ardyer Posted June 9, 2006 Share Posted June 9, 2006 I am currently building one of the metal chaos dreadnoughts and I am using rare earth magnets to allow for swapable gun arms. So far I have trimmed the post on the body by the thickness of two of the magnets and glued a 1/4 inch magnet to the end. After glueing another magnet into the arm, it holds fine, except the arm tends to rotate so the barrels of the guns point to the ground. This generally only happens if anything touches the arm. I would like to stabalize the arms so this does not happen. The two ideas I've had so far are: Put a pin in the body and a hole in each of the arms, so the pin keeps the arm from rotating Put an additional 1/16th inch magnet in the body and the arms I am afraid that a pin would eventually get bent or scratch up the rest of my models, while another magnet might not be strong enough, since there is only enough space for a 1/16th inch magnet. Does anyone have any experiences with these or other ideas? Link to comment https://bolterandchainsword.com/topic/89285-rare-earth-magnets-and-dreadnoughts/ Share on other sites More sharing options...
Yamez Posted June 9, 2006 Share Posted June 9, 2006 If it moves because of the weight, I would go with the second magnet. BUT, If you can, I would keep it movable, It's much more fun when you can move arms up and down :) Link to comment https://bolterandchainsword.com/topic/89285-rare-earth-magnets-and-dreadnoughts/#findComment-1026830 Share on other sites More sharing options...
-Q- Posted June 9, 2006 Share Posted June 9, 2006 Pinning is going to be the strongest solution. Use hollow brass rod, it will be a lot stronger than thin wire, paperclips, etc. Drill your holes for a very tight fit, or use Greenstuff to keep it snug. A short hollow snug rod should not bend. Link to comment https://bolterandchainsword.com/topic/89285-rare-earth-magnets-and-dreadnoughts/#findComment-1026848 Share on other sites More sharing options...
Legacy40k Posted June 9, 2006 Share Posted June 9, 2006 The best solution.. Don't use metal dreadnaughts :rolleyes:. However, the pinning idea does work, I've done it. -Legacy40k Link to comment https://bolterandchainsword.com/topic/89285-rare-earth-magnets-and-dreadnoughts/#findComment-1026873 Share on other sites More sharing options...
Azazal Posted June 9, 2006 Share Posted June 9, 2006 Fo the arms, I found that the 3/8 inch magnets are fine. I have a metal dread and the magnets hold any arm without a problem Link to comment https://bolterandchainsword.com/topic/89285-rare-earth-magnets-and-dreadnoughts/#findComment-1027026 Share on other sites More sharing options...
Sian Posted June 9, 2006 Share Posted June 9, 2006 If you just want swappable arms, not poseable, (with a metal dread, I wouldn't bother, arms are just too heavy) magnet+pin is ideal. My plastic and resin dreads are pretty fully poseable.. a 1/8"x1/2" rod magnet slips right into the torso arm posts after drilling them out and and is strong as hell. Link to comment https://bolterandchainsword.com/topic/89285-rare-earth-magnets-and-dreadnoughts/#findComment-1027128 Share on other sites More sharing options...
SigmundMan Posted June 9, 2006 Share Posted June 9, 2006 An additional magnet is enough, here are the two arms on my dread: http://i12.photobucket.com/albums/a245/Sigmundman/P6095008.jpg http://i12.photobucket.com/albums/a245/Sigmundman/P6095009.jpg Orginally I thought that I would want to move the CC arm up or down so there are 3 magnets, but really theres no way to make that dreadnought not look static without serious modification. Link to comment https://bolterandchainsword.com/topic/89285-rare-earth-magnets-and-dreadnoughts/#findComment-1027165 Share on other sites More sharing options...
Heimdal Posted June 9, 2006 Share Posted June 9, 2006 I Link to comment https://bolterandchainsword.com/topic/89285-rare-earth-magnets-and-dreadnoughts/#findComment-1027245 Share on other sites More sharing options...
ardyer Posted June 9, 2006 Author Share Posted June 9, 2006 The best solution.. Don't use metal dreadnaughts ;). Well, I bought this thing long before Forgeworld was even imagined by GW, so I don't really have a choice ;) Thanks all for the help, it looks like either options will work and I have tubing on hand, but not the smaller magnets, so I think I am going to go that route. Thanks!!! Link to comment https://bolterandchainsword.com/topic/89285-rare-earth-magnets-and-dreadnoughts/#findComment-1027261 Share on other sites More sharing options...
