ODM returns
ODM
So, here's the next step. It may not look like much, but the base coats and the washes for the bone and metallic areas are done.
Tomorrow I should be able to clean them up and highlight those secttions.
After that it's the green areas, then the details on the front and the wear and tear.
http://odmiller.tripod.com/sitebuildercontent/sitebuilderpictures/droppoddoorswashes.gif
https://bolterandchainsword.com/topic/179904-odm-returns/#findComment-2137678
Oooh ive been out crusading for a while and came back to this - how timely!
Mine's been sitting at basecoat stage for wuite some time now hopefully i'll grab some inspiration from what i can only assume will be yest another well executed ODM project ;)
I await the secret project with interest!
https://bolterandchainsword.com/topic/179904-odm-returns/#findComment-2137722
Here's my latest progress.
I completed the highlights on the green inside of the doors (hard to see).
http://odmiller.tripod.com/sitebuildercontent/sitebuilderpictures/droppoddoorsinnercomplete.gif
I based and washed the icons on the outside.
http://odmiller.tripod.com/sitebuildercontent/sitebuilderpictures/droppoddoorsouter1.gif
And I completed the icons. Don't worry about the bad photos, once they are done I'll take some close ups.
http://odmiller.tripod.com/sitebuildercontent/sitebuilderpictures/droppoddoorsouter2.gif
https://bolterandchainsword.com/topic/179904-odm-returns/#findComment-2157658
I had another marathon session tonight. I got the outside of the doors painted. Now I just need to weather and do a little clean up on them tomorrow night.
http://odmiller.tripod.com/sitebuildercontent/sitebuilderpictures/droppoddoorsoutsidedone.gif
http://odmiller.tripod.com/sitebuildercontent/sitebuilderpictures/droppoddoorspainted.gif
I then cleaned and primed the bases so I can start the base coats of the next step. This is exciting because the pods can start to take shape.
http://odmiller.tripod.com/sitebuildercontent/sitebuilderpictures/droppodbasesprimed.gif
https://bolterandchainsword.com/topic/179904-odm-returns/#findComment-2157784
Well, I've finally had some free time to make some progress. Here are the doors and bases assembled and almost completely painted. The only painting left to do is the weathering, which I'll do once the drop pods are done.
http://odmiller.tripod.com/sitebuildercontent/sitebuilderpictures/droppoddoorsbasedone.gif
Here is the next step, the inner cores. As I use these pods for dreads only, I will leave the harnesses out. These have the base coat and ink wash. I have to highlight and add the details.
http://odmiller.tripod.com/sitebuildercontent/sitebuilderpictures/droppodinnerturret.gif
https://bolterandchainsword.com/topic/179904-odm-returns/#findComment-2162398
Thanks Isiah.
Well, more progress today. I finished the "turrets" inside the pod, primed the fins, and did the base coats and washes for the metallice and bone colors on them.
http://odmiller.tripod.com/sitebuildercontent/sitebuilderpictures/droppodcenterturretsdone.gif
http://odmiller.tripod.com/sitebuildercontent/sitebuilderpictures/droppodfinsprimed.gif
http://odmiller.tripod.com/sitebuildercontent/sitebuilderpictures/droppodfinswashes.gif
https://bolterandchainsword.com/topic/179904-odm-returns/#findComment-2162814
