BLARGAG!!! Posted December 14, 2007 Share Posted December 14, 2007 just a quick question.... where do i cut the clip for the side mounted clip. just the actual clip or the part that holds it onto the bolter also.. i really want to try some of the side mounted clip bolters for my up and coming army. Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1443124 Share on other sites More sharing options...
kanan Posted December 15, 2007 Share Posted December 15, 2007 the part that holds the clip. ill post a pic to show you hold on. http://i161.photobucket.com/albums/t229/zrolimit88/DSC03284-1.jpg Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1443577 Share on other sites More sharing options...
Ardus Posted December 15, 2007 Share Posted December 15, 2007 GM SFD, Kanan is correct the scope is from the vindie's rifle. The line is ment to be there, it's a modular extension to a bolter, kinda STC for a bolter given to crack shots. Ardus. Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1443633 Share on other sites More sharing options...
kanan Posted December 15, 2007 Share Posted December 15, 2007 Ardus i noticed initially in your design you had a plasma gun stock but after trying to attach a shoulder pad you removed it. am i right? Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1443648 Share on other sites More sharing options...
Ardus Posted December 15, 2007 Share Posted December 15, 2007 Ya, you are right. When everything was just tacked together and there was no shoulder pad it looked good, but once I put it him together with the shoulder pads and tilted the bolter to get him looking into the scope it just didn't look good any more. Kanan, what are you using for the barrels? The lase scopes look a little big on the bolters. maybe if you trim them dow n a bit it might work better. Ardus. Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1443670 Share on other sites More sharing options...
kanan Posted December 15, 2007 Share Posted December 15, 2007 Ardus, i thought so ~grins~. anyways the barrels are from johnson & johnson cotton buds. they are the only brand to use as other companies use a different kind of shaft made up of either a very flimsy solid plastic rod or an equally bad, plastic tube which doesnt glue well and drops off after a day or so lol. i have posted a pic to show you clearly what i am talking about. oh and the laser scope is in fact meant to be a starlight scope but maybe i will take your advice and trim the next one back a bit. thanks for the help mate. http://i161.photobucket.com/albums/t229/zrolimit88/DSC03291.jpg Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1443686 Share on other sites More sharing options...
Brother Bohemund Posted December 24, 2007 Share Posted December 24, 2007 not a real conversion but at least a small update inspired by the new ork bits Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1451140 Share on other sites More sharing options...
Red-Dragon Posted December 24, 2007 Share Posted December 24, 2007 Hey Im wondering if anybody has an ideas of how i can make a drum fed boltgun with the ammo drum on top.I saw a machine gun that had it on tv the other day and really want to use it for my marines. Thanks From The Red Dragon Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1451148 Share on other sites More sharing options...
Korloth Darkwolf Posted December 24, 2007 Share Posted December 24, 2007 Here's a WIP combi bolter for my wolf lord conversion im doing. http://i159.photobucket.com/albums/t145/jsr_darkone/100_2142.jpg Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1451246 Share on other sites More sharing options...
Grey_Death Posted December 29, 2007 Share Posted December 29, 2007 Chopped this one up tonight. Just an idea that's been floating in my head for a while that finally got to see the light of day. It's a Gears of War style Close Combat Bolter. http://i116.photobucket.com/albums/o31/raynotisick/IMG_0500.jpg Thoughts comments and suggestions are welcome. It's still pretty WIP of course and rather rough around the edges, but it gets the idea across ;). Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1454353 Share on other sites More sharing options...
Brother Bohemund Posted December 29, 2007 Share Posted December 29, 2007 I like your cc bolter very much, Gray-Death. Have to try something like that on my templars. I only might try to move the chainsword a bit up so that it looks as if the chain could run into the bolter casing. Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1454430 Share on other sites More sharing options...
Grey_Death Posted December 29, 2007 Share Posted December 29, 2007 I like your cc bolter very much, Gray-Death. Have to try something like that on my templars. I only might try to move the chainsword a bit up so that it looks as if the chain could run into the bolter casing. Yeah that's my plan as well. I'm going to toy around with this some more and share the results as I get more completed. Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1454618 Share on other sites More sharing options...
derLumpi Posted June 16, 2008 Share Posted June 16, 2008 Hi folks, sorry for reanimating this thread. Really nice conversions. I was wondering if there are pictures of a bolter + flamer conversion? Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1601031 Share on other sites More sharing options...
Apoc666 Posted June 16, 2008 Share Posted June 16, 2008 Anyone got any ideas as to how to make pre-heresy style bolters? I need it for some pre-heresy Dark Angels I am working on. Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1601328 Share on other sites More sharing options...
Tigris Posted June 16, 2008 Share Posted June 16, 2008 Hi folks, sorry for reanimating this thread. Really nice conversions. I was wondering if there are pictures of a bolter + flamer conversion? Here linky T Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1601339 Share on other sites More sharing options...
derLumpi Posted June 17, 2008 Share Posted June 17, 2008 Hi folks, sorry for reanimating this thread. Really nice conversions. I was wondering if there are pictures of a bolter + flamer conversion? Here linky T thx Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1602133 Share on other sites More sharing options...
Asmodeus' Swordhand Posted June 17, 2008 Share Posted June 17, 2008 Here Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1602373 Share on other sites More sharing options...
Apoc666 Posted June 17, 2008 Share Posted June 17, 2008 Thank you Asmodeus. Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1602382 Share on other sites More sharing options...
KJB Posted June 17, 2008 Share Posted June 17, 2008 For once this is a well timed bit of thread-o-mancy - read the topic an hour ago, went and chopped up some cadian Grenade launchers and now have 3 drum fed bolters for Ferrus's finest Dead easy conversion and a good looking one to! Maybe this thread should be cleaned up (i.e. all links and pics together) and then stickied? This is the only topic I've read since I joined the board (in 2002) that made me physically get up and go and try converting!! :P And for that, I salute whoever resurrected this thread! Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1602700 Share on other sites More sharing options...
Castlerook Posted June 17, 2008 Share Posted June 17, 2008 I know this is mainly bolters, but heres a socom bolt pistol I made for a friend a couple of month back. http://i246.photobucket.com/albums/gg111/PaulC1984/S5030259.jpg Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1602789 Share on other sites More sharing options...
Pandora Posted June 17, 2008 Share Posted June 17, 2008 Here's a picture of my underslung 'True Grit' bolter: http://img.photobucket.com/albums/v320/John_Thompson/Death%20Guard/DG1.jpg http://img.photobucket.com/albums/v320/John_Thompson/Death%20Guard/DG2.jpg John that is awesome. :P Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1602810 Share on other sites More sharing options...
TheBaninator Posted June 17, 2008 Share Posted June 17, 2008 Anyone got any ideas as to how to make pre-heresy style bolters? I need it for some pre-heresy Dark Angels I am working on. Try this one: http://i66.photobucket.com/albums/h261/DoctorThunder/Black%20Widows/DSC01050.jpg found in this thread: (this isn't my work BTW) http://www.bolterandchainsword.com/index.p...t=0&start=0 I believe he started with a combi-melta, chopped off the melta barrel, chopped off the heatshield from a flamer, then atached it to the place the melta barrel is. Nice, simple, and streamlined if you ask me. -TB Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1602828 Share on other sites More sharing options...
Eiric Hakon Posted June 18, 2008 Share Posted June 18, 2008 http://i187.photobucket.com/albums/x226/Eiric_Hakon/PICT0294.jpg My WIP pre heresy bolter, havent finished it (stil allot of filling and GSing to do as you can see) yet not alot of time :(. However, you can see the general shape Edit: I'll replace the pic with a better one once I get one. Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1603806 Share on other sites More sharing options...
Brother-Flame Posted June 20, 2008 Share Posted June 20, 2008 I'll also add some pics soon, working on converting some Heavy bolters!!!! :) Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1605136 Share on other sites More sharing options...
kanan Posted June 21, 2008 Share Posted June 21, 2008 hey anarnaxe, that SOCOM bolt pistol is aces. great work! do you mind if i pinch this idea for my Dark Angel SOG? anyways heres my new MKXIII ABT (Advanced Boltgun Technology) sniper rifle. enjoy http://i161.photobucket.com/albums/t229/zrolimit88/DSC04628.jpg peace Link to comment https://bolterandchainsword.com/topic/94979-the-bolter-conversion-thread/page/4/#findComment-1605821 Share on other sites More sharing options...
