Legio Lexicon
(return to index)
gallery_26_6416_3509.pngour honour is your life. Let none dispute it.
YMMV - "your mileage might vary" meaning that advice/feedback given is descriptive rather than prescriptive and that the results aren't guaranteed.
A | B | C | D | E | F | G | H | I | J | K | L | M | N | O | P | Q | R | S | T | U | V | W | X | Y | Z | # | $
(return to index)
gallery_26_6416_1328.pngeal is its own excuse.
'Zerkers - Khornate berzerkers
(return to index)
1K Sons - Thousand Sons (see TS)
(return to index)
gallery_26_6416_26599.png (Abbreviations/acronyms/terms that start with special characters)
=][= - inquisitor or the Inquisition. Also used by the administrators/moderators of the Bolter & Chainsword when providing official guidance in their capacity as rules enforcers (as opposed to simply participating in discussions as hobbyists).
  • 9 years later...
This index has been updated.
Acronyms and abbreviations that appear with a dotted underline are in the acronym filter. If you hover your mouse over them, the definition (or a shortened form of the definition - there are character limits) will appear in a pop up.
Some acronyms and abbreviations will not be added to the acronym filter (or will be removed from the acronym filter) if they are problematic. Such problematic acronyms/abbreviations typically include lower case characters and often appear in other words, causing the acronym filter to function even when the actual acronym/abbreviation isn't being used (which creates confusion).
As always, if you have suggestions for additional acronyms, abbreviations, and terms, please provide them as a reply, including both the acronym, abbreviation, or term as well as a suggested definition. Similarly, if you think that an acronym, abbreviation, or term should be changed or deleted, please post your suggestion here.
