FAQ: Painting White
tahrikmili
WAIT NO!
when ever painting a light color ontop of a dark color, it is almost always a nono to go dark all the way to light without a transition color inbetween. except for metalics. they work diff.
if you are applying white onto a dark color, you may want to work the color up with something like a grey as the middle layer. otherwise, your white might come out with some really undesired results.
best way ive found is this...
straight codex grey, 50/50 dex grey and skull white, then 1 or 2 thin layers of skull white..
ive tried astronomicon grey in the past and never really liked the end result so its always worth seeing if you prefer another method..
also working through from deneb stone works a bit better than astro imho.
  • 3 months later...
  • 1 month later...
http://img.photobucket.com/albums/v230/lonewolf_dcc/010-2.jpg
the white was...
undercoated black
basecoat dheneb stone
badab black wash (undiluted)
dheneb stone highlight
50:50 dheneb stone + white highlight
white highlight
Thats a fantastic dirty white, essp painted from black, hmm im really starting to hate you ;) i may just have to steal the idea :)
I painted up my white scars using: Black Spray Undercoat - Block out the parts with Codex Grey, then Space Wolf Grey, then finally Skull White - the white comes out looking solid and opaque with just a hint of the ice blue from the space wolves grey underneath.
I go with a really bright white rather than a dirty one.
I prime the model with a couple of coats of astronomican grey and then I give them a wash in watered down blue/grey (adeptus battlegrey/mordian blue) and then keep on building up lots of layers of thinned down skull white. I leave the soft armour parts grey.
  • 3 months later...
Hola all
I am going to be painting white for my army and my way is coming out WAYYYY to thick here is my way Black cote to codex gray to bleached to 2 layers of white. It looks goob but its too thick so i want every one to plant on there white ideas
Thanks CHEERS
Guest Azeikel
I agree with Lando. If you are going to paint light colours (White, yellow etc) onto a miniature use white spray as a basecoat.
If painting darker colours use black spray.
Also since you main colour is white your job is half done. All you have to do is touch up the spray with a wash and afew dabs of paint in the recesses you missed.
Azeikel
I use a different technique to paint my white. First , I prime the model with chaos black spray , then basecoat it with Shadow gray , leaving black in the recesses , then use Space Wolves gray , leaving the shadow gray at dark areas.Finally , paint the model with a mix of Skull white 2:1 with Space wolves gray and highlight it with pure skull white.
There are as many ways to do an effective white as there are wasy to do yellow. My way is quite different from the poster in the quote or with those mentioned earlier in the thread but I have no doubt that they are all equaliy effective. Use the different links that the moderator has posted and work out what works for you. Best bit of advice I can give is to definatly thin down the white. takes a little longer having to use multiple layers but the effect is much much better.
I tried a method someone on the boards mentioned and was extremely pleased with the outcome.
Shadow Grey
Then several layers of thinned white. You want the white thinned to consistency of milk. It will look like it's going to run when you paint it on, but it doesn't.
If you are skilled enough you can leave some of the under grey as trimming.
A method I have used is the following...
1) Base coat grey.
2) Dry brush white without trying to get full coverage. The objective here is to just get the edges.
3) Fill in the areas between the dry-brushed edges with thinned white. This may take a couple of coats or more. This will smooth out the chalky look you get with drybrushing but you won't have to worry about slopping white into the recesses because you already got the edges in step #2.
Pretty easy and results in a good table-top quality.
Not only do I always drybrush white over black for a white fig (marine, fantasy, whatever) I must put out a quick hint.
I have just used the best primer I ever have, it is ColorTouch spray flat black enamel, and it is truly a killer tip (best thin coat, fast dry I have ever seen)
But, do what you want.
