Captain Garviel Loken
Awsome so far. I cannot wait to see him done. He is awsome in the books. :3
Alpha
Yeah Garviel Loken does some major ownage, and the model is shaping up to be something impressive indeed. I actually had the similar image in my head of him except he was standing on some rocks or soemthing giving it the authority pose, but to each his own.
Abaddon you say?
yes would love to see that one too! :rolleyes:
anyone thought of doing Jubal yet?
I think Abaddon, Torgadon and Aximal will all be coming after i have Vipus' and Jubal's squads done... :)
As for Lokens pose im having some problems focusing the camera and getting a decently sized pic, but to give you an idea his left arm is extended out and is holding the chainsword, his right has the bolter and is slightly lowered towards the floor, im not sure whether to have him looking in the same direction as the chainsword or the bolter. ;) Ill try and get pics up later on today though ;)
Im also thinking of using thin plasticard to space out the joins in Abaddons power armour as the book has him being a lot taller than the other captains.
Thanks for all the comeback so far, im hoping to have Loken finished by next week, some more ideas for bases would be apreciated as well thanks :wub:
Now that depends. Do you want him to sort of have the 'I'm rock hard come and get it' look Or the 'I'm about to rip your face off and feed it to my dog' look
If you want the 'I'm rock hard come and get it' look have him looking over the bolter, or if you want the 'I'm about to rip your face off and feed it to my dog' look have it looking with the chain sword.
Either way i'll make a nice model. Personally I'd have it over the bolter as that the sort of person I am, but It's your model do what you want :)
I'd go for a combat knife rather than a chainsword, he doesnt use one in the books.
his default weapon however does seem to be a 'broad sword' id asume for 40k gaming terms its a power sword, looking at the front cover if you were to shorten a power sword that would work well... alternatly check the warhammer range.
It actually states in the book that he uses a chainsword, the Emperors Children wield broadswords:
"A jolt of force tore his bolter from his hands, so he reached over his hip and drew his chainsword from its scabbard."
And as for the head ill be using one of the FW MK4 ones as the lunar wolves usually fight helmeted. :)
Test pics in 2 min...
Heres the pics :D :
http://i65.photobucket.com/albums/h222/hal...rk/DSCF0056.jpg
http://i65.photobucket.com/albums/h222/hal...rk/DSCF0024.jpg
http://i65.photobucket.com/albums/h222/hal...rk/DSCF0017.jpg
The 40mm base pictured is one i've had floating about for a bit, :P as it is im still not sure which i'll be using, another idea i've had is to sculpt a demonic face into a 25mm base then add slate so that the face doesnt stand out too much. :)
Ill be using the marine back pack with an exhaust on the back, for the bolter im going to fill in the finger grooves at the front, shorten the back and smooth off the bottom of the clip to make it look older, im not to keen on using the 2nd ed bolters as i dont think they're as detailed.
What do you mean by plain though? :)
