techsoldaten Posted 1 hour ago Share Posted 1 hour ago @GrandMagnus and I were talking cooking, decided it's a good idea to give this it's own thread. Wanted to start off with the observation: if you know how to assemble models and paint, you kind of already know how to cook. Many of the same skills are involved, just applied differently. Following assembly instructions is like following a recipe, mixing sand for a base is kind of like preparing a dough, drybrushing is kind of like applying a rub to a roast, searing is kind of like edge highlighting, etc. The skills transfer conceptually. Also: many recipes lend themselves to cooking while you play Warhammer. Having a crock pot or a smoker means you can prepare meals while satisfying your tabletop urges. This might be the best way to avoid accusations of wasting time on hobbies from family and loved ones. While some things I make are elaborate and take days to make, the most satisfying dishes are usually the ones that cook slow and leave you with a lot of time for other things. There are a lot of recipes I could share, but I wanted to start with a tried and true one I have actually used when hosting games at my house. Baltimore-style Pit Beef - simple to make, uses cheap cuts of meat, cooks quickly and tends to satisfy. Ingredients: Beef: Top round is best, but anything with round in the name will work. You can also use sirloin or Boston Butt for this. You want 5+ pounds. Rub: You can use salt and pepper and it will turn out just fine. The classic rub is Black Pepper, Onion Powder, Garlic Powder and Paprika in roughly equal amounts, plus about 1/2 tsp of Kosher Salt per pound of meat. Adjust to taste. Buns: Any bun will do, am fond of Potato Rolls for this recipe. Condiments: Horseradish, sliced onions, bbq sauce. True Pit BBQ sauce is a sauce used by many roadsides stands serving Pit Beef. Equipment: Grill: Charcoal is the preferred method. Propane will do. Digital Thermometer: optional. There's a target temperature. Unless you can eyeball it, measure the temperature. Prep: 1) Dry brine the beef. This means mixing the rub, applying it generously over the surface of the beef, and letting it sit a few hours or overnight. 2) Heat up the grill. You want it between 435 and 550 degrees F. 3) Put the meat on the grill. Round is round, it should have 3 or 4 sides. Lay it down on the grill at high temp, usually about 10 minutes per side. 4) Use direct heat. You want a charred crust to build up. 5) Pull the meat around 120 degrees F and let it rest. It will rise in temp about 5 degrees over the next 15 minutes. That's medium rare. 6) Slice the beef thinly and serve on a bun with your favorite condiments. Total time to cook: 45 - 90 minutes, depending on thickness and cut. Yields ~ 12 sandwiches. Observations: This recipe is dead simple. Just turn the beef every once in a while and use a thermometer to track the temp. There are some people who do this in the oven, I've tried it but sacrificing the crust changes this to a roast. The dry brine technique is generally applicable to preparing any cut of beef. Beef soaks in flavors from the surface that penetrate to the core. When cooking, natural juices carry them to the top. General rule of thumb: longer the better. This recipe can be overcooked. I've had it all the way to medium well. The important thing to remember is the slicing - keep the slices as thin as possible. The cuts of meat being used are not naturally tender and get worse as they are heated. That said - some people like it well done and that's the only way they will eat it. 1 Back to top Link to comment https://bolterandchainsword.com/topic/388839-bc-cooking-thread/ Share on other sites More sharing options...
techsoldaten Posted 1 hour ago Author Share Posted 1 hour ago Wanted to share another item under the umbrella of non-obvious staples that should be considered for cooking. Cast iron skillets. They add presentation value and can be bought in all sizes. I have several big ones, but something I like is the Lodge series. https://www.amazon.com/Lodge-Pre-Seasoned-Skillet-PFAS-Free-Inches/ Don't actually buy this from Amazon. The same thing can be had at Restaurant Depot for $8. So, the reason you want personal cast iron skillets: you can take a lot of ordinary recipes, add a crust on it, and deliver people their own dish. The amount of additional preparation is trivial. The way to think of it: take any stew, add flour / corn starch to thicken, serve it in a crust, and now you are serving a pie. As a hobbyist, this attention to detail should come naturally. Store bought pie crusts are very expensive compared to making it yourself. A general purpose Flaky Crust Recipe follows. Have been using it for decades, takes about 10 minutes to prepare and can be used for any dish served as a pie. Ingredients: 2 1/2 cups flour 1 tsp salt 1 tbsp sugar 12 tbsp butter 1/2 cup shortening or lard 1 cup iced water Equipment: Plastic wrap: for storing the crust. Rolling Pin: for rolling the crust. Recipe: 1) Mix dry ingredients first. 2) Cube the butter, smaller chunks are better, mix into the dry ingredients. 3) Add the shortening in small spoonfuls. Mix the result, should be floury with some lumps. 4) Add a couple tbsp of cold water for moisture and mix again. You should see a dough starting to form. Repeat until a well formed ball forms. 5) Roll the dough into a ball, then cut it in half, wrap in plastic wrap and refrigerate. Do not kneed the dough or it will not be flaky. 6) When it's time to prepare, roll a chunk of the dough out on a floured surface to cover the bottom of the skillet. Fill the pie, then roll out another layer to create the top. 7) When rollling, aim to keep the layers thing - about 2mm or maybe 1/8th an inch. 8) When creating the top, I like to slice mine and creating overlapping layers exposing the insides. 9) Cook in an oven at 400 degrees F for about 25 minutes. You can go longer if you want the crust more firm, but this sacrifices some of the flakiness. Observations: This is great for chicken pot pie, beef pie and other variants. It's also great for regular pies - works well with a can of cherry pie filling. As long as your cast iron is seasoned, you don't need to coat it with anything for release. When transforming stews into pie filling, I generally start with half a cup, sift part of that onto the top of the stew, stir to assess thickness, and repeat until I get it where I want it. Always do this after the stew is cooked - moisture will evaporate and you can end up with something too thick if not careful. Additional prep to consider: add an egg wash to the top of the crust before cooking for color, sprinkle kosher salt for flavor, or add cane sugar / brown sugar for dessert recipes. For the rolling pin: the one I use was purchased at Goodwill for like $1. It's wood. The plastic ones tend to flake paint off after a certain point. Would avoid them and look at thrift stores, people don't seem to use them as much anymore and it's a good thing to have around. Link to comment https://bolterandchainsword.com/topic/388839-bc-cooking-thread/#findComment-6195967 Share on other sites More sharing options...
