The Gauntlet of Fenris
MaveriK
MAP ONE
http://i140.photobucket.com/albums/r35/Azn_MaveriK/KrakenSpawn/DauntlessFew_zps62e4e358.jpg
The Dauntless Few
Rayray - Grey Hunter, Melta, Chainsword
WLK - Wolf Guard, TDA, CML, Power Maul
Zynk - Grey Hunter, Power Sword, Meltagun
Tsor - Blood Claw, Power Maul, Bolt Pistol
Ace - Blood Claw Bolt Pistol, Chainsword
http://i140.photobucket.com/albums/r35/Azn_MaveriK/KrakenSpawn/Solos_zps6f930d9a.jpg
Solo Drunkards
Brother Crazywolf
Wolf Lord Conan
Ace Debonair
Fytharin
Loki-LaughingDeath
Sanctarin
It seems your scanners are malfunctioning, Hunt-Master?
I ride with the Dauntless Few, and as best I can tell we never did successfully clone RayRay. :)
I'm all for the plan as stated by WLK; sounds solid.
Let's see if you can melt that kraken before I shoot the weak spot, Zynk. :P
:: SPECIAL SCENARIO ::
The long summer on Fenris has been intense this year; the eye of the wolf showed no mercy. Algae covered the shores around the southern islands. Vegetation grew to surreal proportions, causing thousands of kraken-spawn to boil out of the seas of Fenris. Alarmed filled all the scanners from both on orbit and from the mighty fortress known as the Fang. The brotherhood of the Iron Isles sealed their vaults, preparing for the onslaught and attack.
++++ INCOMING TRANSMISSION +++
"Our scanners from both the Fang and on orbit, are seeing massive migratory movements of kraken-spawn. All heading towards the southern islands. This event has not been seen by the Old Wolf and of the sky warriors since the Anvil, Arjac rose to distinction and becoming the champion he is today. Unfortunately eleven of the twelve great companies are out on crusades across the galaxy. Only a single great company, along with a skeleton crew of Inglorious Drunkards stand watch over the Wolf Kingdom and the mighty stronghold known as the Fang. For those brave enough to heed the call. Help stop the advance of those kraken-spawn by running the gauntlet." - Hunt Master, MaveriK
MAP ONE
http://i140.photobucket.com/albums/r35/Azn_MaveriK/KrakenSpawn/DauntlessFew_zps5f5aa628.jpg
The Dauntless Few
MAP TWO
http://i140.photobucket.com/albums/r35/Azn_MaveriK/KrakenSpawn/MapTwo_zps8f536955.jpg
The Mighty Alliance
Russ Brother 92 (Blood Claw) - Meltagun, Close combat weapon.
Warhorse47 ( Grey Hunter ) - Power Maul, Boltgun, Bolt Pistol, Wolf Standard.
eyeslikethunder ( Grey Hunter ) - Power Maul, Bolt Pistol, meltagun.
-Volsung- ( Blood Claw ) - Bolt Pistol, Close Combat Weapon.
Khine (Grey Hunter) - Mark of the Wulfen, Flamer, Bolt pistol, Wolf Standard.
MAP THREE
http://i140.photobucket.com/albums/r35/Azn_MaveriK/KrakenSpawn/Claws_zpsa6048cc8.jpg
The Claws
Arez - TDA with Flamer and CML
Skadi (Long Fang) - Heavy Bolter,Missile Launcher and Flamer
Nrth - melta, CC weapon
Forte - Power Axe, Bolter+Bold Pistol
Postal - Melta, CC weapon
MAP FOUR
http://i140.photobucket.com/albums/r35/Azn_MaveriK/KrakenSpawn/Solos_zps95a7cce3.jpg
Solo Drunkards
Brother Crazywolf
Wolf Lord Conan
Fytharin
Loki-LaughingDeath
Sanctarin
--EDIT--
FIXED. Time to get the dice rolling!
Map Three: forgot to put on your troop choice. Please list.
Map Four: I don't know much about your equipment. I placed your locations all on default. You can figure out the your wargear amongst yourselves and nominate a pack leader, or choose to go solo.
It looks like we have boats boys! Personally I will go with the ice beneath my feet. I don't think swimming is something the designers of TDA had in mind. Conan, which set of gribblies shall we take on? I say we go for the large ice pack in the range of E 6-8.
Zynk and Ace (E1) open fire at the Kraken in C4.
Rayray and TSOR (F2) open fire at the Kraken in D7.
If I can (in F1), I’ll split the Krak shots at the Krakens in B1 and B3. If I cant then fire both shots at the Kraken in B1.
I am unsure of the speed of the kraken, so this is my initial suggestions for targeting priority.
Also, unless Rayray himself posts, please consider my posts his as well. (He is my gaming buddy, and we already discussed this anyway)
Sounds good team?
WLK
Sounds good to me.
Ace, let's give these beasts the kiss of death!
Alright to make things simpler, designate one person in each map to post everyone's moves and attacks, that way I don't keep scrolling back and forth through several pages just to find everyone.
Also on a side note: There will be four waves. This is the first wave of kraken spawn. The fourth and final wave will have EVERYONE left surviving placed on a single map. Good luck! you have 48hrs to submit your instructions.
I'd rather shoot them, if it's all the same. :D
Seriously though, let's get these things.
EDIT:
I think we'll be designating Wolf Lord Kieran to be official movement-keeper of the Dauntless Few, since he's already going to be posting for himself and Rayray.
Wait, there's going to be FOUR WAVES of these things? :D
So much for learning to walk before you run, then.
I guess im pack leader for the hunt.
We are going to have alot of trophies after this battle
I nominate Greenhorn to lead our pack. Only because redemption is needed from our first hunt. This could go badly... at least it will be entertaining for all.
--EDIT--
I'll stay in the back Arez, keeping fire support for any kraken that tries to blindside us.
I'm a WG and postal,nrth and forte are Hunters I believe
I'll fire at where my flamer can do the most damage with my CML firing to finish off any that are still alive from the falmes
Wrong...I'm a Blood Claw with a power axe so keep me back till a charge is worth doing.
--EDIT--
Ok,forte will be your Guard then.if anything changes PM me and i'll post it,that goes for all the pack please
Ok,your in charge of protecting Skadi,keep her alive since shes the one with the heavy weapons
--EDIT--
Pmsl...she'll have to hold me back from charging then. Especially if I see you getting stuck in and beating me to a kill!
Fekke-hofud!
There's a reason why I'm at the back you two and a reason why I have a flamer also! get your wits together, or your hairy asses are gonna get burnt. The frostborn has spoken! the cold winds are with us today brothers, lets make hendrik proud!
If im in melee then indeed charge since if they manage to get past our hail of rounds they shall meet a line of ceramite and steel that will not fail
Fekke-hofud!
Forte will run interference so you can use your weapons to keep us from being swarmed and taken out,if we fall make sure the kraken that take us down pay
Pack Master Khine, i like the sound of that >=] Below are the instructions for the Mighty Alliances first turn.
Movement.
Russ Brother 92, Warhorse 47 and eyeslike thunder move to the square of E9.
-Volsung- and Khine move to the square of E8 after the other three have left the square.
Fire / Assault instructions - in Melee combat always use the best possible Melee weapon.
Russ Brother 92 - Firing with Meltagun at Kraken (c9) then over watch the same Kraken if it gets to charge.
-Volsung- - Firing with Bolt Pistol at Kraken (c7) then over watch the same Kraken if it gets to charge.
Khine - Firing with Flamer at Kraken (c7) then over watch the same Kraken if it gets to charge.
Eyeslikethunder Firing with Meltagun at Kraken (c9) then over watch the same Kraken if it gets to charge.
Warhorse47 - Firing with Boltgun at Kraken (c9) then over watch the same Kraken if it gets to charge.
The rest of my pack if you wish any changes make sure to PM them. Also when this turn is complete and the updated maps are up, make sure you PM any instructions you want.
Well I thought that I was going solo so I spent my points on a Flamer and Power Axe so that Way I can do fairly well for a Blood Claw. I don't think that Map has much leadership at the moment and I not a leader but if somebody doesn't step up we die or I will take over.
IF I am taking the reins then I need kit lists YESTERDAY so that I can have half a second to think up our tactics.
Now that I'm no longer half-asleep, I suddenly wonder just how many beasts the fourth round is going to throw at us. :huh:
Also if overwatch is an option, I reckon the Dauntless Few should just shoot at their given targets earlier, unless of course we kill them and something else charges us. :lol:
I'll also take this opportunity to wish everyone luck since we're officially all in this together if we make it to round 4. Good hunting! ^_^
I would take up the reins but I will be in and out of access intermittently over the next couple of weeks. I will go with Wolf guard in TDA and a wolf claw with a combi plasma for the moment. If points are available later on I will take suggestions we need more firepower.
@ Mav: will combi weapons refresh between waves?
I am taking over map four due to lack of....input. So to make things simple we are shifting left one square and up one to invade that little island and going to overwatch for the moment.
Loki has a Flamer
Brother Crazy Wolf is in TDA with a Plasma Combi-Bolter and Wolf Claw
Wolf Lord Conan has been voulunteered to be a Grey Hunter with Wolf Standard and Plasma Gun Bolt Pistol And Chain Sword
Sanctarin stated that he was going to be a Blood Claw and he is going to be packing a Power Sword....
Fytharin is going to be a Grey Hunter with the Mark of the Wulfen.
Mav said that it was too much for multiple entries so seeing as how nobody else stepped up I ended up in charge and this is how it will be
