Everscream Posted June 7, 2006 Share Posted June 7, 2006 So, i have pretty much decided that i want to start a new army... or perhaps just add something to my emperors children army. Why do i tell you this? because i want to theme it for CoD! so, i was wondering, how could i do this? of course, something with the bases would be great, but any other ideas? are you planning on doing anything like this? thanks in advance! - Ever Link to comment https://bolterandchainsword.com/topic/89165-enter-the-cities-of-death/ Share on other sites More sharing options...
millest Posted June 7, 2006 Share Posted June 7, 2006 not 100% marine based - ok well its =I= based at a very large stretch of the imagination but the principles and ides it gives are superb: http://uk.games-workshop.com/imperialguard...ental-assets/1/ just a little bit of help there to get you started cheers millest Link to comment https://bolterandchainsword.com/topic/89165-enter-the-cities-of-death/#findComment-1025456 Share on other sites More sharing options...
lieutenant L Posted June 7, 2006 Share Posted June 7, 2006 Hi Well you could drybrush the lower leg greaves to suggest a dusty urban environment on the actual minis as well as the bases Maybe make some urban based loot counters - this one is some thing i did quickly last week which i might use to suggest that it is an urban environment http://img.photobucket.com/albums/v489/lieutenant_L/Work%20in%20progress%20shots/a88573d1.jpg ( link to it with lights on link ) If you wanted to go more into the minis - why not model on things like capes - night goggles etc. Possibly a detailed brick or torn bits of urban camouflague cloth god luck thanks, L Link to comment https://bolterandchainsword.com/topic/89165-enter-the-cities-of-death/#findComment-1025491 Share on other sites More sharing options...
Freakiq Posted June 7, 2006 Share Posted June 7, 2006 I used roof tiles I smashed up with a hammer (though any flat rocks will work) and glued to the bases with industrial glue. The result is slightly bigger than the slate included in the COD basing set and is reserved for characters or extra large minis. My Emperors Champion and A terminator (both WIP). The bases will have more debris and some slate/gravel and be painted grey and the mini's greaves will be painte to look suitably dusty. Link to comment https://bolterandchainsword.com/topic/89165-enter-the-cities-of-death/#findComment-1025507 Share on other sites More sharing options...
