WarCom has the Balance Dataslate pages up.
https://www.warhammer-community.com/en-gb/articles/b4zj2o7u/the-warhammer-40000-august-update-everything-you-need-to-know/
https://www.warhammer-community.com/en-gb/articles/1b6ozyec/kill-team-balance-update-frenzy-storms-and-burrowing-beasties/
Points and apparently some Detachment restriction changes up on the MFM
https://mfm.warhammer-community.com/en
Some notes:
Despite saying Orks didn't change, they did get some wording changes.
All the Heldrakes have OC0 now.
Titus and Heuron's buddies gained Support and lost their unique "Join my friend" rule.
Psykers seem to have become more expensive across the board.
9 minutes ago, The Pounder said:
I’m definitely going to add some Leman Russes to my list now!
How long does it usually take for the app to be updated?
App update is live now.
You'll probably need to go to your app settings to force the update through tho.
48 minutes ago, Trokair said:
In the Universal rule update it has this:
Where do I see 18.06 and 18.07 as it is in neither the phisical book or in the core rule PDF?
It's on the updated App
Thanks for letting me know, I should have thought of that.
Let’s hope they update the FAQ or the Core rules pdf to incorporate the changes soon, I have been experimenting with a Land Raider list and having Terminators hop out and charge is part of the plan.
This might be a daft question but what purpose does monthly adjustments and even the quarterly changes make when we've not even got the first codex actually designed for the edition?
I understand that some things don't work but aside from some oversights/general late editing like the changes to detachment points last time surely attempting to balance or back fix last editions codex's will throw this edition out of sync as more releases happen.
I know well that there will never be a day that all new codex's appear at once and going last sucks but it seems a huge issue of design.
Could be an attempt at getting the rules "as intented" instead as "as published"? Dunno, just an hypothesis.
So far all it's successfully done is slap Tsons with a nerf every single time despite out winrate falling into the mid to low 40s.
Last edition was apparently a competitive disaster with Eldar auto-6ing into 14 dev wounds on whatever they liked, and a bunch of broken rules on release. They probably committed to the rapid balance passes assuming the community would find some way to break the game early on, and fix it asap
@Xenith that makes sense, I guess if you push tournaments you have to make them "fair".
@Bouargh I'd thought that myself with a little bit of doing something for something's sake added in.
@Indy Techwisp that's mad, Maybe Magnus did do something wrong.
Register a new account
Sign in
