaba and some people avoid attachments because they can have viruses.
THE ANAM TALAMH
ANAM TALAMH · VESSEL NOTICE 214
Passenger Comfort Advisory: Transit Noise
Fifth Warp Leg · Issued 12 November 24603, TSR
Good evening. This is an automated advisory issued on the guidance of the Navigator.
Over the coming watches, passengers may notice the ship sounding a little livelier than usual. Conditions on this leg of the transit are producing a small amount of additional flex in the hull structure. This is entirely normal for a vessel of the Anam Talamh's construction and is well within her design allowances. You may hear occasional creaks or knocks, or a change in the background note of the drive. Some passengers may also feel brief, mild sensations of movement.
No action is required. There is no need to secure belongings beyond ordinary good practice, and all scheduled activities will continue as posted. Should conditions change in any way that requires your attention, you will be informed by shipboard announcement in the usual manner.
We thank you for your patience, and wish you a comfortable evening.
Passenger Services.
I: The Casting
The Anam Talamh had been in the warp for nineteen days on the fifth hop when the readings began to change.
Third watch held the Hub cool and quiet, twelve stations murmuring under the deep note the warp drive put through the deck plating.
Corragh Tarn noticed it first as a pressure discrepancy between Vault Six and Vault Seven, a tenth of a standard atmosphere surfacing on his console without any input the Hub had registered.  It was well within tolerance, but he flagged it.  The integrated systems would resolve a transient at that magnitude on their own, that was what the integrated systems were for.  He marked it for the next review cycle and returned to the thermal profiles Maev had assigned him at the start of watch.
The Hub occupied the intersection of the Anam Talamh’s four primary environmental spines, a compartment the size of a municipal hall.  It was ringed with monitoring stations and dominated by a holo-display that rendered the ship’s internal systems as a luminous schematic thirty metres across.  The vessel’s integrated environmental management ran almost everything below decks without intervention: balancing atmosphere, regulating thermal load, cycling water, distributing power.  The Hub’s twelve operators did not run the systems.  They watched them.  They balanced exceptions.  They handled the small percentage of decisions the automation engines deferred to human judgment because the automation, sophisticated as it was, did not include the authority to compromise a redundant pathway without confirmation.
Corragh had spent nine years learning the difference between a feed reading that was wrong and a feed reading that was a question.  He could read the central display the way a physician reads a face: not feature by feature but whole, registering the pattern before any single datum confirmed what the pattern meant.
The pattern was beginning to ask questions the Hub did not have answers for.
The gravity inconsistencies appeared eleven minutes later.  Decks fourteen through nineteen.  Small variances, the kind the Anam Talamh’s ageing plating produced occasionally during heavy transit.  Then the reactor load began climbing without input from the Core, a slow upward drift that the integrated systems were correcting and that should not have required correction at all.
Maev Torran was already looking at his console.
She read the same data Corragh did and drew the same conclusions, and she was already in motion before he opened the channel, standing, crossing the floor toward Brennius at the central display.
“Flag it up,” she said, on her way past.
Corragh opened the channel. “Pressure, gravity, reactor load,” Corragh reported. “None critical.  Correlated.”
Brennius Caul stood at the holo-display with his hands clasped behind his back.  The posture of a man listening to the ship rather than directing it.  Brennius did not turn.  He had been watching the feeds before Corragh flagged them.
Captain Orla Duach had been speaking to Devra Sull about a ventilation irregularity in the port habitation block when Brennius’s posture changed.  She stopped mid-sentence.
Devra had noticed it too.  She was already turning back to her own station, her hands finding the console with the automatic certainty of someone who worked machinery the way other people breathed, without thought, without hesitation, the physical grammar of competence so deep it had become reflex.
Brennius crossed to the vox station and opened the channel to the Primary Void Engineering Core.  Arthek Vael answered half a kilometre aft and two decks below, in the armoured section housing the reactor spine, the warp drive, and the Gellar field generators.
The Void Master was Brennius’s second-in-command and head of void engineering: reactor, warp drive, Gellar systems, and the fifty-three crew who maintained them.  His voice came through the vox divided between the channel and something on his own instruments that was claiming more of his attention than it should.
“Gellar fluctuation.  Field coherence dropping.  Phase drift across the primary emitters.  Compensating manually.”
“Rate?” Brennius asked.
“Accelerating.  Slowly.  Secondary emitters at full output.  Holding.”
“How long?”
The pause that followed was a man running numbers against instruments that were not cooperating.
“Not long enough.  The drift is deepening.  There is something asymmetric in the field geometry; the secondaries cannot shape it cleanly.  I am losing coherence faster than I can rebuild it.”
Brennius looked at Duach.  He did not need to ask what he was looking for.  She had stepped to his shoulder when the channel opened, and now she nodded once.
“What are your options?” Brennius said.
“None that are safe.  I can hold the field stable from inside the interface chamber via manual coupling.  It is not a solution.  It should buy us time to translate.  The field is going to fail, Brennius.  It is going to fail in the next several minutes whether I do anything or not.  The geometry is wrong and I cannot correct it from outside.”
“How long can you give us?”
“Minutes.  Maybe more.  Enough for the bridge to act.  Get a medical team down here.”
“Understood.  Hold the channel.”
Brennius turned to the Hub. “Maev, isolation prep.  Non-critical sections.  Cargo decks to independent atmospheric loops.”
Maev was already on it.  Across the ship, bulkheads closed in sequence, the standard isolation doors, not the emergency seals, partitioning the vessel into self-sustaining zones.  The integrated systems handled most of the routing automatically.  Maev confirmed the priority sequence and let the automation execute.  The sound the closures made travelled through the deck plating: a low repeated thud at four-second intervals, transmitted through the structural members until Corragh felt it under his boots and in his teeth.  The old voyage phrase rose unbidden in the back of his mind, “hold the line”.  He did not know what line.  Nobody did.  It was a thing the crews said when the ship was getting ready for something.
Duach moved to the bridge channel without leaving the Hub. “Navigator.  Start procedures for translation.  The Gellar field is failing.  We need to eject.”
The Navigator’s reply came back stripped to single words, her attention clearly elsewhere, holding something, fighting something.  There was a quality in her voice Corragh had not heard from a Navigator before.  Not fear.  Incomprehension.
In the Core, Arthek began moving toward the coupling interface.
The channel carried it through.  Heavy steps.  Deliberate.  Arthek speaking to his crew, instructions to clear the chamber, to seal the inner hatches, to fall back to the secondary monitoring station and wait there.  The voices of the Core team acknowledging in the spare cadence of people who understood what they were being told and were not going to argue.  Then the inner hatch sealing.  The hum of the chamber changing as Arthek committed to the override.
The Gellar field ruptured.
Not collapsed.  Ruptured.  Asymmetrically, the geometry tearing in the place where the damage had concentrated, the breach localised to the section of hull adjacent to the Core.  The rest of the ship felt the boundary thin, a moment of wrongness in the air and the light and the way the eye registered space, but the breach itself was contained to the aft armoured section and to the people who held it.
Arthek had been right.  The field was going to fail regardless.  What he gave them was time.
The Core’s life-sign feeds went dark in a sequence that mapped the breach’s expansion across the chamber.  Inside out, outward in waves, fifty-four indicators winking out one after another in the time it took Corragh to draw a breath.  Arthek’s indicator was the first, he had been at the coupling, at the centre of it.  The crew who had fallen back to the secondary station lasted longer.  Barely.
Four seconds.  The integrated systems registered fifty-four deaths in four seconds, and Arthek Vael’s last act, the act of a man who had known the field was going to fail and had walked into the chamber anyway, was to hold the rupture asymmetric long enough to execute a translation.
The Navigator did.
Corragh did not see it happen.  He saw the consequence: the central display registering the bridge command for emergency translation, the warp drive coils spinning up under the Navigator’s control, the field geometry, still ruptured, still wrong, being shaped by hand into the only configuration that could expel the Anam Talamh from the warp before the breach completed.  It was not a controlled translation.  It was an ejection.  The Navigator forced the ship through a window that should not have been wide enough to pass through, and the ship passed through it anyway, because the Navigator made it.
The Hub smelled different after the rupture.  Ozone, coolant vapour, overheated circuitry, and beneath it something metallic and unfamiliar that none of them named aloud.
The deck still trembled intermittently beneath Corragh’s boots, long after the translation had ended, as though the ship’s structure had not yet realised it was no longer inside the warp.
The astropathic choir died during the translation.
Corragh understood this later, from the medicae records that survived.  At the time he understood only that the choir’s feeds went dark and that the bridge crew who later checked the sanctum found six bodies arranged at their stations in postures that suggested effort that had exceeded what the body could sustain.  Psychic burnout.  Soul overload.  The choir had stretched itself to support the Navigator through a translation that should not have been survivable, and the act of supporting it had consumed them.  They had been trained for this.  Whether they had volunteered for it was a different question and one Corragh did not ask.
The translation hit the ship.
It was not a shockwave.  It was the violence of forcing a kilometre of vessel through a doorway too narrow for it, with the field geometry damaged and the warp drive operating outside its design envelope.  The Anam Talamh was wrenched into realspace with a force that travelled through every frame and bulkhead and deck plate in the form of a single shuddering convulsion, stern to bow.
Stars appeared.  Then everything else.
II: The Wounded Ship
The convulsion threw Corragh into his console and held him there for a full second before releasing him.  The central display fractured, not the projector but the data feeds beneath it.  Dozens of system connections severed simultaneously as the ship’s internal network was torn apart by structural stress.  The schematic that had shown the Anam Talamh as a coherent whole dissolved into isolated segments, each reporting independently, each blind to the others.  The ship had been one system.  It became many.
He silenced the alarms and read the raw data.  Cargo restraint failures across four vaults.  Power distribution fractures on three decks.  Atmospheric breaches forward.  Gravity plating failures across the port quarter.  Structural deformation along the keel.
And the personnel tracker.
Maev’s indicator was dark.
Two metres to his left.  The station was empty.  The translation had thrown her into the junction where the Hub’s port access met the environmental monitoring alcove, and a support brace had displaced from the ceiling during the convulsion.  Two metres of alloy, shaken from a mounting it had occupied for longer than anyone in the Hub had been alive.  It came down at an angle that the physics of the moment made inevitable.
Devra was already there.  She looked at Corragh.  The single shake of her head carried it.
Corragh turned back to his console.  There would be time later.  There was no time now.
The bridge relay came through.
The Navigator was dead.  She had not survived the translation she had forced.  The bridge officer reporting it used the medicae phrase, perceptual cascade, in the spare voice of a man delivering an assessment he was not yet ready to feel.  The neural overload of forcing a translation through a damaged Gellar geometry had killed her in the moment of doing it.  She had given them realspace.  She had not lived long enough to see them arrive in it.
Brennius was moving.  The Master of Ship’s Engineering had left the Hub within seconds, heading aft toward the central systems layer where the primary life-support processors and secondary power nodes were housed.  Fifteen minutes at a walk, longer with bulkheads closed and corridors deformed.  Duach remained.  She had positioned herself at Maev’s station, not operating it, but standing there, and the room organised itself around her presence.
Duach opened the bridge channel. “Bridge.  Status.”
The voice that came back was steady but effortful.  Someone speaking through damage. “Helm is functional.  Void navigation is offline.  We are in an unstable spin.  Working on correction.  We lost two at the forward stations.  Pressure failure.  The rest are working.”
“Can you hold the bridge.”
“Yes, Captain.”
“Then I am staying at the Hub.  I will not lose twenty minutes in sealed corridors.  You have helm and navigation.  I have engineering and damage control.  We split the ship between us.”
“Understood.”
Duach closed the channel.  She had not offered explanation beyond the practical.  The decision was made in the time it took to say it.  She turned back to the room and the room was already waiting.
“Corragh.  Reactor?”
“Scrammed.  Core total loss.  No signs, no telemetry.  Emergency reserves.  Twelve, maybe fourteen days at current load.”
“Shed non-essential.  Keep life support, Hub, auspex.  Everything else dark.”
Corragh executed.  The integrated systems did most of the work; he confirmed priorities, the automation cascaded the shutdowns.  Across the ship, sections went silent.  Habitation blocks where families had been preparing the evening meal.  Mess halls where second watch had been gathering.  Work bays.  Reading rooms.  The small specific places where twelve hundred people had built the routines that made transit bearable.  Going dark.  The ship was contracting around its surviving population the way a wounded body contracts around a wound.
The damage assessment came in fragments.  The starboard docking cradles had taken structural damage during the translation, of the eight utility shuttles aboard, four were housed there.  Immediate reports suggested one was destroyed outright when its cradle collapsed and crushed the craft within it.  A second was externally damaged, further details pending inspection.
Brennius reached the central systems layer twenty-one minutes after leaving the Hub.  His voice on the vox shifted, denser, the cadence of a man whose hands were on the damage.
“Primary atmospheric processor lost containment.  Rerouting through secondary.  Corragh, bulkheads forty-seven through fifty-one, sequential.”
Corragh opened them.  The ship groaned as the pressure differentials equalised.  A vibration that travelled through the deck plating and into the soles of his boots and up through his skeleton until he felt it in his teeth.
Nine minutes later, the cascade.
The colonial infrastructure in the cargo vaults, systems that had survived the translation but had been stressed beyond their design tolerances, began to fail, not simultaneously but in sequence.  A ruptured energy conduit in Vault Seven fed back into the power grid, overloading a junction that had been holding at emergency capacity, blowing a containment seal on the adjacent atmospheric processor, venting superheated gas into the section of the central systems layer where Brennius was standing.
Corragh heard it through the vox.  Sharp exhalation.  Roar of pressure.  Something heavy striking metal.  Then Brennius’s voice came back, changed.  The steadiness held, but held now rather than given.
“Corragh.  The auxiliary bridge is complete.  Life support is balanced.  Leave it as it is.”
“Brennius…”
“Medicae team.  Deck twelve, frame ninety-one.” A controlled breath. “I will be here.”
Duach gave the dispatch.  Corragh watched her face as she did.  The micro-expression that crossed it and vanished was the tightening of a person who had just learned that one of the few people she trusted completely was down, and that she could not go to him because she was needed here.
In the cargo vaults, the colonial infrastructure completed its destruction, not from the cascade alone but from the accumulated stress of translation and shockwave and power-system feedback hitting equipment that had already absorbed more than it was rated to carry.  The power-generation arrays in Vault Seven detonated.  The heavy fabrication arrays in Vault Nine ruptured as their internal cells failed.  The atmospheric processors in Vault Twelve, already compromised, finished the journey from damaged to destroyed.
Corragh watched the vault indicators go dark.  Seven.  Nine.  Twelve.  Each number was a category of capability the colony would never possess.  Of the four colonial descent landers in the ventral bays, three were destroyed, two by bay-door deformation, one by structural collapse during the translation.  The fourth was operational.  He recorded it all on the cracked data-slate.
Devra appeared at his elbow.  She set a cup of caffeine on his console, maybe his last, the stores were behind a sealed bulkhead now, in a section that was no longer part of the ship that lived.  Water now drawn from the Hub’s emergency reserve would be his future.  Placed without comment at his right hand.  He drank it.  He kept recording.
The Anam Talamh was not dead.
The primary reactors were offline.  The warp drive was gone.  The Navigator and the choir were dead.  At least one shuttle was lost outright and one was scrap.  Four-fifths of the ship was being sealed and abandoned.  But the structure was holding.  Life support was running on reserves.  The auspex was functional.  Stars were visible through the surviving viewports, and somewhere among them was a system the augers could resolve, and somewhere in that system might be a place that could keep the survivors alive long enough.
Holding.  The old phrase rose again in Corragh’s head, unbidden.  Hold the line.
He did not know what line.  Nobody did.  But the ship was holding it.
III: The Limp
The medicae station adjacent to the Hub ran warmer than the rest of what survived, and it smelled of counterseptic and scorched cloth.  They brought Brennius there.  Farren, the medicae officer, briefed Corragh at the hatch.  Burns across the left torso, fractured ribs, shrapnel lacerations, internal damage the portable scanner could identify but not fully resolve.  Conscious.  Lucid.  Functional in the immediate term.
The phrase drew a boundary around itself.  Corragh heard what lived on the other side of it.
Brennius was propped on the stretcher with a data-slate in his right hand. “Status,” he said.
Corragh reported.  System by system, the language Brennius had taught his people to use, fact, fact, fact, without interpretation.  The Core.  The vaults.  The navigation.  The Navigator.  The choir.  The reserves.  Maev.  He said her name and Brennius closed his eyes for a moment.  When he opened them, he said, “Continue.”
They worked together for the next six hours.  Brennius directed.  Corragh executed.  The Master’s voice carried a thinness at its edges that had not been there before.  Every forty minutes, Farren appeared, checked vitals, and left with an expression that was professionally controlled and personally final.
Life support consolidated to the bridge and adjacent habitation, a fifth of the ship’s volume, sustaining what remained of the population.  Water reclamation reduced to a single loop.  Reserves allocated to life support, auspex, Hub.  Four-fifths of the Anam Talamh sealed and dark.
Brennius made his assessment to Duach when she came to the medicae bay.  Corragh stood at the back of the compartment.
“The reactor core itself is intact behind containment,” Brennius said. “The problem is not the core.  It is the cooling systems.  The translation hit with a thermal shock no one designed against.  Primary and secondary systems are void of coolant.  That means multiple leaks, catastrophic damage.  Tertiary,” he paused, breath measured, “tertiary may be recoverable.  It is the offline standby.  Sensors indicate some damage, but nothing we cannot resolve.  If we can isolate the damaged sections and restore flow through what survives, we get partial coolant circulation.  Not enough for full power.  Enough for the conventional void engines at reduced output. Short burns only.  Station keeping.  Course correction.  Possibly more, depending on what the diagnostic shows.”
“How long to assess?” Duach asked.
“Days.  The work has to be done in person, in compartments that are partially deformed, likely irradiated.  It will be slow.”
“Do it.  In parallel with everything else.  Corragh, you take the tertiary work.  I want four hourly status updates.”
“Captain.”
Duach looked at Brennius.  The look passed between them in the way looks pass between people who have served together for years and who are now considering the limits of that service.  She did not say what she was thinking.  He did not say what he was thinking.
The auger sweep ran while Corragh’s team began the tertiary work.
Even degraded, the array resolved the system: stable mid-sequence star, gas giant with several moons, inner rocky bodies, and one world, fourth from the star, that returned readings the bridge crew studied in silence.  Breathable atmosphere.  Liquid water.  A biosphere of extraordinary diversity.  The world’s designation in the Anam Talamh’s charts was a number; the bridge crew, in the way crews always did, gave it the name from the spectral signature of its surface.  Verdantia.  Jade-green, even at this range.
Corragh and his small team worked the tertiary cooling problem for five days.
The damaged sections of the cooling manifolds ran through compartments adjacent to the Core, not inside the total-loss zone but close enough that the radiation residuals required shielded suits and short rotations.  The work was incremental.  Trace the pathway.  Identify each crack.  Determine which sections could be isolated, which could be bypassed, which had to be sealed entirely.  Where flow could be restored, do the restoration by hand: cutting and welding ceramic-composite housings with portable equipment that had not been designed for this scale of repair.  The fabrication bays that could have manufactured proper replacement components were destroyed or inaccessible.  What Corragh and his team produced was not repair in the engineering sense, it was triage. Patching.  Workarounds.  Engineering the way medics field-dress wounds: not to heal, but to keep the patient alive until something better can be done.
On the sixth day they got flow.
The conventional void engines came up at twenty-three per cent of rated output.  Enough for short burns.  Enough for station keeping.  Enough, Corragh reported to Duach, for course correction toward the inner system, not a fast transit, but a directed one.  The Anam Talamh would not drift toward the sun.  She would limp toward Verdantia.
Brennius died on the fourth day.
He died the way a system fails when the damage exceeds its capacity to compensate.  By degrees, then completely.  Farren was with him.  Corragh was three decks down in a partially deformed compartment, trying to determine whether a bypass on the tertiary feed could carry the load Brennius had told him it might.  Farren’s voice came through the vox with the tonelessness of a professional delivering a notification she had been preparing for days.
Corragh acknowledged it.  He recorded the time.  He completed the bypass assessment.  Then he sat in the corridor with his back against a bulkhead and was still for a while.
The compartment lights cycled twice while Corragh sat against the bulkhead.
Somewhere deeper in the ship, metal expanded with slow irregular knocks as heat redistributed through damaged sections.  Before the rupture, the Anam Talamh had always carried a constant mechanical rhythm: ventilation, pumps, distant machinery, thousands of systems speaking softly to one another through the hull.
Now the silence between those sounds had become large enough to notice.
Devra found him there.  She did not speak.  She sat beside him on the deck and put her back against the same bulkhead and waited, setting no terms on the waiting.
After a time, Corragh stood.  Devra stood.  They continued the work.
Duach ordered the course change as soon as the engines came up.  Verdantia, five weeks at the burn rates the engines could sustain.  The ship would not arrive in good condition.  She would arrive.
Duach ordered the longevity audit and a census of critical surface skills.  Anything critical to colony survival planet side was to be repaired.  Starting with the maintenance of the surviving shuttles and the one remaining planetary lander.
Corragh and the surviving engineering team, seventeen of them now, worked through the ship section by section, documenting what remained.  Maev was gone, and Brennius, and Arthek and his crew, and Alpha and Epsilon shifts in their entirety.  What was intact.  What was damaged.  What could be repurposed.  What was lost.  They repaired what they could as they worked through each section.
The numbers settled.  Of the twelve hundred souls who had entered the warp, eight hundred and seventy-one remained alive.  The dead lay in the sections that had been sealed: in the Core, where Arthek and his crew had been consumed in the rupture; on the hab decks exposed to the void; in the cargo vaults, where the cascade had taken those who worked there; in corridors and compartments where the translation had thrown bodies against metal and the ship’s own structure had become the instrument of their dying.  The bodies that could be recovered had been.  The rest were behind sealed bulkheads, in the dark, in the cold, in the parts of the ship that would never open again.
Corragh delivered the final audit to Duach on the bridge.  She read it standing, the data-slate held in both hands, her eyes moving with the focus of a captain who understood engineering well enough to read the shape of a conclusion before she reached it.
“The orbit at Verdantia,” she said. “What will the geometry give us?”
“Poor.  The insertion will be ragged.  The engines can give us approximate parameters but not optimal ones.  The orbit will be unstable from the start.  It will degrade, and we will need to correct it with station keeping burns.  Regularly.  The tertiary cooling will sustain that for as long as the patches hold and the fuel lasts.”
“How long is that?”
“Months.  Possibly more.  Each burn shortens it.  There is no way to be precise.”
Duach was quiet for a time.  Then she began issuing orders.  Survey shuttle to Verdantia upon orbital insertion.  Descent planning to begin immediately.  She made the decisions that were hers to make, and she made them with the clarity of a captain who had taken the full measure of her situation and would waste no further time measuring.
Six weeks after the rupture, the Anam Talamh passed the gas giant on her conventional engines, ragged and slow but moving under her own power.  She made orbit at Verdantia on a geometry that everyone aboard who understood engineering recognised as the best she could manage and not enough.
The shuttle survey confirmed what the augurs had promised.  Verdantia was habitable.  Its biosphere was immense and stable.  The botanical specialists on the survey returned with readings that made them speak in terms Corragh had not heard from scientists before, not clinical, but close to reverent.  Fael Brannagh, the most vocal of them, spoke at the command briefing. “The diversity is self-sustaining.  This world has been feeding itself for longer than our instruments can measure.  The soil chemistry alone suggests millennia of unbroken biological cycling.”
Duach ordered the descent, Verdantia Settlement (VS) Day 0.
IV: The Plains
The descent took eighteen days, and for all of them engine noise lived over the river plain, shuttle after shuttle dropping out of the white and returning.
The bottleneck was not the air.  It was the ground.  The colonial lander could ferry eighty people per cycle and the six operational shuttles between twelve and twenty each.  The surface end of the operation absorbed cargo at a fraction of the rate the air operation could deliver it.
Each rotation arrived to find equipment from the previous rotation still being unloaded.  Cargo modules dragged across uneven terrain by hand.  Heavy machinery staged in temporary holds that had to be built before they could be filled.  Supply crates broken down and repacked because what had been efficient stowage in orbit was nothing of the kind on the ground.
Between rotations, the shuttles returned to the ship for refuelling and inspection.  The airframes were not designed for sustained atmospheric operation.  The rough landing zones were producing small accumulating damage that the engineering crews topside repaired in narrowing windows.  The pilots rested between cycles.  The ground crews on Verdantia did not.  The pace was set not by the shuttles but by the people unloading them, and those people were exhausted.
Corragh went down on the second day.  Duach’s orders.
“Your place is where I decide it is,” she said, when he objected that his skills were needed aboard. “Those people need engineering capability on the ground more than this ship needs it in orbit.  Go down.  Build what they need to survive.”
The lander had gone ahead with heavy stores, and as the pilot banked the smaller craft into the upper atmosphere, the hull trembled against air that had not been parted by anything human hands had built.
Verdantia rose to meet them.  Through the viewport, the world resolved from orbital abstraction into something that pressed against the senses and did not relent.
For several seconds, nobody in the shuttle spoke.
The vibration of the engines, so familiar after months aboard the Anam Talamh, suddenly felt intrusive against the scale of the world filling the viewport.
Corragh glanced across at Devra.  She was already looking at him.
Neither of them smiled or spoke.  The same quiet recognition passed between them: that whatever waited below, whatever the world became once human hands touched it, they were looking at something impossibly old and impossibly untouched.
Corragh realised, with a faint and irrational certainty, that Verdantia would still look exactly like this long after every human being aboard the shuttle was gone.
The canopy was visible first, not as a feature but as a condition, a green so total it stained the atmosphere itself, turning the light into something filtered and living.  Older than any human word for the colour it resembled.  Verdantian jade.  The oceans carried the same tone, deepened, as though the world’s waters had absorbed the forest’s colour and held it.  Cloud systems moved across the surface with the patience of weather patterns that answered to nothing.
Below the clouds, the geography declared itself.  Plateaus rose abruptly from the lowlands, sheer-sided, their crowns forested, cut by deep canyons from which waterfalls fell in long white ribbons into river systems that carved outward toward the coastal plains.  At the base of the escarpments, the canopy thinned.  Grasslands and open soil formed between river paths and floodplains, the ground softer than the canopy implied, scattered with the dark moving shapes of grazing herds visible even from orbital approach.
The plains were not empty.  Verdantia’s lowlands carried a complete ecology of their own.  Herds of fast moving herbivores dotted the river plains in dense formations.  Birds in numbers that registered on the shuttle’s avian-detection feeds as a continuous scatter rather than discrete signals.  There was smaller fauna in densities that suggested a food web vastly more elaborate than any previous survey had encountered.  There was prey here.  There was abundance.  There was, by every sensor the shuttle carried, a world capable of supporting human life if the human life understood where it stood within the existing structure.
Corragh stepped onto Verdantian soil and the world entered through his body.
The air was warm and heavy with moisture.  It carried a sweetness he could not name.  It was not floral, not mineral, but endemic, as though the biosphere itself had a scent the way a forest has a sound.  The light did not fall cleanly.  It came through the canopy fractured and recast into a constant green twilight that was neither bright nor dim but alive, shifting as upper branches moved in winds that did not reach the ground.  The soil gave beneath his boots, dark, dense, layered with the organic richness of ages of growth and decay and growth again.  Moss gripped every stone.  Ferns pressed into every gap.  The forest floor was bound together root over rock, vine through soil, everything continuous.  The canopy above moved with a constant unseen activity that resolved, when one tried to focus on it, into shapes that were already gone.
Then he threw up.
He was not the only one.  Half the landing party went down in the first minutes, bodies turning themselves out against something with no source to point to: no smell, no sound, nothing the eye or the ear could fix on.  But the body knew.  The body had always known.
What it knew was an absence.  On every world humankind had ever walked, beneath all the noise of the living, there had run a presence so constant and so deep that no one had ever marked it: a faint pressure at the very floor of the senses, the nearness of something vast and unseen pressing in from just past the edge of the material.  People felt it in the dark at the head of the cellar stairs and called it the prickle of being watched.  They felt it in empty rooms and named it nothing at all, because it was everywhere, and a thing that is everywhere is a thing no one learns to see.
Here it was gone.  Not quieted.  Gone, the way a sound you never knew you were hearing is gone the instant it stops, so that the silence after it rings louder than the sound ever did.  The world was not dead, and it was not hostile.  It was diminished, hollowed at a level beneath thought, and the body, never once told the presence was there, recoiled the instant it was taken away.
Thoughts seemed to land more heavily in the mind before moving on.  Sound carried strangely, as though the forest absorbed more than echo.  Even the silence beneath the canopy felt different from the silence of other worlds: not empty, but withholding.  The instinctive certainty humans carried, that unseen things moved always at the edge of perception, seemed muted here, pressed down into stillness.
Several of the landing party glanced upward without understanding why.
One removed his rebreather seal briefly, then fastened it again almost immediately, unsettled by nothing he could identify.
Another muttered that the place felt too calm.
Corragh said nothing.  He only looked deeper into the green dark beyond the clearing, where the jungle climbed the canyon walls in endless layers, and felt that what unsettled him was not the sense of being watched but the sense of standing somewhere the watching itself had been taken away.
The settlement was established on the river plain at the foot of the escarpment.  Flat ground.  Fresh water.  Open space.  The seed vaults were opened on the third day.  The agricultural specialists were in the soil immediately, not in careful rows but in the urgent scatter of people who knew that every day without food planted was a day subtracted from the colony’s margin.  Shelters went up from cargo crating and lander components.  Power units were networked.  Water filtration was adapted from shipboard use.  Each task was concrete, finite, solvable.  And through all of them, the nothingness continued.
The shuttles and the lander sat at the settlement’s edge.  The orbital rotation continued.  Hope, though no one named it as such, was still an operative assumption.  The ship was above them.  The ship would hold.  There would be time.
On the fourth evening, laughter carried across the settlement for the first time since landing.
Children moved between the cargo stacks while the agricultural teams worked the planting rows nearby, their voices drifting through the warm air beneath the growing rhythm of tools, running water, and conversation.  Someone had hung lumen strips along the side of the grounded lander, and in the failing light the temporary camp almost resembled the kind of colonial beginning the expedition had imagined back on Terra.
Corragh stood beside the shuttle ramp checking cargo manifests while Devra worked beneath the open engine housing of the nearest shuttle, her hands blackened with lubricant and dust.
“Feels almost normal,” he said quietly.
Devra glanced out across the plain, toward the darkening tree line beyond the perimeter markers.
“No,” she said after a moment. “It just feels quiet.”
Death came on the fifth day.
A foraging party.  Three people, a hundred and fifty metres beyond the perimeter, gathering a ground-cover plant the botanists had flagged as a possible food source.  Open ground.  Mid-morning.
Corragh did not see it.  He heard the silence after the shout.  A shout that began and did not finish.  Two of the three came back, running in an uncontrolled sprint.  The blind staggering flight of organisms whose nervous systems had encountered something they could not process.
What they described made no immediate sense.  Something from above.  Vast.  Silent for its size in a way that was wrong, that registered as a violation of the air itself.  A shape that blocked the light for less than a second, charcoal-dark with iridescence in the wing edges that caught the canopy light as it fell.  Talons.  They said the word and could not continue.  The third member of the party was where she had been standing.  The strike had happened in place, talons forward, full body mass, the impact and the killing accomplished in the single motion of arrival.  There was a body on the ground, and there was a great deal of soil disturbed around it. There were marks on the corpse that the survivors could not look at and that the recovery team described, when they returned, in the spare clinical language of people who had seen what serrated blades do to flesh and would not see it twice if they could help it.
The thing that had killed her did not stay to feed.  The strike had ended and the predator had climbed back to the canopy and was gone before anyone had time to react.  What it had wanted, evidently, was the kill itself.  A test perhaps, whether this new prey-species could be taken.  The body it left behind was untouched.  The kill had been the whole of it.
The second strike came two days later.  One taken from a water-collection detail at the river’s edge.  The witness saw it clearly.  The creature dropped from the plateau above, wings broad and layered, four metres across or more.  The leading edges carrying the soft layered feathering that made the descent silent.  It did not dive in the manner of Terran raptors.  It fell, converting altitude into velocity without turbulence, talons extending forward in the last instant before impact.  The strike was a single coordinated motion: the talons, the body mass, the killing weight.  It killed where it landed.
The land predators came at night.  And then during the day.
The first was encountered at the settlement’s edge at dusk.  A shape that emerged from the forest’s edge without sound and low to the ground.  Broad across the shoulders, the dense fur catching the failing light in tones of moss-grey and wet-bark dark.  It weighed, by later estimate, close to a thousand kilograms.  It stood as tall as a man’s chest at the shoulder.  It gave no warning.  The ears flattened, the head dropped between the shoulders, the body became unnaturally still for a single breath, and then it moved.
Two settlers died in the first five seconds.  The defenders had sidearms and engineering protection weapons drawn from the workshop tool stores, civilian hunting las-locks from the recreation lockers and a small assortment of personal arms that crew had carried aboard for reasons that had seemed reasonable at the time.  The central armoury, with its proper military-grade las rifles, had been in a section of the ship that was now sealed and dark and abandoned.  The proper weapons were gone.  What remained was inadequate.
The hunting las-locks hit the predator multiple times before it fell.  It absorbed bolt after bolt into the heavy musculature of its shoulders and chest and kept moving forward.  The bolts were dangerous.  The creature was wounded badly, bleeding from multiple places.  It would not have survived the day even without the eventual killing shot, but the weapons could not stop it.  Stopping power and lethality were not the same thing, and the settlers had only the latter.  By the time the final bolt found the base of the skull, two more people were dead and a third was injured beyond what the medicae station could repair.
After that, the settlement learned.  They learned to work in groups, never alone, to maintain unbroken visual contact with the sky and to watch the forest edge, to position themselves so that any approach across the open ground had to cross fields of fire.  And they learned which weapons worked best against which threats, and that none of them worked well enough.
The losses continued, sporadic and unpredictable, a strike every few days, sometimes more, sometimes less.  The predators apparently testing the new species rather than systematically hunting it.  The herbivore herds moved in vast formations a kilometre or more from the settlement, and the predators that took the herbivores took them without seeming to consider the human encampment as a primary food source.  The humans were opportunistic prey.  Targets of curiosity, not sustenance.
But the curiosity cost.
Thirty-four dead in the first three weeks on the surface.  Some to predators, some to injury, some to a respiratory infection the medicae supplies could not address fully, a microorganism endemic to Verdantian soil that the colonists’ immune systems were not prepared for.  A water-filtration failure killed two on its own, and Corragh added the seal failure to the weight he was already carrying because the seals had been his work.  People argued.  People withdrew.  People grieved in the ways people grieve when there is no time to grieve properly: sharply, briefly, returning to the work because the work was what kept them alive and the work demanded everything they had.
Farren spoke at the evening gathering on the twentieth day.  She did not raise her voice.  She did not need to.
“We are losing skilled people we cannot replace.  Every death costs us capability.  The next generation will not have what we have.  The plains are workable, but they are workable at a cost we cannot continue to pay.”
Fael Brannagh spoke after her.  The botanical cohort had been surveying the escarpment since the second week, moving up the giant canyon in groups of three with armed escort, and what they had found offered a different equation.
The plains were not the only survivable terrain on Verdantia.  The plains were habitable.  They were producing crops on the small plots the agricultural team had managed to establish.  Survival was possible here.  But the canyons offered caves and better economics.  They offered narrowed approaches that constrained predator angles, overhead cover that eliminated aerial strikes, natural plateaus and ledges along the canyon walls where soil had accumulated over centuries and where waterfall flow could be diverted to compact growing terraces.  Gardens on the narrower ledges.  Root and grain cultivation on the broader shelves.  Medicinal plants in the shaded alcoves where moisture collected.
Fael described the terrain.  She described what it offered.  She sat down.
The decision took less than two hours.  It was not unanimous.  There were arguments.  The plains were producing, and abandoning what had been built at such cost felt like a defeat that some refused to accept on principle.  But the arithmetic was harder than the principle.  The canyons reduced exposure, offered cultivation, and made survival a matter of work rather than luck.  The plains would not be wasted, harvests could still take place, but heavily armed harvests.
They selected a secondary canyon, off the giant wound that gouged its way through the plateau to the horizon.  It was more basin than canon, with a narrower, more defensible mouth to offer greater safety.
The shuttles flew for the last time.
Duach, monitoring from orbit, authorised the use of all flight-capable craft to move heavy equipment to the Basin site.  The lander made three trips.  The shuttles made more.  The airlift took five days, and when it was complete, Duach gave the order that had been forming in everyone’s mind since the relocation was decided.
Use the craft, ground them for walls.
The shuttles were manoeuvred into the canyon approaches and positioned as physical barriers.  Their hulls forming walls across the narrower entrances, their fuselages closing gaps that would otherwise have required fortification the colonists did not have materials to build.  The colonial lander, the largest hull, was set across the basin mouth like a gate straddling the river.  Its cargo hold was emptied and repurposed as the settlement’s main storage.  Its cockpit, elevated above the basin floor, looking out into the giant canyon beyond, became a watch post.
Fuel was drained and consolidated into two shuttles that Duach ordered kept operational, the minimum needed to maintain the orbital rotation.  They were parked on a protruding ledge, just above the basin, maintained by Devra, who checked their systems with the same quiet thoroughness she brought to everything.
The settlement entered the basin caverns carrying what remained.
The walls rose around them.  The canopy closed.  The light changed, filtered into green and gold, diffused through layers of growth that turned the sun into something gentler and more distant.  The air cooled.  Water moved over stone in the basin floor.  From the ledges above, the thin white threads of waterfalls fed channels the botanists were already mapping with their eyes.
Corragh stood in the basin that first evening, under no open sky and no unobstructed vertical angle, the approaches held by hulls that had once flown.
The basin changed sound.
Wind no longer crossed open ground.  It moved somewhere high above them now, softened by layers of canopy and stone before it reached the settlement floor.  Water replaced engines as the constant background of their lives, the endless rush of the falls threading through the dark like something alive.
At night, the settlement fires reflected from wet stone and grounded hull plating alike, turning the basin walls bronze and gold beneath the green-filtered dark overhead.
Corragh noticed, after several days, that people slept differently here.
Less abruptly.
It was a place where the arithmetic was less hostile.  A place that, maybe, could rescue them from danger.
V: Decay
The orbital rotation continued for four months.
Duach maintained it with the same methodical discipline she brought to everything.  A skeleton crew of fourteen held the Anam Talamh: auspex watch, life support, stores management, and the regular station keeping burns that the unstable orbit required.  The tertiary cooling held.  The conventional engines came up for the burns and went back to standby afterwards.  Each burn was a fuel cost the orbit could not avoid and the supply could not replace, and the operation’s window was the difference between the two.
The pilots flew the resupply rotation every two weeks, carrying food from the canyon settlement and returning crew members who had completed their tour.  Corragh managed the surface logistics: cargo manifests, load calculations, maintenance schedules for the two remaining shuttles.  Every rotation brought news down: auspex readings, reserve status, the slow incremental data of a vessel still dying but dying slowly enough that the word dying had been replaced, by unspoken agreement, with the word holding.
The rotations also brought Duach.
She came down every second cycle, walking the settlement with the same attention she had walked the ship’s corridors during transit.  She knew the basin the way she had known the decks, by the people in it, by their work, by the small accumulating evidence of a community learning to sustain itself.  She sat with Farren in the medicae shelter and reviewed health data.  She walked the terraces with Fael Brannagh and listened to the botanists explain what was growing and what was not and why the soil on the eastern ledges needed different management than the soil on the western ones.  She sat with children.  She asked after injuries, after morale, after the small frictions that accumulated when eight hundred people lived in a canyon and could not leave it.
She did not tell them about the ship.
Corragh watched her during these visits.  He watched her move through the settlement with a steadiness he had come to understand was not innate but built, constructed, maintained, reinforced every day by an act of will she never acknowledged and that cost her something she would never name.  She slept in the lander’s cockpit during her surface stays, in the watch post above the canyon floor, and Corragh knew this because he had gone up there once, late at night, to check the vox relay.  He had found her sitting in the pilot’s seat with her knees drawn up and her eyes open, looking at nothing.
She saw him at the hatch.  She did not startle.  She said, “The vox is fine, Corragh.”
He said, “I know.”
A pause.  The basin sounds below, water, insects, the rustle of canopy in a wind that did not reach the floor.  Then she said, “Steady the keel.”
He recognised the phrase.
“Steady the keel,” he answered.
Devra, during these months, became the person Corragh relied on the way a structure relies on a keystone, not visibly or dramatically, but in a way that meant everything above it was shaped by its presence.  She maintained the shuttles.  She managed the fuel consolidation with a precision that extended the operational window beyond the original arithmetic, because she understood drives the way Corragh understood ship systems: not through manuals but through touch and sound, through the particular vibration of an assembly running clean against one running rich, through the smell of a thruster nozzle that needed recalibration.
On the ground, between rotations, she worked beside Corragh on the settlement’s infrastructure.  The water channels.  The power distribution.  The terracing supports that held the upper garden ledges in place against the canyon’s seasonal rains.  She did not speak much during this work.  She did not need to.
Once, on the upper terraces during a rest break, she looked across the basin and said, “The soil smells different up here.”
“Smells like what?”
“Like it has been waiting.”
It was the closest thing to poetry Corragh had heard her say, and he remembered it afterwards with a clarity that surprised him.
The shuttle came apart on re-entry during the fifth rotation.
The cause was understood later, in the way these things are reconstructed from the auspex data and the maintenance logs and the silence that followed.  The airframes had not been designed for sustained atmospheric operation.  They were transit-shuttles, intended for occasional descent and return rather than the cumulative stress of a sustained ferry running through atmospheric envelopes month after month.  The maintenance ecosystem aboard the Anam Talamh had been gutted.  Spare parts had been pulled from the salvageable wreck of the parts-shuttle until that source was exhausted.  Inspections had become superficial because there were no longer enough qualified hands to perform them properly.  Devra had flagged the structural fatigue indicators on the airframe and had told Duach the shuttle needed to be retired before it failed.
Duach had heard her.  The decision had been made.  No more rotation.  Final cargo and personnel transfer at maximum density, then the shuttles would be grounded.
The fatigued shuttle was the one Duach was returning on.
Corragh was on the surface.  He was in the lower basin, recalibrating a water-channel junction, when the vox crackled with a transmission from the Anam Talamh’s skeleton crew.  The message came through fragmented, broken by interference, by distance, by the particular distortion atmosphere imposed on signals from orbit.  He caught fragments.  Shuttle.  Descent.  Anomaly.
He climbed to the watch post.  From the lander’s cockpit, through the gap in the canopy above the canyon mouth, he could see a section of sky.
The streak was visible for two seconds.  A bright line drawn across the upper atmosphere, too steep, too fast, fragmenting as it fell.  It did not arc.  It did not correct.  It came apart in the way a thing comes apart when its structure has finally exceeded what the engineering can hold: not a single failure but a cascade, the airframe surrendering across multiple stress points simultaneously, the bright line becoming bright points becoming nothing.
Duach was aboard.
Devra was flight engineer.
Corragh stood in the watch post and looked at the sky where the streak had been and was no longer, and the vox was still crackling with fragments, and the basin below him was full of people who did not yet know, and the sound of water over stone continued without interruption because the canyon did not care, nor the water, nor the world, and he was standing in the cockpit of a grounded lander on a world the Imperium had never charted, and the last two people he relied on were falling through the atmosphere in pieces.
He stood there for a long time.
That night, the basin was quieter than usual.
Rain moved somewhere high above the canopy, audible only as a distant shifting across leaves too far overhead to see.  Small groups gathered beneath the overhangs in near silence, speaking softly when they spoke at all, the settlement fires burning low against the stone.
No one said aloud what had changed.
But for the first time since leaving Terra, there was no longer a path back into the sky.
The evacuation of the Anam Talamh’s remaining crew took eight days.  The second shuttle, still operational, flew the final three trips.  Fourteen people brought down with the last of the transferable stores and the auspex logs and the personal effects of a skeleton crew that had held a dying ship for four months and were now leaving it because there was no one left to fly them back.
The Anam Talamh was empty.  The auspex went dark.  The ship drifted, crewless, in an unstable orbit that would decay within the year.
The remaining shuttle was grounded.  Its hull was positioned at the basin approach, beside the others, and it became what all of them had become: a wall, a structure, a thing that had once moved through the void and now held back the forest.
Corragh did not pick up his tool harness.
He went to the upper terrace, the one where Devra had said the soil smelled like it was waiting.  He sat on the ledge with his back against the canyon wall and his hands on his knees, and he did not move for the rest of the day.  People came.  People spoke to him.  He heard them the way a man hears sound through water: present, distorted, reaching him from a distance that was not physical.
The chain was gone.  Brennius.  Arthek.  Maev.  Duach.  Devra.  Not absent.  Not transferred.  Dead.  Dead in the Core, dead in the medicae bay, dead under a brace in the Hub, dead in the atmosphere of a world that had taken them all, one by one, and left him standing with a tool harness and no one to tell him where to point it.
Fael Brannagh found him on the third evening.  She came up the ledge path with the unhurried step of a woman who had been walking canyon walls for months and whose feet knew the stone.  She sat beside him, not close: near enough to be present, far enough to leave him space.
She did not ask how he was.  She did not offer comfort.  She said, “The eastern terrace irrigation is failing.  The channel gradient is wrong and the water is pooling instead of flowing.  The crop on that ledge will drown if it is not corrected within the week.”
“I do not know how to fix it,” she said. “I know soil.  I know water as biology.  I do not know water as engineering.  You do.”
She stood.  She did not wait for an answer.  She walked back down the path, and the sound of her footsteps on the stone faded into the canyon’s layered quiet.
He did not go that evening.  But on the afternoon of the next day, he went to the eastern terrace and looked at the channel, and he saw what was wrong.  The gradient, the pooling, the simple mechanical error that would kill the crop if it was not corrected and he fixed it.  He fixed it because he could.
He did not pick up the tool harness afterwards.  He did not ask where he was needed.  He fixed the channel and went back to the ledge and sat there until the light faded.
Below him, in the basin, the settlement continued.
The botanists moved between the terraces, tending the crops, adjusting the water channels, cataloguing the native plants that were edible and the ones that healed and the ones that killed.  Fael spoke with the families.  She organised the foraging schedules.  She mediated the disputes that arose when eight hundred people shared a space that was shelter but not yet home.  She did this without title, without authority, without any of the institutional structure that had governed life aboard the Anam Talamh.
The other botanists followed her lead.  They became the people the settlement turned to, not for commands but for answers.  Which soil supported which crop.  Which water source was safe.  Which canyon paths could be walked and which held dangers not yet catalogued.  Which plants reduced fever.  Which bark could be made into cord.
The engineers maintained what they could.  Corragh, when he was able, fixed what needed fixing.
Above Verdantia, the Anam Talamh drifted in her decaying orbit, dark and empty.  The settlers did not watch her.  They had stopped watching her the day the last shuttle was grounded.
In the basin, the water moved over stone.  The crops grew on the terraces.  The children learned the names the botanists gave to the trees and the birds and the flowers that pressed into every gap the forest could find.  The settlement held.  It held the way a living thing holds, not through structure, but through root and growth and the stubborn, patient, unannounced refusal to stop.
Corragh Tarn sat on his ledge and watched the light change through the canopy.  He did not know what he was becoming.  He did not know what the settlement was becoming.  He knew only that the soil on the eastern terrace was draining properly, and that the crop would survive, and that somewhere below him a woman who understood the world better than he did was teaching other people to understand it too.
That, for now, was enough.
It would have to be.
THE EARTHBREAKER XI
I: The Repair
The life-support primaries compartment was cold enough to ghost Iorwen Crest’s breath.  She had her sleeves rolled to the elbow and her bare forearms inside the manifold housing, where the cycle had left a residual warmth in the metal, and her forearms took it gratefully.  Beneath her palm, the coupling settled millimetre by millimetre against its gasket, the pressure rising under it slow and even, the way a bone seated itself when a hand left it alone to do its own work.  She held her hands still.  A bedding-in took the time it took.
Earthbreaker XI had been at low load for nine days.  Iorwen could hear her in it.  Beyond the compartment, the ship ran quieter than she had ever heard a ship of her class run.  A thinner vibration in the deck plating beneath her boots.  The bass throb of the reactor pulled down into a note where the cooling could still hold it.  Inside the compartment, the sound went the other way.  The emergency recyclers carried the room loud, running constantly to do the work the primaries had done before the translation.  They were localised and less efficient by half, built to keep doing it for as long as they had to.  Iorwen had grown used to working through their noise.  The taste of the air at this rating was sharper, more metallic, the aromas of everyday life merging into one.
She had grown used to the casualty figure in the same nine days.
Two hundred and seventy-eight living, out of the six hundred and thirty-six who had boarded at Terra.
The medicae count had come up on the second morning.  Captain Brask had read the names to the surviving officers in the briefing room with her voice flat and her face still, and Iorwen had watched her do it, the steadiest thing she had seen anyone do in a long while.
For the first five days after the translation, Iorwen had worked from her station on the bridge.  The damage assessments.  The plan and the assignments.  The report cadences with the surviving engineering teams.  She had held the integrated picture until the plan was running clean.  On the fifth day she had come down to the life-support primaries between her cadence check-ins, because the primaries needed hands and Voss was carrying more than one engineer should be asked to carry.
She was on the manifold now.  Voss worked the next station along, on the secondary feeds.  The vox at her hip ran a half-hour cadence with the void engineering teams two kilometres aft.  Between the check-ins, the work was hers.
The larger failures she had read in the first days, in the logs and the structural telemetry and the long dead silence on every channel that ran amidships.  She had assembled the sequence the way she assembled any failure, backward from the evidence it left behind.
Something in the translation had taken the Earthbreaker by her middle and closed on her.  That was the simplest description.  The records gave her no reason to refine it.  The seven hundred metres of her at midships had folded inward under a force greater than the hull plating could refuse, the way a tin can folds under a closing fist.  The folding reached the forges first.
That was the heart of her, and the heart of what she was.  The Earthbreaker XI was a Heavy Planetary Works Vessel, built to set down on a fresh world the means of remaking it.  Two and a half kilometres prow to drive section.  Seven hundred metres at the beam.  Four hundred and fifty deep.  A central spine ran her length, carrying command and habitation and her structural integrity.  At midships, the spine had opened into the full breadth of the ship, and the breadth had been the fabrication complex.  Forges.  Production lines.  Foundries.  Manufacturing decks.  The whole beam of the ship given over to industry.
The fabrication complex collapsed across the full width in the space of seconds.  The forge lines closed on themselves.  The production decks drove down through the levels beneath.  The master patterns and the templates and the STC archive went down with the armoured vault that housed them.  The vault had been built to outlast a forge fire.  What came was greater than the design.
Forge spaces crushed loud.  The molten reservoirs and the fuel stocks and the pressurised lines that ran the production decks took the crush as a shock.  Several of them failed in the same moment, and those failures kindled.  The detonations that followed walked outward from the centre of the ship in the first half-minute after the translation, and what they found aft of the forges they passed on.
Aft of the fabrication complex, on open cradles bolted to the spine and bared to the void, had ridden the Leviathan Engines.  The Mantlebreaker Excavation Platforms.  The Goliath Quarry Harvestors.  The Macro-Constructors.  Each machine carried its own reactor.  The explosions from the forges reached them, and they ignited in turn.  The cascade ran aft, cradle by cradle, each detonation kindling the next.
The same explosions that ignited the cradles broke them.  The foremost cradles failed outward under the force of the detonations, their hold-fasts shearing, the machines they carried torn from the hull and flung clear into the void with the burning wreckage around them.  The next pulse took the next set the same way.  And the next.  What had been the aft loadout scattered away from the ship along a hundred separate headings, tumbling and burning, in a long thinning trail of contacts the auspex held for the better part of a day before the last of them dropped below detection.
The cascade blew out from the cradles before it reached the engine bulkhead.  The ejecting machines had carried the worst of the explosions out with them as they went, opening a firebreak between the cascade and the rear spine of the ship.  The void engines and the thrusters, behind the bulkhead, came through whole.
The forward spine took the crush as a glancing thing.  It bent.  Compartments shifted out of true, bulkheads sprang, hull plating opened along seams the engineering survey had marked as sound.  Hull breaches bled atmosphere to the void faster than the emergency seals could close on them, and some of the forward crew were gone before they understood what was happening.  The Navigators died in their sanctum.  The seals on the chamber held until the medicae teams forced them on the third day.  The report filed afterward was written in the spare prose of professionals who had agreed, without saying so, to record what they found once and to never revisit it.  The astropathic choir lay in their cells, dead where they had been turned toward the warp.
Damage diminished with distance from the forge plane.  The bridge crew and the void officers had been quartered forward, in the habitation deck on the spine, and most of them lived because of it.  The Industrial Corps had been quartered inside the fabrication complex.  They died with it.  The engineers and the operators and the survey crews who had been along the warehouse holds at the moment of the translation had lived or died in proportion to where they had been standing.  The arithmetic of survival was the arithmetic of position, and nothing else.
Forward of the forges, in the long warehouses that had fed inward toward the forge plane, had ridden the raw stocks the forges had been built to consume.  The warehouses nearest the forges were crumpled paper now, their contents driven down into themselves with the fabrication complex.  The next warehouses forward stood half-damaged, half their stocks lost to displacement or to the leading edge of the crush.  The warehouses further forward again stood intact, their racks still upright, their inventories still catalogued.  The stocks inside them were inert.  The secondaries had stopped at the forge plane.
The Earthbreaker carried, in the forward third of her holds, a forge’s worth of feed material with no forge to feed.  Structural plate.  Bar stock and ingots.  Cable runs.  Bulk consumables.  A colony’s worth of raw material, racked and waiting to feed the machinery that had burned with the ship.
The Earthbreaker kept her void engines and her thrusters.  Enough to move her between the bodies of this one system at need, and that was the whole of what she would ever have.  The system was where they would end.  Iorwen had set the fact down on the second day, in the fixed and finished place where she kept the things she had stopped arguing with, and she had left it there.
The vox at her hip woke.
“Crest.  Bridge.  Captain wants you at the auspex.  Madryn has a contact.”
She felt the coupling go true under her palm before she answered, and she keyed the compartment’s second station while she still had her hand on it. “Voss.  I am wanted forward.  Run the cycle up to half pressure and hold it there, no higher.  If it weeps again, shut it down, mark it, and chase the leak without me.  Just watch you do not bleed the system dry hunting for something that will show itself in its own time.”
“Understood, boss.”
She wiped her hands and went forward, out of the cold of the outer compartments and into the warmth of the spine, where the ship still lived.
II: The Signal
The bridge was warm after the cold of the outer compartments.  The air carried the faint staleness of recycled atmosphere held too long at low load.  The lumens ran dim.  Half the secondary stations were dark.  The watch worked at the low pitch of people running on the snatched sleep of nine days, voices kept down by habit, the bridge holding its quiet.
Madryn was at the auspex when Iorwen came up.  He had been her training partner ten years ago, on another ship, in another life.  He was a senior in his own right now.  The grey on his face was the grey of all of them.  Skin tight under the eyes, jaw shadowed, the attention of a man who had been holding it too long.
“We have a beacon,” he said, and he gave her the rest of it before she asked. “It is the Fortress of Labour.”
Iorwen leaned over the auspex.  The trace ran clean across the display, a steady carrier with the transponder code threaded through it.  The cipher was the plain pre-translation one every ship of the expedition had been issued before the warp run.
The Fortress of Labour had left Terra with them.  She had stood three berths ahead of the Earthbreaker in the Helion-Delta-3 launch order, just over five months ago, and she had entered the warp on the same day.  Her beacon was rising now out of the deep system, a long way inward from where the Earthbreaker had emerged, calling for any ship of the expedition that could hear it.
Two things came at Iorwen in close order.  Relief came first, simple and physical, a loosening below the breastbone.  They had company.  Another ship of the expedition had come through, and it was one she knew.  The dread came a half-breath behind it.  A beacon was a call for help, and the Fortress had reached for it.
“How far?” she said.
“Deep system.  We would be running the drives hard for the better part of a fortnight to reach her, and harder than Brask would like, given the state of them.”
The distance fit a known pattern.  Warp translation could take two ships that entered the same current together and set them down a long way from one another.  It was a navigational hazard, not common in the records but documented well enough.
“And you are certain of the hull.”
“Classification and configuration say it’s her.  Mass seems off, could be damage, same as us.”
Captain Brask had come across from the command station while they spoke.  She read the trace herself, slowly, with the flat attention she brought to everything, and she finished her reading before she answered.
“Your reading, Iorwen.”
“The Fortress of Labour is here, in this system, calling.  She came through the same translation we did and was set down deep in-system.  There are people on that ship, and they are asking for help.  I do not think there is a decision to make.”
“There is not,” Brask said.  She turned to the watch. “Helm, lay me a course to that beacon.  Engineering, I want the drives cleared for sustained running and I want to know the cost of it before we begin.” She looked back at Iorwen, and something in her settled that had been holding for nine days. “Wherever they are, we are going to them.”
III: The Approach
It took sixteen days to reach her.
The drives ran at half their rated output for the first week.  The void engineering teams kept the watch beside them, reading the field harmonics and the conduit pressures in rotations that ran on the snatched sleep of nine days carrying into another sixteen.  By the second week the readings had held steady long enough that the teams trusted them past half.  The ship made better time than her wounds had promised.
Iorwen kept her station on the bridge through the passage.  She had handed the forward life-support work to Voss on the second day after the auspex call, and Voss had taken it with both hands.  Iorwen’s hands were on a console now.   Her work was the work of holding the whole ship in one place.  The displays at her station fed her the telemetry from every section of the Earthbreaker that still answered her.  The vox traffic from aft came up the line of stations in a steady low murmur, watch to watch, hour to hour.
She read the drives through the gauges in front of her.  She read the reactor through the bass throb that travelled the deck plating into her boots and into the chair under her.  She read the engineering decks through the senior void engineer’s voice on the vox, two kilometres aft, a sealed bulkhead between them.  His consonants ran tired by the end of each watch.  His cadence held even, the cadence of an engineer running a long watch with his hands busy and a stranger on the line.
The engineering decks had carried damage of their own.  The cascade had stopped at the aft cradles and the void engines behind the engine bulkhead had been spared the worst of it, but the shockwave that walked through the spine had carried far enough to leave its marks.  Lumens sparked on demand spikes.  Cogitator screens ran cracked across their faces, on reduced field counts, stripes of grey where the pixels had failed.  Conduits wept where the teams had isolated them under reroute.  Deck plating fractured in the outer compartments, walked around with warning tape rather than welded, because the welding was needed on structure.  The work was small.  The teams were grateful for work that small after what amidships had cost.
Iorwen acknowledged each report.  She marked each spike.  She held the picture.
The auspex began to draw the Fortress out of the dark on the morning of the fifteenth day.
The shape resolved slowly.  The Fortress of Labour was on her own out there, and she was moving.  The auspex held her in a slow drift across the field, the kind of drift a wounded ship made working with what she had left.  Her station was open vacuum, the nearest body of any size a long way off.  She had chosen a course and was holding to it on the engines she had been left.
Whatever the warp had done, it had set her down in the emptiest reach of the system, and she had chosen not to stay.
Her profile told the story before the first hail.  Iorwen read it off the auspex the way she read everything, by what the shape of an object said about the forces that had made it.  During the translation, the Fortress of Labour’s aft drive cradle had been caught in a spatial shear.  The primary void engines had been torn clear of the hull, taking the main thrust architecture and the aft engineering galleries with them.  The drive cradle had failed in a way that sealed the habitable spine forward of the tear.  The bulkhead had held.  The systems aft of the rupture had been allowed to fail clean, rather than dragged through the failure with everything else.
Her thrusters were intact.  Her secondary engines were still mounted.  She had lost her power to travel and kept her power to live.
Iorwen looked at the cold black cavity where the drives had been.  The wound was very nearly the wound the Earthbreaker carried.  It was made by the same hand.  Chance had turned it to a different account.
The hail came as the Earthbreaker closed to vox range.
The carrier opened cleanly.  The voice on it was a man’s, steady, older than middle age, pitched in the careful cadence of a bridge officer of the expedition.  The relief in it was carried plain.  He had been holding it for a long time, and the holding had grown tired.
“This is the Fortress of Labour.  It is very good to see another vessel.”
Brask answered the hail herself. “Fortress of Labour, Earthbreaker XI.  We took your beacon when we translated in, and we have come to your aid.  Tell us your condition.”
“Our drives are gone.  We lost them in the translation, and we have made what way we could on thrusters and secondaries since.  We have held the ship together.  We have not been able to take her anywhere worth reaching in a time that would matter.  We are very glad you came.” There was a breath, and then the question that mattered most to him. “How many of you are there?  Did the rest of the expedition come through?”
“Two ships that we know of,” Brask said. “Yours and ours.  We have seen no others.”
The pause that followed was longer than the others.  The distance between the two hulls swallowed whatever was in it.
“Understood, Earthbreaker.  Come alongside.  There is a great deal to discuss, and it will go better face to face than across a channel. My name is Aevyrn Keir.  I have the Fortress.”
The channel closed.  Brask stood looking at the cold hull turning slowly on the display.
“Acting command,” she said. “Whoever held the ship before him did not live, or did not keep it.”
“He told us he had held the ship together,” Iorwen said. “Before he told us his name.  That is the order he put them in.  It tells you most of what you need to know about him.”
IV: The Meeting
The Earthbreaker came up on the Fortress and held station at fifteen kilometres.  Two hulls of that scale required the gap.  The Earthbreaker was over two and a half kilometres of ship.  The Fortress, at two-thirds her length, was of the same scale.  The distance was a precaution every void officer would have insisted on without being asked.  They held it and spoke across it, and the first thing Brask put to Keir, once the stations were matched, was the practical.
“Fortress, name your immediate needs.  Atmosphere, power, medical, food.  Whatever is most pressing, we will load a shuttle and have it across to you within the hour.”
Keir’s answer came back without hesitation. “We have no urgent needs, Captain.  We have air and water and food enough.  What we lack is a way forward: propulsion.  That is not a thing you can load onto a shuttle.  Send your senior people across and let them see the ship.  It will tell them more than I can, and once they have seen it we can make a plan that means something.”
Brask sent Iorwen.  She took a small team of five.  They crossed in one of the Earthbreaker’s few surviving shuttles.
The Fortress had cleared a secondary cargo lock and pressurised it to receive them.  The shuttle mated, the seal took, and the lock cycled with the long laboured groan of a mechanism worked manually for want of the power to drive it.  The inner hatch opened.  Iorwen stepped through, and the ship met her first through her nose.
She had expected the smell of a wreck.  She had been aboard wrecks before, and they all smelled the same, of cold scorched metal and spent fire suppressant and the sweetish underlay of compartments still holding their dead.  She had braced for it as a matter of habit.
What reached her was something else.  The smell of a place that was lived in.  Compost and cooking and warm bodies and the faint vegetable green of growing things, all of it carried on air a half-degree too humid, pushed through a recycler that was plainly working at the very edge of its rating.  It stopped her for a moment, one pace inside the hatch, before she understood why it had stopped her.  The Fortress had passed survival and become a home.
A man was waiting for them past the lock.  He was in his late forties, in an engineer’s coat worn soft at the cuffs and stained dark with old hydraulic fluid set deep in the cloth.  He offered Iorwen his hand.  An older custom than a salute, and a warmer one.  Iorwen took it and felt the calluses of years of manual work where a senior engineer’s hand should have gone soft.
“Tovin Reach.  Senior Drive Engineer.  Acting Master Keir is on the bridge and asked me to bring you up.” He looked at the six of them, and the relief in his face was plain and unguarded. “It is very good to see faces we do not already know.  Come.  Walk with me.”
They walked, and Iorwen read the ship as she went, because she could no more stop reading a ship than she could stop hearing.
The corridor had been remade.  The original wall panels had been stripped from the starboard side and the bare frame behind them reinforced with cargo bracing, cut and fitted by hand, the welds laid down by someone who had grown more practised as the work went on, the earliest of them rougher than the rest.  The port wall carried a maintenance schedule in grease pencil, column upon column of it.  Iorwen took its meaning at a glance.  The recent columns stood sharp and dark.  The oldest had faded until the pencil had gone silver and the figures had begun to lose themselves against the paint.  That much wall called for months of disciplined daily entries.  The wall had received them.
This was no wreck with survivors clinging to a few liveable compartments.  What she walked through was a ship that had been reorganised, deliberately.
The compartments off the corridor were in use.  Through one open hatch she saw what had been a mess hall turned over to growing trays, tier upon tier of them under cobbled strip-lights, green at every level, a woman working the second tier with a pair of scissors and a shallow basket, the girl at her shoulder, not yet a teenager.  The girl glanced up, took in the strangers without alarm, and went back to watching her mother.  Both wore passenger coveralls, not crew.  Iorwen noted it and walked on.
A man passed them in the corridor with a child on his shoulder.  The infant was perhaps four months old, awake, watching the strangers go by with the unhurried gravity of the very young.  The man nodded to Reach and went on without a word.  Iorwen registered the age of the child and stayed silent.  So did Reach.  Iorwen was still trying to reconcile what she had seen when they came to the bridge.
It was running on three live stations and salvaged light, the forward viewport shuttered over with a plate cut to fit, the displays driven off internal feeds.  A man stood at the command station, his hand resting on the back of the captain’s chair.  He was perhaps forty-five, in an engineer’s coat like Reach’s, and he turned as Iorwen came in with the slow deliberate attention of someone for whom a new face had become a rare and serious thing.
“Senior Engineer Crest,” he said, naming her. “Aevyrn Keir.”
“Acting Master.”
Iorwen had come up the corridor meaning to open with the plan.  The thing the corridor had told her had reached the front of her mind and stood there ahead of any business she had come to bring.
“How long have you been here,” she said. “On this ship.  In this system.”
Keir considered the question, and considered her, with the unhurried care of a man to whom questions from strangers had become unfamiliar.
“Eighteen months,” he said. “A little over.  Why do you ask?”
He gave the figure openly.  Keir said it the way a person gives the hour of the day, because to him eighteen months was simply the length of the ordeal.  He had counted the days because counting them was a discipline that held a crew together, and the count had come to eighteen months.  The weight in the number was the weight of the days themselves.
The weight was Iorwen’s to bring, and she brought it carefully, because she could already feel the shape of what it was going to do.
“Twenty-three months since you left Terra?  That cannot be right,” she said.
Keir’s attention sharpened.  The way an engineer’s attention sharpened at a reading that fought the gauge beside it. “Go on.”
“We left Terra together.  The expedition departed nearly six months ago.  The Fortress stood three berths ahead of us in the launch order, and we entered the same translation on the same day.  Earthbreaker came out of the warp twenty-five days ago.  Our fifth hop, the one that ended us, our logs put at nineteen days.  By every clock aboard the Earthbreaker, Acting Master, it has been six months since you and I left the Sol system.  Six months.  Not twenty-three.”
The bridge went quiet, and Iorwen watched the number land.
It hit Keir first, and Reach a moment after, and she saw in both of them the instant the figure became too large to hold.  Keir had carried eighteen months as the plain measure of his own endurance, the thing he had survived.  Now Iorwen had set a second measure down beside it, and the two refused each other.  The instruments aboard either ship were silent on which was the true one, because the terrible thing was that both were.
“Six months,” Keir said.
“Six.”
Reach had turned fully from his station.  He was looking at Iorwen with the particular stillness of a man recalculating something he had long believed was settled. “We have made our way on thrusters for eighteen months,” he said slowly. “We have a maintenance log in my own hand that runs to eighteen months of entries.  We have newborns aboard.  And you are standing on this bridge telling me that in the world we left behind, it has been a month?”
“I am telling you what our clocks say.  I cannot tell you why they disagree with yours.  The people who might have understood what the warp did to us did not survive to explain it.  The Navigators.  The choirs.  Whatever happened to us in the crossing happened to the only people aboard who could have read it, and it killed them.”
The bridge held its silence.  The recycler laboured somewhere overhead, pushing its too-humid air through the bridge, and the salvaged lights held their steady amber.  Iorwen let the silence stand.  It belonged to them.
Keir broke it.  What he said reached past the warp to the thing underneath it.  The thing that had been waiting under eighteen months of discipline for someone to say it aloud.
“Then nobody yet knows we are gone,” he said. “Not the expedition.  Not Terra.  They have not had the time to realise it.”
“Agreed,” Iorwen said. “They have not.”
Keir was quiet for a moment longer.  Then he straightened, and his hand came off the back of the captain’s chair, and whatever had moved through him was put away where Iorwen could only see his discipline. “There is something you should see,” he said. “Reach.  Show her what we have been doing with the time we did not know we were losing.”
Reach brought up the primary display, and Iorwen knew what she was looking at before he had said a word, because the shape of it was plain to anyone who had ever trained on small-vessel work.  A slingshot trajectory.  The nearest planet, an ice giant, was set as the initial gravitational well.  The trajectory used it to throw the Fortress inward, toward an outer moon of the fifth planet, a gas giant.  From there, the projected course chained through two tightening passes around the giant’s gravity well before reaching out at last toward the fourth planet.  The transit time sat in the corner of the plot in plain figures.  Seven years and four months.  A second figure sat beside the first, smaller and in the engineer’s hand of someone who used a marker daily.  Elapsed: one year, six months.  Remaining: five years, ten months.  The remaining figure had been updated recently.
“You are flying there,” Iorwen said. “On thrusters and secondary engines.”
“We have been since the second month,” Reach said. “It is within our delta-v.  We have the consumables for the crossing, if the growing bays hold, and we have run the figures more times than I can count, across all eighteen months.  The plan is sound.  We were going to arrive.” He looked at the slow looping curve on the display.  His voice kept its level.  Something behind it changed. “It was the only road we had.  So we built it, and we have been walking it ever since.”
Iorwen looked at the trajectory, and at the man who had drawn it, and she understood without being told what the Earthbreaker’s arrival had just done to him.  The Fortress had her thrusters and her secondaries and a six-year slingshot before her.  The Earthbreaker had her void engines.  She could carry these people to the fourth planet in a matter of weeks.  The road this crew had been walking for a year and a half, the long patient curve they had been steering against every day, had been shortened to a handful of weeks in the time it took two ships to come within fifteen kilometres of one another.  Iorwen held the recognition silent.  He had reached it before she had.  It was in the way his eyes held to the screen.
“Tell me about the planet,” she said instead.
V: The Telling
She stayed aboard the Fortress, and she listened.  She took the evening meal in a galley that had been a passenger mess, at a table Keir had set with Reach and three others, one a child.
The compartment ran on salvaged lumens turned low against the demand, warm enough to read by.  Other voices carried from neighbouring compartments, low and unhurried, the cadence of a crew at rest.  The recycler laboured overhead, the same humid press that ran through every part of the ship.  The smell of cooked food set against a faint green undertone from the growing bays two corridors over.  The table itself was a cobbled surface, three different alloys welded edge to edge by someone who had given the joins the same patient attention as the welds in the corridor.
The food was thin, carefully portioned and mostly green, and it was served without apology.  They had fed three hundred people for eighteen months on rationed stores and what the growing bays could raise.  The meal in front of Iorwen was the proof of it, and the table ate without ceremony.
Sera Linven was the senior surviving medicae, perhaps fifty, with the worn steadiness of a woman who had carried the only clinical authority aboard for a year and a half without putting it down.  She wore the tiredness in the bones of her face.  The eyes were still doing the work.
“We lost over half in the translation,” she said. “When our primary hab zones breached.  Since then, one hundred and fifty-one dead, most of those in the first ninety days, from the injuries of the crossing and from the things we could not treat once the supplies began to run thin.” She paused, and a smile came to her face. “Four born since.  The youngest is six weeks.”
The third at the table was Bren Maevon.  She had come aboard at Terra as an agricultural specialist and a passenger, bound for a colony still to be built, and the growing bays were hers.  She had built them out of cleared compartments and salvaged light and seed stock meant for another world.  Her daughter Aine was the child.  Ten years old.  Near the end of the meal Aine set a small dish in front of Iorwen, and on it sat a single fruit, dark-skinned and unfamiliar.
“From the bays,” Bren said. “Crossed from two strains we were carrying for the colony.  It will grow under the light we can give it.  It is the first fruit we have raised with weight in the hand.”
Iorwen ate it.  It was sour and dense and not quite ripe, and it was the first fresh thing she had tasted in longer than she cared to reckon, and she said as much.  Maevon nodded once, Aine smiled.
Later, back on the bridge, Reach showed her what the long-range auspex had found.  The fourth planet had begun to resolve within the second month after the translation, and they had been watching it ever since, every day a little nearer because the trajectory was crawling them toward it.  It was habitable.  Returns cited liquid water across the greater part of the surface, and heavy vegetation across the temperate latitudes.  A living world, with a whole biosphere, things growing and other things feeding on them.
“And anyone living among it?” Iorwen asked.
“Too far out to say.  There is no signal of any kind.  No energy emissions.  No structure we have been able to resolve at this range.  If there is intelligent life down there, it is living quietly enough that we have never seen it.” He paused. “Eighteen months of watching has told us what the augurs can read at this range.  The rest would have to be discovered the old-fashioned way.”
Iorwen looked at the green world holding steady on the display, small and far and turning slowly in the dark.
“You meant to take three hundred people to a world you had read at long range, across seven years, on thrusters and faith.”
“We meant to take three hundred and thirteen people to the only world within reach that could keep them alive,” Reach said. “Yes.  We did.  And we were going to.”
VI: The Delta
Brask took the account in order and without haste.  She read Iorwen’s written summary alone in her cabin first.  Then she put it to the surviving senior officers.  Then, across three days, she carried it to the rest of the crew, one watch at a time, so the figure landed where she stood and stayed where she set it.
The facts held under examination.  The Fortress had emerged from the warp eighteen months before the Earthbreaker, out of a translation both ships had entered on the same hour of the same day.  Both clocks were true.  Both counts were true.  The warp had taken them together and set them down apart, in space and in time both.  Explanation died with the Navigators in their sanctum and the choirs in their cells.  The minds aboard either vessel that had been turned toward the immaterium during the crossing were silent now, and they had taken their understanding with them.
Iorwen sat with what the briefings had left for her.  She did it alone, in the half-hour she allowed herself between the end of a working shift and the beginning of sleep, in the quiet of her quarters with the hatch closed and the working ship at one remove.  She turned the thing over the way she would turn a component she did not yet trust.
The Helion-Delta-3 expedition had left Terra with forty-one vessels.  Two were now accounted for.  Thirty-nine were not.
The warp had shown its hand today, by setting two ships in the same place at unequal hours.  What happened to others may never be known to those aboard the Fortress of Labour and Earthbreaker XI.  The likely reading was that the other thirty-nine had run their crossings the way the expedition had planned them.  They had come out where they were meant to come out and continued on the road the expedition had charted.  Iorwen’s road stayed here.  The Earthbreaker and the Fortress were the anomaly.  Two ships set down apart from the rest.  She set the thought down where she kept such things, and she went back to work.
VII: The Salvage
The plan came before the salvage, and the plan came out of a fortnight of meetings.
Brask crossed to the Fortress twice in the first week.  Keir crossed to the Earthbreaker, and on the second crossing he walked the wound of her midships at Brask’s side, with Iorwen and the senior officers of both ships behind them.  They went the length of the open compartments together.  The forward emergency lumens burned dim and cold against the bare structural members where the inner panels had been stripped.  The dead air carried the metallic taint of compartments that had stood open to vacuum and been resealed.  The damage at this scale the eye took in slowly.  The two captains read it in silence and put their questions to the engineers afterward.
Out of those crossings the two crews built a single shared picture of what the pair of ships had and what they lacked.  It took time.  The picture had to be true before any plan could be set on it.
When the picture was complete, it showed two ships with complementary damage.  The Fortress had lost her propulsion and kept her cargo.  The Earthbreaker had kept her propulsion and lost her fabrication.
The Fortress carried the colony itself in her holds.  Prefabricated habs.  Seed stock.  Agricultural plant and construction materials.  Medical reserves.  The whole inventory she had been built to set down on a new world, intact in holds her thrusters could carry to the only world nearby across a span of years.
The Earthbreaker had her void engines and her hull.  Inside that hull was a wound the Fortress had been spared.  The central fabrication complex was gone.  Not damaged.  Gone, with the seven hundred metres of her midships that had housed it.  What stood in her surviving holds was the raw stock for forges that had been crushed out of the ship in a single hour.  The Earthbreaker kept her workshops and her maintenance bays and the means to keep herself running.  The means to make anything new had gone with the forge.
The salvage became a long exercise in choosing what use the Earthbreaker’s surviving capacity would be put to.
The capacity was the problem.  The Fortress was a ship of the same scale as the Earthbreaker, and the room left inside the Earthbreaker after her own losses ran to perhaps a third of what the Fortress carried.  Most of what would have to be left behind, the planners agreed early, was Earthbreaker inventory rather than Fortress inventory.
The Earthbreaker had to make room before she could take anything aboard.  The forward warehouses nearest the forge plane stood as a half-crushed mass of buckled racks and displaced stock, occupying volume the ships needed.  The crews spent three weeks cutting through them, levering out what could be saved, and casting the rest through the open lock into the void on long parabolic arcs that the auspex held for hours before they faded.
The intact warehouses further forward held bulk raw material, plate and ingot and bar stock and cable.  The stocks stayed where they sat for the time being.  The colony would need them once it had hands and machines to shape them, and the Earthbreaker carried them as a matter of course.
The cargo machinery was the easy decision.  The internal logistics gear that had stood far enough forward of the crush to survive, the loaders and the bulk haulers and the cargo tractors and the smaller movers and the lifters, stayed where it sat.  The conveyor mover trains that had run between the raw-stock warehouses and the forge plane stayed with them.  The gear that had once fed forges could be turned to feeding building sites instead.  The planners kept it because the survivors’ first work on their new world depended on machine lifting.
Brask called Iorwen to her cabin in the third week.
“The Earthbreaker is as good as she will get in this system,” Brask said. “The primaries hold.  The recyclers carry.  The void engineering decks are walked and rerouted.  The rest is what proper dock time would resolve, and we have no dock.  Voss can keep the roster.  I need you across.”
Iorwen had been turning the same picture in her own head.  She nodded.
She handed Voss the watch board the following morning, walked him through what the engineering teams aft would flag and when, and crossed to the Fortress in the afternoon shuttle.  She took a cleared compartment three decks below the Fortress’s bridge and lived in it for four months.  She ate in the Fortress galley.  She walked the Fortress corridors and learned the ship the way she learned any ship, with her hands and her feet and her nose, until its sounds stopped being strange to her.
The cleared space ran out earlier than the planners had reckoned.  The Earthbreaker’s holds had been surveyed against drawings the translation had not respected.  Bracing reduced the surveyed volume.  The damage they had taken had warped them out of true, here a metre, there two.  The warping refused cargo the drawings had promised.  Three quarters of the Fortress’s inventory still sat in her holds when the Earthbreaker’s volume had filled.  The loading crews had begun to weigh modules against one another, the manifests growing thin on the items they could still choose between.
Reach said it aloud in a half-loaded Fortress bay one afternoon, with his hand on a strapped-down crate and the manifest in the other.
“Why are we treating this as the only trip we will ever make.”
Iorwen looked up.  Reach’s eyes were on the bay, and through it.
“Earthbreaker has drives,” he said. “Earthbreaker has void engines.  The fourth planet is a month from here on her engines.  She can come back.”
Iorwen and Reach took the question to the Fortress’s bridge.  Keir was there inside the hour.  Brask conferenced in by hologram from the Earthbreaker’s bridge, her image standing translucent at the head of the Fortress’s command deck.  Fifteen kilometres of vacuum carrying the signal between them.  The four of them spoke across that picture.
The answer was plain.  The obvious thing had been obvious all along, missed because everyone had been thinking in single crossings.  The Earthbreaker had her drives.  The Fortress had her holds, still mostly full.  What the Earthbreaker carried on the first trip would go down to the planet.  What stayed behind would wait in the Fortress for the second trip.  Or the third.  Or as many trips as the engines would bear.
The plan reshaped itself around the thought.
The Fortress would stay where she was, holds still mostly full, and serve as the orbital storehouse for the colony.  The Earthbreaker would carry the first manifest to the fourth planet.  She would hold high above the world.  Her shuttles would ferry the cargo down. When the manifest was on the ground, she would burn back to the Fortress for the next.
The first manifest covered the colony’s first year and first foothold.  Habs for half the population.  The first year’s seed.  The first year’s medical.  The growing-bay infrastructure to start the colony’s own production.  Cargo lifters enough to move heavy items on the ground.  The rest stayed aboard the Fortress for the trips that followed.  The rest of the habs.  The second and third years’ seed and medical.  The bulk supplies for the years after.  The raw stocks from the Earthbreaker’s own forward warehouses, when the colony had hands and machines to shape them.
That last decision turned the work back on itself.  The raw materials sitting in the Earthbreaker’s intact warehouses came across to the Fortress, plate by plate and ingot by ingot, freeing the Earthbreaker’s volume for the colony’s first cargo.  The Fortress’s holds opened back up to receive them.  The colony’s first manifest crossed in the other direction, from the Fortress to the Earthbreaker, into the volume the raw stocks had just vacated.  The work was double, and the crews counted it without complaint.  It was the cleanest route to a loaded Earthbreaker.
The cycle would run until the Fortress’s holds had been drawn thin and what remained fell below what a trip cost to fetch.
Keir agreed to it without argument.  The plan honoured his ship and his crew, and it gave the Fortress the role she could still fill with what she had.
Keir oversaw the wind-down himself.  He walked the ship with Reach the day before the parking burn.  They checked the compartments that would be sealed and the compartments that would stay live.  They walked the growing bays one last time.  They confirmed the beacon’s reset settings and the reactor’s wound-down rating against the figures Reach had carried on him for a week.  They spoke when speaking was needed and worked in silence the rest of the time.
The parking burn ran for nine hours.  Keir watched the last minutes of it from a station on the Earthbreaker’s bridge.  The Fortress settled onto the wide ellipse the calculations had given her, a stable solar orbit her thrusters could hold against drift for decades on the minimum-run rating set into her station-keeping.  Her beacon came on at full power, even and steady.  She called her own name now, her position, and the fourth planet beyond her.
The bridge of the Earthbreaker watched it together.  The Fortress was put down where she could be found again.  Her holds were still full.  The work the survivors needed her for was still ahead of them.
The Earthbreaker burned for the fourth planet the same hour.
VIII: The Orbit
The Earthbreaker reached the fourth planet in five weeks and settled into orbit.  A Heavy Planetary Works Vessel was built to hold high above a world and set her cargo down by heavy lifter.  The lifters had gone into the void with her forge and fabrication decks.  The shuttles had survived.  The shuttles would do the work.  The procedure was well documented.  Make orbit, read the world entire, choose the ground.  Then, and only then, go down to it.
The survey was set to run across three days.  Madryn worked it from the auspex arrays.  The Earthbreaker’s orbit carried her round the planet six times in each day.  On every pass the array laid down another layer of the picture, the optical over the spectral over the seismic over the magnetic.  Building toward the full geological understanding a responsible crew required before any landing.  The ground would be chosen when the world had been read, and read again, and understood.
The world below gave back everything the Fortress’s long watching had promised and more.  Forest across the temperate latitudes, deep oceans between the landmasses, an atmosphere Madryn read three times before he would commit to it.  The world was cleaner and richer than anything the Earthbreaker had been built to expect of a colony world.  A living world, and a generous one.  No signal rose from it.  No power.  No structure resolved on the first day’s passes.
The thing that broke the survey did not come from above.
IX: The Ward
The climate was sub-tropical in Terran terms.  Fires here ran for the predators more than the cold.  It was a small community fire, set on a broad canyon ledge where the rock cradled around it.  A dozen or so adults gathered round, the day’s work behind them, some children playing on the lower ledges.  The sound of water came down from the basalt fall and threaded through the talk.
Ailbhe was seven, an age at which wonders still appeared in the world, and the star was a new one.
She pointed it out a little before dusk, when the colour had gone out of the strip of sky between the canyon’s two rims and the fires of the settlement were beginning to glisten off the walls.  She stood with her arm raised.
“Tad,” she said. “Tad, why is that star moving?”
Her father, at the edge of the fire, looked up because the child had asked him to, and not because the question was a serious one.  Stars did not move.  The world began to do peculiar things if you watched through a child’s eye.  The trick of growing up was to learn which of the peculiar things meant anything.  This was probably not one of them.
He found the star she meant.  It was bright and steady and a little to the south of the brightest of the others, framed in the strip of sky between the canyon walls.  He watched it and counted lazily.  By the end of the count, the star had moved.
“You are right,” he said. “It is moving.”
The child took the confirmation the way a child takes any confirmation from an adult, without ceremony.  Heads lifted around the fire.  A woman from the next cave with her evening tea watched the star for a while and looked at her cup more than the sky.
“Comet,” the woman said. “A slow one.”
The herder beside her looked up over his own cup. “Comets do not move that steady.”
“Some do.”
“Not the ones I have seen.”
A younger voice from the other side of the fire, a man perhaps twenty, said something about meteor swarms, and the elder beside him answered without looking, that it was not the season for them.
They watched a while longer.  The star kept its precise crawl, steady in brightness, north over the basalt and out toward the line of the high country.  More of the dozen had turned their faces up to it now.  Two of the women at the back gave it the kind of long look that ran through the possibilities one at a time.
“It could be a ship,” the smith said, at length, in the voice of someone setting a possibility on the table without committing to it.
“It is not a ship,” said the elder, his voice the voice of a man who had lived long enough to recognise a thing that was certainly not a ship when he saw one.
“I did not say it was.  I said it could be.”
The woman with the tea shrugged.  The shrug of a woman who had set aside the habit of looking for ships in the sky. “If it is a ship, it is the slowest one I have ever seen, and it keeps its silence.”
A laugh went round the fire, low and shared.
The smith looked at Corragh.
“You still have the radio in the lander.”
“I do.”
“You could send something.”
A few of the others turned their heads to Corragh, not pressing, just curious.  The herder went back to his cup.
Corragh looked at the star.  Like his neighbour, he doubted it was a ship.  The thought of climbing the spine ladder in the morning and warming a transmitter that had sat cold for some time, to call on what would turn out to be a comet, sat heavy.  He looked at the fire, and at the child on the lower step.
“Sure,” he said.  The conversation moved on.
He went to the lander after first light, because he had said he would.
The lander sat where it had always sat, set across the canyon mouth like a gate, its hull holding back the forest the way a wall holds back a tide.  The cargo hold was the settlement’s main store, full of grain and dry goods and the things a settlement put away against the wet months.  The body of it had gone to other uses besides.  The cockpit, elevated above the canyon floor, served as the watch post and held the vox, and Corragh kept the vox out of habit more than purpose, because he was the last among them who knew the gear properly.  He climbed the spine ladder and let himself in to a compartment empty at this hour, and the smell of cold metal and dust met him the way it always did, and he sat down at the vox station and woke it.
It took a while to wake.  The capacitors had sat unused for some time, and they coughed and caught and faltered on the first attempt, and Corragh let them rest and tried again.  The fourth attempt brought the carrier up.  He set the vox to wide spectrum broadcast.
“This is Verdantia Settlement.  If anyone can hear this, acknowledge.”
He sent it.  He waited.  He sent it again.  He waited.  He sent it a third time, and a fourth, with the breaks between them growing longer because the hope behind them was thinner each time, and after the fifth he sat for a quarter of an hour and watched the silent gauges and thought about leaving.
The answer came on the fifth.
It came in the clean square cadence of a fleet vox operator, and Corragh sat very still.
“Verdantia Settlement, this is the Earthbreaker XI.  We hear you.”
He held silent for a long moment.  The Earthbreaker XI was a name he knew.  One of the engineering ratings he had trained beside had transferred to her crew months before launch.  They had marked the posting with a few drinks in one of the orbital ring’s crowded bars, promising to meet again somewhere beyond Terra.
He keyed the transmitter when his hand would let him.
“Earthbreaker XI,” he said. “From the Helion-Delta-3 colony fleet?”
A pause.  The pause of a bridge readjusting to the question.
“Affirmative.  Identify yourself, please.”
Corragh was already standing, because his hand had let go of the chair without him deciding it should.  He keyed the transmitter once more.
“I need to inform the Ward.  I will get back to you.”
He shut the channel before they could answer.  He stood in the empty cockpit with his palm flat on the panel and his other hand on the back of the chair.  He could feel the blood in his ears more than he could feel the cold of the metal under his hand, and he stayed like that for the better part of a minute before he could trust himself to move.
He found Fael at the seedling beds on the lower terrace.  He stopped at the head of the path, working to find his voice.  She straightened before he had it, and the look she gave him changed when she saw his face.
“What.”
“Contact.  At the Lander.  We need the Ward.”
She set the tool down, and the half-row of seedlings she had been thinning beside it, and she went past him at a walk that was nearer a run, down the terrace path toward the canyon mouth.  Corragh went the other way, and he gathered the rest of them in the order that put him in the shortest line.  Arwen from the stores.  Farren, the medicae, from her alcove.  The huntsman from the lower fence.  Two from the upper terraces.  Seven of them in all, by the time they were in the lander cockpit together.  Seven adults at once was new ground for the cockpit in any year Corragh could remember.
Fael was already at the vox.  She did not sit in his chair.  She stood beside it, the way a person stands at a thing they have not yet been given.
“Tell us,” she said.
He told them.  He told them what he had heard and what he had asked and what he had answered, and he told them whose voice had answered him and what the carrier had said, and he told them the name.  The cockpit was quiet when he finished.  The medicae put her hand to her mouth and took it away again.  Arwen sat down on the engineering bench.  The huntsman looked at the floor.
Fael held her eyes on the vox.
“Bring it up,” she said.
Corragh brought it up.  The carrier was where he had left it.  He keyed the transmitter and sent the call again.
The carrier stayed silent.
On the bridge of the Earthbreaker, Brask had the auspex officer at her shoulder and a problem on her hands.
“You did not get a fix.”
“I did not, Captain.  The transmitter cut before I had a return.  Power on the ground was barely enough to lift the signal clear of the planet’s own noise.  I have a narrow arc on the western continent.  I do not have a point.”
Brask considered it.  The bridge held its breath around her, in the way every compartment of the Earthbreaker had held its breath since the auspex officer had spoken her first sentence forty minutes ago, and the orbit was already carrying them past the arc the signal had come from.
“When can we hail back.”
“On the next pass over the same arc.  Two hours, twenty-one minutes.”
“Hail on the way around.  The same arc, on the same frequency he used.  Identify ourselves plainly.  Tell him we are still listening.”
“Understood, Captain.”
Brask looked at the planet on the display.  The arc the auspex officer had given her covered some thousands of square kilometres of the western continent, more land than the Earthbreaker would put a shuttle down to in any reckoning short of certainty.  The question of geostationary orbit stayed in her thoughts and off her tongue, although a junior officer to her left had already drawn the geometry on a secondary plot.  The orbit they were in was the survey orbit.  The survey orbit was where they would stay until they had a fix to insert against.
“Keir.” She held her station.
He came across from the side of the bridge where he had been standing since the carrier had caught.  He had been brought up from his quarters the moment the auspex officer had spoken the words unknown ground transmitter, and he had been quiet through what had followed.  He held his quiet now.
“I want you here when we get him back,” Brask said. “There are things you may hear in his voice that I will not.”
“I will be here.”
In the lander cockpit, the wait stretched.
Corragh had sent the call three times.  The third had been twenty minutes ago.  He left the fourth where it was for now, because Fael had told him to wait, and waiting was something one could do in the lander cockpit for a long time if one chose to.  The seven of them did, for the first quarter-hour, and then their numbers began to drop.
The huntsman was the first to stand.  He had to prepare for the next day’s hunting and he said as much, quietly, to Fael at the door.  Fael nodded with her eyes still on the vox.  The huntsman looked at the vox once more and left.  One of the upper-terrace women followed him after a few minutes, with a glance at Corragh that was an apology more than a verdict.  The medicae stayed, because the medicae stayed for everything.  Arwen shifted on the engineering bench.
“How long do we wait,” he said.
“As long as we have to.”
“And if there is no one to wait for.”
Fael looked at him for a moment longer than the question had asked her to. “Then we have lost a morning.  And the morning will keep.”
Corragh sat with his hand on the dead panel and watched the gauge that would move when a carrier came in, and he turned the count of his transmissions over in his head as though counting them might mean something, and after a while he simply waited.
The carrier came in on the twenty-third minute.
A new voice held the channel now.  A captain’s voice, lower and more careful, and behind it the cadence of a bridge with rather more discipline on it than the previous channel had carried.
“Verdantia Settlement, this is Earthbreaker XI.  Captain Brask speaking.  We have re-entered communications range and will maintain vox contact for approximately 80 minutes.  Please respond.”
Fael was at the vox before Corragh’s hand had moved.  She stayed on her feet.  She stood beside him and put two fingers on the back of his chair as a person sets a hand on the shoulder of someone steadying them.  Then she leaned forward and keyed the transmitter.
“Earthbreaker XI,” she said. “This is Fael.  I speak for the Ward on the ground.  We hear you.”
“Fael.  Earthbreaker XI.  We are glad to hear you.  We have a great deal to ask, and very little of it that we know how to ask first. Will you bear with us.”
“We will.”
A pause from the bridge above.  Then, carefully, the question Brask had clearly settled on as the one to begin with.
“How did you know we were of the Helion-Delta-3 expedition.”
Fael held her eyes on the gauge.
“Because we left Terra with you,” she said. “Six years ago.  We are from the Anam Talamh.”
The pause that followed was longer than the others.  The carrier hummed.  Somewhere above the bridge of the Earthbreaker a great quiet had opened, the kind of quiet a number can make when it lands in a place that had been holding a different number all along.  Then Brask’s voice came back, slow and exact.
“Fael.  I have your statement.  I need to set a figure beside it before we go further.  The Anam Talamh left Terra alongside the Earthbreaker XI.  Our launch order had her two berths ahead of ours, on the same dock, on the same day.  The Earthbreaker left Terra eleven months ago.”
The lander cockpit held still.
In the background, behind Brask’s voice, faintly, another voice spoke.  It did not address the channel.  It addressed someone on the Earthbreaker’s bridge who had asked it a question Fael could not hear.  The voice was a man’s, older, in the careful cadence of a bridge officer.
“Two years, four months for the Fortress of Labour.”
The line carried.  Fael held her two fingers on the back of Corragh’s chair.  Her eyes stayed on the gauge.  She held her silence for a long moment.
The carrier began to soften under her hand.  The signal had been climbing toward the limit of the planet’s curvature for some minutes, and now it began to fade through it, the words still legible but the consonants going soft.
Brask noticed it the same moment Fael did.  Her voice came over the carrier once more, deliberate, audible through the thinning.
“Fael.  We are losing you on this pass.  Stand by.  On the next orbit we will hold higher.  We will speak again in two hours forty minutes.”
The carrier went out.
On the bridge of the Earthbreaker, Brask waited until the signal was clean of the planet’s noise before she spoke.
“Navigation.  Plot me a geostationary insertion on the next pass, fixed on her transmitter.  I want us above her on the orbit after that and holding station relative to her.”
She looked at the green world turning below them, and at the patch of sky on the western continent where a voice had spoken her ship’s name and another voice had named a year the warp had no business making.  She set her hand on the back of the command chair and stood with it there.  She held her silence.
The bridge went to its work.
THE UNSHIN CURRACH
I: The Hail
The array shed smelled of machine oil, cut timber and wet basalt.  The oil had come down off the Earthbreaker in drums and worked its way into the bench wood years ago.  The timber had come off the Achub basin forest, plank by argued-over plank.  The basalt was the basin itself, which sweated in the hour before dawn and gave its smell up to anyone who came through the door.
Aine Maevon came through the door.
Voss was at the main bench with a relay housing open under the lumen strip, his tools laid out in their rows, his hands in the wiring.  He glanced up and went back to the work.
“Late,” he said.
“The sun is not over the rim.”
“The sun is idle.  You are an apprentice.”
That was Voss being funny.  Aine hung her coat on the peg that had been hers for a year and sat at the secondary bench, where the night’s traffic waited on the slate.  She worked through it the way she had been taught.  Water levels from the river stations beyond the wall.  Weather observations off the plateau posts.  Watch sightings, two, both logged and cleared.  A maintenance request from the southern terraces for another pump.
“Southern terraces want a pump,” she said.
“They wanted a pump last month.”
“The last one broke.”
“It was repaired.”
“The repair broke.”
Voss grunted and kept his hands in the relay.  She added the request to the queue.  The queue never shortened.  It only rearranged.
The labels on the equipment racks above her bench were written in a hand that was neither hers nor Voss’s.  The marker had faded on the oldest of them, but the letters still held their shape, square and deliberate, the hand of a woman who had labelled things so that other people could find them after her.  SOUTHERN REPEATER, read the strip nearest Aine’s shoulder.  FINAL CALIBRATION.
The southern repeater had never been calibrated.  It sat in its crate at the end of the shed under a tarp, beside the crates for the northern expansion and the monitoring posts that had never gone west.  Sian Brynach had planned all of it.  She had built the array itself, two years gone now, out of the last salvage to come off the Fortress of Labour, and she had filled her dataslate with what the array should become.  Then she had gone up the canyon’s high path along the edge of the plateau forest.  A Morgath had taken her, and the dataslate had gone onto the shelf above Voss’s bench, where it stayed.
Aine had been her apprentice for three months.  Long enough to learn the names of things and the order of the morning.  Long enough to understand how much Sian carried.  The how of it had gone out into the grass with her.
Voss had taken the apprentice along with everything else.  He had never replaced the labels.  Aine suspected he never would.
Through the long western window the canyon was waking.  Cooking smoke weaved its way through the lower terrace canopy.  Lumens went out along the third gallery as the light came down the eastern face.  The school caves sat across one of the side basins, and the bridge to them ran out above the treeline into open air.  The settlement had drawn that span in steel cable off the Earthbreaker’s holds.  Where the canopy fell away beneath it they had roofed it, not in salvage plate, the long spans could not carry the weight, but in rope netting threaded thick with ferns, so that anything hunting the high air would find the crossing greyed over and broken up and hard to read.  A line of children was going across it now behind their teacher, small shapes moving through the hanging green, and Aine counted them the way she always counted them, without deciding to.
Twenty-four.
One class of the three.  The classes had been split since the flood, and they had never been merged again, because the numbers had never come back to merge.  The flood had killed nearly a hundred people ten years ago, in the settlement’s second year, when the canyon was the Anam Talamh’s people alone, and perhaps a third of the dead had been children.  Aine had landed five years after the water.  She had never seen the classes whole.  What she could read was the hole the flood had left in the cohort now coming of age, and the thin crossing lines below it that the years since had never fattened.  Each one carried its own spread of ages.
Aine went back to the slate.
At the quarter hour the Earthbreaker’s morning report came down on the long carrier, four standard lines in Brask’s standing format: orbital status, power status, shuttle availability, a note on tracking maintenance.  Brask had run the same four lines for five years.  Aine logged them and reached for the next item in the queue.
The monitor at the end of the bench gave a tone she had never heard it give.
She looked at it.  The channel designation stood at the top of the trace, and she knew it the way she knew her own name, because checking it was the first task of every morning and the last of every evening, and in a year of mornings and evenings it had never once carried anything at all.  The Helion-Delta-3 emergency channel.  The fleet’s distress band, watched by the array on the ground and by the Earthbreaker above, kept open across five years of silence because the procedure said to keep it open.
The channel was speaking.
The signal was weak, ragged at its edges, and it repeated.  Aine put it through the discriminator with her hands moving ahead of her thinking, the way Sian had drilled her in those three months, and the repeat resolved into words on the slate.
VESSEL UNSHIN CURRACH.  EXPEDITION HELION-DELTA-3.  DISTRESS.  DISTRESS.  DISTRESS.
She sat still for the length of one full repeat.
“Voss.”
Something in her voice brought him off the relay without a question.  He crossed the shed, read the slate over her shoulder, and stood with his hands flat on the bench while the loop ran through twice more.
“Raise the Earthbreaker,” he said. “Confirm they have it.”
She keyed the vox.  The second of the geostationary distance sat in the channel, and then Reach’s voice came through, and there was none of the morning in it.
“Verdantia array, Earthbreaker.  We have the channel.  Say what you are reading.”
“Vessel identifier Unshin Currach, expedition Helion-Delta-3, distress call on repeat.  Signal is weak.  No position data in the loop.”
“That matches our read.  Time-stamp your first reception and send it up.  Brask is on the bridge.  We are preparing to break orbit and go out to her.”
“Understood, Earthbreaker.”
“Trainee.” A pause rode the delay. “You were on the channel before we were.  Log it that way.  The first Verdantian to hear her was on the ground.”
The vox closed.  The loop went on repeating under the morning carriers, patient as a pulse.
Voss straightened from the bench.  He looked at the slate for a moment longer, and then he took Sian’s notebooks down off the shelf.
“Log the reception,” he said. “Then clear your bench.  There is going to be work.”
Aine logged it.  Through the western window the basin went about its morning, the smoke standing in its lines, the second class starting across the bridge.  The whole of it not yet knowing that the sky had spoken anew, 11 years after the Anam Talamh first settled Verdantia.
II: The Wait
The Earthbreaker broke orbit that afternoon on a burn the whole basin came out to watch, a hard point of light pulling out of its place in the sky for the first time in five years.  Brask took her out toward the source of the hail, and the distance opened behind her.  The round-trip on the vox grew with it.  The reports came back in chunks.  Aine logged every one.
On the second day Fael climbed to the array herself.
She came up the terrace path with her hands behind her back and stood in the doorway until Voss waved her in.  Fael waited to be waved in everywhere, two years with the title and she still wore it like a coat borrowed from a bigger woman.  She read the latest relay off the monitor.  Then she looked at the crates under the tarp at the end of the shed.
“Sian’s repeaters?” she asked.
“Some of them.”
“If a ship is coming, the Ward cannot run on a dataslate carried up and down the canyon.  Nor can the gates, nor the receiving ground we will need to build.” She paused the way she always paused before asking for anything. “Could the two of you put her plan into the walls?  I am asking.  I know the watch it would cost you.”
“It can be done,” Voss said. “The Ward chamber inside two days.  The gates and the receiving station after.”
“Then I ask it.” She stopped in the doorway on her way out and looked back at the bench, at the faded labels in the square hand. “She drew the whole of it years ago,” Fael said. “We never gave her the hands to build it.  Build it now.”
She went down the path.  Voss pic ked up the dataslate from the bench, blew the dust of and brought it to life.  The work began.
They built the relay net through the days that followed, between the watches on the carrier.  Aine ran cable while Voss set junctions.  The chamber link went live on the second evening.  The Ward heard Brask’s next relay as a voice in the room instead of a dataslate. Aine, listening from the array end, heard the Ward go quiet around it.
Keir had the settlement machines, and Iorwen had half the basin’s standing failures, so none of the engineering hands could be spared.  The rest of the net went up on Voss’s hands and hers alone.  Every junction they sealed was a junction off Sian’s drawings.  Aine found she was checking her work twice, and then understood who she was checking it for.  She kept checking it twice.
On the fifth day the damage report came through.
It came down the long relay in Brask’s flat delivery and ran out of the chamber feed into the array’s speakers, and Aine stopped with a connector in her hand and listened to all of it standing up.
The Currach had lost her forward dorsal section and the command tower with it.  The bridge was gone.  The superstructure was gone from the prow back to the first habitation ring.  A breach ran along her port flank beneath the hangar bays for much of her length.  Decks stood open to the void along the run of it.  Great reaches of the outer hull were simply missing, though the structural members beneath had held in numbers enough to keep her whole.  Emergency bulkheads had sealed what they could.  Her port engines were dead.  She was crawling on her starboard primary alone, with attitude control and a limited power plant and life support in the sections that still deserved the name.
Her captain had perished on the bridge, and the senior officers with him.  Her chief engineer had died in the aft port containment.  A third of her void engineering complement in the same hour.  The man holding her was Sarn Lewell, her chief medical officer, acting captain because the ship’s roll had run out of anyone senior to him.
The feed went quiet.  The round trip for any question stood at two hours by then to the Earthbreaker.  Nine if a response was needed from the Currach.
Aine set the connector down.  She had read about ships dying.  Every child of the colony had.  It was taught in the school caves as beginnings, the fleet of forty-one that had left Terra in the middle of 603, the three that had found this system across the years.  The Helion system they called it now.  The rest unaccounted in the dark.  The Currach made four.  Aine was logging the first new ship of her conscious life.  She had thought she understood what the lessons meant.
She had been aboard a dying ship once.  She had kept less of it than she should have.  What she kept was her mother’s hand closed over her wrist, a corridor of the Fortress of Labour with its gravity failing in slow pulses.  She remembered the list, read aloud in a hold, name after name after name, and two of the names her father and her sister.  She had been nine when the Fortress’s catastrophe took them.  She had been ten when the Earthbreaker found what was left of the ship and took the survivors aboard, and eleven when she stood at a viewport with Bren, five weeks out from Verdantia.  When she watched a green world come up out of the black and did not know how to want it.
Three hundred and thirteen had walked off the Fortress.  The list in the hold had been longer than that.
She picked the connector back up.  Somewhere out in the dark, on a ship with no bridge, there were holds with lists of their own.
The net was finished inside the week, the gates and the receiving station live on schedule, and the southern repeater came out of its crate at last and went onto its mast with FINAL CALIBRATION still legible on the housing.  Voss did the calibration himself.  He wrote nothing on the label and he took nothing off it.
The reports kept coming down the lengthening relay.  Brask reached the Currach.  The transfer of equipment and hands ran across three days on a cadence she set with Sarn Lewell.  Reach went across with an engineering team and what they could carry.  Sarn Lewell handed Reach the engineering of the ship, his rating being equal to it and the Currach having no one left whose rating was. The repair would take what it would take.  The Currach would follow when she could.
On the thirtieth day Brask sent the roster of what she was bringing home, and it came down the relay in chunks across two hours, and Aine logged it line by line as it came.
All who could transfer would cross to the Earthbreaker.  The Currach’s medicae deck had survived intact with its staff, so her injured would stay aboard her where they could be best treated, and she would follow under her own power, four months to Verdantia, less if Reach’s work went well.
Five hundred and sixty-five would come down on the Earthbreaker.  One hundred and forty-seven, crew and injured, would remain with the ship.
Of the five hundred and sixty-five, two hundred and seventy-three were children.
Of the children, a third were orphans.
Aine read the last line when it resolved, and then she read it again, and the figure did not change for the reading.  Around her the work of the array went on, Voss querying the relay about a corrupted block, the routine carriers ticking underneath, and none of it reached her for a while.  Ninety-one, near enough.  Ninety-one children coming down the sky with no one’s hand to come down holding.
The settlement would read the line and see guardianship, housing, schooling, food.  The Ward was probably reading it that way now.
Aine saw a hold, and a list being read, and a hand closed over a wrist.  Someone had done that for her.  Someone had taken her name at the bottom of a ramp, and found her a bed, and put food in her hands, and told her what the strange quiet of the new world was.  She could not remember who.  She had been eleven, and the people of the canyon had been a wall of strangers, and the strangers had simply absorbed her, and at some point between then and now the absorbing had finished and she had been Verdantian.
Ninety-one.  The number followed her down the ledge path that evening, past the second-ring beds where her mother was walking the rows in the last light with the team a step behind her, the botany Bren’s these two years since Fael had set it in her hands.  It followed her through the meal and into sleep.
In the morning it was still there.  She had stopped minding that it was.
III: The Cost
The canyon turned to the preparation the way the canyon turned to everything, without ceremony and at cost.
The salvage crews cleared caves that had stored timber and turned them into habs.  Floor gangs laid lime binder by lumen-light into the small hours.  The receiving station grew a second roof.  The watch rotations thinned to feed the work, bodies that should have been on the wall going instead to the caves and the floors and the cable runs, and everyone knew the price of a thin watch, and the work went on because there was no way to do it that cost nothing.
Voss paid his share on the southern gate run.  A junction he had laid in the first week failed under load on the day he brought the line to full power.  The failure burned the run back thirty metres before the breakers caught it.  Two days went into stripping the damaged length and reseating every connection on the run.  He finished the southern gate five days before the Earthbreaker was due, and came up to the array that evening with the smell of scorched insulation on his coat.  He sat on the bench for a quarter hour saying almost nothing, and drank a cup of the broth they kept on the small burner, and went home.  Aine finished his bench checks herself and said nothing about it in the log.
The wall paid next.  A predator came through the lower ring at the south end, where the watch had gone down by one.  It took two on the wall together inside the same minute, and carried the third out across the grass toward the river still screaming, and the screaming went out beyond hearing and did not come back.  The watch was rebuilt to full count by morning.  The southern posts were doubled.
Arwen ran her harvest numbers to the Ward and the relay carried her flat conclusion up to every station on the net: unless the Currach came in with food in her holds, the basin would be foraging the plateau forest across the lean months.  In the last twelve months seven foragers had gone up into that forest and stayed there, the Morgath the likeliest reason.  The arithmetic was the arithmetic.  Nobody argued with it.
Then the dry season broke and the rains came.
Three days of water came down off the plateaus, and the southernmost of the culverts blocked up.  The culverts were cargo containers, their ends cut away years before and the hollow shells buried through the base of the wall where the river ran through them and out across the grass plains toward the Maurach, the great river.  The whole settlement understood what it meant when one of them stopped running, because the wall had taught that lesson once already at the price of nearly a hundred lives.  The blockage had to be cleared from the outside, beyond the wall, at the water.
The task was simple enough, so they sent an apprentice engineer and two labourers.
Two came back.
Aine learned it the way the basin learned everything, in pieces, on the paths.  The Brysgath had come along the waterline and taken the apprentice before either of the others could raise a shout.  The culvert was cleared the next day by a full crew with a doubled escort, and the river ran, and the wall held, and the price was on the board by the southern gate before the week was out.
She went down to read it.  She had told herself she was passing that way regardless.
The memorial board was old hull plate, planed smooth, and the names ran down it in marker, and rain and sun had greyed the oldest of them to shadows.  The new entry stood black and wet-looking at the foot of the column.
COLM DARGAN.  APPRENTICE ENGINEER. 17 YEARS.  TAKEN BEYOND THE WALL.
She stood in front of it for a long time.
She had known him the way the basin knew everyone, by face and trade and family.  He had been a year older than her.  He had been sent beyond the wall to do work that wanted hands the basin did not have to spare, because a ship was coming and every spare hand was preparing for it.  Something had been working the waterline the way something was always working the waterline.  Now his name was on the plate with the rest.  Sian’s name was fifteen lines above his.  The marker had greyed on it.  Aine had not been down to read the board since they wrote it.
The Currach was still months out in the dark.  The Earthbreaker, days.  People were dying at the ordinary rate in the ordinary ways, and the world had not paused for the ship.  The work the dead had been doing was picked up by other hands the same week.
She walked back up to the array and ran the evening checks and signed the log.
The preparation closed out across the last days.  The caves were dressed.  The floors were cured.  The receiving station stood ready under its doubled roof, the broth and the water laid in, the registry tables built, the relay net live to every corner of it.  The canyon was as ready as the canyon could be made in the time.
The Earthbreaker entered Verdantian space on the twenty-seventh day of the return, and Brask brought her up the long arc into the old geostationary line above the basin’s longitude, and held her there, and the point of light stood again in its place in the sky as if it had never left.
The first shuttle came down the next morning.
IV: The Landing
Aine heard it before she saw it.
The sound rolled up the basin ahead of the airframe, a deep working thunder that brought heads up off benches and out of bed-rows all along the terraces, and conversations stopped, and tools went down, and faces turned to the rim.  Shuttles were nothing new; the Earthbreaker had run them for years.  Every soul in the canyon knew this one was different, and stood still for it, and watched it come over the rim heavy and slow and settle onto the receiving ground beyond the wall in its own storm of dust.
For a moment after the engines died, nothing moved.
Then the ramp came down, and the canyon went back to work.
Aine was on the registry by mid-morning.  The intake had claimed every literate pair of hands it could argue out of the other details, and she could read, write and keep a queue moving, and so a volunteer pressed a slate into her hands and pointed her at a table, and the work began and did not stop.
Names.  Family groups.  Trades.  Medical referrals to the cubicle behind the partition.  Housing chits for the dressed caves and the cleared stores and the communal halls that had become accommodation overnight.  The same dozen questions, asked and answered and logged, over and over until the asking wore a groove and ran in it.
The reports had been numbers.  The ramp gave back people, and people were different.
They came down slowly, and carefully, the way people move who have recently been picked up and shaken.  Some carried bags, some carried children, some carried everything they owned in the world and it did not fill their arms.  A man came down on crutches built from conduit.  A woman came down with an infant on her hip and two children steered by the one free hand.
By the basin’s calendar they had left Terra eleven years ago.  By their own bodies it had been a season.  The warp had folded the years away from them, the way it had folded years away from the Fortress before her, and the catastrophe that had torn their ship open was weeks behind them rather than years.  The grief coming down the ramp was fresh grief.  It had not yet had time to learn how to carry itself.
And under the grief, the Falamh was waiting for them, the profound quietness that sat beneath every other sensation of this world.  Aine watched it take them one by one as they came into the open air, each in their own measure: a pause, a hand put out to a rail that was not there, a man going grey and sitting down in the dust mid-queue, a girl turning aside to be sick with the medicae crew already moving, because by the second day the medicae crew knew to watch for it.  Some it barely brushed.  Some it took by the throat.
Some wept at the bottom of the ramp and some laughed strangely and most did neither, just stood blinking in the open light of a sky they had not yet believed in.
Children passed her table all day.  Frightened ones, sleeping ones, ones too young to understand and ones old enough to understand everything, all of them carrying losses still young enough to be raw.  Some had family groups entered beside their names.  Some had a blank in the column and an annotation in the trade field, apprentice, pupil, none as yet, and those she logged with particular care, and watched go on up the path in the keeping of Roisin’s people, and made herself move to the next in the queue.
She had stood in this queue once.  Someone at a table like this one had taken her name.  The realisation arrived in the middle of the afternoon, between one family and the next, and settled in without ceremony, the way the important things did, and stayed.
Iorwen came through the receiving roof once during the day with a toolkit, ran a fault out of the local vox at the far alcove, showed the man on the set where to look for the same failure twice more, and was gone back to the lower workshops before Aine could do more than nod across the floor.
The second shuttle came down at midday.  The third behind it.  The basin grew louder with each one, more voices, more footsteps, more questions, until it sounded the way Aine could not remember it ever sounding, which was crowded.  Every bed in the settlement filled, and then every space that could pretend to be a bed.  Nobody complained where she could hear it.  Everybody was too busy.
The fourth shuttle came in toward dusk, and with the light going amber down the western face, the Kavane family reached her table.
She had marked them in the queue without meaning to.  A woman of perhaps forty-seven in the working clothes of an agricultural specialist, grey at her temples, four assignment slips folded together in one hand.  A man behind her with his colour gone bad, crouched more than standing beside the smaller of two children, who had been sick on the ground near the ramp, thoroughly, and was leaning into his knee, finished and unsteady.  An older girl of eleven or twelve stood back from them both with her arms folded, pale herself, wearing the particular embarrassment of an older sibling.
The woman set the slips on the table.
“Emer Kavane,” she said. “Four.  Kavane, Brion.  Kavane, Saoirse.  Kavane, Nuala.”
Aine entered them.  The man, Brion, lowered himself the rest of the way down beside the small one and put his head close to hers, and what he murmured did not carry, and he looked worse than the child did.  The Falamh had him by the throat.
“He should drink water,” Aine said. “Slowly.  The medicae will give him something for the nausea if it does not pass in a day.  For most people it passes.  The cubicle is behind the partition there.”
“Is he ill?” The older girl, Saoirse, had a hand pressed flat against her own stomach. “Am I?”
Aine looked at her, and found she had the answer ready, because she had grown up inside the answer.
“It is the feeling of the place,” she said. “Everyone has it when they first come down.  Some worse than others.  We call it the Falamh.  We do not know what it is.  Nobody has ever known.  It fades in your body, and then one morning you wake and you cannot quite remember what it felt like at all.  I came down when I was eleven.  I could not tell you now what it felt like, and I felt it.”
Saoirse considered that, and considered her, and gave the small grave nod of a child accepting an explanation given seriously.
Emer Kavane had not moved through any of it.  She stood with her balance settled and her eyes past Aine’s shoulder, on the wall that closed the canyon mouth.  The leaning bulk of the grounded lander at the walls centre, the stonework and plate and earthworks layered around it.  She was reading it the way a person reads a piece of working infrastructure.  Whatever had hold of her husband had hold of her as well.  Aine could see it once she knew to look.  The stillness was held, the balance was work, and the woman was simply declining to be moved yet.
“These walls are more than a boundary,” Kavane said.  It was said in the even cadence of an observation made at the moment of the seeing.  She brought her eyes down to Aine. “What is it you defend from?”
The queue was long and the light was going and Aine answered her anyway, because the question had earned it.
“The predators built the first wall,” she said. “The flood built the second.”
Kavane waited.
“The first settlers closed the basin mouth with the lander and the grounded shuttles and stone, and most of what you are looking at is that first wall, still standing.  It held the predators out.  Ten years ago, in the settlement’s second year, the rain came down off the plateaus for weeks, and the channels through the wall blocked, and the river backed up until the settlement was a reservoir, and when it broke, nearly a hundred people died.  The rest was built after that.  The culverts through the base, big enough that they do not block easily.  The retaining work.  The earthworks above.  Each piece was paid for before it went up.” She glanced along the wall’s uneven line. “It looks strange because nobody planned it whole.  Each part went up after something went wrong, and none of it ever came down.”
Kavane took that in with a small inclination of the head, courtesy’s exact measure and no more.
“And the feeling,” she said. “The one that has us.  You truly do not know what it is.”
“We truly do not.  We gave it a name and we live inside it.  The newcomers feel it hardest.  You carry it well.”
“I feel it,” Kavane said, in the tone of a woman noting that water runs downhill. “I am busy.  I will mind it later.”
Aine stamped the chits and passed the slips back across the table. “You are assigned to the agricultural details.  The crews muster at the second-ring beds at first light; ask for Bren Maevon.  The hab marked on the chit is up the eastern path.  There is broth at the head of the ramp.”
“Thank you.” Kavane gathered her husband up off the ground with one hand under his arm, took the small one by the hand, and moved her family off into the flow of arrivals at her own steady pace.  Within moments they were gone into it, one family among hundreds, four names among the day’s long roll.
Aine looked after them a moment longer than the queue allowed.
Then the queue reclaimed her.  The light went out of the western face and the lumens came up and the names went on.  The intake closed near midnight, with shuttles still scheduled for the morning and the morning after that, because everyone working it had reached the end of what they had.  The last families were walked to their habs by lamplight, and the receiving ground fell quiet for the first time in two days.
V: Night
Aine climbed to the array ledge in the dark.
The basin below was lit the way she had never seen it lit.  Lights ran along terraces that had stood dark her whole time on this world, lamplight in the dressed caves, lumens strung over the communal halls.  The sound that came up on the night air was voices, hundreds of voices, the flat vowels of the canyon-born.  The ship-worn accents of the Currach folk laid over one another and already beginning to blur at the edges.
The settlement had counted eight hundred and three on the morning she first heard the hail.  The count now was a number the registry had not yet settled, and would not settle for days.
The basin that held them all had a name now, the Achub, as the canyon-born had taken to calling it, the refuge; and the wall still stood at its mouth.  Beyond it the grass plains ran for a kilometre to the Maurach river, and beyond the river the plateau cliffs on the other side stood against the stars with the forest black along their tops, patient, indifferent, hungry on its own schedule.  The rains had brought the herds back onto the grass and the Brysgath had gone down after them.  The dry season would bring them back to the basin’s edges.  The season was a tendency, no more; one had come up the waterline for Colm Dargan at the start of the rains all the same, and his name stood priced onto the board for it.  The Falamh still lay under everything like a held breath, and people would still die here at the rate this world charged, because the world had taken on five hundred new lives and changed nothing else about itself at all.
For as long as Aine had been old enough to count, the basin had been thinning.  A funeral at a time.  A thin crossing line at a time.  A name on the board at a time, the births never quite keeping pace.  The future getting narrower each year by amounts too small to mourn and too steady to ignore.
Tonight the count ran the other way.
Above the rim the Earthbreaker held her point of light in its old place, and somewhere beyond seeing the Currach crawled on toward them on her one good engine, months out, carrying the rest.  Down the sky on the morning shuttles would come more names for her slate, more children for the split classes, more hands for Sian’s unfinished notebooks, more mouths for Arwen’s hard arithmetic.  The world would charge for all of it.  The world charged for everything.
There was, for the first time in Aine’s counting life, something on the ledger worth the charging.
She stood a while longer in the cold with the lights below her.  Then she went into the shed, checked the emergency channel out of five years of habit, found it silent, logged the silence, and banked the burner for the morning’s broth.
The work would go on.
It always had.
THE SOUND OF SILENCE
I: The Grounded One
The settlement had begun on the plains.
The plains smelled of earth.  Not dust, nor the thin scent of cultivated fields, but deep soil, black and damp and rich enough to seem almost edible.  Beneath it lay the smell of growing things, grasses and reeds and unseen roots.  The rainforest at their backs added notes of wet bark and leaf mould.  From the sea came something stranger, iodine and distant blooms carried on the wind.
Aine knew that smell the way she knew her own birth date, secondhand and certain and never seen.  She had the stories from the older generation, who could not describe the river plains without their faces changing.  The founders who had set their landers on the alluvial flats between the cliffs and the sea, kilometres of braided grass and good silt.  They had broken the ground for crops, because crops took time and their food stores were finite.  They had learned, on that open ground, what the sky held.  The plains fed the settlement and the plains killed it in the first month, until the people who were left carried what they could into the canyons.
The plains were still cropped.  They had to be, the terraces could never feed everyone, and the long fields still ran from the basin mouth down and along the great river out to the open plains towards the sea.  Serviced now by caged and roofed crawlers, worked fast and watched hard.  But the living was in the Achub now.
The first ground they had taken inside the canyon, the mouth and the near slopes of the basin, they had cleared for food, timber and the space to live beyond the caves.  To bring down a stand of Verdantian forest cost more labour than anyone would spend twice on the same acre.
The Currach had turned clearing into hunger.
Five hundred and sixty-five people had come down the ramps in the clothes they stood in, and they needed homes.  Homes, the way a body needs a roof every night there is weather and every day there is the Mordrai.  They needed beds and stores and barns, and they needed fields wider than the Achub had ever carried, and every one of those needs came back to trees.
So the Achub cut, and Aine had grown up inside the sound of it.
She came down the array path in the evening, and the evening came down with her.  Resin reek of fresh-cut timber, thick enough to taste at the back of the throat.  Sawdust still hanging gold where the last light came level through the stands.  The ground trembling faintly underfoot, the way it always did near a working logger, a deep patient shudder she felt in the soles of her boots two terraces up.  Cold beginning its slow fall off the high rim.  Her ears rang from a shift in the headset, so the whole canyon reached her one remove away, padded, as though heard through water.
The light was lying long across the south fields, where light had no business being.  In the spring there had been canopy there.  Now there were stumps in rows, and brassica between them.  An open lid of sky over ground that had stood in green shade since before she landed.
She was halfway to the terraces when someone shouted.  The cry carried across the open basin, sharp enough to cut through the chatter of the harvest.  Another voice answered it.  Then another.  Metal rang against metal.
Aine stopped before she realised she had.
The work party had broken apart.  Some were running.  Others backed away through the crop with sickles still in their hands.
Then the wind shifted.
Blood.
Fresh enough that the iron taste reached her beneath the smell of crushed barley and sap.  Aine looked towards the shouting.  At the centre of the torn crop a cutter lay on his back.  Over him, mantling across the crop, a wing the width of a door folded slowly shut.  Only then did her mind understand what she was seeing.
The Mordrai had landed without a sound.
That was the whole of its horror, and every child of the canyon was taught it.  None believed it until they stood where Aine stood.  It had come down out of clean evening air with nothing to mark its falling, and taken a man between the rows while his crew worked ten paces off.  The first any of them knew of it was the shadow and the wet sound under it.
It bent to the kill.  Then it gathered him up in its claws, two toes forward and two closing back through him like a fist, and beat down once to lift.
A grown man is a great deal to carry.  The downbeat threw dirt and chaff sideways, and the Mordrai came up slow, climbing by hand-spans with the weight turning beneath it.  The people under it found their voices all at once.  They broke and screamed and ran, and it was the screaming that saved the rest of them, because the screaming carried to the wall.
Heads came round on the gate platform.  Lascarbines came up.
Three snapped together, a flat triple crack that bounced off the far canyon wall and came back a heartbeat later, and for an instant the failing dusk was full of hard light, the bolts a stuttered line of white across the grey air and, below them, the chain blades of the dropped tools still spinning where they fell, throwing their own cold glitter up out of the green.  A bolt went into the wing root at the shoulder.
The climb broke.
The Mordrai came down into the field with its prize beneath it and one wing folding wrong.  What stood up out of the crop was no longer a hunter taking a clean kill.  It was a cornered animal the size of three people.  One wing dragging like a torn sail through the field, and it was faster ruined than anything whole in the Achub.
What came after, Aine watched from the terrace path, too far to reach and unable to look away.
It killed the man it had dropped, that first cutter, before he could rise.  It caught a woman backing toward the drying racks who never reached them.  And it came up against a cutter who still had a running blade in his hands.  In the thrash of that half-second the blade went where a blade goes when a body is thrown onto it.
A cutter lay pinned to the ground, leg at an angle no human joint had a right to be.  Four of them ran forward.  Two grabbed the cutter, the other two stood over them, chainsaws whirling.
Aine knew one of them, Brion Kavane, the big quiet man off the fourth shuttle.  The one who had gone grey at his first breath of the world and held the ramp rail while the Falamh went through him, whose wife had looked at the wall longer than she had looked at the sky.  He was good on the cutting lines.  People said it the way Verdantians said such things, as a fact with weight.  He put himself between the dragging wing and a cutter pinned on the ground, and he stood there the time it took them to drag the pinned man clear, and then the wing came round and he was not standing anywhere.
It ended with the crews and their blades.  The watch could not fire into the crush, so the cutting teams closed on it instead.  In among the wing and the snapping head with the same tools that had opened the sky over the south fields.  They finished it there in the vegetables, at a cost the lists did not record, because every one who paid it walked away.  From the first shadow to the last blade it had lasted a dozen breaths, no more.  That was all the time the world needed to take four people out of the Achub and leave it holding a kind of fear it had not carried since the plains.
They burned the Mordrai that night on the shingle below the basin lip.  Nobody would eat it and nobody would bury it inside the wall.  The pyre threw its light up the canyon wall and stood late into the dark, and the watch stood with it longer than a dead thing needed, and not one of them watched the fire.  They watched the gap in the canopy overhead, the open place the season’s cutting had made, where the dusk still showed through.
The lists were read in the morning, in the lee of the lander.  Four names.  Aine stood at the back with the array log still under her arm, because she had not gone home.  The Kavanes stood at the front, Saoirse with her small sister’s hand held in hers and their mother on the far side.  They did not weep where the Achub could see them, and the settlement understood that this was not coldness.  It was a household deciding what the loss would be made into.
Emer Kavane walked the Achub the next morning.
Aine watched her from the array platform, a small figure moving among the stands with two of the cutting foremen trailing her.  She was not looking at the ground.  She was looking up, into the crowns, stopping under the great trees, the metre-and-more giants the crews had spent the season working around.  At each one she stood a moment, and laid her hand flat on the bark, and said something one of the foremen wrote down.
She was marking them to keep.
Aine understood it later, in pieces, the way she came to understand most of what Emer did.  The Mordrai hunted from height and it hunted the open.  It took the herds on the plains and it took the cutters in the new clearings, and it did neither thing beneath a closed canopy.  A closed canopy gave it no lane to stoop and no room to lift a kill away.  The Achub had spent a season opening its own roof to feed itself.  It had booked the deaths that followed to ill luck, the way it booked everything to ill luck until someone troubled to count.  Emer had counted.  The trees the crews were about to fell were not timber.  They were cover.  The Mordrai came from on high, onto open ground, and the answer was not to watch the sky harder.  The answer was to leave the sky less to come through, and to know the enemy well enough to take from it the two things it needed, the height and the open.
She did not say most of that.  What she said, the foremen carried back, and by evening the Achub had it in her own words.
The Mordrai did not break in.  We opened the roof and called it down.
The loggers stood idle a day, and then a second.  When the cutting started again it started changed.  Crews marked the stands to keep before they marked the stands to fall.  Canopy stayed standing in bridges over the paths and the water.  The open ground was taken in rows a body could cross in a few strides, never in a single clearing wide enough for a wing to work.  Nobody put it to a vote.  The Achub simply cut a different way that week than it had the week before, and went on cutting that way for twenty years, and the small woman who had laid her hand on the first marked tree never once raised her voice.
II: One Officer
The Earthbreaker came home once a year, and you heard her before you saw her.
Not the ship.  The Achub.  Ten months of the year the old ship was only a voice, four flat lines each morning down the relay from the deep dark where she lay alongside the Fortress, taking her apart for parts.  Aine had grown up on that voice the way she had grown up on the falls, a sound so constant she had stopped hearing it.
Then, for two months, the voice became a homecoming, and the basin filled.
Not with engine noise the way the Kanienn Vras would sound where distant echoes would ricochet, a shuttle’s drives cracking off the east wall and coming back off the west a beat late.  The whole gorge rang like a struck pipe and you felt the returning echo in your sternum after the shuttle itself had passed.  Children put their hands on the rock to feel it.  The apron at the canyon mouth ran hot oil and scorched plasteel into the green wet air, and that smell, more than the noise, was how the Achub knew the year had turned.
Three shuttles lived down here, the air tractors, slung and worked continously.  The rest stayed up where the ship was and the forges were.  None of which Aine had ever had reason to think about, because her work was a headset and a dead channel and the rock between her and the sky.
It was on one of those homecomings, in her nineteenth year, that her name came down off the ship.
It did not go to the apron, or to the board.  Crew was people, and people were the settlement’s to weigh, so the request went first to the Ward, where the settlement’s business was settled, and Fael read it there, then went to find Bren in the seed stores.
Aine was sent for, and came, and did not know why.
Fael had the slate in her lap.  She was not old, whatever a girl of nineteen might think looking at her.  She was of the founders, and they carried their years a particular way.  The woman in the chair was square and quick and somewhere in her forties.  She read the few lines twice before she looked up.
Bren stood at her shoulder.  Her mother, with a flask in her coat and dirt worked into the creases of her hands, who had walked Aine down from the array that morning naming the new growth along the path as she went.
“Reach wants you on the Currach,” Fael said. “For the refit.  He asked for you by name.”
“Why me?”
“Because he knew your mother, on the Fortress, before any of this.” Fael set the slate down. “And because the array girl who runs the vox is the array girl who runs the vox.  He would rather a known pair of hands than a stranger’s.  It is an opportunity, Aine.  That is all it is, and it is not a small one.”
Bren did not reach for her.  She put her hand on the back of Fael’s chair and looked at her daughter the way she looked at a seedbed, reading forward.
“A ship,” she said, and she was smiling. “You will be good on a ship.  Your father was.”
There was no shadow in it.  There could not be.  The thing that had taken Bren’s husband was the warp, and the warp was a decade and a sealed door behind them, no drives, no Navigators, nothing in this whole still system that could ever fold a ship in half again.  The void was just the cold dark her daughter would work in.  A mother could send a child into that and sleep.
“Go on,” Fael said, gently. “Go and be useful somewhere new.”
That was the whole of the leaving.  The two women in the seed store, and Aine carrying it up the canyon wall lighter than she had come down it.
She had not been off the ground since she was eleven.
The fear met her at the ramp, old and real and slower than she was now.  What she remembered of ships was gravity failing in slow pulses and a list read aloud in a hold.  What the shuttle gave her was a worn jump seat, a harness with the shine rubbed off the buckles, and a pilot running checks aloud in the flat voice of someone confirming quantities.  The fear sat down behind her and went quiet.
She rode up with her face to the port and watched the only home she remembered fall away into a seam of green and shadow eight kilometres long, the waterfalls thinning to white threads, the river to a line of solder at the bottom.  She watched it the whole way into the cloud.  The watching steadied her.  It always had.
The Currach was riding alongside the Earthbreaker when they came up on her, and she was not what Aine had braced for.
The whole Achub had carried the damage report of Aine’s sixteenth year.  Bridge gone.  Command tower gone.  Port flank opened to the void.  What hung in the viewport was a ship wearing new plate over those wounds, mismatched and clean, plasteel cut off the Fortress and set into a Currach frame, lit ports running her length.  They were building the Currach back out of the ship that had carried Aine’s childhood.  Knowing it from a morning report and seeing it through a viewport were different weights.
She worked eleven days aboard, slept badly and did good work.
The vox spaces had been gutted in the translation and never properly refitted, stripped to the least a dying settlement thought it could spare.  One board.  One antenna run.  She set to rebuilding the watch board, and on the third day, going aft through the hab rows, she came around a frame and stopped.
There was a chair.
It had been carried across from the Fortress and bolted into a corner of the mess with a dozen others, unremarkable, salvage like everything else.  But she knew it.  The worn place on the left arm.  The cracked seam down the back where the padding had gone.  She and her sister had fought over whose turn it was to sit in their father’s lap in that chair, in a hab two decks down on a ship that no longer had two decks, while he read to them in the hour before sleep.
She stood and looked at it for a while.  Then she went back to her board, and that night she wrote more in her log than the work had needed, and nobody marked it.
Reach found her there on the ninth day, the manifest amendment at her elbow.
“Salvage works to a list,” he said. “That is the list.  What are you doing to it?”
“Adding to it.  But that is backward.” She turned the amendment so he could see. “There is no sense stripping the Fortress until we know what this ship actually needs.  Let me audit the Currach first.  Every system, what is here, what is missing, what is failing.  Then we go to the Fortress with a question instead of numbers, and we lift what answers it, and nothing else.”
He read it the way he read everything, all at once.
“You will not know the Fortress,” he said.  Not unkindly.  Not about her at all.  He was looking past her, somewhere back along his own years. “I will.  I stood her bridge watches when she was whole, before the Earthbreaker, before any of this.  There was not a trunk deck on her I could not have walked blind.” He came back to the amendment. “Audit your ship.  Build me your list.  I will draw you what is where on mine, and we will lift exactly what you have proven we need.”
It was the right way round, and she knew it, and she felt something settle that she did not have a name for.
The audit took the rest of the secondment.  When it was done she had a list that was hers, every line of it argued, and the Fortress runs that followed it were the cleanest the salvage had logged.  Then the work was done, and there was no more reason to keep an array hand aboard.
Reach found her at the lock before she went down.
“You did well up here,” he said. “Better than the job asked.  When there is vox work again, and there will be, I will come back to you.”
“I would like that,” she said, and found she meant it more than she had expected to. “I would like to do more up here.”
She rode the shuttle down with her face to the port again, watching the seam of green come up out of the cloud to meet her.
Her mother, told over the evening meal, made her say twice what she had done up there.  Then she walked the terraces the next morning telling everyone they passed, gardeners and watchers and a Currach woman she barely knew, that her daughter had been to space and fixed a ship and come home.
III: The Giant
Her mother made her say it twice, and then a third time, and was not sorry.
Bren sat across the evening meal with her chin in her hand like a girl at a fireside, and every time Aine slowed she pulled her back with a question.  What did the canyon look like from up there.  Was she afraid on the ramp.  Did the board work when she was done with it, did it really, the first time.  And Aine, who had meant to be modest, found she could not be, the whole of it spilling out of her, the audit and the antenna run and the clean Fortress runs and Reach saying he would call on her again, until she was talking with her hands and laughing at her own pride.
Her mother watched her do it with her eyes gone bright and wet, the particular shine of a woman seeing her child lit up from inside, and once she had to look down at her plate and press her lips together, and when she looked up again she was smiling so hard it must have hurt.
“Listen to you,” she said. “Listen to you.”
In the morning she walked Aine up toward the array the long way, just to hear it again on the path.
It was on that walk that Aine first really saw the lines.
They had been going up for a season while she was aboard the Currach and she had passed under them the way you pass under your own roof.  Her mother stopped her at the foot of the terraces and made her look up.  From the canyon wall a cable ran to the crown of one of the great kept trees, and from that crown to the next, and from the last back down to the far wall, a slack dark thread strung clear across the open air with the morning caught along it.  Below it the walkways were growing roofs, low and shingled, the paths running in and out of shade like stitches.
“Emer’s web,” Bren said, fond and bemused, the way you name a neighbour’s obsession. “More of it every time you look up.”
Aine looked a while.  Then they went on, and she gave the rest of the Fortress to the trees, and her mother laughed in the right places.
The vox hut smelled the way it always had, the faint oxidised tang of warm cogitators, the smell of her own place and her own years, and she barely noticed it, because Voss was in the doorway and she had not finished talking.
He had trained her and lost her to the sky for a season, and he stood with his arms folded and let her run, because she could not stop.  The board she had rebuilt.  The audit, her audit, every line argued.  Reach saying he would call on her again when there was vox work, and her saying yes, she would like that, she would like to do more up there.
Voss listened with the wry, patient half-smile of a man watching something he planted come up taller than the label promised.
“You found the sky,” he said.
“I found the work.”
“Same thing, for some people.” He was still smiling. “I had a feeling you would be one of the ones the sky keeps.”
She worked the board into the dark that night, and walked down the canyon with her mother’s pride still warm on her.
Reach kept his word.  Over the next three years the Currach sent for her more than once, a season of vox work here, a refit there, and each time she came down with more of the ship in her hands.  Bren made her tell all of it, every time, at the evening meal, then walked her up the long way in the morning to hear it again on the path.  The array and the dead channel through the long months, the climb to orbit when the Currach called, the coming home with her voice full of the work: that was the shape of those years.
Emer’s web grew while she was aloft.  More cable every season, more roofed walkway, the open lanes narrowing until a body could cross the basin floor and stand under canopy for all but a stride of it.
Bren was slower than she had been, in the way of a woman who had worked ground her whole life, and no more than that.  She still named the new growth on the path.  She still read forward off a seedbed.
Aine was twenty-two, three mornings down from a season on the Currach, when she climbed to the array with her mother beside her and her head still full of the ship.  They parted where the path forked, and she went on to the vox hut, where Voss stood in the doorway with the night’s log.
The ground hit them through the soles of their boots before the sound came.
A crack, enormous, from the rear of the canyon.  Then a tearing that went on far too long.  Then blows through the stone itself that Aine felt in her shins before her ears caught up.  Voss was out of the doorway already.  Behind her the board said nothing, and that silence was the loudest thing in the room.
She knew before she could have said what.
A canopy giant had stood on the rim above the rear wall since before the settlement, since before the people who built it, its roots in stone seams that eight hundred years of water had been quietly unstitching.  Nobody had touched it.  The rains had been heavy a fortnight.  That morning, the root plate let go.
What came down the rear wall was a tree only at the top.  By the time it reached the terraces it was the weight of one, trunk and root plate and forty metres of crown, into the upper seed gardens and the channels and the people minding them.
Bren had gone up to the terraces while Aine talked to Voss.
They dug for two hours in the wreck of mud and timber.  Aine dug barehanded and the smell went up under her nails and stayed there for days, wet black soil and torn root and sap and, threaded through it, blood, a reek she would meet again every time she broke ground for the rest of her life.  Her hands were full the whole time, so for once she did not count.  Somebody else kept the tally, and read it later, and it was long.
They brought her mother out from the very edge of the fall, where the crown had brushed the third terrace on its way to rest.  Brushed.  The Achub used the word for months, as though the smallness of it were a mercy owed to someone.
Bren was breathing.  Her left side was wrong from shoulder to hip.  But it was her eyes Aine could not get past, when they laid her on the litter: open, moving, and not arriving anywhere.  Looking at Aine and not finding her.  A vast slow confusion in them, and under it the pain only just beginning its long walk up to where she could feel it, so that for a moment her mother lay there hurt past saying and did not yet know it, and that was the image Aine kept, over all the others.
The medicae worked through the night while Aine stood against the rock under the awning, out of the way, waiting on the far side of a silence.
Her mother lived.
The Achub said it that way for a while, and then said it less, and then stopped, because the word had begun to need qualifying.  Bren came back in the spring, slower on her left side, and worked what was left of her terraces, and from any distance she was herself. Close to, the edges showed.  The long pauses inside a sentence, hunting a word she had owned for sixty years.  The ledger she read now instead of wrote.  The way she would stop in a row with a plant in her hand and study it like a letter from someone she could not place.
The woman who had walked the terraces that morning, bright-eyed, did not come back from the third terrace.  What came back was kind, and far away, and courteous to her daughter as to a stranger, and the courtesy was the worst of it.
Aine was twenty-two.  She sat with her mother in the seed store in the evenings and learned the exact distance her mother could now reach, and sat just inside it, and was grateful, and said nothing.
Farren was among the dead the giant took, the founding medic who had held the settlement’s health since the first landing.  The Achub grieved her cleanly, a name read at the lander and a place kept.  A medic was a hard loss, and the settlement had a name to read for it.  Aine’s was harder, and had no name to read.  Her mother had lived, and come back most of the way gone, and kept just enough of herself to make the distance unbearable.  For that there was no list, and no reading, and no place kept.
It was Fael who pulled her out.
Not gently, which Aine could not have borne.  The kindest heart in the settlement, the woman the whole Achub already leaned on without naming why, came and found her in the seed store and put her to work.
“You have been to the Fortress and back inside a year,” Fael said. “You know what is up there better than anyone breathing.  The Ward has a hard call coming, and it should make it knowing what you know.  Come and tell them.”
It was a kindness dressed as a duty, and Aine saw exactly what it was, the settlement’s mother reaching into the seed store and lifting her out by the one handle that would hold, and she was too proud and too grateful to refuse.  She stood before the Ward and told them plainly what the Currach was and what the Fortress had left to give, and found she could, and found the standing of it put something back into her spine that the seed store had been drawing out.
And because she was in the room, she was in the room for the rest of it.
The matter before the Ward was the giants.  Bren’s fall had not been bad luck, or not only.  There were canopy giants standing all along the rim, their roots in the same unstitching seams, and any one of them could come down the way that one had, into the terraces, the channels, the people.  The question was what to do about a forest that might at any moment drop a hundred tonnes of itself onto the settlement’s heart.
The Ward talked for half an hour and arrived nowhere, because every answer cost more than the settlement had.  The giants near the edge had to come down.  But felling them meant crews working the rim, the open plateau, where the forest belonged to the Morgath, and a felling crew bent over a saw is the most killable arrangement a human body takes.
Emer Kavane sat where she always sat, near the wall, and let them finish.  Then she asked her questions.  Aine counted them.  There were three.
How many of the rim giants stand above roofs, terraces, or the water we drink.
The survey answered: about two hundred and seventy-eight, of the many thousands along the edge.
How many seasons of timber are those two hundred and seventy-eight, set against what we keep below.
The price board worked it half aloud and came to something north of ten years, and the chamber went quiet in a new way, because the question had turned a danger into a harvest, and everyone felt the ground move under the argument.
And if we leave them standing, who is under them when the next one falls.
Nobody answered.  It had not been asked to be answered.
She did not raise her voice once.  She laid down what she had seen and let the seeing do the work, and the Ward came to yes the way you come to a yes you wish you could refuse, because the yes had a number on it and the number was paid in people.  The rim crews would work under the Morgath before the clearing was wide enough to protect them.  Some would go up and not come down.  That was the price of not losing the settlement’s heart to a falling giant, and Emer had shown them, without once arguing, that it was the lower price.
The rim was Morgath ground, and Emer treated it as such from the first day.  She walked the cleared edge with the foremen and five armed Watchers.  She showed them the tracks, the wide splayed prints pressed into the soft ground at the treeline, the places where the forest came down to drink.  She set the watch on those places and would not let a crew work a stretch that had not been watched first.  The Morgath came, the way she had said they would, drawn by the noise and the open ground and the smell of labouring men.  Two were killed in the first six weeks, out past the saws, before they reached anyone.  That nobody on the cutting line died in those weeks was not luck.  It was a small grey woman reading prints in mud and deciding where the watch would stand.
Aine sat at the edge of it and felt the cost of survival settle over the room like cold air off the rim.  You did not get to refuse the price on this world.  You only chose which unbearable thing you bought with it.
When it came to how the rim crews would speak to the canyon below, she put up her hand.  She would set the vox.  A repeater on the rim, the crews tied back to the canyon, a warning carried down in the half-second between a crew that scattered in time and one that did not.  It was a small thing beside what the cutters and the watch were being asked to do.  But it was hers to give, and it took her up onto the rim where the cost was, and out of the seed store where the courtesy was, and she was not sorry for either.
IV: The One Who Hears
The seed store smelled of dry paper and timber and husks, a sharp light dustiness with earth and dried leaf under it.  Aine sat on the bench just inside the distance her mother could still reach, and watched Bren sort seed by feel into the labelled drawers, not quite looking at her, and that was the evening Fael came to take her away from it.
Fael did not knock.  She lowered herself onto the bench as though the room were half hers.
“Reach wants you back.  Not for a refit.  For good, a place on the Currach, crew.  He came to me direct.” She watched Bren’s hands move among the drawers. “I told him I would put it to you.”
“I cannot leave her.”
“You can.  That is the trouble with it.” She said it without softening, the only one in the Achub who would. “You keep a watch here every evening that nobody asked for, over a woman who does not know you are keeping it.  It is good of you.  It is hollowing you out.  Go and do the work you were made for.”
“And Mum.”
“I will keep an eye on Bren.  I have known her since the day you both came off the ships, you a sick child on the ramp.” Her voice did not waver. “She will not be alone.  You have my word, and you know what that is worth.”
It was the word that moved her, not the work.
She climbed the canyon wall the next morning with her bag on her shoulder and her face wet, and caught herself, halfway up, smiling.  She stopped on the path ashamed of it.  Then she went on climbing, and the shame did not put the smile out, and she let both of them ride up with her, because there was no holding either one down.
She took the comms role on the Currach, and she stayed, and the years aboard folded into one another the way good years do.
She rose.  Vox specialist, then comms officer, then the whole working sense of the ship in her keeping, operations officer, comms only a part of it.  The old hands stopped remarking on her.  A decade went by in rotations, the Achub a green coin she came home to and left again, and the array girl became an officer who heard the shape of a signal before the words arrived.
And when she came home on the rotations, she found she looked forward to a night or two at the Kavane table, more than she let herself examine.  There was a warmth there that asked nothing of her, a loud crowded family supper with Emer at the head of it and the girls grown, arguing and with partners of their own.  Aine sat in it gratefully and did not think, while she sat, about the quiet seed store and the courteous stranger who was all she had left of her own.
As she rose through the ranks, one thing she never changed.  Wherever she was, she kept the emergency band open under everything else, the way she had kept it open at the array at sixteen.  Ten years it gave her nothing.  She kept it open the way some people keep a light burning in a window, not for a reason they could name.
So it was her ears it reached, the morning the dead band spoke.
A voice in it.  Thin, stretched, wrong with distance, asking in worn Low Gothic whether anyone received.
Her hands went to the board before the rest of her arrived, steadying the gain, marking the time, keying the old answer the basin had drilled for thirty years and never spoken once.  And under her sternum a girl at a surface array, sixteen years old, stood up out of seven thousand silent mornings and listened.
Two ships in her life had spoken out of the silence.
Both had come up under her hand.
V: The Shaft
The Currach had gone out to the dead band, the way the Earthbreaker had once gone out for her, and brought back what the dark had left of the Torvaine: half a hull, a few hundred living, and the officer who had held them after the captain died at his station.  The salvage of the broken ship would wait, off in the dark, until her people were down.
Rozenn Trevelyan had not seen a living world in half a year, and it showed in how she held herself at the viewport.
Aine rode the jump seat behind her, escort on a courtesy flight, while the Currach shuttle came down the long fall toward the cloud.  The XO stood with one hand on the frame and said nothing.  Behind her two of her officers had given up pretending to check their straps.  Half a year ago they had left Terra whole.  A month ago they had been one ship, and then half of one, fighting the dark for air.  Now the cloud broke under the shuttle and Verdantia came up to meet them, green to the curve of the world, water threading silver off the high plateau, and the XO made a sound that was not a word.
Aine knew the sound.  She watched the back of her neck and the set of her officers’ shoulders, people looking down at the first living ground under them in half a year, and she did not look away and she did not speak, because there are things you cannot say to a stranger without trespassing.
“Take the long line in,” she told the pilot. “Over the second basin.  Give them a good look.”
The pilot brought the shuttle out over the unbroken forest east of the Achub, and the Torvaine officers leaned to the ports, and Aine looked with them, half seeing it through their eyes.
Which was why she caught the mist.
It was wrong.  Mist came off the canopy after rain in flat sheets the wind tore apart.  This stood up.  A single slow column of it, turning on itself, rising out of one point in the forest where there was no water and no clearing to feed it.  Half a lifetime of reading signals for the one return that did not match the rest, and her eye went to it before her mind found the reason.
“Come left a touch,” she said. “Hold this line.”
The column kept its place as they came round it, rising and rising out of the green, out of nothing.
She carried it to Fael that evening, and Fael, who trusted Aine’s eye, sent surveyors into the forest to find what was breathing under it.  Aine was not among them.  She had a ship to get back to.
What they found she heard in pieces, on the rotations.  A hole under the world.  A shaft, and under it a dark the sounding lines paid out into and did not catch.  A space a kilometre deep, levels under levels, side caverns off side caverns.  At the peak of the day, the piercing shaft of daylight would fall through the high opening to caress a floor of black stone polished smooth as standing water.  People twenty years on Verdantia went down and came up changed, saying it was landfall again.  The old hollow back under the breastbone, the Falamh worn away to nothing pressing up fresh out of the stone.
Fael went down, and came up wanting it.
A road under the world, she told the Ward, a way between the basins the sky could not reach and the Mordrai could not read.  Widen the passages, make them safe, move in what the settlement could not afford to lose.  They gave it to her, because she was rarely wrong and never loud.
The trouble in it was Aine’s.  You could not speak to the place.  It lay too deep under too much stone for any signal the settlement owned, and a heart you cannot speak to is no heart.  So Fael asked Reach for her, and Aine came down for a rotation to wire the deepest room on Verdantia into the light.
She did not work it alone.  Nuala worked it with her, Emer’s younger girl grown into the settlement’s vox officer, holding the surface array Aine had left a lifetime ago.  There was a strange grace in it, the two of them threading a signal down through the dark, the woman who had left the array and the woman who had taken it.  Aine showed her the cavern from an operations officer’s eye, the whole shape of it, what a system this deep had to survive.  Nuala learned fast.  She had her mother’s way of going quiet and getting it right.
They ran hard line in from the Achub and seated repeaters up the shaft until every chamber could speak to the surface.  They cabled through to the Bevan for the second array, the redundancy Aine would not do without, and set the parts on order from Keir’s forges. But they could not raise it.  The Bevan was still forest, unsurveyed, uncleared, Morgath country, and you do not build in Morgath country until the trees are down and the ground is held.  So the Bevan array waited, begun by Aine, a promise cabled into the dark and left for a safer year for Nuala to finish.
The Achub side was good work, and nearly done.
She was five weeks from the end of her planetside rotation when the lander came down.
She did not see it.  She was eight hundred metres under the world with a splice in her hands when the lines carried it to her.  Every surface station keying at once, the wrongness of many voices on a channel she had built for few.  A footing thirty years buried gave under the weight it had held since First Landing, and the lander that had straddled the Achub stream came down across it.
They had gathered under it for a naming.
The names came down the line clean and level, exactly as she had built it to carry them.
Fael.
Aine heard it and did not understand it.  She asked the station to say again, and it said again, and she still did not understand it, because the word did not fit anything.  Fael was not a name that went on that kind of list.  Fael was the fixed point.  Fael was the one who was always there.  Fael had sat in the seed stores and given her word and let her go to a ship.  The splice was still in Aine’s hands.  She looked at it.  She could not remember what it was for.
Then it reached her all at once, the way the dark reaches you when a lamp fails, total and from every side.  She was on her knees on the cavern floor eight hundred metres under the world with her hands over her mouth and a sound coming out of her she had never made before and could not stop.  The black stone took it all and gave nothing back.  Nuala was there, somewhere, saying her name.  Aine did not hear it.  There was no room in her for anything but the one word that would not fit, and the tearing it did going in.
She did not think of her mother.  That was the thing she carried afterward, the shame of it folded into the grief.  In the worst minutes of it there was no Bren in her mind at all.  There was only Fael, and the size of the hole where Fael had been, and herself on the floor of the world coming apart.
It was later, climbing up out of the shaft into a daylight that had no business still being there, that she thought of Bren.  And the thought was not grief.  It was need.  She wanted her mother.  She wanted to put her arms around the broken woman in the seed store and be held badly and completely by her, and grieve Fael with the one other person who had loved her.  She went looking for Bren with that need driving her up the path faster than her legs wanted to go.
Bren was gone.
She had heard, the way the whole Achub heard.  She had set down whatever was in her hands and walked out through the wall toward the trees, and nobody stopped her, because nobody ever stopped Bren walking.
Standing in the empty seed store with the drawers half sorted, Aine understood what she had been too torn to see.  Fael had been the thread.  Fael was the last of the old warmth that still reached Bren, the one who called her by the woman she had been.  Cut that thread, and there was nothing holding the rest.  The lander had not killed one of Aine’s mothers.  It had killed both, the second by taking the first.
They left a lamp at the gate.  They watched from the wall.  No one would follow a woman who had chosen the Morgath at dark, and no one knew which way she had gone.  She did not come back, and the forest gives back neither a body nor a certainty.
Aine stood at the wall in the grey mornings after, and looked at the treeline, and kept her face still, because she had nothing left to do with it.
She had come down to lay a cable.
The cable worked.
VI: The Stillward
They held the first Ward in the new chamber because there was nowhere else left that the whole settlement could agree to grieve in.
The lander’s lee was rubble.  The old chamber in the Achub wall was too small for what had to gather.  So they went in through the Achub tunnel, the first time the Ward had ever met underground, into the great black space Aine had spent four months wiring.  The settlement’s leaders sat in a ring on the polished stone with the blade of noon light falling eight hundred metres through the dark to lie across the floor between them.
Aine sat among them because she was the Currach’s operations officer and because the chamber they were sitting in had been put right by her own hand.  She would have given both those things and her own to be anywhere else.  They had buried Fael that morning.  They had read the mother’s name, and the baby’s, four days old and named twice now, once at the lander and once over the ground.  There was no name to read for Bren.  Aine had stood through all of it with her face still, and now she sat on the cold stone among the living and listened to the world decide what came next, and felt very far from it.
It was Reach who said it, settling onto the stone with an old man’s care, looking up into the dark where the light lost itself.
“Quiet down here,” he said. “Quieter than quiet.  Like the first day.”
Nobody answered for a moment.  Everyone had felt it coming down, the Falamh pressing up out of the stone, the world emptier here than anywhere on its surface.  Old Verdantians and new, they had all gone still on the way in.
“The still ward,” one of the elders said, half to herself, looking around the ring. “We are sitting in the still ward.”
The name was true the moment it was said, and nobody ever unsaid it.  The Stillward.  The settlement’s heart, and it had got its name the way the basins got theirs and the titles got theirs, out of someone speaking a plain fact aloud in a room that recognised it.
They confirmed Arwen Caradoc as Ardrui first, because the settlement could not sit a day without a head, and Arwen had run the stores through a decade of hard years.  The people knew her hands were steady.  She took it the way the role was always taken on this world, with a nod, as a thing that had landed on her rather than a thing she had reached for.  Fael’s chair did not pass to a Brannagh.  The Brannaghs had three children left to carry the blood, and that was as far as the family’s inheritance went.  The leading was the settlement’s, and it went to the woman who had been quietly leading half of it already.
Then Brask spoke, down from the Earthbreaker for the funeral, square and grey and seventy-eight, and she put a thing in front of the Ward that none of them had quite seen whole.
The Currach was a working ship now.  That changed everything in orbit, though nobody on the ground had thought it through.  With the Currach running the system, the Earthbreaker no longer had to be a ship at all.  She could stop holding station as a vessel waiting to be needed and become a place, fixed, permanent, the fabrication brought back as far as it would come, the old hull made into the thing that kept the settlement in metal for a century.  It wanted doing.  It wanted someone to do it.
Emer Kavane asked the questions.
She was there as a courtesy, an elder of standing, not a seated voice, and she asked them the way she asked everything, quietly, without reaching for anything.  Who holds the fleet now, she said.  Not the ships, the fleet, the whole of what flies and what it is for.  Who speaks for it when the Ward sits, when the Ward sits underground in a place no ship can see.  And if the answer is the captain of whichever hull is in orbit this season, then the answer is no one, because no one is steering the whole of it.
The room worked it through, and the working-through arrived where Emer’s questions had already gone.  The fleet needed a voice in the Ward.  A head of the fleet who sat with the settlement’s leaders and answered for everything aloft.  Somebody gave it a name, Ardmorluith, head of the fleet, and the name went looking for the person.  There was only ever one person it could land on, because Brask had been the head of the fleet since the Earthbreaker first sat in orbit over Verdantia.  The title did not make her anything.  It said aloud what she had been from the first.
She would not come down to take it.  She told them so plainly.  She had tried the ground, in the days since the funeral, and the ground would not have her; the Falamh sat on her like a stone she could not put down.  She had spent too long in clean ship-silence to learn to carry it now.  She would sit on the Ward from the Earthbreaker, down Aine’s own lines, a voice in the dark like the one that had spoken off the dead band.  The ship would be her home until it was her grave.
Which left the forges, and the work of making the old ship a station, and that wanted a smith.
Keir took it.  He had held the settlement’s machines nearly as long as Brask had held the fleet, and he was the Fortress’s own chief engineer before that.  When Brask said the Earthbreaker needed a someone to run her forges and keep a century in metal, the room turned to Keir before Brask had finished, because everyone already knew.  Ardgobha, somebody said.  Head smith.  Keir nodded the way Arwen had nodded, taking up a thing that was already his, and said he would go up.  Keir would give the settlement’s ground machines to Iorwen Crest, who had earned them twice with a steady hand and the engineering in her bones since the recovery years.
It was almost done when one of the elders, an old woman who had come down on the Anam Talamh and had watched Fael choose this canyon out of the death of the plains, turned in the ring and looked at Emer Kavane, and asked her the question back.
And who holds the defence.
Emer did not answer.
The elder asked it properly, the way Emer had asked hers.  Who has held it, she said.  Not who will.  Who has stood between this settlement and the things that take it, year on year, since the start of our second decade.  Who moved the cutting when the sky came down.  Who marked the trees.  Who walked the rim and read the giants and put the lines up over every path a body has to cross.  We have a head of the fleet and a head of the forge and a head of the settlement, and we have had a head of the defence all that while and never once said her name aloud.
The room was quiet.  Aine watched Emer take it, the small grey woman sitting where she always sat, near the edge, present as a courtesy, and saw her understand that the thing being done to her was the thing she had spent her life doing to problems, the plain fact spoken aloud until the room reorganised around it.
Ardcosantor, the elder said.  Head of defence.  It is only a name for what you already are.
Emer did not take it, because there was nothing to take.  She inclined her head, the way she had once inclined it at a watcher she was moving three paces back from a wall, and the title settled onto her the way the others had settled, the way Fael’s had settled years before it existed, because on this world you did not become the thing.  You did the thing, for long enough, in the dark, and one day a room full of people said your name and the word for it in the same breath, and that was all the ceremony there ever was.
Aine sat in the wired dark and watched her two worlds change hands.
The settlement she had landed in as a child of eleven was gone, buried that morning with the woman who chose its ground.  What sat in the Stillward now was something else, something that had decided, in one afternoon underground, to outlast its founders.  A head of the settlement who came off the stores.  A head of the fleet who would never come down.  A head of the forge going up to build a fabrication engine.  A head of the defence who had never asked for a soul to follow her and was followed by all of them.  The carried-down children, grown grey, taking the world off the shoulders of the ones who had carried them down.
And the two who had stood in that seed store and let her go to a ship were not in the ring.  One was in the ground.  One was in the trees.  And the chamber that held all this deciding, the still heart the settlement would govern itself from for as long as it lasted, was quiet around them in the way that had given it its name, the deep warp-silence pressing up out of the black stone, the Falamh that Aine had felt at eleven on a ramp and felt now on the floor of the world.
She had laid the lines that carried every word of it.
She sat in the silence she had wired, and let the settlement talk, and grieved, and was, for that hour, the only still thing in the Stillward that the stone had not made still.
THE LYS ENYS
I: The Beacon
When she was young, Aine Maevon had thought a bridge was made of voices, and had run to each one as it came.  She was fifty-two now, and she no longer heard the words.  She heard the shape under them: a half-second’s lag out of engineering, a navigator drawing breath before a number, a shuttle report landing three minutes late.  Somewhere in the years the bridge had stopped being a set of stations and become a single body, and she stood the watch the way a physician stands at a bedside, listening to a thing breathe.  She had spent the first half of her life learning to speak for the Currach, and the second half learning to understand her.
Most of the watch were her own, taught at her shoulder.  That was the part she had not seen coming, back when the hearing was hers alone.  Rozenn slept below; the Currach had come down from Reach like a handed-on coat five years ago, and the bridge, lit and quiet, was Aine’s.
“XO.” The comms officer had a hand flat to one cup of his headset, the old gesture, the one she had made ten thousand times. “Emergency beacon.  Bearing two-seven-one, eight degrees below the plain.  A long way out.”
“Source.”
“Automated.” He was already working it, hands ahead of his mouth, the way she had taught the watch to work a contact. “No voice on it.  Only the carrier, repeating.”
The ident came up on the plot, a cold point at the outer rim, fleet-code laid down on Terra before most of them were born.  The comms officer read it, stopped, and looked up, and something crossed his young face she had not seen there before.
“Say it,” she said.
“Helion-Delta-Three.  The Lys Enys.”
The bridge went still, the way a table goes still when someone long gone walks back through the door.  The flagship of the Enys Trading Dynasty, a name the Terra-born had handed down the way you speak of a brother who went to sea and never came back.  Forty-one ships had left Terra.  Five had reached Helion.  And here, forty-seven years on from the first, the sixth had come in at last.
The lift came up in her chest before she had a word for it.  She had felt it at sixteen with her ear to an array, and again at thirty-two, and both times a ship had lived and come home.
“Wake the captain,” she said. “And raise the Lys Enys.”
“I have been hailing since the ident.” He did not stop, which was right. “They are two weeks out.  Five hours for a word, there and back.”
The lift went out of her quietly, the way a room dims when a cloud takes the sun.  A beacon was not a voice.  She would wait five hours to learn whether anyone was left to send one.
“Helm.  Plot the intercept, ninety on the burn.” Ninety was their ceiling; the engineering for a sustained hundred had gone into the warp with the Torvaine. “Get me the captain.”
II: The Crossing
“Still nothing?” Rozenn came back onto the bridge easy and unhurried.  Two weeks on the intercept had worn the excitement down to function, and the Currach had come about twenty kilometres off the great ship’s flank.
“She has power,” Aine said. “It reads strong.  Most of her systems are dark, even so.  The beacon will have triggered on its own, after a major failure.”
They went through the returns together and came to the same plain reading.  The Lys Enys was whole.  Her drives were cold and she was silent, and nothing about her spoke of disaster.  She turned in the slow, stately roll a ship takes on when its guidance has gone dark.  That happened.  A failed automation engine could leave a vessel deaf and blind, unable to lift a hand to a hail.  Perhaps her crew were behind the dead boards, alive and unable to answer.  Perhaps her air had gone when the systems did, and there was no one left to answer at all.  Either way, it was a thing they knew how to do.  Every hail the Currach had sent for a fortnight had gone out as though someone were listening.  None had come back.
There was nothing left to learn from the outside.
“You take it,” Rozenn said. “It is the Lys Enys.  It needs a senior officer who can speak for Verdantia.”
Aine said yes.  There had been no other answer in her from the moment the name came up off the machine, and Rozenn had known it, which was why she had offered it and not ordered it.
So Aine went across, and took nine of her people with her.
The clamps released, and for a moment she was still inside the Currach’s patched ribs, the smell of oil and old plasteel.  Then the hangar parted and the great ship filled the dark ahead of her.
Even at twenty kilometres she could not have covered it with her fist, and even at twenty kilometres it was plainly not a ship.  It was a city.  A floating continent, bright against the far stars.  As the shuttle closed, the detail came up out of the brightness: terraces and gardens, domes of crystal, rivers of light running the length of her flanks, windows upon windows by the kilometre.  Forests stood under glass.  Lakes held the light of false suns.  Towers rose out of parks, and bridges crossed open air.
What tightened in Aine’s chest was not fear, and it was not awe.  It was something older, something close to remembering.  She was looking at proof, the first she had seen in her life, that there had once been hands and years enough to build a thing not only to survive in, but to live in.
A soft tone sounded in the cockpit.  Helion-Delta-Three, approach authority accepted.  Nessa lifted her hands from the controls, and the dead ship guided them down.
Riordan put the access open, and the Lys Enys breathed into the cradle.
Aine had braced for the air of a ship in distress: scorched insulation, the chemical reek of suppressant, the sourness of too many people in too few compartments.  What came out was clean.  Recycled, maintained, the breath of a vessel whose systems had never once failed.  Under it ran a thread of something metallic that settled at the back of the throat and stayed.
The corridor past the hatch was an ordinary corridor.  Grey plasteel, white lumen strips, decking worn smooth by generations of boots, the kind of corridor aboard every ship human hands had ever built.
Someone had been at the walls.
The marks began at the hatch and did not stop.  Eight lines, cut parallel, deep enough to catch a nail, and then eight more across them, and more across those, whole runs of bulkhead thickened into forests of grooves until wherever the eye landed the same eight strokes were waiting under it.
“What do you make of it?” Riordan asked.
Aine touched one.  The edge was sharp, the metal bright where it had been opened.  Recent.  She drew her hand back. “I do not know.”
That troubled her more than the marks.  Ships gathered habits the way people did, and crews left themselves on the walls of the places they lived: a tally, a joke beside a hatch, the small daily insistence that a person had been here and was more than a number on a manifest.  This was none of that.  It carried no message and asked for no reader.  It was not communication.  It was compulsion.
“Split,” she said. “Riordan, take Taran and Gwen, the left passage.  The rest with me.  Stay on the vox.  Find me someone.” She glanced back at the lock, where the shuttle sat warm in the cradle. “Nessa, hold it for us.  Keep it ready.”
The two teams parted, and the silence closed in behind them.
It was not only the absence of voices.  A ship keeps a body of small constant sounds: the engines through the deck, the air plant breathing behind the walls, a hatch always closing somewhere, machinery always turning in the dark.  The Lys Enys had all of it.  What she did not have was people, and the deeper they went the louder that grew.
The first sleeping place was three junctions in.  A blanket folded square against the wall, three empty ration tins stacked beside it, a water bottle set down with care between them, the whole of it made by someone who had meant to come back.  The second was twenty metres on, and the third past that, and by the next crossing Aine had stopped counting somewhere past thirty.
The crew had left their quarters and moved out into the corridors.  Bedding and clothing and the small gear of living ran along the walls, camps grown into every space a body could fit.  One kept family picts propped where the light would hold them.  One held a child’s toys.  One held a stack of books set straight with a care close to ceremony.
Every camp was empty.
“We are seeing the same,” Riordan said on the vox. “Hundreds.”
Aine looked down the corridor, where the camps ran on past the reach of her lamp and past the reach of the next.
Not ten, or twenty, but hundreds.
People crowded together when they were afraid, because company felt safer than a shut door.  Whatever had come to the Lys Enys had come slowly, slowly enough that thousands of souls had given up their rooms and built a second life out here in the open, where they could keep one another in sight.
The first body sat in a mess compartment, against the far wall, hands folded, eyes closed.  A man who might have sat down to rest after a long shift but for the dark stain down the front of him.  The blood had not pooled where he sat.  It had been collected.  Thirty-two bowls stood in a row along the wall, each filled to the same measure as the next, set out by a hand that had taken the time to make them match.
Daveth looked at them. “Why?”
Aine studied the row as though the answer might rise off it if she looked long enough.  It did not.  The bowls stayed bowls.  The man stayed dead.  The question stayed where it was.
They found the writing on the next deck.  It covered every surface that would take it, walls and doors and the housings of the machinery, the same line over and over in a hundred hands, some neat, some shaking, some gouged in with whatever had been at hand.
Has the beacon stopped?
It ran the length of the corridor and around the corner and did not end.  Aine stood at it longer than she meant to.  It offered her the start of a chain she could almost close her hand around: a beacon had begun to sound, the crew had heard it, the hearing had turned to worry, and the worry had turned into all of this.  Past that point the chain went down into the dark.
“Movement.” Taran’s voice cut across the channel, and the rest of the vox went quiet. “Lower maintenance access.”
Aine was already moving. “How many?”
“I cannot tell.” A pause, and something in the pause pulled the muscles tight across her shoulders. “I cannot see them.  I can hear them.”
“What do you hear?”
The answer was a few seconds coming. “Laughing.”
It went with her down the corridors.  Not a scream, which she could have understood.  Laughter, thin and far, carried along the ducting from somewhere ahead, and then gone, and the quiet that took its place was worse.
A voice came out of the dark in front of her, a man’s voice, worn raw, as though he had been speaking for days without rest.
“Has the beacon stopped yet?”
No one answered.  A few moments on it came again, the same words on the same fall, nothing in it changed and nothing waiting for a reply, a recording running in a damaged mechanism because nothing had told it to stop.
Aine came round the corner and saw him.  A crewman under the lumen strips, middle-aged, well-fed, not a mark on him.  For one breath she read him the way she had been trained to read a casualty and found nothing wrong, and the word that rose in her was survivor.  Then he lifted his head.  His eyes came across the corridor and settled on her, and his mouth went up into a smile, and the skin at the corners of it had split and dried and split again.  Old blood marked his chin.
“Has the beacon stopped yet?” he asked her.
Behind him the dark began to move.  They came out of the side passages and the maintenance hatches, a dozen, then a score, then more than she could hold in a glance, and every one of them was whole and fed and sound.  Whatever had taken the Lys Enys had wanted something underneath the body, and had left the body working.
Every face wore the same smile.  Every set of eyes was empty.  Every hand held something with an edge.
The man tilted his head, the way a person does listening for a sound at the edge of hearing.  Then his eyes found Daveth, and the smile widened, and Aine felt the moment turn the way the air turns before weather comes down into a valley.
“Stop,” Aine said.
The word meant nothing to him.  He took another step, and the sharpened plate in his hand dragged screeching along the floor.  It did not trouble him at all.  More came out of the dark behind him, the whole company of a working ship: a mother with a kitchen knife, a boy of fifteen with a length of conduit, an enginarium woman with a wrench gone black with old grease.  All of them whole.  All of them well.  None of them anyone she could speak to.
Beside her, Pell drew a pistol.  A needle pistol, small and civilian, a thing she had not known he carried.  The sight of it in his hand was its own small shock.  He put three needles into the chest of the man in front.
It changed nothing.  The man did not break stride.  Whatever the needles carried would be working in him by now, slow and certain, but he could not feel it and would not live long enough to be troubled by it.  Between this moment and that one there was nothing in him for pain or fear to take hold of.  He came on, and the rest came with him, from walking to running with nothing in between, and they came in silence.  A charge should have a voice.  This one had none, and the silence of it was worse than any sound.  Hundreds of feet on the deck at once, and through them only the scattered voices, pieces of thought falling out of the crowd as it came.
Has the beacon stopped yet.
The light is underneath.
Do not sleep.
Mother said not to sleep.
“Fall back,” Aine shouted, and the corridor came apart into running and bodies meeting bodies.
The first man reached Pell before he could fire again.  Pell struck him across the face with the pistol, hard, and the man went into the wall and slid down it, whether from the blow or from the needles finally telling she could not say and it did not matter.  The gap closed before Pell could set himself.  Hands took him from three sides, more than he could turn to, and bore him down by weight alone.  A small figure came in under the reaching arms, a girl no older than twelve, and put a sharpened spoon into the side of his neck.  Once, and again, and again.  Pell went down without a sound, and the girl kept on after he had stopped.  Aine never learned her name.  The corridor closed over both of them.
“Move.”
They went back the way they had come, the crowd after them at a pace that never closed and never let go, every passage giving up more of them, every hatch another cluster of smiling faces.  The ship was not empty now.  Somewhere in the last hour it had filled, and she understood it had been full the whole time.
Daveth’s lamp swung across an open compartment as he caught his footing.  Fifty people sat inside it, all facing the same wall, all carving the eight lines into the plasteel over the lines already there.  Not one looked up as the fighting went past the door.  The sound of their cutting followed her down the corridor, a thousand small scrapings at once, like insects working in a wall.
Daveth looked back.  One breath of attention turned the wrong way.  A man came out of a maintenance hatch above him and dropped onto his shoulders, and the weight put him on the deck.  Aine turned, and the crowd was already closing over him.  She saw his face once through the press, the face of a nineteen-year-old who did not understand what was happening to him.  Then there were hands across it, and the corridor carried her on.
She did not see him again.
The cradle was close now.  Where the passages met, short of the lock, the left-hand team came in to join them, or what was left of it.  Riordan was on his feet, but not by much.  A shard of metal stood out of his thigh where one of them had put it, and the leg was going under him by the step.  Taran had an arm beneath him.  Gwen came behind them both, walking backward, her eyes on the dark they had come out of.
There was a blast hatch at the join, heavy, on a manual track.  Gwen put her shoulder to it and began to walk it across the passage, to buy the lock the seconds it would need.
Riordan’s leg gave out.  He came down hard, and the crowd surged at the sight of him down.
Taran could not hold him up and reach the shuttle both.  For a fraction of a second Aine measured the distance to the lock against the distance back to Riordan.  Her mind did the arithmetic without asking her, and gave its answer just as fast.
She turned back.
A woman reached her first and drove the sharpened edge of a deck plate through her shoulder.  The pain went down her arm like a current, and she had no room to attend to it.  She put the heel of her hand into the woman’s face, got past her, took Riordan by the harness, and hauled him up. “Move.”
Behind them Gwen had the hatch almost across.  She did not finish it.  The dark she was holding back came around the edge of it and over her, and the hatch stood half-shut and unmanned, and that was the last of Gwen.  Aine did not see it.  She had Riordan’s weight on her and the lock ahead, and then the cradle had them.
Taran was at the shuttle hatch, no weapon in his hands, only the edge of the door, hauling it to as they came through.  Aine went down inside with Riordan and stayed down, her shoulder gone to a distant heat, the deck tilting under her until she understood she was on her knees.
“Nessa,” she said, toward the cockpit.
No answer came.
She got herself up.  The shuttle was not as they had left it.  The forward seat had been wrenched half out of its mount.  A panel hung torn from the wall by its wiring.  Nessa lay across the deck on her side, one hand still closed around the grip of a utility knife, and the blade was buried to the haft in the chest of the man against her.  He wore a ship’s uniform.  He was not a big man.  He had come aboard through the hatch she had been holding open for them, and she had fought him, and it had finished them both on the cockpit deck.
Aine knelt by her.  The wound that had killed Nessa had gone in below the jaw and across, and she had gone fast; quick, or quick enough.  Aine made herself read the rest of it the way she read everything.  The open hatch.  The torn panel.  The knife.  The two of them down together.  Every step of it was there to be followed, plain as prints in mud: a man had crossed the cradle and come through the hatch and killed the woman holding it, and she had killed him for it, and there was not one part of the sequence she could not lay out in order.
She understood every step of it.  She did not understand a moment of it.
Not the bowls.  Not the lines.  Not the smiling.  Not a fed and healthy crew who had crossed the dark only to meet the people who came for them like this.  The sequence sat whole in her hands and the meaning had gone out of it entirely, and that was the thing she carried off the Lys Enys that never afterward left her.  Not the fear of dying.  The fear of standing inside a thing she could follow to the last step and still not understand at all.
“Strap in,” Taran said.  He was at the forward board, not flying it, he could not fly it, only finding with his eyes the few things he knew.  The hatch seal.  The pressure cycle.  The release, which the Lys Enys would answer on her own protocols the way she had answered the approach, without a pilot’s hand.  He brought them up in order.  The hatch ground shut.  The pressure came up with a long sigh.  The cradle let them go.
Through the small port Aine could see the lock.  The crew of the Lys Enys had come as far as it and no further.  They stood at its edge and did not cross, hundreds of them now, men and women and children, gathered at the threshold and doing nothing but watching the shuttle go.  Aine searched them even so, for a face that knew its own name, for any sign that someone was still behind the eyes.  She found none.  The smiles held.  The eyes stayed empty.
Then an old woman stepped to the wall beside the lock, a sharpened fragment of plasteel in her hand, and began to carve.  One line.  A second.  A third.  Her hand moved with the ease of long practice.  Others came to join her, one and then another, until dozens were bowed to the steel around the lock, hands moving patiently over walls that had no room left for them.
The shuttle came off the cradle.  The lock shrank to a small bright rectangle against the great dark flank, and even at that distance there was movement around it, small figures bent to the doorway, cutting.
The ship hung against the stars, whole and bright, every lumen burning along her spine.  A sound vessel, by every reading an instrument could take, carrying several thousand living people.
Aine caught herself wishing she had found a graveyard instead.  A graveyard would have been simpler.  A graveyard was a thing she knew how to understand.
The Lys Enys drew back beyond the canopy.  The last of her Aine saw was the docking cradle, a small wound of light on her flank, and around it the figures still bent to the steel, cutting lines that would be there long after the last hand that cut them was dead.
III: The Long Way Home
The shuttle came back into the Currach’s bay carrying three where it had taken ten.
Taran could not fly.  The bay crew had talked him down the last of the way, a voice in his ear until the clamps closed and there was nothing left for him to do wrong.  Aine had ridden it in the second seat with her shoulder bound, no use to the flying and none asked of her.  She kept the cabin from coming apart the only way she could, with her voice, low and even, while another voice brought them in.
She sat a moment in the stilled shuttle and did not move.  The routine of the landing ran on outside her, without her involvement.
Then she opened the shuttle and went out into it.  She got Riordan to the medics and let them see to her shoulder when there was time for it.  She said the two who had come back with her by name, because they were alive, and a living person should hear their own name in a voice that knows it.
They brought one body down out of the shuttle, and only one.  Nessa had fallen where a hand could reach her.  The other six had been lost in the ship, in the corridors and at the lock, and the Lys Enys had not given them back.  That was an ordinary kind of loss, on Verdantia.  The dark took people and kept them, it always had.  What was not ordinary was the one it gave back, the single still shape they carried down past the living, and Aine found she could not look away from it, because it was the only part of the whole accounting that had a shape at all.
Rozenn was down from the bridge already, at the foot of the ramp, her face still and her eyes going over the ones who had returned and over Aine, reading.  Aine made her report standing, in order, complete, in the flat voice the record is made in, and Rozenn heard all of it without once looking away.
When it was done, Rozenn was quiet a moment.  Then she said, “You are certain.  That they were alive.  That the crew were living people.”
“They were living people,” Aine said. “There is nothing wrong with their bodies.  The ship is whole.” She heard how it would sound to anyone who had not stood in the corridor, and made herself say the rest regardless. “What is wrong with them is not in the body.  The warp took the people out and left the rest.”
Rozenn tried to hold that and could not, the way the mind slides off a thing it has no handle for.  Then she did the one thing a good captain can do with a weight too great for one pair of hands.  She set it where more than one pair could carry it. “We take this to the Ward,” she said. “All of it.”
The report went down the long channel ahead of them, because the ship was four weeks out and the world should not wait four weeks to learn what had come across the dark toward it.  Aine made it herself, in the flat voice.  She felt the words go down through the dark to the Stillward and land, and felt the silence that came back.  It was not the silence of a poor signal.  It was the silence of a people receiving knowledge they had nowhere to put.  They knew the warp killed.  They had made their peace with it as a thing that broke ships.  They had not known, until that day, that it could leave the ship whole and reach inside the crew and take the people out and leave the bodies walking.  There was no word on the world for that.  The word would have to be made, and the making of it would take years, and it began in the quiet that came up the channel out of the Achub, a whole people going still at once.
Then there was the crossing home, four weeks of it, Nessa in the cold of the hold and the six who were not, and the three who had carried one of them out moving through a ship that had room for them now.
The Currach made orbit over Verdantia, and a shuttle brought Aine down, and Nessa down, and Emer was waiting at the pad.
She was eighty-three.  She had read the report weeks before, like everyone with the standing to read it, and had counted the days since.  She had not come to be told anything.  She had come because she had been a soldier once, a long time ago and a long way from here, and had sent people into the dark who did not come back.  She knew the particular shape of the walk Aine had ahead of her.  She knew there should be one door at the end of all those doorways that asked nothing.  So she stood at the pad in the cold, the small grey shape of her.  When Aine came down she said only that there was a bed at her place and the fire was lit, and she turned and walked, and Aine went after her.
The house was quieter than Aine remembered it.  Saoirse was off with the medicae.  Nuala had risen beyond the array now, under Iorwen Crest, holding the post on land that Aine had held on the Currach, a woman who had been a sick child on a landing ramp the day they first met.  Whatever small ones the daughters had given Emer were abed.  It had become a grandmother’s house.  Emer put Aine in a bed that had been a daughter’s once, and Aine slept the way the very tired sleep.
In the morning Nuala came with a crawler.  She had her mother’s economy and none of her years; she said only that she would drive, and that she would go where Aine went.  Aine was grateful in a way she could not have put words to.  The woman at the wheel had taken the array Aine left behind when she went to the void.  There was something in being carried by the life she might have lived, and she did not examine it, and did not refuse it.
She would not ride to the ones in the Achub.  Those she walked to, house by house, through the cold and the black stone, with Nuala walking the crawler along beside her at a footpace and saying nothing, because some debts a person pays with the soles of their feet or does not pay at all.  The crawler she kept for the two families out in the Bevan, too far to walk and be any use at the end of it.  And she kept it for Nessa.
The seven went on the list.  That was how Verdantia grieved, and always had, since the first years on the plains when the dark beyond the wall took people and gave nothing back, and there was never a body to stand over, only a name to read.  The list did not need a body.  It had been built, across forty years, for exactly the dead who had none.  Six of the seven would live there now, in the reading of it, and their families had known since the long channel that this was the grief they would be given, and had already begun to make their peace with the shape of it, because the shape was one they knew.
But there was Nessa.
Nessa had come home, and that was the rarest thing the dark ever did, and it undid her family in a way the list never could have.  Aine brought her out to them in the back of Nuala’s crawler, the one still shape against all those names.  A mother and a father came out into the cold and understood, slowly, that they were among the very few on the whole of Verdantia ever asked to put their own child in the ground with their own hands.  They did not thank her.  There was no thanks in it.
The mother laid a hand flat on the crawler’s cold side, where her daughter was, and left it there a long while.  She said at last, not to Aine and not to anyone, that she had not known whether to hope for this or to dread it.  And that now she knew.  And the knowing was worse than either.  Aine had no answer for her.  She had stopped, by then, looking for answers to give people.  She stood with them in the cold until they were ready to take their daughter inside.
It was at Emer’s table that night, by the fire, the lamps down and the small ones asleep, that Aine let go of the rest of it.  She had held her face still through seven doorways, the way you hold a cup that is too full, and at the fire the stillness went out of it.  She did not weep, quite.  It was worse than weeping.  It was the face of a person going back over a thing step by step, looking for the place they could have changed it, and not finding it, and going back again.  She told it badly, out of order.  The clean air.  The eight lines.  The bowls.  The man who smiled.  Nessa, in the cockpit, and the thing she could follow to the last step and still not understand.
“I took them across,” she said, when there was nothing left to set down. “Vox hands.  Enginarium crew.  A boy of nineteen.  Not one of them a fighter, and I knew it, and I took them across anyway, because they were mine and it never once crossed my mind that I was carrying them to it.”
Emer let the fire have the silence a while before she answered.  When she did, there was sympathy in it, but it was not the soft kind.  It had edges, the edges of a woman who had stood where Aine stood, once, on another world.
“You did not carry them to it.  You carried them to a rescue.  What was waiting is not on your account.” She looked at the fire, not at Aine. “I sent people into the dark more than once, a long way from here, when I was a different woman with a different trade, and some of them did not come back.  You learn, doing that, that there is a grief you are allowed and a guilt you are not, and that the second will eat the first if you let it, and leave you no use to anyone.  The dead are owed the grief.  They are not owed your ruin.”
Aine looked at her. “You never told me you had been a soldier.”
“No,” said Emer. “I came here to stop being one.” She was quiet a moment. “I have had five and thirty years to be glad of it, and I am about to spend whatever is left becoming one again, because the warp has finally sent us a thing that needs it.  So you will forgive me if I have no patience left to watch it take you too.” She reached across and laid two fingers on the back of Aine’s hand, briefly, the way she did everything, with economy. “You will teach them what you saw.  You will make them ready in the ways you were not. That is the only thing the seven will ever ask of you, and it is the one thing you can still give them.”
Outside the window the Achub held its dark, and the black stone held the silence they had crossed the warp to reach.  Somewhere far out in it the Lys Enys turned, whole and bright and full of the thing that had no name yet, her thousand hands still cutting.  Emer banked the fire, and the room went to embers, and the two women sat on in the quiet a while longer, the old soldier who had chosen peace and been found by grief regardless, and the younger one who had just learned that the choosing does not always hold.
IV: The Making Ready
The Ward met in the Combroga, on the second level, where a gallery cut into the black stone looked down over the floor of the great cavern.
The cavern had changed in Aine’s years.  When the Torvaine’s people first opened it, it had been a route under the plateau, a way to move between the basins without crossing open ground.  Now it was the heart of the settlement.  The floor below the Combroga was a town held in a single room, a space so vast that the lumen-strings strung across its roof read as a low constellation and the far wall stood at the edge of seeing.  You could have set a cathedral down on that floor and had room left over for the bathing pools that caught the light around its edges.  Off the main cavern the dark opened into more dark, gallery upon chamber upon side-cave, the settlement growing into the stone the way the stone allowed.  Over all of it lay the black stone’s particular silence, the warp-still that the old people still could not abide, and that Aine, who had been a child when she came, still felt the tug of emptiness in this space.
The Ward did not argue.  That was the first thing a stranger would have noticed, and a thing no stranger ever saw, because there were no strangers in the Combroga.  Six seats, and not one of them held by a person who had come to win a point.  They had all read the report and all sat with it.  Reach had lost crew of his own out there, void hands he had trained.  He carried it the way Emer carried Brion and Aine carried the seven, which is to say not where it could be seen, and in everything he said.  When the matter reached the table, the question was never whose the Lys Enys was to answer.  The question was only what the settlement would do about the largest thing that had ever drifted into its reach.
Because that was the other half of it, the half that grief kept trying to push under the table and need kept putting back on top.
A people who had come to this world on the broken backs of five ships, who had built forty years out of salvage and rationing and the slow arithmetic of what could not be replaced, had a derelict the size of a city sitting four weeks out in the dark.  Her holds full.  Her forges cold but sound.  A part of a future they had stopped letting themselves imagine.  Whatever it had cost to reach her, and it had cost seven, to leave her out there was a thing the settlement could not afford, and knew it.  The grief said do not go back.  The arithmetic said you cannot not.  In the Combroga the arithmetic won in the end, because the arithmetic was only survival wearing a colder face.
So the Ward decided to take her.  From that, everything else followed.
Emer set the shape of it, plainly, the way she set everything, because she had been a soldier once and a soldier does not dress a problem up. “Three things went wrong out there,” she said. “We had too few.  We had nothing to fight with.  And no one we sent knew how.  Mend those three and we can take her.  Fail any one of them and we lose another ten and gain nothing.”
So they found the people first.  The Watch was the seed of it, the best of them, the ones Emer had spent thirty years making.  The best of the hunters came as well, men and women who could move quiet and hold their nerve in the dark.  Eighty of them, and then a hundred, against the chance of a long and ugly job.  One in every ten trained to heal, because they had learned at the Lys Enys what a place that deals wounds and no quarter does to people sent in without a medic at their shoulder.
And they would not be scattered this time.  That was the lesson written deepest.  A breach team would force one of the great hangars and put the whole force down together, onto ground they held, because the gentle docking that had welcomed Aine’s shuttle was the very thing that had swallowed her people a corridor at a time.  Pilots for that, every pilot the settlement owned.  The Currach would carry the force and its boats the four weeks out.  But at the wreck the shuttles had to cross the last short gap into a forced hangar and set a hundred armed people down in good order, and that was no small flying.
Then they armed them, which was the harder half, because Verdantia had almost nothing to arm anyone with.  They would not strip the wall.  That lesson too had been paid for in blood, the year the forest came over a thinned stretch and did not wait politely while the defences were away.  So they gathered from everywhere else.  The settlement’s few security weapons.  The personal pieces folk had carried down from the ships and kept oiled in drawers for forty years, a mismatched armoury of anything that could put a body down at a distance.  Emer broke the people into fire groups around the guns they had, so that the few covered the many.
The rest came off Keir’s anvils on the Earthbreaker.  Shields.  Armoured crawlers to push down the broad ways and break a charge. Spears, short swords, battle axes, the close work, for when the long reach was gone and the corridor came apart.  For three years the forge that had been raised to make the settlement’s tools made the settlement’s first weapons of war instead.  The glow of it never went out.  Keir ran it without complaint and without joy.
And the three who had come back taught them why they would use it.  Aine, and Riordan, and Taran, the only living people who had stood in those corridors and walked out.  They handed the knowing over the way you hand down a thing you do not want anyone else to learn as you learned it.  The clean air.  The smiling.  The silence of a charge with no voice in it.  And the last lesson, the hard one, the backward step and the sealed door and the count of who is through, which a person can only be taught by someone who has had to do it.  They taught it, and teaching it they learned it deeper, because all three of them knew they would be in the first shuttle down.
And across the whole of that time, the Currach worked the Lys Enys.  She could not simply sit on her.  Every year she had to run the four weeks back to Verdantia for stores, and the four weeks out again, so the watching came in long spells broken by the journey home.  But spell by spell she held station off the great silent flank, and there was nothing to watch.  Nothing aboard ever changed.  The eight lines were cut and could not be cut deeper, the dead did not move, and the beacon she had no way to reach went on crying its one question into the dark with no one to answer it.  She watched anyway, and reported home, and across those years did the other half of her work, the half that mattered, learning the way in.  How the automated docking might be killed, or a great hangar forced from the outside.  So that when the force came at last, it would not be handed gently into the body of the ship to be taken a corridor at a time.  It would break the door itself, and come in together.  And on the last run out, she carried more than stores.  She carried the shuttles, and the weapons, and the people who would use them.
Out in the dark the Lys Enys turned, whole and bright and patient, asking her question of no one.  And on the world four weeks away, in the black stone, a people who had never made a weapon to use on their own kind made eighty of them, and a hundred, and learned to hold a corridor, and waited for the day they would go back and answer her.
V: The Ghost Ship
They went back to the Lys Enys in the third year.  The Currach carried them out, four weeks of dark she had crossed and re-crossed across the building years, and in her holds this last run rode the shuttles, and the forged weapons, and eighty people who had spent three years learning to use them.  This time they did not knock.
The Currach had found the way in across the watching years.  Not the automated service dock that had taken Aine’s shuttle and fed her people into the ship one corridor at a time, but a hangar, forced from the outside, its great doors worked open across the long spells of station-keeping by people learning a machine they could not ask.  The Currach stood off the breach, and the shuttles dropped from her and crossed the last short gap together, all eight of them, into a single held space.
Aine had taken the hangar mouth for the hangar.
Then the lead shuttle crossed the threshold, and the space beyond swallowed the opening whole.  The walls fell away on either side.  The roof climbed into a distance she could not read, and the eight shuttles were all at once absurdly small, a handful of grey insects set down in a hall built for something else.
It was not packed with cargo or machinery, the way every working space Aine had ever stood in was packed.  It was empty.  Not abandoned-empty.  Empty on purpose.  Garden terraces ran along its flanks, gone wild and grey now but unmistakable.  Water lay in long still channels that had once caught the light.  Whole reaches of polished floor stretched away under the shuttles’ lamps serving no purpose she could name, going nowhere, holding nothing.
Six vessels rested far apart on separate terraces, each ringed by enough bare floor to lay out a Verdantian street.  The nearest was farther off than she first took it for, its size folded into the size of the hall.  Their hulls held a faint crystal sheen, silver-grey at a glance and then not, threaded underneath with copper and a pale water-green, like old bronze seen through clear water.  They did not look built.  They looked grown, or carved.  Falcons at rest, folded and waiting, each one worth more than everything Verdantia had carried down from five ships.
And around them, the emptiness.  Back home a roof covered something or it was not raised, a wall held something in or it was not built.  Here the unused air alone could have housed thousands, and no one had ever meant it to house anyone.  That was the thing that told Aine what the Enys had been.  Not the six sculpted hulls, nor the wealth she knew lay sealed in the holds below.  The space they had been rich enough to leave empty.
The ramps came down, and the force came out into all that grandeur dragging Keir’s iron behind them.  The armoured crawlers ground down onto a floor polished for the slippers of a trading dynasty, rudimentary and necessary and, in that hall, very nearly laughable, squat metallic things made to break a charge in a corridor, set loose in a garden.  No one laughed.  But Aine saw the youngest of them look up at the vanished roof, and then down at the crawler at their shoulder, and take the measure of what they had come to take.
Aine waited for the fear.
She knew this ship.  She had stood in it when it was full, and her body knew, ahead of any order, what the next moment held.  The clean dead air.  The first smile out of a doorway.  The first voice climbing into the litany.  The charge that came on with no sound to warn it.  She felt her shoulders set.  She felt the old cold climb the back of her neck and lift the hair there.  She waited, in the place behind the breastbone where she had learned to keep the fear so that it did not show, for the thing to arrive.
Nothing arrived.
The hall held its quiet, and the quiet did not break, and that was worse than any smiling face, because a part of her had crossed four weeks of dark braced for the one and had no idea at all what to do with the other.
They did not take the quiet for safety.  It was a ship six kilometres long, and the only thing worse than an enemy you could see was a ship that size telling you there was none.  So they did what they had drilled, in the order they had drilled it, breath loud in their helms and lamp-beams swinging across the great floor.  The hangar became a beachhead.  Command went up in the lee of the lead shuttle, and the medics laid their station beside each of the others.  A perimeter closed around the landing ground, fire groups facing outward at every dark mouth that fed the hall.  Every shuttle stayed crewed and cold and ready to lift inside a minute.  And not one of them went past the perimeter until the way back to it was held, because the lesson of the first boarding was in all of them now.  You do not let the ship take you a corridor at a time.
Far back in the command shuttle, Emer Kavane sat at the vox with the whole of it laid out before her, and ran the clearing of the Lys Enys the way she had once run lines of soldiers, by the numbers, deck by deck, never more committed than she could pull back.
It took nine days.
Nine days to walk a dead city compartment by compartment, shields up and the long blades ready and the crawlers grinding ahead down the broad ways.  The force lost no one.  There was no one left to lose them to.  Deck by deck, the Lys Enys gave up what had happened in her across three years, and none of it needed a blade.
The Lys Enys company had not stopped when Aine’s shuttle pulled away, that three years ago.  They had gone on.  With the boarders gone, there had been no one left to turn the sharpened steel on but each other.  So they had turned it on each other.  Slowly, for as long as there were two of them left standing to do it, the way the beacon had gone on and the ship had gone on turning.  A thing set running that had forgotten how to stop.  The camps stood empty.  A wall of scored marks ran to eight and stopped partway into the ninth, where the hand that cut it had simply ended.  The long forged blades Keir had made for holding these people at arm’s length rode the whole nine days on their bearers’ shoulders, unblooded.  The thing they were made to hold had finished itself, with no help from Verdantia.
The last had gone out a lock.  Aine found the place on a low deck, an outer hatch with its inner door standing open, its cycle run, its outer seal still parted a hand’s width onto the black.  Someone had been the last living soul aboard the Lys Enys.  Someone had stood in the silence after the final cutting stopped, alone in a dead city with the stores full and the air clean.  And had walked down to the lock, and opened it, and stepped out into the dark that had unmade them all.  Rather than stay one more hour with what the ship had become.  Aine stood at the parted seal a long while.  Of everything the Lys Enys had shown her, across two boardings and three years, that was the single thing in it she understood.
They found their own, too, where they had fallen in the first hour three years gone.  The ship had kept them, after its fashion, which was not a kind one.  The maddened had not left them as they lay.  Gwen had been part eaten.  One of the others had no eyes.  Aine had them brought up herself, and let no one else do the wrapping, and laid them in a shuttle to go home.  Somewhere on the world below, six families who had been given only a name to hold would now be handed a thing to bury, and she did not know, looking at what she was sending them, whether that was a mercy or a cruelty.  She had learned, at a doorstep, from a mother’s hand flat on a crawler, that it could be both.  She was less sure than ever which this was.
And then, because it was the thing they had crossed the dark to do, they counted what the ship was.
The ship was whole.
The madness had scored the walls of the places the crew had lived, and broken the fittings, and turned the salvage on its own people, and all of that went into the count.  None of it had reached the holds.  None of it had touched the deep pattern-stores Keir’s forges had been starving for since the Torvaine carried hers into the warp.  The Lys Enys had crossed the worst of creation with the wealth of a trading dynasty in her belly and a part of a colony’s future sealed below.  The warp had taken every soul aboard and left the cargo untouched, waiting in the dark for someone to come and claim it.
Aine stood at last on a bridge built for a city and laid her hand flat on the cold of a dead console, the way she had laid it on a hundred dead boards in the salvage years.  A whole ship.  A gift the size of a grief, bought with seven names she had carried to seven doors, and a boy of nineteen, and a girl whose name she never learned, and the strip of dark at a lower lock that a last soul had chosen over the quiet.  Hers now, by the order of the Ward and the count of who was senior, to bring home.  Under her hand the metal was cold, and somewhere far beneath it the ship waited, the way a thing waits that has not yet been told it can stop.
VI: Home
Three months later the bridge of the Lys Enys was lit, and warm, and full of the small sounds of people at work.
It had taken that long, not to mend her, but to learn her.  She had come through whole, her systems sound under three years of cold, and the Torvaine technicians at her consoles now were not rebuilding anything.  They were reading her.  The careful, unhurried people the Ledger had brought, the ones who could meet a system they had never seen and come to know it by listening, sat with their slates and ran her through her checks.  Then ran the checks again, against each other.  They would learn every path through her before they trusted one.  You did not simply start a ship like this.  You came to understand her, wholly, and only then began.
Emer stood at the rail beside Aine and watched them work and said little.  She was eighty-six.  She did not climb to bridges often any more.  She had climbed to this one.
The Lys Enys did not give herself up quickly.  She was a Terran-built city, made by people who never expected to have to know how she worked, and so every system ran three layers deep where a colony hull ran one.  The Torvaine took it patiently.  They were not in a hurry.  The ship was not going anywhere they did not take her.
And the inventory came in, and the inventory remade what Verdantia believed about its own future.
It was read to the Ward over the long vox each week, and each week’s list was a year of plenty on its own.  Cutters in their cradles, swift craft the size of a house, the larger cousins of the sculpted boats in the yacht hall.  Heavy landers built to set great weights down on a world.  Seed held in cold sleep, not the crop-seed a farmer sows but the deep stock beneath it, the seed that makes seed.  Conservatory gardens far down in the hull where, tended all those years by the automation engines of the ship and no one else, living fruit trees had gone on quietly fruiting in the dark, over the madness and the dying.  Pens of breeding livestock, a rich house’s prize stock, kept for a table that would never be set again.  Weapons.  And better than weapons.
Patterns.
That was the thing beneath all the rest, the thing that made Aine go still when she understood it.  The Enys had not packed a world’s worth of goods.  They had packed the means to make a world’s worth of goods, and make them again, and again.  Everything in the holds, the ship also carried the pattern for.  The cutters and the shuttles.  The weapons.  The tools, and the tools that made the tools.  A people who had spent forty years carefully mending the same dwindling stock, making nothing new because they had lost the knowing of how, had been handed the knowing back.
Most of it they could not use.  Not yet.  The patterns called for forges Verdantia would not raise for lifetimes, foundries and engines and a depth of industry the settlement could barely picture.  The making-knowledge had come home to a people who could not yet make.
But not all of it lay beyond them.  Here and there through the lists was a pattern plain enough, a thing within reach of Keir’s anvils as they already stood, and those few Keir would have.  The rest the settlement would keep, and grow toward, for as long as it took.  The future was still mostly years away.  But for the first time in forty years it had a floor under it.
There were vaults they had not opened.
Deep in the ship, behind doors the technicians could have reached in an afternoon, lay what the manifests named the dynasty’s own.  The Enys treasure, the heirlooms and the art and the jewels, the gathered wealth of a great house.  No one had opened them.  No one much wanted to.  It was not respect.  Verdantia owed the Lys Enys dead nothing, and grieved them not at all.  It was simpler than that.  On a world that counted its wealth in seed and steel and clean water, a vault of gold was a vault of soft yellow metal too weak to make a tool from.  The dynasty had treasured these things above almost everything they owned.  They were the one cargo aboard that Verdantia had no use for at all.  So the doors stayed shut, and the treasure stayed in the dark, and the people who had crossed the void to take this ship walked past a fortune every day and did not give it a thought.
On the bridge, a vox-channel opened with a click, and a voice came up from far down in the ship, the enginarium after three months of cold work.
Void engines answering.  Drives at function.  Holding stable.
A moment later, the same voice, lower.  Shield up.
The bridge operations technician turned from her console and gave Aine the words plainly, the way the ship gave everything plainly. “She runs, executive officer.  Engines online, shield holding.  She will carry us home.”
Emer did not look away from the rail.  For a while she said nothing at all, and Aine let her have the silence, because she had learned at a table by a fire that Emer’s silences were where the deciding happened.
Then the old soldier straightened.
“Then it is time,” she said, “to take the bounty home.”
Aine crossed to the command station.  She did not touch the controls.  She had never flown anything in her life and never would, and there were pilots at the helm who had given three years to be ready for this hour.  What she did was the thing that had always been hers to do, since the night a beacon first came up out of the dark and she was the one who heard it.
She opened a channel to the Currach, and she spoke.
“Currach, Lys Enys.  Rozenn.” A pause, the old distance between two ships hanging in it. “We are whole, we are ready, and we are bringing the future home.  Request permission to follow you in.”
The answer took the time it took, four weeks of cost folded into a few cold seconds of waiting.  Then Rozenn’s voice came back across the gap, steady, and gave it.
The two ships came around together onto the long heading home.  The little scarred frigate that had heard a cry in the dark and gone to answer it, and behind her, vast and lit and living, the city she had called up out of the silence, following her in on the voice of the woman who had heard it first.
Far ahead, four weeks off, the small world that had taken them all in turned in the dark, and waited.
THE ENUMERATOR
Being the personal history of Jasper Lucidorientem, Senior Enumerator of the Helion System, Novice of the Verdantian Writers’ Guild, set down in his retirement, covering the years 891 to c. 940
I: The Descent
VOYAGE BULLETIN 7 Passenger Information Update Martoros Route – Final Translation
Pursuant to guidance issued by Navigator Primus Halix, all passengers are advised that recent translations into the Helion System have demonstrated elevated inertial instability during re-entry to realspace.
Passengers are reminded that all restraints are to remain secured until advised otherwise by shipboard announcement. Movement throughout passenger compartments during translation is prohibited.
Medical personnel have been positioned in accordance with standard voyage protocols.
Compliance is mandatory.
Administratum, 891.M30
I read the bulletin and dismissed it.
It differed little from a hundred similar notices I had received across my career. Every established route accumulates its peculiarities. Some emerge from the warp with their clocks inexplicably out of agreement. Others leave men nauseous for hours after translation. A few acquire reputations for violence that outlive the Navigators responsible. The Martoros Route, it seemed, had developed a temper.
I closed the dataslate, stowed it, and tightened the restraint across my chest. Around me the passenger compartment settled into the familiar ritual of translation. Conversation dwindled. The woman opposite closed the cover of her devotional, a genre the Imperial Truth assures me does not exist, and which I have found aboard every vessel I have ever travelled on. An elderly clerk folded his spectacles into an inside pocket with the care of a man who owned one pair. Somewhere behind me a voice ran through the Litany of Safe Passage at the speed of long habit. The lighting dimmed, and no announcement followed, because none was required. Everyone aboard knew what came next.
I looked down at the book open in my lap. I never reached the bottom of the page.
For an instant the universe ceased to agree on where down was. My inner ear said falling. My eyes said seated. My body believed both, and then reality returned with violence. The restraint bit into my ribs as the compartment threw itself sideways. Tables tore free of their deck locks. An overhead locker burst and the devotional woman vanished under a rain of splintered plastek. The lights cycled through white and amber and red and darkness while the hull groaned somewhere beyond the walls, deck after deck being forced to remember where it belonged. A junction box twenty metres forward burst in blue-white sparks, took flame for half a heartbeat, and drowned under the suppressant mist before my mind had finished accepting the fire was real. The ship convulsed once more, harder, and luggage struck the ceiling, and the lights went out entirely.
Then everything stopped.
The ventilation still breathed. Cooling metal ticked overhead. A child was crying, and beyond the compartment door came the sound of running boots, and I discovered I was gripping the restraint hard enough to hurt. I waited for the next blow. It never came. The violence had lasted perhaps twenty seconds, which had been long enough to convince me the vessel was dying, and the vessel had not so much as changed course.
Three days later we came across the Verdantian cutter holding station off the Mandeville approaches with the patience of a lighthouse, one of the rotation that keeps that watch, and there our Navigators disembarked. All of them, Primus Halix at their head, moving with the shortened stride of people leaving a room in which they have said something unforgivable. The crew treated it as ordinary, a thing the route required, the way a river requires a portage. No one offered a reason. No one asked for one. The remaining five weeks were conventional burn, quiet and Navigatorless, the inner system growing slowly ahead of us, and I spent them on my files, because there was never an Imperial record of this system, and a man posted to a place without records brings his own.
Verdantia came to me first through cloud, water, and scale.
The land below the shuttle was not a plain. It was a plateau broken by a wound so vast my eye mistook it for a fault line in the continent. Kanienn Vras cut east to west through the high country, winding inland so that no single view revealed its end. Its walls fell near sheer for the better part of eight hundred metres, dark and wet and banded with vegetation, green where roots had found purchase and black where water had polished the stone bare. My dataslate gave me numbers, and for the first time in my professional life the numbers did not help. Two kilometres and more from wall to wall. Eighteen kilometres inland before the inhabited reaches gave way to forest, and then forest to the horizon. On the canyon floor the Maurach braided itself in silver channels, and between the river and the raised basins lay broad flood-scoured flats that I took from height for pale cloth laid across the stone. Only in descent did they resolve into fields, commons, causeways, and low districts threaded between the annual flood lines.
Waterfalls dropped from the plateau rim in dozens, and more appeared as our angle changed, and more again, until the cliffs seemed to be draining the sky. I attempted a count, out of habit, and abandoned it. Some fell clean for hundreds of metres. Others struck shelves, split into veils, and became mist long before the lower air. The wind carried the spray sideways through the canyon in pale banners, white where the sun found it, smoke under cloud.
And then came Kanienn. The capital of Verdantia had not conquered its canyon. It had learned it.
Habitation occupied the walls, the terraces, the hanging basins, the cut galleries, the cliff roads, the bridgeheads, the aqueduct piers, the stone shelves where a lesser people would have put shrines to the unreachable. The Achub Basin opened off the great canyon like a sheltered wound within the wound, its floor raised above the ordinary floods, its rear wall alive with staged falls. Beyond it the Bevan reaches lay river-threaded and bridged and built over in patient layers, and beyond that the Goleuni took the patchwork of fields, and then the Ffynor, and on. From above, the city refused every expectation my briefing had given me. It had no governor’s citadel squatting at the centre of a rectilinear plan, no prefabricated hab-grid, no shrine-axis imposed on a reluctant landscape. It had no single ground level at all. It rose, descended, folded sideways, vanished into caverns, reappeared across bridges, and climbed again, grown into the canyon’s opportunities the way a root system grows into soil.
Then the shuttle banked, and I saw the Stillward.
At distance I took it for a mountain left standing in the canyon’s heart: an oblong mass of grey stone almost two kilometres along its long axis, veined from base to crown with ribs of black, aligned with the basins, its lower reaches half-hidden by habitation and water vapour and the masonry of the surrounding city. The longer I looked, the less the word mountain survived. Mountains do not hold planes that straight. Mountains do not carry bridges through their own flanks while refusing to look cut. I would learn, in time, what I was seeing: bedrock threaded through with the black stone the Verdantians live among, denser there than almost anywhere else on their world, rising in exposed ribs through terrace after terrace and gallery after gallery. The first generations had not built it, nor carved it, nor mastered it. They had survived beside it, in the caverns of the surrounding rock, and when later centuries cut down from the plateau and inward from the basins, they had found the black stone waiting through the full height of the mass, and they had not removed it. They could not. They had cleared around it, and that distinction was visible from the air: immense volumes of ordinary rock cut away, and the Stillward left standing where canyon and basin and hidden cavern-city met, joined to the plateau by deliberate causeways broad enough to carry water, transit, and rows of buildings.
The surface changed with height. Low, it read as excavation: stone walls ribbed with black, terraces bitten into the rock, water channels cut with the certainty of dam engineering. Midway, habitation thickened, gardens hung from shelves, orchard roofs stepped down the dark faces, and civic galleries opened in long horizontal cuts lit by daylight carried through engineered shafts. Aqueducts came in from the plateau on spans so clean my mind rejected them as bridges and tried to file them as geology. The highest of them entered the mass two-thirds of the way up, and above that line there was no falling water anywhere, no cascade spent for show. The water came in at height and descended by intention, through channels, through the stone itself, out across terraces in shining lines, down through controlled falls to the civic systems and the Maurach. Higher still, the black stone was built rather than exposed. Columns of it ran up the tower faces in straight, dressed verticals, unmistakably constructed, homage paid to the wild seams below. The towers themselves were drawn out of the underlying rock in faceted verticals and severe curves, domes seated in terraces like dark glass under copper-green roofs, causeways passing through and around it all with the lean grace of gravrail rendered in stone. The lines were restrained, exact, almost cold, and softened everywhere by leaves and moving water. Every major terrace carried green. Even the bridge decks carried trees. In the canyon air, with spray drifting through the sun shafts, the whole structure seemed to breathe.
Only then did I grasp the population. What had looked from orbit like one city was a layered urban system: plateau, canyon wall, basin floor, hanging valley, internal cavern, lower river, outer cliff, and the Stillward binding them. The basins were not fields with houses. They were inhabited bodies of the city, streets following water, districts nested under gardens, the canyon floor holding markets and river quays and flood-adapted habs that looked up at walls nearly a kilometre high.
I had been briefed to expect a frontier colony. A compliant one, newly recovered, perhaps proud in the manner of isolated settlements that have forgotten scale. I had expected shortages disguised as tradition, local deviation, improvised authority, a ruling council that would need reminding, firmly, of its place beneath the Imperium. The briefing was not careless. It was correct in every particular the records could hold, and the records held nothing, and beneath my shuttle was a civilisation that had spent twelve centuries solving one problem from every direction it could be approached: how to live in a canyon that flooded, farm without losing the basin, move water without wasting height, build where there was no level ground, survive the sky and the forest and the dark and the stone that resisted human tools, and turn that stone from an obstacle into a centre.
The shuttle descended between two bridge lines, and the Stillward filled the forward glass. At fifty kilometres it had been a mountain. At twenty, an anomaly. At ten, an engineered impossibility. By the time the landing field came into view, I understood the first thing Kanienn had told me without words.
The city was not built to impress the Imperium. It had been built because the Imperium was absent.
And it had endured long enough to forget that absence was meant to be temporary.
II: The Falamh
The air was the first wrong thing, and it was wrong by being right.
I came down the ramp of the lighter prepared for a frontier port. I had served at two. They smell of promethium and hot rockcrete and the particular sourness of atmosphere processors running past their rating, and they sound like grief, because everything in them is being asked to do more than it was made for. I had my coat sealed to the collar and my case in both hands and my expectations filed in good order, and the air of Verdantia came up the ramp to meet me and it smelled of rain on leaves.
Cold. Clean. Water somewhere, moving. Under it a green smell I had no name for then, and have too many names for now.
The field crews worked the lighter’s cradle with hand signs and few words. I noted that. I noted it the way I noted everything in those first days, as an entry waiting for its column. Efficient local practice, I wrote that evening. Low verbal traffic. I had columns for everything, and after five weeks of conventional burn in from the relay I had needed them, the passage in having been the kind that makes a man tidy his files as an alternative to thinking.
So I was standing on the apron with my case in both hands, cataloguing, when the world went quiet in a way that had nothing to do with sound.
I want to be precise about this, because I have read accounts by others who came after me, and they reach for poetry, and the poetry is wrong. Nothing pressed on me. Nothing whispered. It was a subtraction. Somewhere between one breath and the next a thing I had carried my whole life without once perceiving it was gone, and the first I knew of having carried it was the weight of its absence. My thoughts did not stop. They landed heavily, is the only way I can set it down. Each one arrived and sat, like a bird in still air, before it would move on.
My inner ear voted for the deck of a ship. My stomach seconded the motion. I put my case down and set my hand flat on a cargo crate, and I stood there, a clerk of the Administratum of Terra, thirty-one years old, holding on to a crate of agricultural spares with the great seal of the Imperium on my collar and my breakfast in open rebellion.
A dock worker stopped beside me. Big woman, forearms like hawsers, a coil of signal flag line over one shoulder. She looked at my face with a professional eye, the way one checks a load for shift, and she unhooked a water flask from her belt and held it out.
“It is the Falamh,” she said. “It passes. Mostly.”
“What is it?” I asked her.
She considered the question. I have thought about that pause many times since. It was not that she lacked an answer. It was that she had never needed one, and was searching her stores for something she had not been asked to carry in years.
“The world is quiet,” she said at last, and picked up my case for me, and walked me to the terminal building, and that was the whole of my induction into the deepest fact of the place I would spend the rest of my life.
I have set down what the Falamh is in the proper place in this history, as well as anyone who is not born to it can. What I mean to set down here is what it was to a newcomer, on the first day, because every record I inherited was written by people who had stopped noticing it, and a fact that no one notices is a fact that goes unwritten, and things unwritten are lost. So:
It is a stillness under the world. It does not touch the ears. Sound behaves strangely here, but that is the forest and the stone and comes later in this account. The Falamh is beneath that. It is the difference between an empty room and a room where no one has ever been. For the first days my body treated it as a threat it could not locate. I slept badly. I woke in my assigned quarters in the small hours certain that something in the room had just stopped, and lay listening for the resumption of a sound I could not have named, and it did not resume, because it had never been. The lumen strip hummed. The water pipes ticked. Beneath them, all the way down, nothing. A held breath that is never released and never needs to be.
The men and women of the port worked inside that stillness like fish in water. That was the second thing, and it took me longer to see than it should have. They were not subdued. I watched for subdual; the Administratum trains you to read a population’s compliance in its noise. They laughed, they argued a manifest discrepancy with real heat, a crew chief dressed down a loader in terms I recorded for my private lexicon. But it all happened inside the quiet, and none of it disturbed the quiet, and when the words were done the quiet was simply there again, the way the ground is there when you stop walking.
On the fourth night I gave up on sleep and sat at the small desk with my arrival report, which was overdue, because I could not complete the environmental annexe. The form allotted one line to local conditions adverse to Imperial personnel. One line. I had drafted and struck four versions. Persistent low-grade disequilibrium. Unexplained perceptual deficit. Atmospheric effect, source unestablished. Each of them was accurate and each of them was false, the way an inventory of a cathedral is false.
Outside the window the lights of Kanienn lay along the basin rim, and past them the forest stood up black against the stars, going on for a distance my Terran eyes refused to accept as land.
I sat with my stylus over the line for a long time.
Then I wrote: Quiet.
And signed it, and went to bed, and slept.
III: The Stillward
The Prefect received me on my second morning, in an office whose window he kept shuttered against the canyon.
Vey had held the mission for eleven years by then, and he had the manner of a man who has been holding a queue: courteous, unhurried, and organised around the assumption that whatever you had brought him would still be there when he reached it. He read my posting order, verified my seals, and gave me the Helion assessment the way one hands over a chronic illness.
“The assessment has been open since before the forge designations,” he said. “It has outlived two Enumerators and will outlive you. Every year the sector office directs us to finalise it, and every year the system changes classification underneath us, and the directive is stale before it arrives. Your work is not to close the assessment, Adept. Your work is to keep it honest.” He set my order down. “You will be paired with a counterpart from the Ward. They have assigned you a Merour. I advise you to understand what that means before you meet her.”
I did not understand what it meant, and there was no one in the mission I was willing to reveal that to, mypredecessor in the office having departed on the ship that brought me, not troubling to hide his relief. So I met Delwen Sarn knowing nothing, which she saw within a minute, and repaired without comment, which I later understood to be the whole character of the woman.
She came to collect me on the ninth day. She was perhaps fifty, dressed in grey and green, and she watched me pack my satchel with the incurious patience of someone who has seen many men carry many papers.
“The rolls are kept in the Stillward,” she said. “Your assessment will live or die by them, so you should see where they live. It is an hour’s walk and a lift at the end. There is a lift road the whole way, if you prefer to ride.”
I said I would walk. I wanted to see the city at the pace of the people who lived in it, and I have been grateful for that small vanity ever since, because the walk taught me more than the rolls did.
We went down through the Achub terraces and into one of the ways.
I had seen them from the air without understanding what I was seeing: roads that ran into the cliff faces and did not come out. From inside, the way was a street. It was cut broad enough for four carts to pass abreast, lit by shafts that brought the daylight down in angled columns, lined at intervals with stalls and doorways and the mouths of smaller passages, and it carried the ordinary traffic of a city morning, grav carts and work crews and children being walked to instruction, all of it moving through the inside of the world as though that were where streets had always gone.
And with every hundred paces, the stillness deepened.
I had four days’ acquaintance with the Falamh by then. I had stopped noticing it in the mission house, or believed I had. In the way, it came back the way cold comes back in water, gradually and from all sides, until somewhere in the second kilometre I found I was walking more quietly, though I could not have said what sound I was avoiding making. Sarn walked beside me at an unchanged pace.
Then the way opened, and I stopped walking. I am told most newcomers do, and that the Verdantians allow for it, the way one allows for a guest pausing at a threshold.
The mission’s induction file on the Stillward informed me that the cavern was large. I had stood, once and briefly, in the great processional vaults of the Palace on Terra, an admission owed to a clerical error I never reported, and I made the comparison the file invited, and the comparison failed in my hands. The Palace vaults are architecture. They mean to be vast, and the meaning is the point. The Stillward does not mean anything. The cavern simply goes on, floor and water and light, until the far side is a matter of testimony rather than sight. Daylight came down from an opening high in the roof in one great shaft, and from lesser cuts around it in angled columns, the engineered light of later centuries laid beside the original, and where the shafts crossed, the air itself seemed lit. There were lakes. I want that recorded plainly, because I did not believe the file when it said so: bodies of standing water inside the stone, with people bathing at their margins, and beyond them terraces of lamplit galleries rising into the dark, and the black stone showing through the worked surfaces in long ribs, the way bone shows at the knuckles.
It was not quiet. That was the second failure of my expectations. The cavern held the sound of water and voices and somewhere a saw, all of it arriving strangely, flattened, spent, as though sound were permitted here on the condition it did not carry. Underneath all of it lay the stillness, deeper than I had yet felt it, deep enough that I understood at last that the two things had never been related. The name is not a description of the ears. Members of the mission who have held this posting twenty years tell me that inside the Stillward they feel the world’s emptiness as they felt it on their first day, every time, without softening. The Verdantians cannot tell me what it is like. They were born inside it, and a sailor born at sea has no word for dry land.
We crossed the floor, skirting the largest of the lakes, and took a lift at the cavern’s northern side, a shaft rising through the living stone for long enough that my ears registered the climb. It opened into daylight.
I had not understood, from the air, that the whole of it is the Stillward. The cavern where I had stood, the terraces above it, the shaped towers I had taken from the shuttle for a crown set upon the mass: one name, one place, grown out and up across the centuries until the black stone carries a vertical city well over a kilometre high. The Ward keeps its halls in the built upper reaches, and I had expected, after the cavern, something made to overawe, and was wrong in the other direction. The halls are plain. Stone and timber and glass, wide corridors, good light, and nothing in them that does not work for its place. Water runs through the building in open channels, crossing the floors under foot-bridges a stride long, feeding stands of green at the corridor junctions, and the sound of it goes everywhere, small and constant. We passed the tall doors of the Combroga, where the Wardens sit in session, standing open on a hall of benches and one long table, and Sarn named it for me and kept walking. Her own offices lay two corridors beyond, and were the size of a room.
She was not a Warden, and she was not the Penn Cofreser. The Wardens hold the council and carry the old Ard titles, and I would wait some years to stand before one. The Penn Cofreser is the Ward’s highest clerk, keeper of all its rolls, and stands above the daily traffic between our institutions. Sarn was a Merour, of the rank below: a senior clerk of the Ward, given to me as my counterpart. I know now the placement was exact. The Imperium had sent an enumerator, and Verdantia had received him with an enumerator. Rank to rank, function to function, measured to the grade.
At her table of dark wood worn pale at the edges, she asked to see my commission, and then she read it. All of it. Imperial commissions are written to be glanced at, their weight carried by seal and letterhead, and I had never before watched anyone read one to the final line, and it took some minutes, and I stood while she did it because there are silences it does not occur to you to sit in. When she finished she set it flat on the table and squared its edges with two fingers.
“Which records does the assessment require of us?” she asked.
I gave her the schedule: census, tithe assessment rolls, production accounts, the movement registers. She nodded once at each item as though checking it against a list she already held.
“They will be provided. The census is taken in the first month of the year. You will have the current roll before you leave today.” She drew a slate toward her, one of theirs, thin as a knife blade, its display like still water, and woke it with a touch. “Now. Your name in full, your place of birth, your office, and the day of your arrival.”
I gave them. It was only as she entered them that I understood what was happening: I was being recorded. Somewhere in my satchel were the forms by which the Administratum of Terra recorded the existence of Verdantia, and here was Verdantia, recording the existence of me, in the rolls of the Ward, in an entry I have since consulted, and I am in it between a shipment of tin and a marriage.
“The record has been kept since the first landing,” she said, setting the slate aside. “You will find it complete.”
I did not doubt her. That was the thing I carried out of the Ward halls, past the census roll they gave me, which stated the population of the world in a figure with commas in places my forms did not allow for. I did not doubt her, and I had been trained across my whole career to doubt exactly such statements, because every world claims its records are complete, and no world’s are.
On the way back down I stopped at a gallery rail on the second level and looked out at the cavern floor, at the bathers and the lamps and the long ribs of black stone, and the great shaft had moved since I crossed under it, shortened and swung eastward, lying across the floor like the hand of a clock that kept some slower time.
I watched it until Sarn touched my sleeve, and then I went back out through the way, into the afternoon, carrying the census of a world the Imperium had only just remembered, written by people who had never once forgotten themselves.
IV: The Cutters
The sky over Kanienn is never empty, and the first surprise it gave me was recognition.
A heavy lifter came up off the river quays my second week in residence with a grain barge slung beneath it, and I knew it. Not its kind. It. An Arvus-pattern lighter, the Imperium’s light logistics workhorse, the same blunt-nosed shuttle I had watched fly circuits over two frontier ports and the fields of Terra itself, and it climbed out over the Bevan reaches with its load as though it had taken a wrong turning somewhere in my own past. I stood at the window with the particular vertigo of meeting a countryman in a place he has no business being. In the days after, I learned to see them everywhere: lighters, landers, atmospheric boats of half a dozen classes, all of them common patterns the Imperium flies to this day, worn into local variation by a thousand years of building but never past knowing. The sky of this world is full of the Imperium’s own designs, flown by people who had never heard the Imperium’s name.
The administrative half of the explanation assembled itself within the month. Branoc’s Reach had carried the patterns of its function, and its function was ordinary: landers, lighters, the working craft of any founding. Common designs, held in common across human space. The colony had simply gone on building them, as it had gone on doing everything else. When the production accounts came to my slate for verification against the tithe schedule, the atmospheric columns of my annexe very nearly filled themselves, class after class mapping to Imperial designations because they were Imperial designations, separated from mine by a millennium and still on speaking terms.
The voidcraft column defeated me.
My annexe required me to enumerate interplanetary hulls by class, and had ruled twelve generous lines for the purpose, and the Verdantian rolls recognised one class. I searched my registries, and then I searched my memory, and a records officer’s memory is not a modest instrument. Nothing. Whatever the rolls called a cutter, the Imperium had never seen one.
I took the problem to the landing field.
The field lies east of the city on the plateau, and its long pads serve the interplanetary traffic, and I stood at the perimeter through the change of a morning shift and watched a cutter come down from orbit. It was long-bodied and clean, the shape of a seed pod drawn out, and it settled onto its pad with an economy that made the lighters working the near apron look briefly like livestock. Over the following hour I watched three more. A tanker variant, deep-bellied, in from the fuel runs. A passenger boat, the same hull opened with viewing galleries. Something leaner with hard points along its spine that the field’s registry clerk called a patrol cutter and did not elaborate. Under the differences, under the stretched holds and the added tankage and the varied liveries, every one of them carried the same lines. The same nose. The same wing root. The same way of sitting on the ground, unhurried and certain, like a workman who has held the one tool so long it has worn to his hand.
They were all the same craft, and the rolls confirmed it when I went back to them. One class of cutter, built for twelve hundred years, its patterns running to dozens and its class running to one. Everything Verdantia flies between its worlds that is not one of the three old haulers is that craft in some body or other. And it belongs to no lineage I could cite. It came, the rolls state, from the flagship, from the proprietary holdings of a trading dynasty no Imperial registry has ever heard of, and it has been the spine of this system since before the Imperium reached it. The Arvus in the canyon below my window had cousins on ten thousand worlds. The cutter on the field had none anywhere, and my annexe had ruled twelve lines for it, and eleven of them were going to stay empty.
The registry clerk was a man named Coll, and the registry of a world lived in the slate he carried, a Verdantian instrument the thickness of a knife blade with a display like still water, beside which my own Administratum-issue slate looked and felt like a roofing tile. I asked him why one class. He gave the question the pause I had learned to expect here, the search of the stores for an answer to a thing no one asks.
“It is right,” he said. “Why would we keep classes that are less right?”
“On Terra we would say diversity of design strengthens a fleet.”
“That may be true of a fleet,” he said, and passed me the next roll, and did not elaborate. I gave both lines to my autoscribe that evening, and in thirty years I have not heard the Verdantian position improved upon.
I wrote my annexe honestly. The atmospheric columns I completed to schedule. In the voidcraft column I entered the single class, appended a schedule of variants, and spent the remarks field, all of it, on what I had seen from the perimeter: that the absence of diversity was not a poverty but a perfection, one design refined across centuries until it did every task the system asked, and that in my assessment the voidcraft rolls of Verdantia represented a mature industrial culture and should be read as such. I marked the annexe for the sector office, and it went up with the season’s dispatches, and the reply came back fourteen months later, which was the rhythm of correspondence by then, the route being what it was.
The reply directed me to confirm the apparent absence of diversified interplanetary hull classes, to assess the deficiency against compliance benchmarks, and to advise on remediation.
I have kept it. The slate lives in the third drawer of this desk as I write, its charge maintained across three decades for no reason I have ever been able to defend at requisition, and I take it out sometimes, because it taught me the lesson I have spent the rest of my life trying to write my way around. The sector office was not staffed by fools. They read my annexe carefully, and they saw the word one, and every instrument they possessed told them that one is a small number. I had sent them an account of mastery, and their forms had received an account of shortage. Nothing I wrote after that year was written the same way, because I understood then that a record is not what is set down. It is what can be read back, and between those two things a world can go missing.
I drafted a fuller explanation. It went up with the next dispatches. If an answer came, it never reached me.
The evening the directive arrived, I stayed late at the mission and watched the light go out of the canyon. The waterfalls dimmed from white to grey. The lamps came up along the terraces of the Stillward in their slow thousands. Out east above the plateau a cutter rose from the field for orbit, running lights steady against the first stars, and it occurred to me only as it climbed that I had barely heard it lift. They are quiet, the cutters. I had noted it before without weighing it, the way one notes a courtesy. It went up with a sound like breath, and higher still, in the darkening east, a slow star was rising that was not a star. The Asterion, outbound for Caelus on the run her rolls said she had made two thousand times, a ship that has never once touched the world she serves, older than the Imperium’s knowledge of it, climbing her old road while the directive on my desk asked me to advise on remediation.
I turned off the lumen and watched until both lights were gone.
V: The Yard
The forge designations broke my columns before I ever saw the worlds they applied to.
The difficulty was elegant, in the way that only a truly insoluble filing problem can be. A forge world, under the schedules I was raised on, is exempt: it renders its due in materiel to its own masters and stands outside the common tithe. Caelus and Dravus had been designated restricted forge worlds twenty-four years before my arrival. But they were not forge worlds as my schedules understood the term. They were Verdantian industrial worlds, built by this system for this system, assessed for sixty years as the productive heart of the Helion tithe, and then re-designated mid-assessment, without the assessment ever being ruled closed. Half my registry treated Caelus as exempt. The other half carried it as the largest single line in the system’s due. Both halves were signed, sealed, and correct. I put the question to the sector office in my first year, and the answer, when it came back, directed me to resolve the ambiguity with reference to the applicable schedules, which was the ambiguity.
So in my third year I did what an enumerator does when the record will not agree with itself. I went and counted.
Caelus is not a journey. It is the moon. It stands over Kanienn on clear nights close enough that children point out the yard lights to each other, and the passenger cutters run to it on a schedule so ordinary that the manifest describes the crossing as local. I had come to this posting through half a year of warp and eight translations, the last of which rearranged my internal organs alphabetically, and my first assignment of consequence was a day’s ride to somewhere I could see from my office window. I filed the travel authorisation anyway. The Administratum requires the form regardless of whether the destination is visible from the filing desk, and I have always found a quiet comfort in that, the way one is comforted by any institution too large to notice it is being ridiculous.
Caelus from approach is two shipyards wearing one name.
The old yard is Verdantian, and the first thing it taught me is that it does not look like what it builds. The cutters are sleek in the way of things whose lineage I could not cite. The yard is older work and plainer: a station grown outward from a ship’s bones on the practical patterns of the seed fleet, slips and gantries in ordered rows, settled, certain of itself, anchored there for eleven centuries. The new work is Imperial, and it looks like the Imperium: vast, unfinished, and arriving. The Mechanicus expansion stood in whatever year of its construction it had reached, ribs of a structure that would, when complete, swallow the old station the way a cathedral swallows the chapel it was raised over. Black Ship ways, built to a scale no Verdantian hull required, lay empty and waiting along the new frames. And on the old slips, in the middle of all of it, the cutters were still coming, hull after hull after hull, the one class in its many bodies, sliding out of the yard that the whole Imperial programme existed to repurpose, at a rate my production accounts showed as undiminished in any year since the designation.
I recorded that. I recorded it as parallel programmes, existing capacity maintained alongside conversion works in progress, which was accurate, and complete, and true in the way my first cutter annexe had been true. I have wondered since what I would have found if I had asked one further question, and I have concluded that I would have found nothing, because there was nothing hidden to find. The yards were doing what they had always done, openly, in full sight of the tech-priests who walked their gantries. Nobody was defying anybody. The conversion proceeded. The cutters continued. Both facts went into everyone’s records, and no record anywhere held the third fact, because the third fact was not written down in any form a record could hold.
At the heart of the old station they keep the Earthbreaker.
I had her in my registry as a decommissioned hull, preserved. The words had not prepared me. The station grew around her the way the city grew around the black stone: she is the core of it, her ancient frame threaded through the newer decades of construction, and deep at her centre they have kept her command deck whole. Not restored. Kept. The consoles are M25 work, the real thing, the kind of instrument my Administratum trains you to call archeotech and treat with dread, and here they stand in ordinary lamplight with a hand-rail around them and a Verdantian docent who recites the ship’s service the way my colleagues recite litanies, except that she understood every word of hers. Children come through on instruction days. They stand where Brask stood, at the station of a ship that found the Fortress of Labour adrift and brought her people in, lifted a colony’s freight for a century and more, saved Branoc’s Reach, and then gave up her mobility and became the place her own forges built.
I stood at the rail for a long time. The docent let me.
Around us, through the old hull, came the working sound of the yard: the deep intermittent ring of the fabrication bays, the sigh of pressure doors, somewhere the burr of a cutter’s drive under test. And under that, from further off, through however many decks and kilometres of station, the other sound, the new one, the Imperial one: construction, endless and enormous, the future being assembled around the past.
The docent asked whether the Imperium kept its first ships.
I told her I did not know. I have thought about the question ever since, and I still do not know, and it has stopped being a question about ships.
VI: The Rendering
The tithe schedule of the Administratum provides for psykers rendered, psykers withheld, and psykers concealed, this last with a thorough annex on applicable penalties. It does not provide for a world that renders the opposite of a psyker. I checked. I checked twice, the second time with the index, which is how a details man prays.
Helion owes the Great Tithe like every human system, and the Great Tithe means the Black Ships, and the Black Ships come for psykers, and Helion does not have any. I do not mean it hides them. I sat with the rolls for a season looking for the shape of concealment, because concealment has a shape, and an enumerator learns it the way a fisherman learns weather. There was nothing. The world is simply quiet, in its people as in its stone, and what it yields instead, at a rate my superiors on brighter worlds would not credit, is the other thing. The still ones. The schedule has no line for them. The Sisters of Silence have an entire order for them, which tells you something about the relative preparedness of our institutions.
I should record here my single greatest misapprehension on arriving, which was that I looked, in my first week, for the mission’s choir. Every posting I had held kept astropaths the way a building keeps stairs; one does not admire them, one simply cannot imagine the structure without them. There is no choir here. There cannot be. This world does not permit that kind of listening, and the Imperium, whatever else may be said of it, does not brick people into their own skulls for nothing. So every word the mission exchanges with the Imperium travels as cargo, in a satchel, in a hold, between the flour and the machine parts, at the speed of a ship, and my first dispatch to the sector office left this world the way a letter left a village ten thousand years ago: physically, patiently, and in the company of freight. I found it absurd for about a month. Then I found it clarifying. A message that costs a ship teaches you what is worth saying.
In my fourth year the rendering fell due, and certification of a tithe rendering is an enumerator’s duty, so I went up to the citadel to watch a world give the Imperium the one thing no other world gives it gladly.
The citadel of the ordu stands on the plateau south of the city, and it is the only building on Verdantia that argues with the landscape. Everything else here negotiates. The city folds itself into the canyon, the landing fields borrow a clearing from the forest, even the Mechanicus works at Caelus grow around what stood before them. The citadel argues. It is Imperial work, gold and black and vertical, walls that want you to know they are walls, and it stands on that green plateau with the magnificent wrongness of a funeral candelabrum planted in a vegetable garden. The landscape, being Verdantian, declines to argue back, and simply grows moss at it.
The families were already gathering when I arrived. That was the first thing my training refused to process: families, gathering, the way families gather for a graduation. On every other world in the Imperium the coming of the Sisters empties streets. I have read the accounts; we all have; the dread is in the training manuals as an operational consideration. Here there were perhaps two hundred people on the approach ground in their good clothes, and children running between them, already grass-stained, playing a game whose rules appeared to involve the solemnity of everyone else.
Nine were rendered that year. Girls near grown and young women, each with her people around her, each carrying the single bag the ordu permits and the several additional bags her mother had argued past the permission. They were not being given up. That is the plain fact of it, and I set it down against every expectation I carried up that hill: they were being sent, the way this world sends its daughters to the fleet or the far basins, with pride out in the open and the grief kept for the walk home.
The Sisters came out to receive them, and my body, which had been on Verdantia four years and thought it knew the local silence, discovered it had been attending an introductory course.
I want to be exact, because I have read too many accounts of the Sisterhood written by men whose fear did their describing for them. The Sisters are not giants. They are women, human as I am, and a good quarter of them stood shorter than the Verdantian mothers facing them; the gold war-plate adds presence, not stature. What they carry is not size. A Sister of Silence, close to, is the Falamh with a face. The stillness I had learned to live inside came off her the way heat comes off a stove, concentrated, personal, and pointed, and every animal instinct I own stood up in the back of my skull and requested, in the small voice of a junior clerk reporting a filing error, permission to be elsewhere. I did not grant it. I am modestly proud of that. The Verdantians around me, meanwhile, felt nothing at all, or felt something and had no quarrel with it, and their children looked up at the gold-armoured women with the frank hero-worship my own generation spent on Titan crews.
The Sisters do not speak. Their voice that day was a novice, a girl of perhaps nineteen who had not yet sworn what they swear, and she read the instrument of rendering aloud in careful High Gothic while her sworn Sisters stood in a stillness that made the plateau wind sound loud. The eldest of them, a Vigilator by her wargear, received each recruit by taking her hand in both gauntlets, a gesture I have never found in any account of the order, and which I suspect does not exist anywhere else the order goes.
And then the mothers reached the front of the gathering, and I watched the Sisters of Silence, the dread of a thousand worlds, be ambushed by Verdantian hospitality.
They had brought provisions. Of course they had brought provisions; this is a world that sends nobody anywhere without food; but I do not think the ordu’s protocols had a contingency for it, because when a broad grey-haired woman pressed a cloth-wrapped bundle and a sealed jar of preserves into a Vigilator’s hands, the Vigilator went entirely still, and it was a different stillness from the working one. She stood holding the jar as though it were live ordnance of an unfamiliar pattern, and the moment stretched, and her helm turned a fraction toward the novice as if the order’s whole apparatus of signed language had failed to cover the case. Then she bowed, very slightly, and stowed the jar in a belt pouch with the precision my own order reserves for founding charters, and the woman patted her vambrace twice and went back to her family, satisfied, having fed someone.
I recorded the rendering. Nine souls, willingly presented, received with honour. In the remarks field, where by then I lived, I noted that the psyker yield of Helion remained nil, that the world was in consequence formally delinquent under schedule, and that its delinquency had just been carried up a hill by its own mothers with baked goods. I recommended the schedule be amended. I am still waiting.
There was no ship. That was the last correction the day made to my training, which had me half-listening for engines through the whole ceremony, because on every world I knew, a rendering ends with a hull swallowing the rendered. Here the nine shouldered their bags, and their several additional bags, and walked up through the citadel gate with the Sisters around them, into the place where they would be made whatever it is the Sisterhood makes. The gate is Imperial work, vast and gold. It did not boom shut. Someone closed it the way you close a door on a house where people live.
And the families did not leave. They set out the meal there on the approach ground, as the evening came down off the plateau, because the daughters were behind that wall, not behind the sky, and a wall you can walk to in a day is a different grief entirely. The garrison Sisters who remained outside were folded into the gathering the way relatives are folded in at a wake, handed things, included.
A girl of perhaps seven planted herself in front of one of them and began to sign, small hands working through shapes too deliberate to be play. The Sister watched, and then her gauntlets moved in answer, slowly, at a child’s pace. I asked the novice what language it was. Thoughtmark, she said: the order’s own, the speech of the sworn. The schools here teach it now, the way schools elsewhere teach a second alphabet. Nobody had asked the order’s permission. I looked at the Sister answering the child, patient as a grandmother at a gate, and concluded that permission had been granted anyway, some time ago, in the only form her order uses.
One of them stood at the edge of it holding a cup someone had put in her gauntlet. She did not drink. I do not know if she could have, armoured and sworn as she was. She simply held it, in that gold stillness, while the ordinary evening assembled itself around her, and the last light came off the forest, and nobody was afraid.
I walked back down to the lift road with my certification sealed and my animal instincts still filing complaints, and it occurred to me somewhere on the descent that I had just watched the Imperium receive tribute, and that nothing in my training had a word for what I had actually seen, which was a world adopting its conquerors one jar of preserves at a time.
VII: The Conversion
Two sets of returns crossed my desk every quarter, and they described two different moons wearing the same name.
The first set was mine, or became mine: the production accounts of Caelus, rendered through Sarn’s office from the yard rolls, exact to the hull. The second came from the Mechanicus, from the office of the expansion, and it accounted for the same moon in the units of the conversion programme: frames raised, ways laid, tonnage of the great works accreting over the old station year on year. Both were true. I had learned by then to stop expecting truth to be singular, the way one stops expecting rain to be dry, but I filed them side by side each quarter and each quarter the space between them said something neither would write down.
The conversion schedule held that the cutter lines would wind down as the Black Ship ways came up. That was its architecture, and its arithmetic, and its entire reason: the Imperium had found a shipbuilding people and meant to point them at the hulls it needed. The ways came up. I certified the tonnage myself, and the expansion is honest work, vast and exact. And for a time, the arithmetic ran. Through the later years of the century the expansion drew labour and slips the way a fire draws air. The cutter output in my returns fell for the first time in any record I held, quarter on quarter, exactly as the schedule said it should.
The schedule was satisfied. The Ward was not. The Ward had done its own arithmetic, on ships rather than tonnage. The three ancient haulers that carry this system’s blood are older than the Imperium. The Currach was already running at seven-tenths to spare her reactors. A fleet of that age does not decline politely toward a scheduled replacement. It stops, somewhere, on some unscheduled day. The cutters were the insurance against that day. The Combroga ordered the lines restored and maintained at strength, and the yards obeyed, because the yards had obeyed the Ward for twelve centuries. The expansion office found its labour projections short by exactly the difference. My directives asked me, at fourteen-month intervals, to reconcile the divergence. I reported what my returns held: the schedule assumed a thing would stop, and the thing, after one interruption, had declined to. You cannot reconcile a schedule with a fact. You can only choose which one to believe, and the Administratum pays me to believe facts, a policy it adopted, I assume, without reading it.
My counterpart in the expansion office was a logis, Arcten by designation, a man perhaps a third of whose original issue remained under the augmetics, and I record with some care that I liked him. We exchanged returns on the fifth day of each quarter, in a chamber the Mechanicus kept at dockside, and our exchanges had the comfortable rhythm of two men playing regicide by correspondence who have both privately concluded the game is unwinnable and see no reason to stop enjoying it.
It was Arcten who first asked me for the process documentation.
The request was reasonable. It was, by every standard either of our orders keeps, overdue. The conversion programme was raising Imperial patterns in a Verdantian yard, and the yard’s own methods, the working practice of eight centuries of cutter-craft, existed in his returns as an input of unspecified character. His office wished to specify it. He asked me, as the officer of record for Verdantian production, to obtain the pattern documentation, the process records, the fabrication instructions, in whatever form the yards held them.
I took the request to Sarn, and Sarn took me to the yards, and the yards showed me what they held, which was masters and apprentices.
I want to set this down carefully, because it took me years to understand what I saw in an afternoon. There was no vault I was kept from. There was no archive withheld. I was walked through fabrication halls with a courtesy that bordered on the ceremonial, shown anything I pointed at, answered on any question I could form. The knowledge was everywhere and it was in no form I could requisition. It was in hands. It was in the eight-year shape of an apprenticeship, in the way a woman read a weld seam with her thumb, in corrections made before errors happened by men who could not have told me how they knew. I asked one master where the tolerances were recorded. He held up his own hand and turned it over, showing me both sides, in case I wished to make a copy.
I reported to Arcten that the requested documentation did not exist, that the process was conveyed by instruction and practice, and that this appeared to be the method entire. I flagged it, Emperor forgive me, as a records deficiency. Some lessons have to be paid for twice. Arcten filed my report, and his office classified the Verdantian process as pending characterisation, and I came to understand across the following years that pending is the Mechanicus category for the things it has decided not to be troubled by. The cutters flew. The patterns performed. A machine that works is a prayer answered, and his order does not interrogate answered prayers, it catalogues them and moves on to the ones still outstanding. No one ever asked again. There was nothing to ask of. You cannot requisition an apprenticeship.
To the Ward’s order, the expansion office responded as the Mechanicus responds. Its writ, as its adepts read it, was total. A designated forge world owes its output to the designation, and the direction of that output belongs to Mars. Absolutely, and without negotiation. A fact of the designation the way weight is a fact of mass. Directives were issued. The Ward received them with courtesy and continued building cutters. More directives followed, in harder language, and were received with the same courtesy. I certified, quarter after quarter, the returns of a moon on which two absolute authorities were mutually declining to notice each other. The Verdantians watched their yards feed a programme that had never once fed them back, and said nothing, and built. The tech-priests watched a subject world disobey by the simple method of continuing, and had no category for it. Disobedience, in their experience, announces itself. This did not announce. It persisted.
I went to Arcten. I want to be honest about why, because the why had changed under me without my noticing. Ten years earlier I would have gone as the Administratum’s man, to explain the Ward to the Imperium. I went instead to explain each to the other. The difference is the confession of this entire chapter. I laid out the Verdantian arithmetic as the Ward saw it. Not defiance: insurance. Three irreplaceable hulls of unknowable age carrying the whole interior economy, and no successor laid down anywhere in the programme’s future. Then I laid the proposal I had walked in with, and I record that my masters would not have recognised it as mine. Share the capital patterns. Let the yards lay Imperial-standard replacements for the old fleet on the slips the Ward was defending. The programme would gain what it actually wanted, which was the yards’ eventual whole attention. The Imperium would gain what it should want, which was the retirement of three archeotech hulls answerable to no template Mars has ever blessed. And the Ward would stand down a defence it had never named, because the thing it was defending against would have been removed.
Arcten was silent for a time, in the way of a man consulting authorities I could not see. Then he observed that his Skitarii detachment, indented for at the designation and confirmed in three successive manifests, had still not arrived, three decades on. Persuasion, in the doctrine of his order, is a function of presence. I agreed that it was. He looked at whichever of us his remaining eye preferred, and filed my proposal upward. The patterns were released within the year, which by the standards of his order is the speed of panic. The Ward accepted them the way the Ward accepts everything, with thoroughness and without gratitude. The first Imperial-standard keel for a Verdantian hull was laid on the number nine slip before the decade ended. I have wondered since whether I served the Imperium that afternoon or merely described it accurately to itself. I have concluded that I no longer always know the difference, and that this, too, belongs in the record.
My promotion to Senior Enumerator arrived in the ninety-eighth year of the century, with the spring dispatches, eleven months after the death of the senior officer whose desk I inherited and whose returns I had, in practice, been drafting for two years. The assessment of Helion became wholly mine. The Prefect marked the occasion by giving me the one piece of guidance he ever volunteered in my hearing, which was that an assessment is a portrait, and a portrait can be accurate or finished, and I should decide early which I was painting, because no one had ever managed both. I have thought about that sentence for thirty years. I am still deciding.
And through all of it, quarter on quarter, the transit annexes lengthened. A materiel convoy came in nineteen days over schedule, then a season over, then not in the year expected. The sector’s directives arrived with their dates already historical, instructions from a world that no longer quite existed by the time they reached the world they were written for. I recorded the variances. Variance is a comfortable word. It suggests a norm that will be returned to, and I used it for years, in return after return, the way a man keeps saying late about something that has stopped coming.
On the last evening of one Caelus inspection, Arcten walked me to the transfer gallery, past the viewing ports that overlook the new works. The Black Ship ways stretched off under their arc-lights, immense, immaculate, and empty, waiting for the future the schedule promised them. Below and beyond, half-lit at the edge of the old yard, a cutter stood on the number nine slip with her hull plating half-hung, the one class in its newest body, and there were figures moving on her scaffolds at that hour, unhurried, certain, the way they had moved for eleven centuries.
Arcten stood with me a moment, looking at whichever of the two his remaining eye preferred.
“Your returns are very clean,” he said, which from the Mechanicus is intimacy.
I thanked him. We understood each other perfectly, I think, in the way of two record-keepers standing in front of a fact too large for either of their systems, each confident the other’s would fail first.
VIII: The Reach
The Dravus half of the assessment could not be done from a window.
Dravus is the far side of the ledger: the iron moon of the gas giant, re-designated Auxilia Forge World in the same stroke of 867 that re-designated Caelus, and owing its due to the programme in steel. My registry carried its outputs in columns that had been growing steadily for eight decades: ore, manganese, chromium, adamantium, castings, rolled plate. An enumerator can verify a great deal from returns. He cannot verify everything, and in my sixth year the sector office directed me, in a dispatch already fourteen months old on arrival, to conduct a physical assessment of the Auxilia works and their outputs. I record with gratitude that for once the Administratum and I wanted exactly the same thing.
Passengers cross to the Aelios family by fast cutter. I booked the Asterion. An enumerator learns early that a defensible tasking is a currency that buys such things, and on the Dravus run no invention was even required, because the Asterion’s outbound cargo wasmy subject. She loads coking coal at Verdantia, thousands of tonnes of it, with limestone in proportion, because the purpose of Verdantian coal is steel and the purpose of that steel begins in her holds. I would spend weeks riding the exact line of my own ledger from one end to the other. There are men in my order who wait entire careers for an audit to become a boat trip, and I do not intend to apologise for enjoying it.
I knew her age from her rolls before I boarded, and I do not think I believed it until I stood in her boarding gallery and put my hand on a stanchion worn to the shape of hands. A thousand years and more of service. Older than the Imperium itself. The Verdantians do not treat her as a relic. She is a working ship on a working run, crewed by people who speak of her the way one speaks of a grandmother who still keeps her own accounts.
On the second day out, a crewman walked me forward along the spine gallery, and we came to a place where the corridor simply stopped. A bulkhead sealed it, old work, the welds gone dark with age, and the metal around the seal was wrong: rippled, flowed, two structures become one in a way that the eye refused before the mind did. The crewman told me plainly what it was, because it is not a secret, it is history. The Torvaine came through the warp fused into her, and the dead of both ships are in there still, and the ship has carried them on every run since. I thought about my columns that evening. I had two of them for the vessel I was riding: keel age, and classification. Neither said anything true about her at all.
The weeks pass strangely on a hauler. The crew work their watches, and the void does not change, and a man with a slate and a census can be perfectly happy, which I was, and slightly ashamed of it, which I also was. Then the gas giant arrives. It does not approach; it arrives, the way weather arrives, and one morning Aelios owned half the forward ports, banded and enormous, with the refinery platforms strung along their orbits like beads of light and the tanker traffic crawling between them. Somewhere below the cloud decks was the promethium that lit half my registry. I stood at the port for a long time and understood, in the way the returns had never quite made me understand, that the system I assessed was not Verdantia with outbuildings. It was two civilisational hearts, and I had spent six years living in only one of them.
The Asterion does not land on Dravus. Nothing two kilometres long lands on anything. She was making for the Reach, and so, therefore, was I, and I record honestly that no briefing document had prepared me for it, because the briefing documents were mine, and I had written them from the returns.
You see it first as a contradiction. Something the size of a small city, in orbit over an iron moon, green at the middle. Two hulls lie back to back across a gap of six hundred metres, joined by limbs of built metal a village could stand on. One hull turns its garden decks to the moon, terraces and glass and green. The other turns its docks away from it, great gantries hanging outboard into the dark like the legs of some patient sea creature. From the approach you cannot tell whether you are looking at a station built like ships, or ships that became a station. You are looking at the second thing.
Ten kilometres out, the tugs came for us. The Asterion shut her drives down and gave herself to them, an old courtesy between working vessels. They walked her in and laid two kilometres of hauler onto the gantries as calmly as a harbour takes a fishing boat. It was only as the limbs closed around us that I understood what I was reading in the station’s bones. The docks that held us were a ship. The garden towers facing the moon were another ship. I was watching a thousand-year-old vessel berth in the embrace of two vessels older still, Branoc’s Reach and the dynasty flagship, lying side by side in their retirement and joined for good. And every soul aboard all three of them, at that moment, was there on the ordinary business of a Tuesday.
The Verdantians call it the Reach, and it is where the Aelios family keeps its front door. The haulers dock; the holds tranship; and a constant weather of landers and shuttles moves between the station and the moons and the refinery platforms, dispersing downward everything the big ships bring and lifting back everything the moons produce. I watched my coal leave before I did: heavy landers loading from the Asterion’s holds in a queue that had the patience of something that has been happening for centuries. Then I boarded a shuttle of my own and followed my manifest down.
Dravus took eleven days.
I will not reproduce the annexe here; it is in the record, and it is one of the better annexes I have written. What the annexe does not contain is the steelman at the second blast-works who, on learning what I was, took it upon himself to educate me about manganese for the better part of an hour, with the missionary intensity my colleagues reserve for the Imperial Truth. Nearly every tonne of steel contains it, he told me. No manganese, no steel; no steel, no ships, no mills, no anything. He said it the way a man delivers the punchline of the universe. I have audited forge-tithe on three worlds and I had never once thought about manganese, and I have thought about it ever since, and I put it to you that this is the whole difference between a record and an education. The furnaces he showed me were running on Verdantian coal, some of it conceivably the very tonnage I had ridden out with, and I confess to a wholly unprofessional satisfaction at watching my own manifest go into a fire and come out the side of a ship. Or rather, the side of a plate, stacked for the lander queue and the Reach’s holds, because the ships themselves are born at Caelus; Dravus makes the iron truth of them and sends it up the well.
The mining towns are free towns. I set that down deliberately, because my training supplied expectations for what a mining moon looks like, and Dravus declined all of them. I found wage books and family registers and the ordinary Verdantian habit of building a school before the second shift-hall, where my training had promised indenture rolls and penal ledgers. My schedules, which have categories for penal extraction and indentured labour and voluntary servitude in three grades, coped with free miners by pretending the case was unremarkable. It is not unremarkable. I have seen what the Imperium’s mining worlds hold. I recorded the wage books without comment, and the absence of comment was the comment.
I went back up to the Reach with the plate.
It was there that I first stood before a Warden, and the audience my training had prepared me to expect on day nine arrived, instead, in my sixth year, in an administration hall of the old flagship where the water runs under foot-bridges exactly as it does in the Ward halls at home. The Ardbal keeps the mining seat at the Reach, at the centre of the economy that answers to it. I had been advised to expect courtesy and a quarter of an hour. I received the courtesy. The quarter of an hour lasted most of an afternoon.
She had read my commission. Of course she had; I know now that they all do; but she had also read my annexes, the six years of them, and she had them on the table in the Verdantian slate format, annotated in a hand that asked questions in the margins. Mining is the heaviest line in the assessment of Helion. Of all the Wardens, the Ardbal owns the largest share of whatever my numbers eventually mean, and she had decided, with the unhurried thoroughness I was learning to recognise as the national character, to understand precisely what an enumerator is.
“Your assessment,” she said. “When you complete a figure and send it, who reads it, and what do they decide?”
I told her the truth, which is that the figure goes to the sector office, where it informs the aestimare, and the aestimare in time sets the grade, and the grade sets the due, and the due comes back as a schedule.
“How much time?”
“Years. The correspondence loop alone is fourteen months. A grade ruling can take a decade.”
She noted that, with the particular attention of someone fitting a new gear into a machine she already ran. “So the schedule that arrives describes a Dravus from ten years before it is enforced.”
“Yes.”
“And if the figure is wrong?”
“Then the schedule is wrong,” I said, “and the schedule does not know it. Which is why I count carefully.”
She looked at me for a moment. “An assessment is not a demand,” she said. “When does it become one?”
I have been asked many questions in my career, most of them by people who wanted a smaller number. I had never been asked that one, and I gave it the honesty it had earned: that the assessment becomes a demand at the moment someone with authority decides it should, that the deciding happens far from here and years from now, and that the best protection against a bad demand is an exact assessment, because exactness is the only thing I control. She considered this the way her miners consider a rock face.
“Then we will make certain,” she said, “that you are never given cause to be inexact.”
It was not a threat. I want that understood, because I have replayed the sentence many times and there is no reading of it that is a threat. It was an offer of alliance between two record-keepers, made by the person with the most to lose from bad records, and it explains everything about my next twenty years of Dravus returns, which were the cleanest in my registry because an entire Warden’s office quietly saw to it that nothing reached me late, partial, or rounded. The Imperium believes accuracy is extracted from subject worlds. On Dravus it was handed to me, in weighed and dated consignments, by people who had concluded that the truth was their best armour. My training had no category for that either. I was running out of categories at a rate that should have alarmed me, and had instead begun to feel like the point of the journey.
Before I left her that afternoon, she came to the thing she had kept for last, and I record it as it was said, because I signed what followed.
“My seat answers for the heaviest line in your assessment,” she said. “When your grade is ruled and your schedule arrives, the Aelios family will render a share of everything these moons produce. Tell me what comes back.”
I did not answer, because we both knew the answer, and she did not make me say it. Nothing comes back. The tithe is not an exchange. It is the Imperium’s due, and I had been trained to regard the question itself as somewhere between an error and a heresy.
“I will not argue with your purpose,” she said. “You count what is here. That is right, and we will help you do it. But a mine is not a hole that gives. Before one tonne reaches your column, it has been fed, housed, schooled, healed, and entertained. The miners’ towns, the Reach, the hospital, the gardens you walked through to reach this room: that is what a tonne costs. Assess the yield without its cost, and your figure will be exact and false. The schedule it becomes will demand a Dravus that does not exist. And when the demand cannot be met, it will be met anyway, and you have seen the worlds where it is met anyway. You told me you count carefully. Count all of it.”
I sat with that for a long moment. Everything I had been trained in said the cost of production is the world’s affair and the due is the Imperium’s, and the two must never meet in a return. Everything I had verified said she was describing the truth. I had lately stood in a dockside chamber and given the Verdantian arithmetic to the Mechanicus. I had not expected to receive it myself, whole, from the other side of a table, within the same handful of years.
I agreed. I record that plainly. I built the cost of production into the Dravus assessment, netted before the due, itemised to a standard my own order would have called devotional. And I felt, signing it, a distinct nausea that I have never entirely argued away. It was not the nausea of a wrong act. It was the nausea of a man watching his training and his judgement part company, and discovering which one he was.
She was not finished with me, though the rest arrived over years rather than that afternoon. A suite was found for me on the Reach, against my future inspections: not a stately one, nothing above my station, but set on the garden side, with a view down the long terraces that I have never once entered without stopping. Foods began to find their way to my desk, small Verdantian specialities with notes in a clerk’s hand saying only what they were and where they were made. The sender knew, it seems, that provenance, to a man like me, is the better half of flavour. Introductions were made. I met the Ardcludiant that way, and two Wardens whose seats I had known only as signatures. Each received me as a colleague whose work had been explained in advance, favourably, by someone they trusted.
I knew what was being done. I want that in the record, because the record is unkind to men who were managed and did not notice, and I noticed. She had read me the way she read a rock face. She had seen that the man the Imperium sent was still the Imperium’s, but softening, gone some measurable distance toward the world he was counting. Further than any of my predecessors, and further than I had admitted to myself. And she had decided the distance was an asset, and cultivated it, patiently, with suites and preserves and friendships, the way her miners follow a promising seam. I record that it worked. I record also that everything she gave me was true, and everything I signed was exact, and that I have searched the arrangement for thirty years for the place where the corruption sits, and have not found it. She never once asked me for a number. She only ever made certain I had the right ones.
On my last evening I sat on a green terrace with my slate and did not write anything. Through the canopy glass, past the tended trees, the Asterion lay along the dock spine taking on plate for the Caelus run, and from that angle you could see her scar, the great angular half-kilometre of scarred hull where the Torvaine had been cut out of her, lit softly by the gantry lights. Grass at my back. Aelios rising vast and banded beyond her. Three old ships, all of them wounded, none of them finished, holding up the roof of a world between them.
I sat there until the horn sounded for the evening meal, and I did not audit anything at all.
IX: The Seams
My schedules classify eleven hundred and forty kinds of stone. I have counted. There are four categories for marble alone, graded by the quality of Imperial portraiture they will sustain. The stone this world is actually famous for, the black stone the Astra Telepathica crosses half a year of warp to secure, appears in none of them, and in my ninth year the sector office noticed, and directed me to resolve the classification, and I want it recorded that somewhere on Terra there is an office that waited thirty-five years into a strategic mineral programme to ask what the mineral is. I have never felt closer to my own institution.
The far seam lies eight hundred kilometres from Kanienn, and I went out to it on a morning cutter, over the forest.
I had not, until that flight, understood the forest. From the city one sees the canopy at the canyon rim and thinks of it as scenery. From the air, for two hours, it is a fact of a different order: a single green organism from horizon to horizon, swallowing hills whole, mist standing in its folds, and not one road, because the Verdantians never cut one. The pilot flew it the way men drive a route they have driven all their lives, and pointed out, at intervals, things I could not see until the moment I could: a river’s glint, a Warden’s fire tower, a shadow that moved against the grain of the wind and which she identified, without adjusting course or tone, as a wing. I made a note to look up the word and then decided, on reflection, that I was happier not knowing while airborne.
The town at the seam is called Dubhros, and its landing ground sits two kilometres out, on the far side of the orchard slopes, for reasons nobody explained and I did not need explained by then: noise goes where the people are not. The pilot shut her engines down and nodded at the road.
“You will meet the door on the walk in,” she said, and did not elaborate, which I had learned was not rudeness but economy: the thing itself was the explanation.
I had nine years of the Falamh in my bones by that morning, and I had stopped noticing it the way one stops noticing the weight of clothes. On the orchard road, somewhere past the first kilometre, I noticed it again. The quiet got quieter. It came on gradually and directionally, the way cold comes up through a boot sole, deepening with every hundred paces toward the workings, and I understood the miners’ word for it before anyone confirmed the word, because it was exactly like a door: you were on one side of something, and then you were on the other, and behind you was the country of the merely silent.
Dubhros is two thousand people, timber and stone, built in the practical Verdantian way around the mine head, with the orchard rows planted straight up the old spoil slopes because level ground is for houses and no ground is for waste. There is a school. There is a mill. There is, among the houses, a small stern building of Imperial stone with gold at its gate, because the Sisters of Silence keep a watch-house at this seam, six of them, posted from the citadel. It was built at the town’s edge, I am told, and the town, growing, declined to leave it there. The houses have closed around it on every side, to the order’s visible and continuing annoyance, and the town has knitted the Sisters into itself so thoroughly that I watched a Vigilator carry a child’s kite down off a roof with the same ceremonial gravity her order reserves, elsewhere in the galaxy, for the binding of rogue witches.
The stone itself I was shown without hesitation, because nothing about it is hidden.
The galleries run shallow and cool, timber-shored, dry underfoot, and the seam stands in the working face like a vein of poured night. It does not glitter. It does nothing at all, which is the thing about it, because down there, close to it, the Falamh is not an atmosphere but a pressure, and the world’s quiet gathers around the black stone the way light gathers around a lamp, if a lamp could be made of the opposite of light.
The miners cut it with saws, patiently, in consignment blocks, and the saws are the least of it. The founders lived in and against this stone for generations, in the Stillward itself, before anyone recognised it as a material rather than a fact of the ground, and once they tried to work it, it ruined their tools and their assumptions for generations more. The craft that cuts it now was not invented; it was accumulated, blade by broken blade, across centuries, and it lives where all Verdantian knowledge lives, in hands. The shift-master, when I asked how the cutting was done, gave me the same answer the yards at Caelus had given the Mechanicus, though she said it in fewer words: she introduced me to her apprentice.
I asked her whether the miners felt what I felt, standing at the face. She considered the question honestly, which took a moment.
“We were born inside it,” she said. “You are visiting it. It is not the same house to us.”
I held a cut block before we came up. They offered; it seemed discourteous to refuse; and I record, as accurately as I can, that the strangest thing about it in the hand is that nothing about it is strange. It is smooth as riverglass, dark with a dull sheen, ordinary in weight, a stone like the memory of a stone. Everything it does, it does to the world around your hand: the quiet gathers at it, and holding it is like holding the pause in a conversation, and I was glad to give it back, and the shift-master took it from me the way you take a tool from an apprentice, with no ceremony whatsoever.
The consignments go out under the Sisters’ seal. That is the Imperial arrangement: the miners cut, the Ward weighs, the Sisters certify, and the blocks travel to the plateau fields and thence off-world: some of it to Caelus, into the Black Ships rising there, and the rest to destinations my registry renders as a code I have never had the clearance to expand. I audited the weigh-house, which was in a state of accuracy I can only call devotional, and then I stood in the yard and watched the afternoon’s certified consignment, the most strategically guarded mineral in my entire assessment, loaded onto a grav cart and driven off down the orchard road by a girl of about sixteen who was eating an apple, with a Sister of Silence walking escort at the exact pace of the cart, gold and silent among the fruit trees.
As for the classification, I drafted my resolution in the weigh-house that evening, with some pride. The stone is not ore, for nothing is smelted from it. It is not gemstone, building stone, or sacred stone, though I suspect it of being nearer the last than my schedules would enjoy. I entered it as aggregate mineral extraction, strategic: category pending, deploying the single most useful word the Adeptus Mechanicus ever taught me, the filing status that means both we do not understand this and no further questions are expected, and I dispatched my resolution to the sector office feeling that taxonomy and I had fought an honourable draw.
Fourteen months later the sector office corrected me. The classification, their dispatch explained, existed. It had existed for some time. It was sealed under Astra Telepathica authority at a level my commission did not reach, and I was directed to strike pendingand file all tonnage against a designation rendered as a string of characters whose meaning I was not cleared to hold. I complied, with a joy I have never entirely justified. I had believed pending was the summit of Imperial filing. I was a child. Above it, it transpires, sits the category that exists and is itself a secret, so that somewhere at the far end of eight translations, a clerk with clearances I will never possess reads my exact tonnages of a substance whose name I am not permitted to know, and finds them, I hope, very clean.
I walked back out the next morning, and somewhere past the orchards the door passed over me the other way, and the ordinary quiet of a merely silent world came back, and it felt, for the first hour of the flight home, almost loud.
X: The Silence
In the hundredth year of the century I ruled a new annexe form, because the old one had run out of room in the column where I recorded the difference between when things were promised and when things came.
I want to be accurate about how a system dies, because I watched one do it, and it was nothing like the accounts. There was no event. There was arithmetic. The relay logged the translations, and the translations came fewer, and harder, and further apart, and the Navigators came off the incoming ships greyer each year, men and women being asked to read a river that was silting closed. I never learned the pilotage of it; I only kept the columns; but a column is an instrument of perception if you keep it long enough, and mine showed a curve that any clerk on any world could have read. Eleven arrivals in the year of my promotion. Seven, four years later. Then five. Then three.
Nobody used the word decline. The Administratum has a genius for words that hold a fact at arm’s length, and I had spent years admiring it: variance, deferral, rescheduling under route advisement. I filed them all. I knew what I was filing. So, I think, did the sector office, at the far end of a correspondence loop that had stretched from fourteen months to twenty, because their directives began arriving with a certain quality of prepared patience, like letters written to be read by someone the writer does not expect to meet.
In the second year of the new century, the Prefect was recalled to Bakka.
The dispatch requested him by name, for a briefing concerning Verdantia, and I record the detail that struck me at the time and has never released me since: they summoned the man. The Administratum does not summon men. It summons files, and the men carry them. Whatever question Bakka held about this world, it was a question someone wished to ask of a person, in a room, off the record, and Vey read the dispatch twice, and shuttered nothing in his expression, and booked passage on the next departure with the unhurried thoroughness of a man who had been holding a queue for twenty-two years and did not intend to be hurried by the void itself.
I saw him off from the plateau fields. He gave me no guidance on that occasion; he had already given me the only piece he owned. What he said, at the ramp, was: “Keep my window shut. The draught is criminal.” And then he went up the ramp of the cutter, out to the relay, into the last leg of a route that was silting closed, carrying with him the answers to questions I did not know how to ask yet.
The record of Prefect Vey, in every archive I can reach, ends where his ship translated. I asked after him while asking remained possible: a query with each departing ship, addressed to Bakka, in the years when ships still departed. Nothing ever came back. Perhaps the queries never arrived; perhaps the answers never did; the route was dying under both. Somewhere at the far end of eight translations there may be an arrival notice, an onward posting, a death certificate, a pension instruction; there may be a whole file, thorough and signed. I can tell you only that no word of it exists on this side, and that after the seventh year there was nowhere left to even post the question. My record of the man is not wrong. It is complete, and it ends. Those are different things, and I am the last man alive who cares about the difference.
No successor was appointed. Appointing one would have required a form declaring the office vacant, and no one was prepared to sign it, and I understood that too, in the end. We were four senior officers. We ran four offices. We told each other, in the corridor, for five years, that the arrangement was temporary.
The convoys thinned. The consignments stacked in the certified store, awaiting hulls that were awaited. A materiel shipment for the Caelus expansion arrived in 904 with a manifest dated 899, like light from a dead star.
In the sixth year, a Black Ship came, took on the sealed consignments, and lifted. It was the last one. Nobody marked it, because the last of anything is invisible from inside the moment; a last thing is created afterwards, retroactively, by all the things that fail to follow it. I have the departure log. It is nine lines. There is nothing in the nine lines to distinguish that departure from a hundred others, which is, I have come to believe, how everything in this galaxy actually ends: on schedule, unremarked, survived by paperwork.
Then it was the seventh year.
No dispatch announced it. The Imperium does not send a letter saying there will be no more letters; the possibility is not in the form-set. What happened is only this: in the spring a freighter came in, five months past her window, carrying correspondence dated the better part of two years earlier, and among it a directive addressed to Prefect Vey, whom the sector office still believed to be holding his queue. I filed it unopened against his return.
No ship followed her.
I kept the arrivals column. That was all the vigil there was to keep, and I kept it as I keep everything, ruled and dated. The summer passed, and the Custodia’s relay cutters reported the approaches quiet, and the autumn passed, and I ruled the next line, and the winter passed, and I did not use it.
The column for the seventh year is in my registry still, and it is the truest thing I have ever filed. One arrival, in the spring. Then ruled lines, dated and empty, one after another down the page, and nowhere any declaration, because nothing was ever declared. That is what the end of the Imperium looked like from inside it: a column that stops filling. A date the way a door is a wall.
The cutters were still coming off the slips at Caelus. The census was taken in the first month of the year, as it had been for twelve centuries. My assessment remained open, and I maintained it, accurately, for an office that had stopped writing back.
That winter I went into the Prefect’s office, five years shut, to retrieve a register.
I found the register. Then I stood for a while in the cold room, among the filed decades, and I opened the shutter he had kept closed against the canyon for twenty-two years, and the draught came in, and it was criminal, exactly as he had ruled it, and below the window the ways ran on into the black stone, and the morning traffic moved through the light-shafts, grav carts and work crews and children being walked to instruction, all of it going on, and on, and on.
I left the shutter open. It is open still.
XI: The Interim
In the eighth year the Imperium finally sent us a directive. It walked down the hill.
We were four offices by then, and had been for six years, and we had perfected the small liturgy of the corridor: one of us would say when the Prefect returns, or until the route reopens, and the others would agree, and we would go back to our rooms and administer, with genuine care, the local affairs of an empire that had stopped writing. I do not mock this. I was a full participant. There is a kind of discipline in maintaining a fiction that everyone recognises and no one names, and the Administratum trains for it better than any institution in human history, and I have come to believe the training exists because the Imperium runs on exactly such fictions, maintained at every scale, from a corridor to a throne.
She came in the spring, in the morning, unannounced in the way of a person to whom announcement does not usefully apply. The Knight-Centura of the ordu, in full plate, with a single novice at her shoulder: a Verdantian girl of perhaps eighteen, unsworn, whose voice was still her own and was, that morning, also the Imperium’s.
We received her in the records hall, the four of us, because it was the only room with a table of sufficient dignity and because nobody proposed the Prefect’s office, and nobody was ever going to.
She did not sit. She signed, in the spare angular language of her order, small movements at the waist, and the novice rendered it into Gothic with the careful exactness of someone who has been drilled that on this duty she is an instrument and not a participant, and what the Knight-Centura said, through her, was this:
“Contact with the Imperium has been lost. I am the senior Imperial representative in this system. You will report to me until contact is restored.”
That was the whole of it. Three sentences. I have spent my life among documents that take four pages to establish jurisdiction over a grain store, and I sat in the records hall of a silenced world and watched sovereignty over the entire Imperial presence change hands in the time it takes to pour tea, and the thing I felt, and I record it honestly, was relief. Not at the substance. At the grammar. Until contact is restored. Six years we had been saying temporary to each other in a corridor, privately, guiltily, like men passing contraband, and here was the one person on this world with the standing to say it officially, and she had chosen to say exactly that and nothing more. Nothing was conceded. Nothing was declared ended. The fiction we had been maintaining in the corridor was simply promoted, with full honours, to policy.
I want to be precise about what she did and did not claim, because the precision was hers before it was mine. She claimed the Imperial mission: our four offices, the certified stores, the standing instruments of the tithe and the census liaison. She claimed nothing else. Not the Ward, not the yards, not the world; the word Verdantia did not appear in her three sentences at all; and I understood, watching her, that the scope had been measured before she came down the hill, exactly, the way a good officer measures a field of fire. She was not taking a planet. She was taking a post: the last post, and holding it.
Then she divided us. She had clearly read us the way she would read a defensive position, because the division took four sentences and required no discussion: records and the assessment to me; the civil registry and census liaison to the second office; stores, materiel, and the certified consignments to the third; works, the mission’s properties, and the plateau liaison to the fourth. It was not how the Prefect had organised us. It was better, and I say that with some professional pain, because the Prefect had been a friend of mine and a fine administrator, and the Knight-Centura had reorganised his mission in under a minute according to principles I recognised only afterwards as those of someone arranging four soldiers to cover four approaches. She had no appetite for administration. That was evident in every line of her, the flat patience of a person handling a necessary material she does not love. But she knew its worth. You do not hold a fort with soldiers alone. You hold it with rolls and rations and records, and she had grasped, faster than we had, that the four of us were the fort.
The novice read the instrument aloud, once, in full, and I thought of Sarn reading my commission to the last line, seventeen years before, and of everything that habit of thoroughness had taught me since, and then we each acknowledged, and I filed the instrument, and the filing is nine lines, and the ninth line is the word until.
I have thought about that word for longer than any other word in my registry.
An assessment can be finished or accurate; the Prefect taught me that. An arrangement, it turns out, can be provisional or honest, and hers was both, which I had not known was possible. She did not promise contact would be restored. She did not concede it would not be. She built the whole structure of our remaining lives on a conditional clause, and the conditional clause was load-bearing, and it held.
When it was done she inclined her head to us, a precise fraction, and left, and I went to the window of the records hall and watched her go back up through the morning: one gold figure on the citadel road, the novice a pace behind, the forest coming down close on either side, walking unhurried out of the last office of the Imperium toward the only garrison it had left.
We reported to her from that day, and, in time, to her successor. The instrument was never redrafted. The word until served them both.
Contact has not yet been restored.
Register a new account
Sign in
