Valkyrion Posted September 18 Share Posted September 18 A lot of Torrent weapons have ignores cover - why, when you don't roll to hit? I feel like I'm missing something blindingly obvious! Link to comment https://bolterandchainsword.com/topic/388535-ignores-cover-silly-question/ Share on other sites More sharing options...
Lathe Biosas Posted September 18 Share Posted September 18 I think the idea is that it's hard not to get wet when sprayed with a fire hose... or a tad toasty when sprayed with a flame thrower. In 40k, these short ranged weapons will hit you if you get too close. Link to comment https://bolterandchainsword.com/topic/388535-ignores-cover-silly-question/#findComment-6187555 Share on other sites More sharing options...
Valkyrion Posted September 18 Author Share Posted September 18 No, I mean why grant a weapon that doesn't roll to hit an ability that ignores the BS modifier for having the benefit of cover? Link to comment https://bolterandchainsword.com/topic/388535-ignores-cover-silly-question/#findComment-6187557 Share on other sites More sharing options...
Dr. Clock Posted September 18 Share Posted September 18 Because the rules haven't been changed since the Spring (10th edition) when cover reduced weapon AP instead of Hit roll. Cheers, The Good Doctor. 1 Back to top Link to comment https://bolterandchainsword.com/topic/388535-ignores-cover-silly-question/#findComment-6187565 Share on other sites More sharing options...
Valkyrion Posted September 18 Author Share Posted September 18 Ah, okay. So when the codexes are updated, any weapons that had TORRENT, IGNORES COVER will lose the Ignores Cover bit due to redundancy? Link to comment https://bolterandchainsword.com/topic/388535-ignores-cover-silly-question/#findComment-6187569 Share on other sites More sharing options...
Dr_Ruminahui Posted September 18 Share Posted September 18 (edited) Probably - as you correctly noted, it is simply a legacy issue, so it makes sense that it would be removed. And for my recollection, I don't think any of the many torrent weapons in the new orks codex have ignores cover - for example, none of ones in the revealed orks datasheets post on Warcom do. Edited September 18 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/388535-ignores-cover-silly-question/#findComment-6187591 Share on other sites More sharing options...
Valkyrion Posted September 18 Author Share Posted September 18 Thanks all, I never played 10th so I've happened upon an oddity I don't need to concern myself with any longer. Link to comment https://bolterandchainsword.com/topic/388535-ignores-cover-silly-question/#findComment-6187622 Share on other sites More sharing options...
