Blackadders Warlord WIP
Blackadder
Forgot to take these images. Command deck fully inserted showing access to the connecting tunnel to the Flight deck and cockpit. The two naves on either side of the tunnel were going to be sanitary facilities but I was apprised do to bio-engineering of the crew there is no necessity for necessaries.
Some sort of bag I suppose.............
http://i.imgur.com/lezcj6x.jpg
http://i.imgur.com/lezcj6xl.jpg
And the frame of the blast door component fits just right. Whew!
http://i.imgur.com/vf6gmn4.jpg
http://i.imgur.com/vf6gmn4l.jpg
Referring back a dozen pages or so concern was expressed as to where the pocket doors would slide when they were opened. That problem appears to have been resolved although if I decide to re-install the WC's, they will be out of service when the pocket doors are opened.
Access denied!:
http://i.imgur.com/4ILPn3F.jpg
http://i.imgur.com/4ILPn3Fl.jpg
The pocket doors closed:
http://i.imgur.com/RCBSBCQ.jpg
http://i.imgur.com/RCBSBCQl.jpg
I've just about reached my limit of patience in rendering detail. I'm a bit out of practice working this fine.
Here is a good point to show how I cut fine detail pieces not that I am as proficient as some who work with styrene but this works for me.
You will note that the door detail is still attached to the sheet (Which is upside down BTW the top of the door is at the bottom of the image). This gives you more of an area to hold onto while you are cutting the detail. After the lines are cut and the holes are final filed then I separate the piece from the sheet.
This is one of the few times I use a #11 Xacto tip for cutting, I usually use it to pick up tiny objects such as rivets to place them on the work.
I cut out any holes first which saves you from tearing the plastic trying to cut close to an edge. For some reason cutting the hole after you have done you straight slices causes the blade to wander.....
I'm trying something new cutting on cork board which seems to work rather well, I usually cut on an old wood butchers block board.
You can see at the top of the image the sketched in door detail for a slightly smaller door. That will be the door to the vestibule leading to the rear exterior door on the back of the Titan.
http://i.imgur.com/itDg7rn.jpg
http://i.imgur.com/itDg7rnl.jpg
After you have rough cut the holes with the knife, dress the edges and rounded corners with jeweler's files and or diamond needle files and yes that is an steel emery nail board; an indispensable trimming tool.
http://i.imgur.com/34WlNwE.jpg
http://i.imgur.com/34WlNwEl.jpg
I constantly receive suggestions that I could make these repetitive items faster if I moulded them. While I consider moulding a legitimate form of scratch building, it is a labor intensive and costly alternative to the first time user. I have attempted casting on a small scale to be sure but I have not obtained satisfactory results. Just the other day I attempted casting computer panels that I discarded as inferior. While casting doors may seem a quick alternative there is a lot of problems that the uninitiated do not realize. Bubbles are my big downfall. My castings of the computer panels would have been perfect were I to have a vacuum chamber but such things do cost money and it takes away from the hand crafted aspect of the hobby.
Leave the quick route to the professionals of whom can be said, "they're in it for the money." For the misguided few that build for the sake of building there is a certain satisfaction in saying I did it by hand.
Of course with the help of the sheet styrene industry and the designers of the original item and the internet for making available the access to the product in the first place and DAMNME if Obama wasn't right, I didn't build that, someone else did. :D
I almost think that some of the parts you make multiples of would be easier to make a mold and cast them in plastic.
Sorry to waste your time but I am trying to come up with a viable amniotic tank to immerse my Princep in and I have come up with this taken from Antenocitis Workshop.
These dedicated to 28 mm accessories look beautiful but are out of my price range to make this Titan viable plus they do not fulfill the requirements I deem necessary for my construct.
Never the less the ideas seem viable.
The amniotic Tank:
http://i.imgur.com/OsFD90q.jpg
http://i.imgur.com/OsFD90ql.jpg
http://i.imgur.com/Sgh1zBs.jpg
http://i.imgur.com/Sgh1zBsl.jpg
Thus far...................
I seem to have reached my limit attempting usable door frames for the side doors. I suppose I shall just go for the chiclet style wall panels so prevalent in SF venues. The door frames I coveted were much too fine in detail to render in a workable fashion.
The flash image reveals crudeness in the frame opening that I hope to remedy with the modified door trim.
http://i.imgur.com/OnRflIG.jpg
http://i.imgur.com/OnRflIGl.jpg
Well that's about it for this builder, I've devoted enough time to this door assembly not that I've put in a lot of time to this but enough already, unless I have a major epiphany the door is done as is............. Yeesh! :D
http://i.imgur.com/dM5BUtv.jpg
http://i.imgur.com/dM5BUtvl.jpg
http://i.imgur.com/uuorZWA.jpg
http://i.imgur.com/uuorZWAl.jpg
DANGER! DANGER Will Robbinson!!!!!!!!!! Ha!
The catwalks installed under the carapace in a rough and tumble fashion awaiting a touch of refinement and hand rails. Note that the command deck is not slid all the way into the slot so the rough front ends of the catwalks are exposed.
These catwalks will adjoin the front walks out to the main guns for servicing with appropriate ladder assemblies to the gun stanchions down to the guns themselves.
The left side walk with access to the Command deck vestibule..........
http://i.imgur.com/CqKxAzF.jpg
http://i.imgur.com/CqKxAzFl.jpg
The right side walk...............
http://i.imgur.com/ji7Pr5F.jpg
http://i.imgur.com/ji7Pr5Fl.jpg
So far almost all the interior is "plug in" modular so painting and view interior detail shouldn't be a problem.
http://i.imgur.com/wq9eDG1.jpg
http://i.imgur.com/wq9eDG1l.jpg
http://i.imgur.com/UjIubeP.jpg
http://i.imgur.com/UjIubePl.jpg
The only thing that bothers me is this is beginning to look like the promenade deck on the Titanic and there's not enough space for the deck chairs..........
http://www.mapsphotos.net/p%20photo/landscape/main/P1186.jpg
What about armoured blast shutters over the windows apertures? Look like an armoured Titanic promenade then :)
Stunning work can't wait to see this (and your Thunderhawk) all built and painted.
Thanks,
God's Blud marry if'n it hasn't been many a fortnight since I hung this abomination together in one piece. What strikes me the most is the numerous areas not yet adorn with detail on the exterior.
I've been working on the interior for at least two weeks and yesterday I started on the engineering level............... Since there are many interlocking pieces to the lowest deck I had to be sure the whole of the construct could be assembled.
On the plus side it can but on the minus side the leg joints and waist joints barely support the weight. I was sure that would be the case and have allowed for the 2.5 kilos the upper body weight.
The 1/4 inch hip bolts still need to be 'Loctited' once the final hip assembly is made but for now I'm afraid 'Dirty Harry' must stand splayed legged.
The straight on overall front view; the first wholly assembled image since before I built the Turbolazers.........
http://i.imgur.com/GVZUDEl.jpg
http://i.imgur.com/GVZUDEll.jpg
A very precarious infantryman's eye view of the God Machine............
http://i.imgur.com/57dvZNi.jpg
http://i.imgur.com/57dvZNil.jpg
A shot of the side armour fully installed but still a lot of detail needs to be added to the side of the carapace..........
http://i.imgur.com/OeIMqrX.jpg
http://i.imgur.com/OeIMqrXl.jpg
The upper waist rotation plate and the bottom of the pelvis block are totally devoid of detail; Fa!
http://i.imgur.com/6Hx4Dmk.jpg
http://i.imgur.com/6Hx4Dmkl.jpg
In all I am quite pleased with the results after almost exactly a years work but I would hazard a minimum of six more months to completion.
It's anyones guess what these triangular components are from a safety crib side rail to a cooling grid for airconditioning. I ran out of images for this area on the DS Warlord so I am referencing the SM game Warlord Titan
Anyway here is the inner panel of the chest armour and the upper engineering viewing window panel in the closed position.
http://i.imgur.com/0PPQ9so.jpg
http://i.imgur.com/0PPQ9sol.jpg
And here we have it in the open position to permit viewing of the interior detail. This whole central hull of the Titan is very strong but it looks like a house of cards.
http://i.imgur.com/P9KImjf.jpg
http://i.imgur.com/P9KImjfl.jpg
here we have the left side view with the Command deck gallery slid into place.
http://i.imgur.com/JHeVVwx.jpg
http://i.imgur.com/JHeVVwxl.jpg
and lastly the overall quarter view showing the reworked rear door frame just to demonstrate the fallibility of the Blackadder and a flash image of the same area above.
http://i.imgur.com/X1UrX8n.jpg
http://i.imgur.com/X1UrX8nl.jpg
Omnissiah be praised this is a Warhound eek.gif ! Keep up the amazing work Blackadder, I would like to see this Warmachine come into the service of the Imperium!
Thanks,
I have a favor to ask of you. Can you supply me with a link to a German/Austrian 40K forum?
