[WIP] Scouts
Cadian heads wrought with ultra soft sandpaper.
http://i43.photobucket.com/albums/e392/The_Ravenheart/Dark%20Angels/Scouts/Scouts4.jpg
http://i43.photobucket.com/albums/e392/The_Ravenheart/Dark%20Angels/Scouts/Scouts2.jpg
http://i43.photobucket.com/albums/e392/The_Ravenheart/Dark%20Angels/Scouts/Scouts1.jpg
http://i43.photobucket.com/albums/e392/The_Ravenheart/Dark%20Angels/Scouts/Scouts3.jpg
https://bolterandchainsword.com/topic/89940-wip-scouts/
I love the idea with this, I tried it myself with metal scouts and gave up after 2 because it was such a pain for me without the tools, They look great to me but one thing I'd suggest if you want to try to avoid some of the "looks like guard comments" is to try to greenstuff structures on the helmet similar to the ones marines have around the back of the head and the vent thingy on top.
looks great to me though, bolt pistols look great without the silencers too
great stuff
https://bolterandchainsword.com/topic/89940-wip-scouts/#findComment-1034489
Those scouts look amazing! But I agree, initially they do look more like special forces Imperial Guardsmen than scouts. But the idea of the helmets is a good one. This has seriously got me thinking about how to alternatively model scouts to do away with the fat necks.
The helmets make sense, because only a fool goes to war with his melon exposed. But they DO look too much like IG.
What about gask masks ala Steel Legion troopers instead? That would be hard to do, but might be worth a try. I think you'd have to probably sculpt the masks on, because it would get expensive to use Steel Legion trooper heads for all your scouts. But this is a good step, using alternative heads.
I personally dont even mind the IG heads. They look great to me.
https://bolterandchainsword.com/topic/89940-wip-scouts/#findComment-1034507
Its interesting to see how better the scouts are when they arent using their typical 'Jay Leno' heads.
I think some more detail work needs to be put into the helmets as they stick out as semi Guard looking.
Must admit, i wouldnt mind a box or two (or even three!!) of the new scouts, but their heads HAVE to go.
https://bolterandchainsword.com/topic/89940-wip-scouts/#findComment-1034514
  Brother Atheos said:
  Arbites_Augmentented said:
Are those ork sluggas? :ph34r:
It took me 3 glances and severe eye strain but you'd be right :ph34r: They dont look too out of place which is much more alarming.
3 glances and severe eye strain? Those are regular bolt pistols with the barrels trimmed down?
https://bolterandchainsword.com/topic/89940-wip-scouts/#findComment-1034517
I like helmets on Scouts. I put shaved Marine helmets on mine. I figure the helmets won't need all the powered stuff a full Marine would but they'd still have some amount of breath filters and targeting junk.
Once yours are painted up they'll look great. In the context of a full army there will be no confusion about Marine vs Guard, it's just a byproduct of raw plastics.
One recommendation would be to shape the bottom of the helmets to have a bit more curve. The straight end to them makes them look a little odd. You don't want them looking like balls, just a curved down final edge with less of an outward flare.
https://bolterandchainsword.com/topic/89940-wip-scouts/#findComment-1034523
Are those ork sluggas? :o
It took me 3 glances and severe eye strain but you'd be right :P They dont look too out of place which is much more alarming.
Ah... i think you may well be right :P :) . *Dives under the nearest moving Land Raider*
https://bolterandchainsword.com/topic/89940-wip-scouts/#findComment-1034662
