Varnish questions and recommendations
Go to solution Solved by Helias_Tancred,
First question: how important is it to use a varnish? I see people say it’s to protect your minis. What’s the real value? Does it significantly change the durability of your paint job?
Second question: it seems like there are a lot of threads about how someone messed up a model with a varnish. Stuff like a cloudy finish or reactivating paint. How do I avoid the pitfalls of a varnish? Is this overblown? Or are there quite a few ways to mess up your mini at this step?
I read all of the @Helias_Tancred thread on this page. That thread was more concerned with the shine than the protection. But I just don’t want to ruin a model in the process of trying to protect it.
Any tips or recommendations are welcome.
  • Solution
If you handle your miniatures often, then a varnish first job is to add a layer of protection so your paint doesn't wear thin from contact, or chip off, or just rub off? Yes it does put a sealant on your painted miniatures and models. As someone that plays 40k on average about twice a month, using a varnish for me is a non-choice.
It is hard to completely avoid the pitfalls of using a varnish. I've been in the hobby since 2013 and in that tine I have messed up a miniature or model several times because of the varnish. All in all it's not that bad, because you normally quickly figure out what caused the mishap when it does happen. Its educational, and it doesn't tend to happen a second time. Lastly, the application of a varnish can also affect the paint job and its final look. For example some very matte varnishes will give the paint job a "buttery smoothness" between the colors when it dries? Or a more satin or gloss will make the color and lines between the colors more sharp? Opinions vary based on model, type of varnish used, and brand of varnish.
When using a varnish there's two factors, the brand and type of varnish used, and the environmental situation in which you use it. You will learn which brand type works for you, and you learn under which conditions (temperature and humidity, you want to avoid higher levels of both!) are good for using a varnish vs. which are not. There are three types of varnish based on the degree of shine it gives; matte, satin, and gloss. Most prefer a matte, or flat look with little to no shine. However some like a satin (In-between the two for level of shine) or even a gloss look? Also with type do you prefer a brush-on varnish out of a pot, or do you prefer to use a spray can? In my experience I use both. I will use a brush-on varnish to address specific needs such as helping set or take the shine off of newly placed water decal slides, or to protect a part of the painted miniature (the side of the base) while I handle it to place decals. Personally I prefer to have both a brush-on varnish and a spray.
Brands. What automotive brands do you like, and which would you never consider buying (I'm a Volkswagen man lol)? This is where a lot of your testing is at. You'll figure out what degree of shine you prefer, and whether you prefer a brush-on or a spray for an overall varnish for your miniature and model. But what you have to really figure out is which brand's products you prefer for the task versus the others? My current preferred varnish brands/products are Vallejo Matt Varnish out of the bottle for technical uses like decals or spot varnish for limited purposes, AK Ultra Matte varnish out of the bottle if I want to brush it on all over the miniature or model, and I'm currently looking for a new go-to matte varnish spray. I'm leaning into trying AK's Matte Varnish spray for that type.
How to avoid the pitfalls of using a matte varnish is never use a spray in any warm or humid temperature! Also if you use a spray do not use it too close to the miniature or model (12" is fine). That is another reason why some prefer brush-on. When using a brush on try not to goop it on ... like a paint try to keep it more thin and don't let it pool up as it dries either. I like drying my models in front of a fan, especially if the temp is warmer. Lastly some varnishes can simply be crap, and when they dry you will sadly realize that. Doing your research before you try a brand and type is highly recommended.
Edited by Helias_Tancred
All of what Helias says is very good.  My own additions:
1.  The importance of your varnish also depends on what your models are made of.  Metal models chip their paint jobs very easily, so if you want to preserve their paint jobs, you probably want to varnish them.
2.  Generally, the shinier the varnish, the more durable the coat.  Therefore, its not uncommon for people who paint metal models for them to give them a gloss coat of varnish, then a matt coat overtop the cut the shine.
Edited by Dr_Ruminahui
Great info @Helias_Tancred . Thanks for taking the time to share your knowledge! I’m only in my 2nd year of the hobby and most of the stuff I’ve watched on YouTube hasn’t even mentioned varnish.
Thank you as well @Dr_Ruminahui ! My only metal model at the moment is Ezekiel. But that is good to know for painting him!
THIS ^ ... sage advice!
The most important advice I can share after years of painting is that humidity is the greatest risk when spraying varnish, regardless of the brand. Moisture getting caught in the aerosol is the leading cause of "blooming" (where the varnish develops white, cloudy patches). My golden rules are:
  • Never spray if it is raining or there is standing water on the ground.
  • Never spray if it is misty, foggy or damp
  • Never spray first thing in the morning or late in the evening as temperature changes drive changes in humidity
  • Ideally spray on dry, fine days (which in the UK restricts me to about 3 days per year :laugh:).
  • Like 2
  • Agree 2
  • Love 1
  • Support 1
For what it's worth, back in the mid 2010s I once foolishly sprayed a gloss varnish on too humid a day. I ended up some sad miniatures. Although I was able to remove some but not all of the frosting with olive oil.
Since then I've been using brush-on gloss and matte varnishes and I've been happy. So you might want to consider brush-on varnishes, available at most hobby stores.
Most of the horror stories with varnish involve spray varnish, typical problems involving:
1.) Problematic weather conditions (temperature, humidity, particles floating in the air)
2.) Poor can or spraying too close
3.) Accidentally using can of white undercoat instead of actual varnish
My personal approach is to use brush-on varnish, which may be slightly slower than spraying, but a lot safer. I started with gloss varnish, but have since then moved over to satin varnish (Vallejo brand). I have tried a few matte brush-on varnishes over the years, but never really enjoyed the look they provided. My tips for brush-on varnishing:
a.) Allow the models to dry properly between painting and varnishing (at least overnight).
b.) Thin down the varnish sufficiently with water so that it flows nicely.
c.) Use a large brush and don't let the varnish pool up (use the brush to remove any pools).
d.) Afterwards, allow the varnish to again dry properly (at least overnight) in the open.
When getting started, you may want to buy a couple of different varnishes to compare. Apply them over some small test pieces and see which one you prefer. Those brush-on varnishes that you do not like can be put to other uses; e.g. a mixture of water, PVA glue and varnish is good for glueing sand to model bases.
Varnish is important, I consider it essential.
A few hard-earned lessons:
- Thin your varnish. A lot of people use Liquitex, cut that in half. The thickness of the coat make s a huge difference and that stuff dries thick.
- Golden's varnish is the museum-grade stuff. It dulls this the least and controlling the viscosity is very easy with their thinner. Expensive, but a bottle will last you years and it doesn't seem to care about humidity. It's all I use.
- Varnish dulls your colors, especially metallics. Matte is worse than gloss. It's a matter of degree, most times it's not noticeable.
- Absolutely legal to mix varnish with acrylic paints and medium to make them shiny. Have done plates on Brass Scorpions this way, reduces color dilution in subsequent passes.
- You can mix pigments with varnishes. A tiny amount of mica powder can compensate for dilution of metallics.
- You can do a matte coat over a gloss coat. Use that to take off the shine where needed. A good practice is to really thin your final coat - like to 20%. But this will make it more durable and gloss coats help you with pin washing.
- If you put on a coat that's too thick, Smart Strip can remove some varnishes. Worked with Liquitex the times I tried it. Did not work with Golden's.
This?
That's it.
Remember you also need the thinner. It's called MSA Solvent. No way to use the varnish without the thinner.
https://www.amazon.com/GOLDEN-Professional-Removable-Protective-Paintings/dp/B00A6VWVIC/ref=sr_1_10
When I bought this in the past, I discovered the best price was from Jerry's Art Supplies. They also did coupons for additional discounts.
  • 2 weeks later...
I'll just chip in that it absolutely used to be the case that gloss varnishes were more durable than matte ones due to differing composition, but it's not always true these days.
Some paint finishes are particularly delicate and benefit from varnishing, e.g. Contrast paint, whilst others are more durable, and gaming models benefit more than display pieces due to the increased amount of handling they'll go through.
On a topic that someone on here brought up that matte varnishes can make your models too dull and flat .... lol, I think that is what I'm running into using that AK Ultra Matte varnish! I've been working on my Dark Angel Inner Circle Companions, and yeah using that stuff may be making them TOO flat and matte, really having an affect on the vibrancy of the colors and the metallics.
I may be cursed to never find the solution I want, because I'm now thinking it may be too matte and flat :(
hahahahaha ... I can't win.
I use ultra matte myself; haven't experimented with others, but I know some content creators go for mixes. Duncan Rhodes has a video on varnishes from a few years ago going over his preferred mix: 50:50 AK ultra matte and Contrast medium. I think Cult of Paint might also do a mix of ultra matte and matte varnishing but I can't recall off hand. If matte isn't matte enough, and ultra matte is too matte, this could be worth trying out!
Register a new account
Sign in
