Dang nabbit Arkley! I'm going to have to create seven new chapters to catch up to you!
Great work there!
There's talk about upping the bar a little, minimum word count, required image of the chapter badge, if the SM painters are used then more images would be required. Encouraging brothers to paint up actual miniatures in their chapter colors. That old chestnut.
I agree with what you say :tongue.:.... Chapter Badge I think should be a must. I think using SM painter is a must.
I will be padding out what I have done at some point I just wrote down basics.
WIP on a Jade Hawk :smile.:
http://i1116.photobucket.com/albums/k574/jetpaczx/2013-04-09202925_zpse19d7bcd.jpg
Edited by Arkley
I would advice everyone to keep the Black Pearl banner on their let corner because althoug yoy may not notice it well, the new Chaptermaster banner actually has a half DA emblem on both corners so will merge seamlessly on both side.... Hope that makes sense.. :)
EG: http://fortressofunforgiven.homestead.com/Path_to_Redemption_08BP.jpghttp://www.fortressoftheunforgiven.com/BHoA_Eternal_Banner.jpghttp://www.fortressoftheunforgiven.com/Chapter05_Blades_of_Altena.jpg
SG
I would advice everyone to keep the Black Pearl banner on their let corner because althoug yoy may not notice it well, the new Chaptermaster banner actually has a half DA emblem on both corners so will merge seamlessly on both side.... Hope that makes sense.. :smile.:
SG
Ah seems like I'm using the wrong Chapter Master banner then. Thanks!
  • 1 year later...
For all of those that haven't already done so, please submit your DIY Unforgiven Successors to the Tabula Astartes. The submission criteria can be found here (as far as I can tell, every Chapter with a completed submission for this challenge meets the criteria).
Note that this includes DIY renditions of official Chapters. These DIY versions are listed separately from the official entries (so there is a canon Angels of Absolution entry and a DIY entry - this is what we've done for a number of other DIY renditions of official Chapters).
All you need to do to submit your entry is post a reply with the following information:
Chapter/warband name:
Creator: (only necessary if you are not the author)
Founding:
Gene-seed:
Predecessor:
Article link:
Image(s) link: (only necessary if the images aren't in the article)
Notes:
Note: If/when you submit your Chapter, please ensure that you provide a link that goes directly to your entry, either a dedicated topic or the reply in this topic in which your Chapter is presented. If you post a link to this topic, you can find your Chapter's post by right clicking on the post number that appears in the upper right, then copying the URL.
Register a new account
Sign in
