mooMan Posted June 13, 2006 Share Posted June 13, 2006 I've just go my hands on some super sculpy, and was just wondering if anyone knows any tip, tricks or tutorials I could use. I've used green stuff before, so know basic sculpting techniques, just want to know if there is anything that I should take in consideration when using it. Thanx in advance. Link to comment https://bolterandchainsword.com/topic/89509-super-sculpy/ Share on other sites More sharing options...
Legacy40k Posted June 13, 2006 Share Posted June 13, 2006 Don't over cook it, it burns (has more to do with too hot than too long), It can be worked in layers, so you can make a rough shape, then go over it with more and bake it ontop (or use greenstuff overtop) If thin, it is brittle and will shatter if you try and bend it or drop it. Breaking it can leave a really cool rock look on the break Carve into it pre baking. You don't need to keep your tools wet. pinning into it works well. sanding can leave a polished stone like surface. Don't bake on a base, bake seperatly then glue on. I think thats enough for now.. -Legacy40k Link to comment https://bolterandchainsword.com/topic/89509-super-sculpy/#findComment-1029536 Share on other sites More sharing options...
Purge The Weak Posted June 13, 2006 Share Posted June 13, 2006 I bnake muffins while I use it! Yum! Link to comment https://bolterandchainsword.com/topic/89509-super-sculpy/#findComment-1029539 Share on other sites More sharing options...
mooMan Posted June 13, 2006 Author Share Posted June 13, 2006 Thanks for the tips Legacy. Link to comment https://bolterandchainsword.com/topic/89509-super-sculpy/#findComment-1029556 Share on other sites More sharing options...
Deacoknight Posted June 13, 2006 Share Posted June 13, 2006 I've also seen it mixed with Green Stuff to act as a looser sculpting base. If mixed with Green Stuff, it won't harden as fast and you'll have more time to work in details. Never done it myself, but I have heard of using it in that fashion. Link to comment https://bolterandchainsword.com/topic/89509-super-sculpy/#findComment-1029660 Share on other sites More sharing options...
madscuzzy Posted June 13, 2006 Share Posted June 13, 2006 Just make sure you bake it Raw super sculpy melts plastic. Takes a while but definately does. Link to comment https://bolterandchainsword.com/topic/89509-super-sculpy/#findComment-1029878 Share on other sites More sharing options...
Chaoswolf Posted June 13, 2006 Share Posted June 13, 2006 Obviously this would only be for metal models, baking would be bad for plastic. Or is there some other way of 'baking' it? Link to comment https://bolterandchainsword.com/topic/89509-super-sculpy/#findComment-1029916 Share on other sites More sharing options...
rabblerouser Posted June 14, 2006 Share Posted June 14, 2006 Unbaked sculptey will melt GW plastics!! But very slowly. So you need to bake it eventually Link to comment https://bolterandchainsword.com/topic/89509-super-sculpy/#findComment-1029938 Share on other sites More sharing options...
Legacy40k Posted June 14, 2006 Share Posted June 14, 2006 Unbaked sculptey will melt GW plastics!! But very slowly. So you need to bake it eventually Why would you be leaving it on plastic long enough to melt it? -Legacy40k Link to comment https://bolterandchainsword.com/topic/89509-super-sculpy/#findComment-1029986 Share on other sites More sharing options...
DXM Posted June 14, 2006 Share Posted June 14, 2006 One more tip..... Bake your piece as per temperature and time on the instructions , them turn off the heat and leave your piece in the stove till the oven cools back to room temperature. Super sculpy has a nasty habit of forming hairline cracks if cooled down to quickly. Also sculpy kind of smell when you cook large pieces, the owner of the stove might appreciate this. That is why some sculpters use an old toaster oven to bake their pieces. Hope this helps.........DXM Link to comment https://bolterandchainsword.com/topic/89509-super-sculpy/#findComment-1030015 Share on other sites More sharing options...
