Primer22 Posted June 21, 2006 Share Posted June 21, 2006 Ok, here is a link to some waterslide decal paper for use with inkjet printers. Now my question is has anyone tried this stuff before because I want to do banners for my death guard and not pay someone else to do the printing. Link to comment https://bolterandchainsword.com/topic/90081-waterslide-decal-paper/ Share on other sites More sharing options...
primarch111 Posted June 21, 2006 Share Posted June 21, 2006 I HAVE USED IT SEVERAL TIMES AND THE RESULTS VARY DEPENDING ON THE QUALITY OF YOUR PRINTER. IF YOU ARE DOING BANNERS USE THE WHITE BACK GROUND PAPER IT HELPS THE COLOR AND DETAIL COME OUT, USE A STRAIGHT EDGE TO CAREFULLY CUT THEM OUT OTHER WISE YOU WILL HAVE SOME WHITE SHOWING ON EDGES . FOR CHAPTER BADGES AND SQUAD NUMBERS USE THE CLEAR AS THEY WILL BETTER BLEND WITH TH MINI. DON'T FORGET TO SPRAY THE SOLUTION ON THEM OR ELSE WHEN U PUT THEM IN WATER THE IMAGE JUST FALLS OFF. (SORRY MY CAPS LOCK IS STUCK) Link to comment https://bolterandchainsword.com/topic/90081-waterslide-decal-paper/#findComment-1036234 Share on other sites More sharing options...
Obliterator Posted June 21, 2006 Share Posted June 21, 2006 (SORRY MY CAPS LOCK IS STUCK) HAVE YOU TRIED USING A SCREWDRIVER TO FIX IT? :tu: Link to comment https://bolterandchainsword.com/topic/90081-waterslide-decal-paper/#findComment-1036273 Share on other sites More sharing options...
primarch111 Posted June 21, 2006 Share Posted June 21, 2006 YEAH AND THE BUTTON FLEW OFF :tu: :P :P :wink: AHWELL HAVE TO GET A NEW ONE TOMMORROW :ot: :ot: :ot: :ot: Link to comment https://bolterandchainsword.com/topic/90081-waterslide-decal-paper/#findComment-1036325 Share on other sites More sharing options...
Crosscheck42 Posted June 21, 2006 Share Posted June 21, 2006 CAPSLOCK IS LIKE CRUISE CONTROL FOR "COOL." Just kiddin' :) Link to comment https://bolterandchainsword.com/topic/90081-waterslide-decal-paper/#findComment-1036350 Share on other sites More sharing options...
Shinobi_soldier Posted June 21, 2006 Share Posted June 21, 2006 I have sworn off decals forever, i try to do freehand (emphasis on try) whenever i can. sometimes it doesnt turn out as well, but the fact that it's freehand gives me a sense of satisfaction. however, i think the idea of custom decals is a good idea, because you could design your own fo a DIY chapter or something... show us some pictures if you decide to get the paper Link to comment https://bolterandchainsword.com/topic/90081-waterslide-decal-paper/#findComment-1036375 Share on other sites More sharing options...
OwlandMoonGuy Posted June 22, 2006 Share Posted June 22, 2006 I use it all the time~ Here are some examples: I make custom decals for almost every loyal squad I paint-up. So if you Link to comment https://bolterandchainsword.com/topic/90081-waterslide-decal-paper/#findComment-1036535 Share on other sites More sharing options...
Primer22 Posted June 22, 2006 Author Share Posted June 22, 2006 Thanks for the replies and it looks like I'll be getting some next time i have the money, currently job seeking, Cheers. BTW OwlandMoonGuy those look great and nice use of the Plauge marine heavy weapons head. Link to comment https://bolterandchainsword.com/topic/90081-waterslide-decal-paper/#findComment-1036546 Share on other sites More sharing options...
