Lathe Biosas Posted September 1 Share Posted September 1 I had a great idea. Instead of attaching the shoulderpads to the marine, and then painting them, why not paint them separately and glue them together when I'm done. The question I have is how do you hold a shoulderpad to paint it? Also, no one seems to recommend this online, is there something I'm missing? Link to comment https://bolterandchainsword.com/topic/388462-need-help-painting-marine-shoulderpads/ Share on other sites More sharing options...
Griefbringer Posted September 1 Share Posted September 1 19 minutes ago, Lathe Biosas said: The question I have is how do you hold a shoulderpad to paint it? I have not tried this, but I would expect it to work: take a cocktail stick, add some fresh Blu Tack to one end, and then push the inside of the shoulder pad to the Blu Tack. Then push the other end of the cocktail stick to something that is easy to hold. Personally, I prefer to paint the shoulder pads in their final position. Link to comment https://bolterandchainsword.com/topic/388462-need-help-painting-marine-shoulderpads/#findComment-6185184 Share on other sites More sharing options...
Lathe Biosas Posted September 1 Author Share Posted September 1 (edited) The reason I thought it would be easier if the color scheme was different, then you could prime/paint without having to worry about base colors. In my case, I am painting red corsair models all black/silver/red as Risen Dark Angels... but I want to give them green shoulder pads so they match the rest of the dark angels army. Edited September 1 by Lathe Biosas Link to comment https://bolterandchainsword.com/topic/388462-need-help-painting-marine-shoulderpads/#findComment-6185187 Share on other sites More sharing options...
Karhedron Posted September 1 Share Posted September 1 I normally compromise by priming the pads separately and then gluing them on. They are easier to paint when on the model in most cases but priming separately means that you can get any awkward places that might be hard to reach after assembly. Link to comment https://bolterandchainsword.com/topic/388462-need-help-painting-marine-shoulderpads/#findComment-6185200 Share on other sites More sharing options...
Mazer Rackham Posted September 1 Share Posted September 1 (edited) Some options I use: 1) Small number/Individual models: Prime the pads on the sprue. Clip off, and tidy up gates. Take an old paint pot with a flat top. Put a thumb-sized lump of blu-tac on it, stick the pad to the tac for clean-up paint and other layers. Glue on when ready. 2) Batch painting: Clip the pads off the sprue. Glue them onto the models. Spray the pad the colour you want. Blu-tac over the pad. Prime rest of model, finish model, remove tac, finish pad. 3) Old size 1/2 brush handle with the old, massacred brush head cut off. Blu-tac pad to round end so it's a good, reasonably firm fit. Paint. Glue when ready. The second method works better if the pad colour is lighter than your main model colour, eg: Ragnar's Great Company (red and yellow) but main model colour basecoat is The Fang or similar. Edited September 1 by Mazer Rackham Link to comment https://bolterandchainsword.com/topic/388462-need-help-painting-marine-shoulderpads/#findComment-6185237 Share on other sites More sharing options...
sbarnby71 Posted September 22 Share Posted September 22 I always paint my pads separately: clip them from the sprue, get a cocktail stick and break it in half (2 pad holders), use a knife to shave the broken end on one side a bit flatter, use really cheap super-glue and glue the stick inside the pad. You can stick the pointy end of the stick into a cork or I use a cork sanding block as that will hold loads of sticks. The cheap super-glue will hold while you paint the pad and will allow you to break the stick away once you're done, any left over stick or glue can be cleaned away. The trick is cheap super-glue, that way the bond can be broken easier when you're ready. 1 Back to top Link to comment https://bolterandchainsword.com/topic/388462-need-help-painting-marine-shoulderpads/#findComment-6188607 Share on other sites More sharing options...
Grotsmasha Posted September 28 Share Posted September 28 I use blutac/poster putty. I start by doing the "inside" first, and paint the whole armour trim, then flip it and then paint the outside 1 Back to top Link to comment https://bolterandchainsword.com/topic/388462-need-help-painting-marine-shoulderpads/#findComment-6189358 Share on other sites More sharing options...
