Shadowtracks Posted August 9 Share Posted August 9 THE EDICT OF BLACK FEATHERS Kephrys, circa 988.M30 I: The Cargo Hold The hold smelled of machine oil and grain dust. Thestus lay in the dark between two shipping containers, his armour’s systems running cold, and listened to the freighter settle around him. The vessel had been in transit for eleven days, following a low-priority freight corridor through the tithe collection circuit at the unhurried pace of a cargo run that nobody was waiting for. He had not moved from this position in nine hours. He did not intend to move for another three. There were six of them in the hold. His second occupied the gap beneath the aft cargo gantry, invisible even to Thestus, who knew precisely where to look. The rest were distributed in the lower tier, each positioned to observe two exit points without being observed from any. Helm-lenses dimmed to nothing. Vox sealed. In every measurable respect, Cargo Hold 5 contained exactly what its manifest declared: eighteen modular crawler tractors, eleven atmospheric haulers, a plethora of crates totalling 12,460 tonnes of assorted agricultural spare parts and the particular silence of a vessel too old and too ordinary to warrant inspection. Thestus had chosen this freighter himself. Not the fastest transit. Not the most direct. The one whose captain filed paperwork that nobody read, whose cargo was never checked because it had never been worth checking, and whose route through the Kephrys system followed the tithe collection cycle with the dull regularity of a heartbeat. The enemy is not looking for what is not there. He is looking for what he expects to find. Give him that, and he will look no further. Corax had said that during reconnaissance cadre induction aboard the Shadow of the Emperor, walking between the kneeling intake like a shadow that had learned to speak. Thestus had been one among many. The instruction had not been meant for him more than for any other. But he had carried it longer than most, and worn it smoother, until it ceased to be a lesson and became the shape of how he thought. The freighter would reach Kephrys within the hour. The docking procedure would take forty minutes. The crew would disembark. The cargo would be processed through the tithe assessment chain. Somewhere in that chain, the manifest would be stamped by a clerk who did not know that the six crates marked as replacement hydraulic components contained nothing at all. Six crates. Distributed access into the subsurface infrastructure. Thestus closed his eyes. Not to sleep. To listen. The freighter’s hull groaned against the void, and beneath it, like the sub-harmonic of a sound too low for human ears, was the particular quality of silence that meant everything was exactly as it should be. He held that silence the way he held his blade, with the certainty that its edge would be needed, and the patience to wait until it was. II: The Scheduled Arrival The Persephone’s Vigil entered the Kephrys system on its scheduled rotation, two days after the freighter. It was a Black Ship. Not a large one: a Vigil-class cutter operating under Astra Telepathica transit authority, one of dozens that moved through the compliance corridors collecting tithes of psyker-potential souls for processing and transport to Terra. Its arrival was expected. Its docking clearance had been filed two months in advance. The port authority at Kephrys Secundus acknowledged the transit clearance without delay. There was no inspection. There was no engagement. The docking corridor had been pre-cleared before the cutter’s approach, and the local officials who oversaw it found reasons to be elsewhere before the ramp descended. The docking seal hissed pressurisation. The temperature dropped three degrees as the port’s atmosphere mixed with the cutter’s recycled air, and the sound changed: the close hum of shipboard systems opening into the deeper, hollow resonance of a docking bay built for vessels twice the Vigil’s displacement. Athelia Veyra walked down the ramp without pausing at the threshold. Kephrys was unremarkable. A mid-tier compliance world: industrialised enough to be productive, bureaucratised enough to be stable, forgettable enough that its tithe assessments were conducted by mid-level Administratum functionaries who rotated through on annual cycles and left no lasting impression. The kind of world that appeared in strategic overlays as a colour-coded dot and was never discussed unless the dot changed colour. Its tithe had changed colour. Not dramatically. Not in a way that triggered investigation through standard channels. The psyker-potential yield from Kephrys had declined by eleven per cent over the preceding three assessment cycles. The numbers were within normal variance. The Administratum had noted the decline, adjusted the projection models, and moved on. Malcador had not moved on. Eleven per cent was not a shortage. It was a diversion. Someone was reaching the psyker-potential population before the tithe collection did, and redirecting them. The yield was declining because the source was being siphoned. And the siphon was invisible to every standard detection method the Imperium possessed, because whoever was running it understood the collection system well enough to operate inside its margins. Behind Veyra, five Sisters descended the ramp in formation. Four Vigilators in gun-metal blue Vratine plate. The surfaces had been treated to kill reflection, leaving the armour cold and flat as deep shadow in the docking bay’s industrial light. At the formation’s shoulder, positioned forward where she could be seen by the cadre lead and by anyone the cadre met: Meren. Novice-Sister. The youngest, the one whose voice still worked because she had not yet taken the Vow of Tranquillity. Meren could fight. She carried a short blade and the foundational combat training of her order, enough to hold ground and to kill with efficiency. The Vigilators behind her carried the heavier weapons of their rank and the deeper precision that years of operational discipline had layered over the same foundational lethality. The difference was refinement, not kind. But Meren had not yet surrendered her voice, and until she did, that voice had a function: rendering the angular precision of Battlemark into spoken Gothic for those who could not read sign. It was a function that belonged to her status, not her identity. She was a Sister first. The voice was provisional. Veyra did not look at her cadre. Their readiness was a condition of their presence. Each wore a suppression torc at her throat, a psycho-reactive band that constrained the null-aura to a working radius. Veyra touched hers as the docking clamps locked. A habitual gesture. The metal was warm from her skin, humming faintly against her fingertips with the contained frequency of the field it held in check. Two days behind the freighter. Separate insertion. Separate authority chains. Separate records. The operation existed in two archives, neither aware of the other, and the whole picture lived only in the space between them. Veyra walked into Kephrys Secundus at the pace she had chosen before boarding the Persephone’s Vigil. She did not hurry. She did not survey. Her Astra Telepathica transit authority preceded her through the port’s processing chain, and those who handled it did so at a distance, passing her credentials forward without meeting her gaze or holding them longer than necessity required. She passed through without leaving an impression on anyone. III: The Probationer The narthecium case weighed four kilograms and sat against the small of Vicente Sixx’s back like a second spine. He checked the instruments inside by habit every four hours. They were always clean. Apothecary-Prime Vorleth had taught him, in the first week of induction, that a narthecium in disorder was an Apothecary in disorder, and that the XIXth Legion did not tolerate the latter. Sixx had been an Apothecary for nine months. The rank was probationary. He wore the white gauntlet on his left hand, the only visible marker of his station, and carried the weight of it with the particular awareness of a man who had spent decades in the Legion without one. He had served under Thestus before the Apothecarion. Three years in Thestus’s reconnaissance cadre, long enough for Thestus to observe his composure under fire, his discipline under privation, and the clinical quality of attention that made him notice things other legionaries filed under acceptable and forgot. Thestus had recommended him for induction. The Apothecarion had accepted. And now Sixx was back in Thestus’s squad, carrying different instruments and a different function, and the lieutenant who had vouched for him was watching to see whether the new role had cost anything the old one had built. Thestus had told him: ‘Rear position. Observe. Stay out of the operational line unless I tell you otherwise.’ The same words he would have given any legionary whose function had changed mid-deployment. Not unkind. Not personal. The judgement of a lieutenant who would not risk an operation on a capability he had not yet verified in the field. Sixx had accepted without argument. Thestus was not wrong. The narthecium changed what a man noticed, what he prioritised, where his attention went in the first seconds of contact. Whether it had also changed Sixx’s instinct for ground and geometry was the open question, and only the operation would answer it. He would provide the answer, or he would not. The data would present itself either way. IV: Two Lenses Five days after the freighter docked, three days after the Sisters landed, the two elements initiated direct integration. They had not met. They had not communicated directly. The dead-drop protocol (physical message points in the subsurface infrastructure, checked on rotating schedules that never overlapped) had established the integration point: a disused water processing facility beneath the industrial district’s tertiary waste management level. It was a place that existed on maintenance schematics but had been marked as non-functional for six years. Nobody went there. Nobody thought about it. It smelled of mineral deposits and old metal, and the only sound was the distant pulse of the active systems three levels above. Thestus arrived first. He swept the space with the thoroughness of a man who did not trust environments he had not personally cleared, found it acceptable, and took a position that placed his back to the wall and his sightlines on both entry points. They came through the eastern access. Six figures moving with a quality of silence that was not his. Not the silence of a predator in controlled descent, every footfall placed and every movement governed by the discipline of the hunt. Something else. Something that belonged to the space around them rather than to the figures themselves, as though sound chose not to carry in their proximity. His autosenses resolved them without difficulty. Six women in gun-metal blue Vratine plate, surface-treated to flatness, moving in a formation he did not recognise but whose discipline he did. The lead carried herself with the economy of a commander who has no need to signal authority because authority is simply the condition she occupies. There was something else. Faint. At the edge of perception. Not a pressure, not a sound, but a quality. A thinning. As though the air in the facility had become fractionally less substantial in a way that had nothing to do with atmospheric composition. Thestus noted it the way he noted all environmental data: precisely, without reaction. The torcs were doing their work. Veyra stopped four metres from him. Inclined her head. Not a bow. An acknowledgement between professionals who did not yet know each other but recognised the quality of what they were looking at. Behind her: four Vigilators, flanking. Meren slightly forward. Meren spoke first. Her voice was low, clear, and carried the precision of someone who understood that every word she produced in this space was a concession to necessity. ‘Vigilator Pursuivant Veyra. Lieutenant Thestus. The integration point is confirmed. I will translate for the Vigilator Pursuivant during the planning phase.’ Thestus nodded. ‘Understood. We have five days of physical intelligence. Handler routes, convergence points, temporal patterns. The picture is incomplete. We need the other lens.’ Veyra’s hands moved. Thoughtmark. The gestures were close to her body, barely visible: small shifts of finger spacing and wrist angle, fluid transitions that an untrained observer might not have recognised as language at all. Where Stalk-Argot carried meaning in finger movements and closed fists, Thoughtmark carried it in timing, in the precise distance between one gesture and the next, in subtleties that made the signer appear almost motionless while communicating everything. Meren translated: ‘The Vigilator Pursuivant concurs. Her cadre has mapped the disturbance pattern across the tithe processing chain. Two days of observation. The picture from our side is also incomplete. She proposes overlay.’ Thestus looked at Veyra. She held his gaze, the directness of someone who communicates through a language that requires eye contact to initiate. ‘Agreed,’ Thestus said. ‘Show me what you have.’ It took three hours. Thestus laid out the physical intelligence his squad had gathered over five days of subsurface observation: handler movement patterns, route convergence points, temporal clustering of disappearances within the tithe processing chain. The data described a network that operated inside the Administratum’s own logistics framework, using the movement of tithe-assessed populations as cover for a secondary extraction pipeline. Psyker-potential individuals were being identified before Imperial collection, diverted through a subsurface route network, and moved to a location that the physical data alone could not resolve. He had mapped the body of the network. He could not map its mind. Veyra’s cadre provided the other lens. Where the Raven Guard read movement, route, and timing, the Sisters read disturbance. Repeated psychic activity left residual interference perceptible to trained nulls, marking where something had been drawn upon and not fully settled. The Sisters had spent two days mapping these disturbances, identifying the points where the absence pattern deviated from the physical picture. The deviation was the siphon. Meren translated as Veyra’s observations were laid against the physical data. The two pictures overlapped. The physical convergence points matched the disturbance signatures. The subsurface routes aligned with paths where the absence pattern showed repeated interference, places where something had passed through and left the local psychic environment temporarily flattened. And at the centre of both pictures, like the point where two trajectories resolve into a single target: a location. Subsurface. Deep within the industrial district’s abandoned tertiary level. Accessible through three routes the physical data had identified and one that only the disturbance pattern revealed. Sixx watched from the rear of the space where Thestus had positioned him. He saw the two data sets converge and felt, for the first time in his probationary career, the sensation of watching something that had not existed before come into being. Not the target. The method. Two forms of perception, each incomplete alone, producing a picture that neither could have assembled without the other. He made a note of it in his clinical shorthand. It seemed important, though he could not yet say why. Thestus looked at the overlay for a long moment. Then he looked at Veyra. ‘Yes,’ he said. A single word. It carried everything that needed carrying. Veyra inclined her head. The rest was execution. V: The Envelope They moved through the subsurface as a single formation for the first time eighteen hours later. The approach route followed the deepest of the three physical paths: a maintenance corridor that had been sealed eight years prior when the tertiary level was decommissioned. Thestus’s squad had opened the seal without leaving evidence of entry, re-closing it behind them with the patience of people for whom concealment was not a step in the process but the process itself. The corridor was dark. Cold air pooled in the lowest sections where the environmental systems had long since failed, carrying the mineral taste of exposed rock and the faint chemical trace of corroded sealant. The Raven Guard moved through it in the pattern they had refined across decades of guerrilla warfare: across compliance actions on a hundred worlds, across the endless rehearsal of what the Legion was. Patient. Silent. Methodical. Each legionary maintained spacing precise enough to support the man ahead without crowding, loose enough that a single blast could not take more than one. Armour running cold. Vox sealed. Communication in Stalk-Argot only, the angular field-sign of Raven Guard stealth operations, voiceless and precise. The Sisters moved with them. Their silence was different. Not the silence of a predator in controlled descent, every footfall placed and every movement governed by the discipline of the hunt. Something else. Something that belonged to the space around them rather than to the figures themselves, as though sound chose not to carry in their proximity. Something more absolute. The silence of a space from which a fundamental property had been quietly removed, leaving the air thinner and the dark deeper and every sound that persisted somehow lessened by what was no longer there. Five hundred metres from the target location and two levels above, Thestus halted. The signal passed back through the formation in heartbeats: a closed fist, held at hip height, and the subtle redistribution of weight that told every legionary behind him that what came next would be different from what had come before. He looked at Veyra. She stood four paces behind him, her cadre at her back, Meren at her shoulder. Veyra raised her hand to the torc at her throat. The suppression field collapsed. Not gradually. All at once, like a seal broken on a chamber that had been held under vacuum. The null-aura expanded outward from the six Sisters in a wave that had no sound, no visible effect, and no physical analogue that any training had prepared for. The world became quieter. Not in frequency. Not in volume. In something deeper, something that existed beneath the architecture of sound, beneath the electromagnetic spectrum, beneath every measurable phenomenon. The warp-presence that existed in all things, the faint background resonance of the Immaterium pressing against the material universe: gone. Extinguished. As though it had never existed. The envelope. Sixx’s autosenses registered the change as a cascade of micro-adjustments. His secondary heart maintained rhythm, but the beat altered: a fractional irregularity that corrected within seconds. His sus-an membrane pulsed once, as though confused by a threat stimulus it could not categorise. His Lyman’s ear registered a sub-auditory pressure drop that had no physical source. He recorded all of it. Heart rate variance: 0.03 per cent deviation, corrected in 4.7 seconds. Ocular response: pupil dilation consistent with low-light adaptation, despite no change in ambient illumination. Neurochemical profile: elevated norepinephrine, consistent with threat response, declining to baseline within eleven seconds. Eleven seconds. That was how long it took a fully enhanced Astartes to adjust to the null-field. Eleven seconds of a body rewriting its own responses because something it had never been designed to notice had suddenly been taken away. Five of the six settled within the window. Sixx watched their biorhythmic signatures stabilise in sequence: heart rates finding their corrected cadence, autonomic responses returning to operational norms. The fifth to settle was Thestus himself, whose adjustment registered as a single controlled fluctuation and nothing more. The sixth did not settle. The readings came from forward-left of the formation. A veteran, one of the squad’s longest-serving. His heart rate corrected, then spiked again. Corrected. Drifted. His norepinephrine remained elevated past the eleven-second mark, declining in an uneven curve rather than the clean drop the others showed. Not a crisis. Not incapacitation. But a pattern that did not resolve the way the others did: a body finding something to manage rather than something to absorb. Sixx noted it. He did not name the legionary. He recorded the variance and moved on, because the formation was moving, and the data would be there when the operation was done. The sensation never became natural. Only manageable. But Sixx watched. And what he saw, what he would not fully understand until much later, was that the adjustment was not merely physiological. There was something in the way Thestus and the four who had settled moved inside the null-field after those eleven seconds. A tension they had carried without knowing it had been released. They were not diminished inside the envelope. They were quieter. VI: The Breach The target was a chamber carved from the bedrock of the industrial district’s deepest level, a space that had been a water cistern before the tertiary infrastructure was decommissioned. It had four exits. Three were the physical routes Thestus had mapped. The fourth, the one only the disturbance pattern revealed, was a concealed passage beneath the primary coolant line, accessible through a maintenance hatch that had been welded shut from the outside and then unsealed again from within. The welds were recent. The passage was in use. The organiser was inside. The disturbance data confirmed it: a concentrated interference at the chamber’s centre, surrounded by the flat, suppressed signatures of people conditioned to mask their own presence. The organiser’s defence had never been force. It had been foreknowledge: the ability to sense the approach of any conventional search the way a spider feels vibration on a web, to feel the psychic displacement of incoming forces, and to relocate before the search resolved. Inside the null-field, there was nothing to sense. The search had become invisible because the searchers had ceased to exist in the medium the target was watching. The formation split at a junction two hundred metres short of the chamber, where the maintenance corridors diverged around the cistern’s original drainage infrastructure. Thestus took the primary element east: four legionaries, Sixx, and two Vigilators. Veyra took the concealed passage approach with her remaining two Vigilators. The coordination was a synchronised count. No vox. No signal. A shared time-mark set during the briefing, precise to the second. Both elements would breach simultaneously. The null-field would hit the chamber from two vectors at once. Thestus positioned his element at the eastern entry. Two legionaries covered the aperture. Two more stood ready to move through and seal the adjacent exits the moment the breach began. Sixx held rear position. The two Vigilators flanked the entry point, their null-aura already pressing into the chamber’s edge. On the far side of the cistern, Veyra waited in the concealed passage. The passage was narrow enough that a single Witchseeker Pursuivant in full Vratine plate could hold it. Her null-aura, unshielded and focused at that range, was not a barrier. It was a negation: the removal of the medium through which the target’s only weapon functioned. Meren remained with Thestus’s element. The final coordination had already passed. There was nothing left to translate. The count reached zero. Nine seconds. The breach was simultaneous across both entry points. Thestus’s element entered from the east. The chamber’s interior resolved in the green-white of autosense amplification: stone walls, equipment benches, eleven people caught in the posture of those who have been interrupted and have not yet decided whether to fight or flee. The two reserve legionaries moved immediately, crossing the chamber to seal the remaining exits. Nine seconds from entry to full containment of all four points. The organiser was at the centre. A woman. Slight, dark-haired, wearing the administrative robes of a mid-level tithe assessor. Her hands rose, not in surrender. The reflexive gesture of a psyker reaching for the only weapon they possess. She reached for the warp. The warp did not answer. The look on her face was not fear. It was incomprehension. She reached for a faculty that had defined her existence and found nothing. Not resistance, not suppression, but absence. She turned toward the concealed passage. Instinct. Veyra was already there. The null-aura at four metres hit the organiser with the force of a sensory obliteration. Her psychic reach collapsed: her only defence, her only means of detection, the faculty that had kept her network invisible for three assessment cycles. The handlers recoiled. Baseline humans inside a null-field of that magnitude lost coherence before they could form resistance. Cognition fractured. Instinct dissolved into a formless withdrawal, a flinching away from an absence their minds could not name or navigate. They did not fight. They could not. The world they had relied upon to organise thought and response had been quietly removed, and what remained was not enough to sustain either. No weapons discharge. No alarm. No withdrawal required. And in the nine seconds of the breach, Sixx had done something that Thestus did not notice until afterward. The two legionaries sealing the far exits had moved through the chamber on a line that left a blind angle at the junction between the eastern entry and the adjacent drainage channel. The angle should have resolved as the legionaries reached their positions. For approximately three seconds, it did not. The geometry opened for a body’s width toward an uncontrolled sightline. Sixx read the geometry in the first second. He saw the angle. He saw the gap. And he moved to it. Not forward into the operational line, not across anyone’s field of fire, but laterally, along the wall, to a position where he covered the blind angle with his body and his bolt pistol. He had not been told to do it. He had not asked permission. He had seen dead ground and filled it, because the gap existed and gaps are filled. No one came through the angle. The operation did not require his intervention. He held the position for three seconds until the reserve legionaries locked their exits and the geometry resolved. But when Thestus conducted his post-action sweep, his gaze found two things. Sixx at the junction. And the legionary whose movement line had left it open. He paused. Half a second. Perhaps less. Then he moved on. Sixx did not know the pause had happened. He was already recording physiological data from the collapsed organiser: loss of motor coordination, autonomic shutdown, a neurological collapse his narthecium classified as acute sensory deprivation consistent with sudden loss of a primary perceptual faculty. The breach, from initiation to full containment, lasted nine seconds. Sixx recorded the duration with the same clinical precision he recorded everything else, and noted that nine seconds was not the remarkable datum. The remarkable datum was that inside the null-field envelope, with both elements operating as a single integrated force from two approach vectors, the capture had belonged to no one element. The Raven Guard had controlled the approach. The Sisters had defined the boundary. The breach had been executed by both. The target’s neutralisation was the product of the envelope and the insertion operating as components of a single mechanism. He had never seen that before. He was not certain anyone had. VII: After The subsurface facility was cleared in forty minutes. The psyker-potential individuals who had been diverted from the tithe were accounted for: seventeen, held in a secondary chamber off the main hub. Thin bedding on a stone floor. A single water reclamation unit, military surplus, scratched with tally marks along its housing. The conditions suggested processing rather than captivity, but the tally marks said that someone had been counting the days. The organiser was secured for transport. The handlers were neutralised. The extraction protocol was compartmentalised, as the insertion had been. Veyra’s cadre would return the diverted psyker-potential individuals to the tithe flow through the Black Ship’s standard collection process. From the Administratum’s perspective, the yield anomaly would self-correct over the next two assessment cycles. Thestus’s squad would withdraw through the subsurface and depart via the same cargo traffic that had delivered them. No evidence of forced entry. No evidence of Imperial military action. No record that connected the Raven Guard presence to the Sisterhood presence. From the outside, Kephrys had never failed. The network had simply stopped functioning, for reasons that no surviving member could explain. They were in the tertiary maintenance corridor, the same corridor where the envelope had first expanded. The operation was concluded. A brief combined debrief, conducted in the corridor while the details were immediate. Each element would file its own detailed review separately, through its own chain. Before Thestus’s squad withdrew back into the subsurface routes, Sixx sealed his clinical notation for transmission through secure XIXth Legion channels. The Sisters had re-engaged their torcs. The null-field had contracted to its contained radius, and the background presence of the warp had returned to the edges of perception like a sound one only notices when it stops and then starts again. Thestus and Veyra were standing four metres apart. Meren was nearby, though her posture said she was present as cadre rather than as voice. Thestus looked at Veyra. Then his hands moved. Not Gothic. Not speech. His fingers formed a sequence that began in Stalk-Argot and then shifted. The grammar opened. The hand positions changed into something that was not quite Stalk-Argot and not quite Thoughtmark, but occupied the space between them: fragments of two sign languages that had never been asked to speak to each other, assembled in real time by a man who had spent three hours watching the other language work and had taken enough of its shape to use it. The torc. Inside the formation. It reduces the envelope. Sixx saw it from his position. He could read Stalk-Argot as fluently as any legionary in the cadre. Thoughtmark was closed to him. But he could see exactly where Thestus’s hands departed from the familiar signs into something he could not follow, and he saw the effort that transition cost. Not emotional effort. Technical. The concentration of a man building a sentence in a language he does not speak, using the parts he has observed and trusting the recipient to read intent where grammar fails. Veyra was still. Not the stillness of surprise. Not consideration. The stillness of a commander receiving an operational assessment from a quarter she had not anticipated. The torc constrained the null-field to a radius that permitted coexistence with unshielded humans. Inside a formation that had already adjusted to the full envelope, that had operated more effectively inside it than outside it, the constraint reduced capability. Thestus was not speaking about comfort. He was speaking about function. Veyra looked at him. Then she raised her hand to the torc at her throat and touched it, the same gesture Sixx had watched her make before releasing the suppression field in the approach corridor. The confirmation that it remained sealed. She did not remove it. Not then. The gesture was acknowledgement, not action. The adjustment would come later, in stages, as the Edict operations continued and the operational data accumulated: the kind of doctrinal adaptation that is not decided but discovered, through repetition, through evidence, through the slow demonstration that a cost absorbed by both elements produces a capability available to neither alone. Sixx recorded the exchange in the margin of his clinical notation. He recorded it as a datum: the formation’s senior elements had identified the suppression torc as an operational constraint during integrated deployment. He did not record what it meant, because he did not yet know. He sealed his case. VIII: Two Archives The operation’s records were filed through separate chains within the week. Thestus’s report was sealed for Corax’s personal review. It described an interdiction operation conducted against a psyker-extraction network operating inside the Kephrys tithe system. Method: subsurface insertion via civilian cargo traffic. Duration: eight days including observation phase. Result: network neutralised, tithe flow restored, zero Imperial signature. The report noted that operational success had been achieved in coordination with a specialist partner element operating under separate authority, whose specific capability had proven essential to target resolution. The partner element was not identified by name, affiliation, or mandate. Their capability was described only as ‘complementary detection methodology not available to XIX Legion assets.’ Veyra’s report went through the Sisterhood’s secure chain. It described a psyker-tithe recovery operation conducted under Astra Telepathica authority, utilising standard Black Ship collection protocols augmented by direct field investigation. Duration: five days. Result: seventeen psyker-potential individuals recovered and reintegrated into the tithe flow. The report acknowledged that the recovery had been facilitated by a partner force whose insertion and interdiction capability had enabled access to a target location the cadre could not have reached independently. The partner force was not identified. Their methods were described only as ‘specialist subsurface insertion beyond Sisterhood operational scope.’ Neither report was false. Both were incomplete. But both, read carefully, said the same thing: we could not have done this alone. No complete operational account survived within any one archive or registry accessible to a single authority. It existed in the bodies and the reflexes of the people who had been in that corridor. In the eleven seconds of adjustment that would be shorter next time. In the fragments of two sign languages that a Raven Guard lieutenant had assembled because the operation had made the gap between them too narrow for a voice to be necessary. In the clinical notation of a legionary who had recorded data that did not yet have a category, and who carried it in a sealed case alongside instruments that were always clean. Sixx did not know what the data meant. He did not know that it was the first empirical record of what would become, over years and decades, the foundation of something that had never existed before: a formation built from two traditions that had no precedent for integration except the one precedent that mattered. They had operated inside the same envelope, and the capability it produced justified every cost it imposed. He sealed the case. And he waited for the next operation to provide more data. The Edict of Black Feathers continued. Akum-Sothos would follow within the year. The corridor beneath Kephrys would be remembered by no one who was not there. This is how things begin: not with declarations, but with the quiet demonstration that a method works. That is the only foundation that holds. The Velleth Silence A Shadow Talons narrative The Veiled Region, circa 994.M30. Six years after Kephrys. I: The Approach Sixx had learned to know a warp-touched world by the taste of its air. The helm’s samplers drew the atmosphere in. The auto-senses rendered the analysis the way his training had taught him to read it, as flavour, laid across a tongue the air itself never touched. The smell told him nothing he did not expect. Rock dust and coolant, the animal warmth of too many people held too long in too little room. The sweet rot of a reclamation plant that had failed a season ago and been left to fail. The taste lay underneath all of it. A thin bright wrongness on the back of the tongue. The flavour a place took on when something had been reaching into it long enough to mark everything it touched. He had tasted it on world after world since Kephrys. He tasted it in the ore-galleries beneath the Velleth hold now, and his body did with the knowledge what it had been remade to do, which was nothing. He could measure the change the years had worked in him, if he chose. On Kephrys he had counted the eleven seconds. Every legionary counted his own, the first few times, and no two counts ran quite alike. Eleven seconds of a body arguing with a silence it had no organ to understand, the null-field of the Sisters pressing on senses built for a galaxy full of small background noise and finding, all at once, none. He had counted them then the way a man counts his own pulse to be sure of it. He did not count them now. The envelope had come up an hour ago, out beyond the loading throats where Thestus wanted it. Sixx had stepped into the clean silence of it the way a man steps out of weather into a room. The wrongness of Velleth stopped at the edge of the field. Inside it there was nothing at all. It had never become natural, and he had stopped expecting it to. It had become a tool. The work went better inside it than outside it, and so he had learned to work inside it, the way a man learns any hard instrument: not loved, used. The torcs had gone on at the airlock. That was the measure of six years, if he wanted one. On Kephrys the suppression torcs had been a permanent condition, a courtesy the Sisters extended to a galaxy that could not bear them. It had taken a full operation, and Thestus’s flat assessment at the end of it, to name the band at each throat for what it was inside the formation — a constraint. Since then the cadre went unbound among the squad as a matter of course. The torcs lived with the wargear. The silence the Sisters carried was allowed its full reach because the men it fell upon worked better inside it. Tonight the torcs had come out. The approach ran beneath ten thousand sleeping people, and a null the size of a cadre walking unbound through the roots of the hold would have moved through those sleepers like cold water through a wall. Enough of them would have felt it. One of them, the one who mattered, would have felt a wrongness he could not have named. So the field walked on a leash tonight, its radius held to a dozen paces. The leash would come off when Veyra decided it came off, and at no other moment. Mission parameters. Thestus’s phrase, six years old, become doctrine without anyone writing it down. Twelve of them moved through the dark, and the field moved with them. The squad entire, Thestus, Sixx, and the other four Raven Guard. The cadre entire, Veyra and her five, Meren at her shoulder. One file inside one silence, two Sisters walking ahead and two behind, the legionaries interleaved along the leash’s reach. Sixx near the centre with the narthecium cold against his spine, reading the walls the way Thestus had taught him years ago to read them — the wear of boots, the age of a weld, the direction a frightened people had last been driven. Above, through a half-level of rock, the hold held its thousands. Somewhere in it was the man they had come for, and the whole shape of what he was could be read in the composition of the force sent to end him. He had begun to reach into the warp, and so the Sisters had come, because no one else could stand in front of him. He had made himself beloved, and so the removal had to be silent, because a beloved man taken from his people in the open does not die. He becomes a story. A story travels faster than a Black Ship. The Edict existed to end such men before anyone beyond their own rock ever learned there had been a man to end. He had made himself an army, and that was why the Raven Guard had come. Two hundred armed men must be taken all at once, in the dark, at the root, with a condensed weight of firepower and elimination no other force could deliver at a size the galaxy would never notice. The Sisters could reach him where nothing else living could stand. They could not silence a garrison in a single watch. The Raven Guard could silence the garrison. It could not cross the last hundred metres to a mind that would feel it coming. Tonight existed in the overlap. Either half alone left a story alive. Both together left rock. Veyra walked the forward edge of the field, where the clean silence met the taste of the world. She wore the same gun-metal blue she had worn since Kephrys, the Vratine plate surface-treated to kill reflection, cold and flat as deep shadow. The Chamber of Oblivion had not changed her armour when it took her. It had changed what walked in it. Sixx had watched the change arrive across six years and a string of worlds, not as a transformation but as a settling, the way a blade settles into a grip that was always the right size for it. She commanded the cadre in her own right now. The order had put its highest word on her. The word had simply confirmed a fact the squad had operated on since the first week. He had learned to read her the way he read the walls. The two fingers she laid to the torc at her throat, a single deliberate check of the clasp. The tilt of the head that was acknowledgement and nothing else. The particular quality of her stillness. He had once mistaken it for the absence of anything behind it. He knew better now. There were two stillnesses. One meant she had nothing to say. The other meant she was holding something. The difference between them was smaller than the thickness of a blade’s edge, and he had learned to see it anyway. She stopped. The field stopped with her. Her hand came up, close to her body, and moved once. Ahead, a grille stood in the gallery wall where the ducting climbed toward the living floors, and through it, faint through rock, came the first sound Sixx had heard in an hour that the field did not swallow. A voice. Many voices. A hold full of people, up in the light, singing something with one throat. II: The Overlay The vantage was a maintenance gantry above the hold’s grand gallery, behind a lumen housing that had been dark for years. Thestus had chosen it from the survey data before they made planetfall, and it was exactly what the data had promised. The eyes that had walked it first had been the Sisters’ own; a null moves through a watched place as an absence the watcher forgets, where six legionaries would have been felt the moment they left the silence. A black shelf over a lit world, with sightlines down the full length of the gallery, and an exit into the ducting that two hundred years of hold-life had forgotten existed. Sixx lay at the shelf’s edge between Thestus and the Sister called Ivenna, and watched a world that worked. The working was not the wrongness. Working was what a hold did. The wrongness was that this one should not have been able to, and it did. He had been made for war of every kind, and the feathers had trained him for the deviance that announced itself: the flayed shrine, the mob, the hunger that stopped pretending. This kind the feathers had never named. The grand gallery of the Velleth hold was clean. The people in it were fed. They moved through the evening concourse with the unhurried competence of a community that trusted its own systems. The singing that rolled up the gallery from the shrine mouth at its head was in tune. The children being carried home along the margins were asleep on shoulders. Every lumen in the vault was lit. Three years of tithe records said this hold should not exist. Velleth’s seam had been dying for a generation. The survey data showed a population that should have been halved by emigration and was not, rations that should have thinned and had not, an infirmary that logged a tenth of the deaths the actuarial tables demanded. Twice now, the Black Ships had come for the tithe of the touched and gone away empty. The paperwork had been perfect. The candidates had simply not existed. Two cycles, no yield, no unrest, a compliance record without a flaw in it. A place could be sick in the direction of health. That had taken Sixx years to learn. The overlay taught it to him again now, laid out below him in lamplight. Ivenna watched the shrine mouth without moving. She had made one gesture in an hour, before they bellied onto the shelf — her thumb drawn once along the flat of her greatblade where it lay scabbarded against her side. An old smith’s habit, Meren had told him on the transit years ago, from a forge-clan world where you checked the temper of steel before you trusted your weight to it. The blade had never once failed her. She checked it anyway, every descent, and Sixx had come to find the gesture steadying in the way of all honest rituals. Meren knelt at Veyra’s shoulder, a pace back from the edge. Six years had thickened the novice into a veteran of everything except the Vow itself. Her voice remained. The order had weighed the Edict’s need for a tongue against the age of its custom and granted the deferment, and Meren carried the dispensation the way she carried everything, as a duty with a term. Below, the singing ended. The crowd at the shrine mouth did not disperse so much as settle, the way iron filings settle when the magnet under the paper stops moving. A man came out onto the shrine steps. Sixx’s autosenses resolved him at four hundred metres: a man in a processor’s coverall, gone grey at the temples, work-thick through the shoulders, no mark of office on him anywhere. He raised no hand. He wore no sign. He walked along the front of the crowd and touched the people nearest him on the arm or the brow. Where he touched them they straightened. A woman who had been carried to the steps on a pallet stood up off it and wept into her hands. The crowd made a sound that was not a cheer. It was lower than a cheer. It was the sound a people makes when it is grateful in a place beyond performance. Beside Sixx, the readings on his own instruments stayed flat and meaningless. Inside the leashed field there was nothing to read. That was what the second lens was for. Veyra had gone to the far end of the shelf, past the reach of her own cadre’s torcs, and knelt alone at the field’s edge with her head bowed. What she was doing there had no instrument and no name that Gothic would carry. She was listening with the thing she was. A null does not sense the warp. A null senses what her absence does to it, the shape of the hole she makes, and a Sister of Veyra’s strength could read the disturbance an active mind pressed against her own negation the way a submariner reads depth against the hull. She knelt there for thirteen minutes. When she rose she stood for the length of one breath with her hand flat against the rock, the way a diver stands when the depth has come up with her. Then whatever it was had been put away. She came back down the shelf and her hands began to move. Meren’s voice, pitched under the crowd-sound, rendered the angular precision of Thoughtmark into words. ‘He is not a witch who has taken a hold. He is a hold that has grown a witch. She says the reach of him is in everything. The lumens. The rationing. The infirmary. She judges a binding laid through the population, light on each of them, thousands of threads. He does not command them. He carries them. They love him because the binding is made of the benevolence. It is the same structure.’ Thestus watched the man on the steps. ‘The tithe candidates?’ Veyra’s hands moved. ‘Below,’ Meren said. ‘Under the shrine. Alive. He wakes what the Black Ships would have taken. She reads the press of them — more than two or three would give, fewer than a score. A choir.’ ‘Assessment.’ The pause before Veyra’s hands moved again was the second stillness, the one that held something. ‘Alpha,’ Meren said. ‘At the least. She has stood before one alpha. She says this one is stronger and kinder, and the kindness is the more dangerous of the two, because it is true.’ No one on the shelf spoke for a moment. Below them the man on the steps had crouched to take a child’s hand, and the child was laughing. Four hundred metres above him, twelve killers and the instrument of his erasure lay in the dark and watched him be gentle. Sixx set it down in his clinical notation later, in the flat language the record demanded, and the flat language held it the way a stretcher holds a man: Target presents as benign. Benignity assessed as load-bearing structure of the anomaly. No malice observed. Malice not required. The picture assembled itself the way it always did, both lenses laid one over the other until the depth came. A dying hold that a dying man had refused to let die. A gift that had arrived in him late and enormous, and that he had spent, as far as either lens could show, entirely on his own people. Grain that stretched. Wounds that closed. A seam that kept yielding past the geology. Ten thousand people who had stopped being afraid. A binding through all of them that grew a thread at a time, love-shaped. It had already crossed the line past which the man could not have unmade it even if he had wished to. He did not wish to. Beneath the shrine, a choir of stolen sparks being fed and taught and kept from the Ships. Two cycles of yield the Ships had never taken — nine, by the tithe arithmetic, and the pressure Veyra had read said the arithmetic was right. In three years, or five, a reach that would cross the void to the next hold, because it had crossed every other line drawn in front of it. In ten, the Veiled Region would have a saint. Sixx had read the histories that the Legion did not circulate. He knew what the Imperium did to the worlds of saints, and what it cost. He knew how the stories ran ahead of the burning like rats ahead of water. Each retelling seeded the next man like this one. The fire made the thing it fed on. That was the arithmetic of the Edict, and no part of it required the man on the steps to be anything other than what he visibly was. Thestus’s hands moved through the plan at the fall of the third watch. Stalk-Argot and Thoughtmark ran interleaved along the shelf now with barely a spoken word between them. No Battlemark — the broad field-signs were cut to carry through smoke at a hundred paces, and nothing the Edict did happened at a hundred paces. This work was close and quiet and asked for the small register, meaning held in timing and in the spaces between, signs a sentry three metres off would never have seen. Six years of shared grammar did the work that Kephrys had needed a translator standing in the killing space to do. By the fourth watch the hold was asleep. Every night, in the fourth watch, the man went down alone below the shrine to sit with his choir. The squad would take the garrison armoury and the vox in the first minutes, and then the barracks galleries, in the dark, all at once. Two hundred armed men who had taken the man’s coin and the man’s creed. Condensed violence, delivered once, to the root. The cadre would take the shrine stair and the space below it. The silence, walking down to the man nothing else living could stand before. The split was the plan’s one exposure, and Thestus’s hands did not hide it. Outside the field, the Raven Guard could be seen. Not by eyes. By him. A mind that read ten thousand sleepers could read six legionaries the moment they left the silence. The assessment said he would not be looking. He kept no watch. His gift lay woven through the binding, not standing guard over it, and each night he went below to a sanctuary he believed no one living knew. If the assessment was wrong, the plan still held. Six Astartes falling on an armoury read as a plain attack, iron against iron. His attention would go up, toward his people. The cadre would come down the shrine stair beneath it, inside a silence he could not see into. The Raven Guard were the strike. If it had to be, they were also the lure. The charges Thestus’s squad, each man paired to a Sister whose silence hid him from the mind above, had spent the previous night seeding through the exhausted workings under the shrine district would take the rest: the chamber, the evidence, the story. Velleth would wake to a seam collapse in the old galleries, a night of grief with rock dust in it, and a man who had gone below one evening and not come up. Rock takes whom it takes. There would be no body to raise a shrine over, no wound to point at, no soldier seen, no Imperial boot on record within a system’s breadth of the hold. Within a year the extraordinary would have run out of the place like heat out of stone. The tithe would resume. The assessment cycle would note the correction of an anomalous decline, and move on. Erasure was the whole of the product. The kill was only its first component. Sixx watched Veyra while Thestus’s hands walked the cadre through the shrine stair timings. She was looking down the gallery at the far lit steps, at the small grey figure now sitting on them like any tired workman at the end of shift, letting the last of the crowd bring him their days. Her face held nothing he could read easily. Six years ago he would have called it nothing at all. Now he caught the small tell at the corner of her mouth, held for a breath and put away, and knew only that there had been something to put away. Her hands, when she answered Thestus, said only: Agreed. The fourth watch. III: The Shrine Mouth They came into position an hour before the strike, and the waiting began. The space below the shrine had been a pump gallery once. The hold had rebuilt it across three years into something between a sanctuary and a school: nine sleeping alcoves cut into the old machine bays, a long table, shelves of salvaged books, a floor swept so often it had gone smooth. Lumen-strips turned down to ember. It smelled of recycled air and stone and, faintly, of bread. The cadre held the dark at the gallery’s inbye end, past the reach of the ember light, in the total stillness that was the Sisters’ resting state. Sixx was learning it still, after six years. A legionary’s stillness was a discipline laid over readiness. Theirs was something else, a stillness that went all the way down. Waiting inside their leashed silence in the dark of a sleeping sanctuary was the loneliest work the Edict asked of him. He passed the hour the way the Apothecarion had trained him to pass all hours, in inventory. The narthecium’s loadout, checked by touch. The element’s biometrics, five steady green threads on his retinal feed from the galleries above, where Thestus lay against the armoury and the barracks like a held breath. The cadre had no threads to give him. His instruments, when he turned them on the six women, read six ordinary human returns, mass and heat and breath, nothing a machine could find remarkable. The absence was not in the readings. It was in him, in the sense the Legion had no name for. He had long ago stopped finding that strange. That was itself the datum he had never put in any report. Ivenna knelt nearest him, at the edge of the choir’s ember light. Her thumb moved once along the flat of her greatblade. Movement at the gallery’s far end. The stair door. Slippered feet on old iron. The man came down into the ember light alone, carrying a covered bowl in both hands like an offering or a supper. Nine sleepers stirred in their alcoves at his coming, the way children stir at a parent’s tread, half-waking into safety and going deeper down. He set the bowl on the long table. He straightened the blanket over the nearest sleeper. He sat down at the table’s end with his back to the darkness, tore the bread, and began, quietly, tiredly, in a workman’s under-the-breath murmur, to sing to himself the song his hold had been singing to him five hours before. Veyra’s hand rose to the torc at her throat. Sixx had seen the gesture a hundred times as confirmation. He watched it now become the other thing. Down the line of the cadre, five more hands rose in the same movement to five more throats, and there was a beat of perfect suspension, the whole gallery balanced on the pin of it. The torcs released together. There is no sound when a suppression field collapses. Sixx felt it as he always felt it, as an enormous soft concussion of nothing, the leashed silence standing up to its full height all at once. The ember light did not flicker. The air did not stir. Every thread of a binding woven through ten thousand sleepers, every wall the man had ever raised, every reach and gift and grace of him, went out like a lamp in deep water. At the table, the singing stopped. The man sat very still with the bread in his hands. Then he turned on the bench, without haste, and looked into the darkness at the six shapes it held, and Sixx watched him understand. Watched the understanding go through him in one long wave — what the silence was, what it meant that it was here, what stood inside it, and what could not now be reached for. The whole architecture of three years fell out of the world between one breath and the next, leaving a grey workman on a bench with bread in his hands. He looked at the shapes in the dark, and his eyes found the one at their head. ‘They will still be hungry,’ he said. Veyra walked out of the darkness toward him. Behind her the cadre flowed past into the alcoves, one Sister to each, unhurried, and Sixx moved with them, because the nine were his to keep alive the moment the blades were done. Above them all, through the rock, the first far sound of the squad’s work arrived — a tremor more felt than heard, the armoury door going in, Thestus beginning. IV: The Unbinding The record of the next four minutes, as Sixx sealed it afterward, ran nine lines. The choir, taken sedated, nine litters, his own hand steady on each throat in turn with the narthecium’s mercy, the oldest of them fourteen. The target, terminated by Oblivion Knight Veyra at the fourth watch. Structural erasure initiated on schedule. What the record did not carry, because no record could, was the way she did it. She stopped in front of him and let him see her. That was the first thing. He had risen from the bench. He stood in the ember light unarmed, the bread still absurdly in one hand. She stood before him in the gun-metal blue, the greatblade still at her back, and gave him the width of one breath in which nothing happened at all except that they looked at each other. The woman who was a hole in the world and the man whose world she had already ended. He said something to her too low for even Sixx’s autosenses to take cleanly. The shape of it might have been a question about the nine. Veyra inclined her head. It was not a bow. Sixx had watched her make that exact movement to Thestus on a docking apron six years before: the acknowledgement between professionals, given now, entire and unhurried, to a dying man’s last competence. Then the blade came off her back, and she took his head the way a door closes. The sound that went through the hold above them in the next second was in the rock itself. Ten thousand sleepers, one thread cut in each of them at the same instant. Sixx, kneeling over the fourth litter with his hand on a child’s pulse, felt the whole mountain wake wrong above him, like a body starting from a nightmare it cannot name. The binding had not been command. Veyra had said so on the shelf. It had been carried love, and it did not let go of ten thousand people gently. It tore. The strike had planned for grief and panic. What came down the stair shafts and along the old workings in the next quarter hour was past both. The garrison’s survivors and the shrine district’s strongest, cut loose at the root of themselves. They followed the last direction the severed thing in them remembered, downward, toward where he had gone every night. A hold’s love, arriving with mining mauls and cutting bars and its own screaming. The strike was still falling in the galleries above. The charges were counting. The plan compressed the way plans do. They were two hundred metres out along the extraction working, the shrine element at the double with nine litters slung between them, through a dead seam propped a century ago. Then the frenzy found the working’s mouth behind them and came on in the dark by feel. Ahead of the master count, the early charges fired — the set laid to bring down the chamber and take the evidence with it. The rock gave worse than any survey had called it, three years of over-mining gone to rot in the dark, and the shaped blast that should have dropped a single chamber threw its shock the length of the dead seam. Somewhere overhead a load column that had already been half killed let go. Sixx heard the column go. He had time to read the sound, place it, and put his body over the fourteen-year-old’s litter. The roof of the working came down on him, four tonnes of it, without malice and without hurry. V: The Throat He came back to himself buried in stone. His helm chronometer had lost forty seconds. The litter under his body held a living pulse: that fact arrived first, before the pain, and he filed the pain when it came, catalogued it one-handed the way he would have catalogued any casualty’s. Pelvis fractured in two places. Left leg pinned to mid-thigh under a fall he estimated at four tonnes. Left arm crushed at the forearm, the narthecium’s mountings driven into the plate, the hand below it silent. Suit breach at the hip, sealed. Bleeding contained by the armour’s grip and his own carapace. Ambulatory: no. The working around him had become a throat. The fall that had taken him had brought the roof down in a slope of broken rock that halved the passage. Through the gap it left, the ember-dark of the seam behind them showed torchlight now. The torchlight was coming, and it was screaming as it came. His retinal feed gave him the shape of the next minute with a clinical completeness he would have traded for ignorance. The litters and their bearers were through and clear, moving hard up the working toward the exfil rise. Thestus’s element was ninety seconds out, converging, carrying its own wounded out of the barracks fight, Brother Arven’s thread on the feed running amber into red. The charges under the shrine district had one hundred and ten seconds left on the master count, and when they fired, this whole dead seam went with them. That had always been the design. The design had not included an Apothecary under four tonnes of it. In the gap in the fallen roof, in the throat itself, stood Ivenna. She had not been caught by the fall. She had come back through it. She stood in the half-closed passage with her greatblade in both hands, unbound, her null filling the throat from wall to wall. Sixx understood the shape of the next minute from where he lay, because he could see both halves of it at once. The mob coming up the seam had fire with it. Two more sparks, lit late or hidden deeper than even Veyra’s reading had reached, came now in the front of the frenzy, their wakening gift running loose and ragged off them like burning oil. In open rock, against unshielded bearers and nine sedated children, that fire would have cooked the working end to end. In the throat, against Ivenna, it was nothing. It guttered against her the way a torch gutters in water. The mob would have to put her down with iron, in a space one Sister wide, and every second they spent failing to was a second the litters climbed. The arithmetic was total and Sixx was on the wrong side of it. Digging him out was a two-body task with a lever, thirty seconds at best, in the mouth of the throat itself, under the fire’s gutter-range, inside the count of the charges. He keyed his vox to the command channel and said what the Apothecarion had trained him to say, and his voice came out level. ‘Casualty is non-recoverable in the window. Clear the working. That is my assessment.’ The reply was Veyra. She came back down the working out of the dark at a dead run, Meren a stride behind her. She looked at the fall pinning him, at the throat, at Ivenna in it. Sixx watched her take the whole arithmetic in a single pass of the eyes, the way she had taken the manifest of a world from a gantry shelf. Then her hands moved, once, to Ivenna. He knew enough Thoughtmark by now. Six years of watching had opened the plainest of it to him, and what Veyra’s hands said was plain. Hold or fall back. Yours. It was not an order. Sixx understood that much even then, and understood it fully only years later: that at the last gate the Sisterhood did not spend its own. It asked. Ivenna did not turn her head from the torchlight. One hand left the greatblade’s grip, made a single shape, and returned. Meren, hauling the fallen prop-iron out of the rubble beside Veyra, did not translate it. Nobody had asked her to. Sixx read it unaided, and it was the last coherent thing he took in before the lever bit under the fall and the pain whited his feed to static. Spend it. His own strength moved nothing. Four tonnes of Velleth had him, and until the prop-iron broke the stone’s grip he was cargo. Without the two women he did not leave the seam. He knew it as arithmetic, even then. Veyra drove the iron. Meren hauled at his harness with both hands and her whole weight. When the stone gave he pushed with the good leg and dragged at the rock with his working hand. Between the three of them he came out, his shattered pelvis grinding through the armour’s grip. He retained what followed in fragments that he never afterward tried to assemble: the ceiling of the working sliding past above him. Meren’s breath, harsh and even. The light of the choir-fire guttering orange against the walls of the throat behind them and dying there, again and again, on a silence that would not let it pass. The bell-note of a greatblade meeting a mining maul. Veyra under his right arm, taking what the good leg could not, spending everything and wasting nothing, her breath through her teeth in fours. He did not hear Ivenna fall. There was nothing to hear. Her silence simply went out of the world behind them, at the ninth second of the master count. The world did not change. That was how he knew. Everything a Sister is leaves quietly. The primary charges took the seam. The mountain closed over the shrine district in an exhalation forty seconds long, a rolling settlement of rock that Velleth’s survivors would remember as the night the ground grieved too. The throat and the fall and the mob and the fire and the greatblade and what remained of a man’s three years of love: the seam took all of it, and pressed it into one stratum, and kept it. Sixx went up the working between Veyra and Meren, the good leg driving what it could, the rest of him carried, the dark rock sliding past overhead and then gone and then back again, his own training reaching him from the wrong end. At the exfil rise, where the litters were rigged for the climb, Veyra set him down. He broke the neck seals one-handed and dragged the cracked helm clear. The display inside it was dying. He wanted the air, even this air. She knelt over him for a moment. Checked the seals on his hip breach with two fingers, the same pressure exactly with which she confirmed the torc at her own throat. Looked once into his face, at whatever was in it. Her hands said: Work later. Live now. Then she rose and went back down the line of nine litters, checking each strap, and did not look at the closed seam at all. VI: The Second Kind The extraction vessel held them in the trailing dark of Velleth’s moon for a day while the world below composed its story, and the story composed itself along exactly the seam the plan had cut for it. A collapse in the old workings. A hold in mourning for its dead and for one man in particular, gone below in the night as he went every night, taken by the rock with the others. Grief with dust in it, no body, no wound to point to. Already, in the vox traffic the vessel skimmed and logged, the first small subsidences of the extraordinary back into the ordinary: a ration board meeting. A dispute over a pump rota. An infirmary reporting its deaths at the actuarial rate. No soldier had been seen. No shot had been fired above the fourth sub-level. The Imperium had never been there, because the Imperium had needed never to have been there. In a year the seam would yield poorly. The hold would shrink the way dying holds shrink, and the tithe would come off it small and regular. The man who had refused all of that would be a name said quietly at wakes, by people who had loved him and could not have said precisely for what. Nine children slept in the vessel’s hold, bound for the Black Ships they had twice been hidden from, carrying in them the only living record of what he had been. Sixx spent the day in the medicae bay, in traction of his own rigging, doing one-handed what could be done and dictating the rest. He refused the full sedation twice. Both times he was aware of the flat amusement with which the bay’s servitor logged the refusal of an Apothecary who would have overridden any other patient making it. What the bay could do for him was holding, not mending. The leg would wait for the deep apothecarion at Deliverance, or it would not come back at all. His clinical notation ran long that night. The nine, their doses, their stability. Arven, holding. His own workup, written in the third person, precise. At the end, in the space the format reserved for operational observations bearing on future integrated deployment, he sat a long time with the stylus against the slate. He had watched a Sister of Silence be asked, at the last gate, whether she would die, because her order would not spend what it had not been given. He had watched her give it. He had watched the commander who asked bring a broken legionary out of the stone, thirty-one seconds bought against a body’s certainty. He had watched her check his seals afterward and walk away down the litters without one glance at the ground that held her Sister. None of it fit the format. He wrote: Integration doctrine functioned under total load. He sealed the case. The Legion’s dead were entered on the second day, in the manner of the Legion. Thestus came to the medicae bay with the roll and read the two names to Sixx. The barracks fight, delivered in the flat cadence the record deserved, and the flatness the blow. Then he keyed the names into the Legion’s rolls, appended the manner of their deaths, and closed the slate. The XIX did not hold ceremonies for its dead. It remembered them and went on, and the remembering was the ceremony. The cadre kept its observance the same evening, in the vessel’s small forward hold, and no one was asked to attend. Sixx did not go. The leg would not carry him, and the bay would not have released him if it would; what the fall had done was past the ship’s mending, a case the servitor had already marked for the deep apothecarion at Deliverance. He lay in the rigging instead and let himself see it, the way he had seen it before. Six years had taught him to see it exactly. Five Sisters stood in a ring that held a gap, the space where the sixth would have stood, and there was nothing in the middle at all. There were no words. There was no Thoughtmark. They stood unbound, the full weight of their silence filling the hold the way water fills a lock, for as long as it took the vessel’s air to cycle twice. Veyra stood at the head of the ring. She did not move for the whole of it, except once. Her hand rose and lay flat over the clasp of her torc, covering it, and was still. Meren came up the companionway afterward, the last to leave, and stopped beside his frame. She looked at him for a moment, deciding something. Then she gave him the cadre’s account, quietly, as translation, which was her office. ‘Ivenna. Vigilator. She held.’ Sixx entered the name in his own record that night, with the phrase attached — the one time he let the two orders’ records cross, where by design they never did. The silence the Sisters had kept around the empty ring was their own kind, the kind he had spent six years learning to read. It had not been empty. He knew now that it had never once been empty. Veyra came to the medicae bay on the third day, unbound, unarmoured, in the grey duty-wear of the order with the sleeves folded back. In six years, Sixx had never seen her out of plate. He had assumed the economy was the armour’s. It was not. She crossed the bay the way she crossed a gallery under arms, nothing spent, nothing wasted, each footfall placed before the last had finished. The whole of her moving the way water moves through a channel cut to fit it. The strength was there to be read in the bare line of her arms and the set of her shoulders, the working musculature of fifteen years behind a greatblade. He had catalogued a thousand bodies built for war. Hers was the first he had ever thought of as built the way a bridge is built, nothing on it that did not bear load, and all of it, somehow, at rest even as it moved. Sixx found he had assessed her twice, once as an Apothecary, and once in a register he did not have a form for. She stood over his traction rigging, took up the slate at the bed’s foot, and read his workup, top to bottom, the way she read everything. At the entry he had written on himself, third person, precise to the millilitre about a body she had dragged out of a mountain, her shoulders moved once. A laugh with no sound in it, because the Vow kept the sound and nothing else. She set the slate back. Sixx had prepared words. He was aware of them the way he was aware of the narthecium on the shelf, tools out of reach of his working hand. That she had come back down a collapsing working against his own broadcast assessment. That the arithmetic had said leave him, and that he had run it himself and broadcast it. That she had heard it and come anyway. That a Sister was in the stone of Velleth because the sum had been paid on his side of the ledger. That he would carry it. That there was no length of service at the end of which he would not still be carrying it. He said none of it. Six years had taught him what speech was worth in that silence, and whom it served. It was not her. ‘Ivenna checked her blade before every descent,’ he said instead. ‘The temper. I never learned where the habit came from.’ Veyra looked at him for a moment. Then her hands moved, unhurried, in the plainest register of Thoughtmark, the one she knew he could read unaided. What they said he did not enter in any record, and kept. From steel that was asked once, and held. She confirmed the seal of his hip dressing with two fingers. Her hands moved once, and what they said she kept, though the shape of it was plain — that he was to mend, and come back whole from Deliverance. Then she went out of the bay, down the corridor toward the hold where nine children slept. Sixx lay in the rigging and looked at the ceiling of a vessel running dark toward the fleet, his working hand resting on the place where the seals held. The silence she left behind her in the room was the second kind. The kind that was full. Link to comment https://bolterandchainsword.com/topic/388361-shadow-talons-part-two-edict-of-black-feathers/ Share on other sites More sharing options...
