Rau le Creuset Posted June 15, 2006 Share Posted June 15, 2006 Sorry, that I don't possess your eloquency and nevertheless tried to explain my idea (that could be helpful for somebody). ^_^ But thanks for this constructive/useful post of yours. back to topic: Problem is, my digi-camera's cable is lost and I don't have a card reader, so I can't make a picture of my tech-priest with the shoulder pads. Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1031251 Share on other sites More sharing options...
-Q- Posted June 15, 2006 Share Posted June 15, 2006 Easy fella. I tried and tried to make any sense and I just couldn't. I didn't mean any disrespect for your attempt to try to help... it just didn't come across for me. Seemed useful and constructive to explain that your post didn't make sense. I tried to make it funny but I guess that didn't work for you. Sorry :) Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1031275 Share on other sites More sharing options...
Rau le Creuset Posted June 15, 2006 Share Posted June 15, 2006 Somehow this explanation is not really useful -.- Edit: I hope Gryphin allows me to use one of his pics for trying to explain my idea: I think I said clearly with this two sentences, that I'm not really satisfied myself with the explanation, but I can't really describe it better. If someones interested in it, I could try another time.Seemed useful and constructive to explain that your post didn't make sense. I tried to make it funny but I guess that didn't work for you. Sorry biggrin.gif Ok then I have a different sense/understanding of humour and constructive posts. Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1031290 Share on other sites More sharing options...
Marshal Draziel Posted June 15, 2006 Share Posted June 15, 2006 Imho - that drawing could use a bit of sense, but I think I understand it when I look at it carefully... Though I find it really nice that you try and contribute to the topic :) always good to get more input from people I found what Q said, to be highly constructive :D On topic - The shoulder plates are really easy to convert, it's actually only a question of bits! Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1031326 Share on other sites More sharing options...
Rau le Creuset Posted June 15, 2006 Share Posted June 15, 2006 http://img.photobucket.com/albums/v212/wolfslord/123v8kl.jpg Ok a try to explain the drawing. First just cut the shoulderpads at the red lines. Then turn the shoulderpad in 90 degree and the "B" side is then glued to the torso of the marine. Under this shoulderpad, I used normal normal marine shoulder pads because it looked better than without any shoulderpads. For a good looking pre-heresy terminator head I would use a grey knight like helmet. I think somewhere here was a very good tutorial how to make such a helmet out of a normal one. EDIT: @Brother Beork, brilliant idea and tutorial :) Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1031338 Share on other sites More sharing options...
-Q- Posted June 15, 2006 Share Posted June 15, 2006 AH! I get it!! Cool idea. :) It's the turn 90 degrees that was the key to understanding I think. Nice tip Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1031365 Share on other sites More sharing options...
Rau le Creuset Posted June 15, 2006 Share Posted June 15, 2006 Ok, sorry the "key" was lacking in my other posts, but I'm glad my idea is no more understandable :) It's hard to explain when you have the mini right before you, but somebody else doesn't. Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1031367 Share on other sites More sharing options...
Danius Smithe Posted June 15, 2006 Share Posted June 15, 2006 It would be helpful if you could find the post about converting the heads into grey knight style ones :D Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1031462 Share on other sites More sharing options...
Brother_Beork Posted June 15, 2006 Share Posted June 15, 2006 +++ Off topic +++ On request, my original post about the termi helmets, mods can delete if they feel it's to far off topic. Knightly helmets: http://photobucket.com/albums/v331/brother...utorial%20pics/ Those pictures should say everything In terms of words; try to first cut along the cheeks of the helmet (picture 2) but try not to cut inward too much as this will ruin the helmet. After this cut down from the nose at an angle similar to that of a GK helmet (picture 4), again try not to cut too much inward as this will make the angle to big. Additional shaving and cutting is easier than putting plastic back on. Chance will be that the fresh cut helmet will not look anything like a GK helmet, in that case just shave the cheeks with a sharp blade (filing works to) untill the nose part is a straight point (like a GK helmet). I later added decoration like the 4 holes in the side and a small cross in the other side, all of which can be done with a small drill (for a cross, put the holes close together and connect them with a small cut, practice first to know what you're doing). Beork Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1031471 Share on other sites More sharing options...
Danius Smithe Posted June 15, 2006 Share Posted June 15, 2006 Thanks very much, although I don't feel that this is off-topic as it is still to do with pre heresy terminators, albeit not the shoulder pads :ot: Considering I doubt many people would go to the hassle of making pre heresy shoulder pads for a termi and not make it entirely PH... Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1031487 Share on other sites More sharing options...
chenley Posted July 18, 2006 Author Share Posted July 18, 2006 Great now I really want to buy the new plastic termis. Too many ideas to do! Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1057144 Share on other sites More sharing options...
ixupi Posted July 18, 2006 Share Posted July 18, 2006 +++ Off topic +++ On request, my original post about the termi helmets, mods can delete if they feel it's to far off topic. Knightly helmets: http://photobucket.com/albums/v331/brother...utorial%20pics/ AH! I've been trying to figure out a way to convert the termie helm to look 'older' if you will. B) You've just made me a very happy(and confused I never thought of it, considering I'm a huge GK fan) man! Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1057168 Share on other sites More sharing options...
TheDeinonychus Posted July 21, 2006 Share Posted July 21, 2006 Hmm.. I may try doing some sort of articulated shoulder pad for one side of my Chapter Master conversion. Interesting idea Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1059811 Share on other sites More sharing options...
Cptn. Palladorus Posted July 25, 2006 Share Posted July 25, 2006 Yuck. If there is one thing mini' companies shouldn't rip off from GW it is "Powerfist in the air like you just don't care" poses. OT: I was thinking about that pose recently, and I decided that the massive powerfists would probably be heavy as hell, even for a space marine, hence the strike last penalty for using one. What I was thinking is that armour that is set up with a powerfist has some kind of mechanism set into it where you hold it in that position and give it the exact little twist and the arm armour locks into place, supporting the fist so the marine doesn't have to, or at least so he doesn't have to keep wasting power output to hold it up. Makes sense to me anyway. And even if that's not true, next time you're holding something heavy in one hand, put your arm in that position and tell me it isn't easier to hold it up. Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1063372 Share on other sites More sharing options...
Dammekkos Posted July 25, 2006 Share Posted July 25, 2006 Yuck. If there is one thing mini' companies shouldn't rip off from GW it is "Powerfist in the air like you just don't care" poses. OT: I was thinking about that pose recently, and I decided that the massive powerfists would probably be heavy as hell, even for a space marine, hence the strike last penalty for using one. What I was thinking is that armour that is set up with a powerfist has some kind of mechanism set into it where you hold it in that position and give it the exact little twist and the arm armour locks into place, supporting the fist so the marine doesn't have to, or at least so he doesn't have to keep wasting power output to hold it up. Makes sense to me anyway. And even if that's not true, next time you're holding something heavy in one hand, put your arm in that position and tell me it isn't easier to hold it up. You think too much. Painting is better than thinking in most cases. Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1063416 Share on other sites More sharing options...
Solvo, Of the Fallen Posted July 25, 2006 Share Posted July 25, 2006 Wow.... amazed its that simple :tu: I was thinking about this was orgianally gonna try plasticard, then I was gonna try those shoulder pads off of the ornatly armored inquisitor (from inquisitor, cant remember his name). But this is so simple thanks! :o Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1063421 Share on other sites More sharing options...
Imperator=][=Romanus Posted July 26, 2006 Share Posted July 26, 2006 I used to have a tutorial saved that showed you how to make pre heresy termis, but i seem to of lost it. All i could find is this Custodes Terminators which doesnt extacly outline how to make them but gives some nice pictures. hope it helps Link to comment https://bolterandchainsword.com/topic/85127-pre-hersey-terminators/page/2/#findComment-1063595 Share on other sites More sharing options...
