Big Woop Posted July 4, 2006 Share Posted July 4, 2006 Are there any tricks to make greenstuff harden/dry faster? Link to comment https://bolterandchainsword.com/topic/90960-greenstuff-query/ Share on other sites More sharing options...
Angrons_Chosen Posted July 4, 2006 Share Posted July 4, 2006 put it in a rather hot place eg. sun, really hot lamp... Link to comment https://bolterandchainsword.com/topic/90960-greenstuff-query/#findComment-1045740 Share on other sites More sharing options...
Commander Trask Posted July 4, 2006 Share Posted July 4, 2006 As far as i am aware, GS drys harder/faster depenting on the ration quantity of the mix. More yellow adds elascicity to the mix so it stays pliable for longer, while more blue makes it harder. I do know that if you add a small quantity of poly-cement (plastic glue) you can spreat the GS more easily almost as if it were the same consistency as margerine or soft butter. Link to comment https://bolterandchainsword.com/topic/90960-greenstuff-query/#findComment-1045743 Share on other sites More sharing options...
Volkainen Posted July 4, 2006 Share Posted July 4, 2006 The ratio of blue/yellow makes a difference, however you can also set the piece under a light (even as low as 40 watts) to speed up the hardening.just be sure it doesnt burn or droop under the heat. Link to comment https://bolterandchainsword.com/topic/90960-greenstuff-query/#findComment-1045956 Share on other sites More sharing options...
macorrie Posted July 4, 2006 Share Posted July 4, 2006 As far as i am aware, GS drys harder/faster depenting on the ration quantity of the mix. More yellow adds elascicity to the mix so it stays pliable for longer, while more blue makes it harder. I do know that if you add a small quantity of poly-cement (plastic glue) you can spreat the GS more easily almost as if it were the same consistency as margerine or soft butter. If you do add plastic glue to the putty be sure to mix it VERY well ( i didnt once and it cause bubbling real bad) Link to comment https://bolterandchainsword.com/topic/90960-greenstuff-query/#findComment-1045998 Share on other sites More sharing options...
Commander Trask Posted July 4, 2006 Share Posted July 4, 2006 As far as i am aware, GS drys harder/faster depenting on the ration quantity of the mix. More yellow adds elascicity to the mix so it stays pliable for longer, while more blue makes it harder. I do know that if you add a small quantity of poly-cement (plastic glue) you can spreat the GS more easily almost as if it were the same consistency as margerine or soft butter. If you do add plastic glue to the putty be sure to mix it VERY well ( i didnt once and it cause bubbling real bad) i tend to add just a spot after its mixed and applied ot the area. I just put a spot (a very small spot) on the sculpting tool and it lest is spread easily handy for smooth joins Link to comment https://bolterandchainsword.com/topic/90960-greenstuff-query/#findComment-1046017 Share on other sites More sharing options...
stayeatingpaint Posted July 4, 2006 Share Posted July 4, 2006 As far as i am aware, GS drys harder/faster depenting on the ration quantity of the mix. More yellow adds elascicity to the mix so it stays pliable for longer, while more blue makes it harder. when i took the Academy Class in Games Workshop they told me that the yellow makes it harder. Link to comment https://bolterandchainsword.com/topic/90960-greenstuff-query/#findComment-1046022 Share on other sites More sharing options...
Legacy40k Posted July 4, 2006 Share Posted July 4, 2006 As far as i am aware, GS drys harder/faster depenting on the ration quantity of the mix. More yellow adds elascicity to the mix so it stays pliable for longer, while more blue makes it harder. when i took the Academy Class in Games Workshop they told me that the yellow makes it harder. They were wrong. Blue makes it harder, blue is harder to begin with. -Legacy40k Link to comment https://bolterandchainsword.com/topic/90960-greenstuff-query/#findComment-1046183 Share on other sites More sharing options...
patsy02 Posted July 4, 2006 Share Posted July 4, 2006 when i took the Academy Class in Games Workshop they told me that the yellow makes it harder. They were crap teachers. :( Link to comment https://bolterandchainsword.com/topic/90960-greenstuff-query/#findComment-1046185 Share on other sites More sharing options...
