maximo Posted June 7, 2006 Share Posted June 7, 2006 +EDIT+ new photos further down Hey there, This is the inside for my command rhino for my dark Angel army. Its still WIP but is almost done. Basically i would like some opinions on the attempted weathering/mud on the floor cause i think it looks pretty dodge. I just did a quick drybrush without really thinking about it and as a result didn't turn out how i intended. So what should i do? These are the options i came up with: 1. Leave as is. 2. Try and fix it by painting over with more weathering. 3. Re-spray white and either repaint bone and try weathering again, or repaint bone without any weathering. Thanks for reading. If you've got any advice/opinions/help then fire away. Here are the pics: http://static.flickr.com/54/162264631_0d7ddb2017_o.jpg Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/ Share on other sites More sharing options...
pinkbunny Posted June 7, 2006 Share Posted June 7, 2006 try a qnother quick drybrush of bleached bone, as the dirt would fall into the cracks and not collect on top Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1025244 Share on other sites More sharing options...
miniaturepainter Posted June 7, 2006 Share Posted June 7, 2006 To be honest, it looks fine. I like the fact that you added detail from where they would enter/exit the vehicle. The rest looks good. Thats a problem I have. You have something good, but then you look again and start thinking about how it could be better. Thats why I don't have a complete army :huh: Leave it as it is. :huh: Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1025246 Share on other sites More sharing options...
WhiteSpeed Posted June 7, 2006 Share Posted June 7, 2006 DO NOT RESPRAY lol it looks great i think....just like the mud has scuffed off onto the floor.....you cud try adding something lke sand or somethin to make it look lke mud is on the floor....but i think it looks just right Btw.....that rhino Looks VERY NICE...i hope you paint outside as well as youve painted inside Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1025247 Share on other sites More sharing options...
miniaturepainter Posted June 7, 2006 Share Posted June 7, 2006 As whitespeed said, maybe add some clumpage (not much). I believe there is a "debri" tut over at gamesworkshop website. Linkage here. it shows how to build debri, maybe if you applied the same method, change the coloring around a bit, you'd have mud. But then again it looks like your an accomplished painter, I'm sure whatever you come up with, will be good. :huh: Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1025250 Share on other sites More sharing options...
Captain Hat Posted June 7, 2006 Share Posted June 7, 2006 If you want to get really detailled with your worn paint and scuffing, you should concentrate it around the areas where the Marines' feet will be when they sit down. Other than that, it looks pretty good so far. I have little to add beyond those comments already posted- but a drybrush in your "paint" colour (as opposed to your mud" colour) might make it look more natural (as has already been said, dirt hides in recesses) and depending on how worn you want it to look, a little Boltgun drybrushing on those parts of the floor where the marines' feet will be most often (in front of the seats and so on) might be worth considering. Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1025273 Share on other sites More sharing options...
mannstein Posted June 7, 2006 Share Posted June 7, 2006 Firstly, add a subtle wash to add dirt into the recesses, then drybrush a little of the original floor colour over the raised areas to bring the colour back up. Then, a very light drybrush of boltgun metal to pick out the edges and show a little wear, then another very, very light drybrush of an earth colour. Thats how I would do it, anyway.... Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1025296 Share on other sites More sharing options...
-Q- Posted June 7, 2006 Share Posted June 7, 2006 This is some of the best dirty/used interior Rhino painting I've seen, the mud patterns on the floor are very realistic. Maybe add some butt marks on the seats with mud and/or scrapes. The worn/chipping paint idea is good too, but a Rhino can be muddy without being old and worn. Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1025381 Share on other sites More sharing options...
rat of vengence Posted June 7, 2006 Share Posted June 7, 2006 Definitely add a thin wash, make sure you put a bit of detergent to stop tide marks. You want to have some grime/dirt in the 'gutters' down the floor, not just on top of them. then, like someone else suggested, a very light drybrush over it so to make the effect more subtle. Have fun :drool: RoV Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1025689 Share on other sites More sharing options...
NoxI Posted June 7, 2006 Share Posted June 7, 2006 That looks good! I'm going to go ahead and jump on the bandwagon and say put dirt in the recesses and bring some of the original color back on top. As to the chipping/wearing, that really depends on how you paint the rest of your rhino. Also, you might want to consider adding blood in a dragged pattern, like a wounded marine was dragged into the middle recently. Anyway, good job! Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1025706 Share on other sites More sharing options...
Artimis Vergadin Posted June 7, 2006 Share Posted June 7, 2006 don't respray it, for all that is good and holy don't respray it :P As suggested, try drybrushing bleached bone again. I wouldn't glue any sand on, that'll look daft. My best advice, try fiddling with it, muck around a bit and see what you like and don't like. :blink: Aritmis Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1025754 Share on other sites More sharing options...
maximo Posted June 8, 2006 Author Share Posted June 8, 2006 hey thanks everyone for your suggestions. 10 replies in less than 24 hours! thats why i post here. About the re-spraying: nothing is glued so if i resprayed it would only be the floor section and nothing else would be ruined. But i think ill try adding some ink and paint in the recesses then more drybrushed brown and then more bone over the top. Maybe even some small blood stains (thanks NoxI). After that i might consider adding some debris/mud. I put some mud on my predator using sand, static grass and pva, and it looked ok. Once again thanks for the replies and ill get some photos up either tonite or tomorrow depending how i go. -Max Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1025941 Share on other sites More sharing options...
maximo Posted June 23, 2006 Author Share Posted June 23, 2006 yeh so it took me about a week to repaint my rhino...darn school. Anyway i added some more dirt in the recesses and repainted the top part bone then added more drybrushed mud and some blood splatters. Im much happier with it now. Check it out: http://static.flickr.com/69/173083776_6d51a5a9a7_o.jpg Thanks all for the help. -max +++ Oversized image turned to a link, pleaserefer to the forum rules for more information. +++ Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1037404 Share on other sites More sharing options...
Obliterator Posted June 23, 2006 Share Posted June 23, 2006 The freehand and detailing is amazing! I'm not a huge fan of the red blob in the middle of the floor though. The rest of the dirt is ace, but that red seems... wrong? Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1037444 Share on other sites More sharing options...
pinkbunny Posted June 23, 2006 Share Posted June 23, 2006 any decent CC squad will wade through gaurdsmen Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1037544 Share on other sites More sharing options...
Obliterator Posted June 23, 2006 Share Posted June 23, 2006 any decent CC squad will wade through gaurdsmen :angry: huh? Are we looking at the same pics here? Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1037570 Share on other sites More sharing options...
Rymeer Posted June 23, 2006 Share Posted June 23, 2006 yeh so it took me about a week to repaint my rhino...darn school. Anyway i added some more dirt in the recesses and repainted the top part bone then added more drybrushed mud and some blood splatters. Im much happier with it now. Check it out: http://static.flickr.com/69/173083776_6d51a5a9a7_o.jpg Thanks all for the help. -max +++ Oversized image turned to a link, pleaserefer to the forum rules for more information. +++ Looks to me like you've fixed all problems related to the floor. The addition of the blood mark in the center of the floor just adds charactor to my point of view. Instant back history in one glance at the model. Keep up the good work and finish painting the exterior to the level of quality of the interior. I especially like the free-handed side panel artwork. Very well done and no doubts inspiring to the squad as they are conveyed to the battle. Rymeer Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1037594 Share on other sites More sharing options...
maximo Posted June 23, 2006 Author Share Posted June 23, 2006 Hey sorry for the large picture. And thanks for the comments guys @Obliterator: i was going for a blood splatter effect, maybe too much? Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1037634 Share on other sites More sharing options...
Obliterator Posted June 24, 2006 Share Posted June 24, 2006 @Obliterator: i was going for a blood splatter effect, maybe too much? IMHO it guides the eye to the centre of the floor, instead of the gorgeous detail work on the walls. I preferred the original foor, but that'sapersonal thing guess. Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1038215 Share on other sites More sharing options...
Shinobi_soldier Posted June 24, 2006 Share Posted June 24, 2006 any decent CC squad will wade through gaurdsmen what is he talking about? did he post in the wrong thread? Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1038217 Share on other sites More sharing options...
Commander Biguss Brutus Posted June 24, 2006 Share Posted June 24, 2006 i think he means that the squad is bound to have blood all over its boots, what with all the killing and wading through blood they do. very very nicely done, makes me wish I hadn't glued my rhinos and crusader shut, and at first glance i thought the angel freehand might have been a painted piece of a forgeworld door :P and on closer inspection, wow. Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1038312 Share on other sites More sharing options...
Ju'kosian Posted June 24, 2006 Share Posted June 24, 2006 whow nice paint job dude.. that angel is :P ;) :tu: Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1038315 Share on other sites More sharing options...
maximo Posted June 25, 2006 Author Share Posted June 25, 2006 Thanks all for the comments. @obliterator: yeh i see what you mean ay. :P I got a bit carried away finding different mixes of red, brown ink and water. But im not too fussed about it, could have been better but for me it still looks alright. ha ha and i really think that pinkbunny guy has got the wrong thread ay. -max Link to comment https://bolterandchainsword.com/topic/89149-wip-command-rhino/#findComment-1038847 Share on other sites More sharing options...
