Mutated Hull
Okay, yesterday I got myself a Chaos Predator for my Word Bearers. I want to convert it to have the Mutated Hull upgrade. The problem is, I can't figure out how to do it. I've got plenty of ideas, but they all seem to overlap with daemonic possession/parasitic possession. I've done a search and can't find any topics on it.
So, how have you represented mutated hull?
https://bolterandchainsword.com/topic/90870-mutated-hull/
Right,
Parasitic possession: The only thing here holding the vechicle together is the daemon, it would look as if it could fall apart at any moment.
Daemonic possession: A daemon has taken control of the vechicle and must be bound to it, terefore all hatches would be covered in sigils and chained shut with runic chain.
Mutated hull: The vechicle is not neccessarily possessed, yet the hull constantly changes, moves and writhes with a life of its own. Try looking at the "flesh" bonding the armour of the new deathguard models and try replicating it on a larger scale on the panels of your chosen vechicle.
https://bolterandchainsword.com/topic/90870-mutated-hull/#findComment-1044901
I've been planing to do a mutated hull on my chaos pred for a while now and the idea I came up with was to use the heads from the chaos mutations spru. Cutting them in half and gluing them to the hull, then melding them together with GS. Warning: this is proving to be a huge amount of work (:blush: me after a few hours of doing this) and getting enough heads is proving to be a problem.
https://bolterandchainsword.com/topic/90870-mutated-hull/#findComment-1044978
With Mutated hull, all it is, it spike coming out the front & other stuff like bullet holes.
Here a exsample, this photo by Vyrus from this site, during the UK GT heat 3 2004
http://www.pbase.com/vyrus/image/37147181
Just simple add cock-tail sticks, green stuff around it & have like crack armour. Or rememeber you get the plate with spikes, on the Chaos spure.
The other op is to have a Crusifed Space Marine.
Hope this helps
IP
https://bolterandchainsword.com/topic/90870-mutated-hull/#findComment-1045024
I quite like the idea of having fleshy areas on the hull, i think that mixed with the idea of spikes, limbs and other random appendages would be quite cool for mutated hull as the way i see it is that the power of chaos has caused the vehicle to mutate in the same way that that it causes a creature to become a spawn. :D
Thinking of this has reminded me of the old nurgle deathguard predator :D
https://bolterandchainsword.com/topic/90870-mutated-hull/#findComment-1045353
I represent mutated hull with blobby growths of putty, with cocktail stick ends pushed in (for a quick job) painted up to look like sore flesh with horn poking out. Some of my bigger pieces have rotten flesh in place of hull components.
For daemonic possession, I sculpt faces into the hull plates.
https://bolterandchainsword.com/topic/90870-mutated-hull/#findComment-1048216
