Captain Semper Posted May 14, 2012 Share Posted May 14, 2012 E TENEBRAE LUX THE DARK ANGELS PAINTING CHALLENGE http://fortressofunforgiven.homestead.com/DA_Challenge_vs_BT.jpg THE CHALLENGE Honored Scions of Sigismund,Your fervor in hunting down the Witch, the Xenos and the Traitor is well known and respected among all loyal forces. But will you be able to live up to your reputation against the full might of the First Legion? Will you be able to come on top when challenged by the Sons of the Lion? This is the time prove your reputation is well deserved! +++ACCEPT ANY CHALLENGE NO MATTER THE ODDS+++Welcome to E TENEBRAE LUX, the Dark Angels Painting Challenge. This Challenge aims to cultivate faction loyalty and tighten the relations of members of the various forums while getting miniatures painted at the same time. E TENEBRAE LUX is structured quite differently compared to the LPC that many of you might be familiar with. It is designed to play down the inherent disadvantage of low vow-count (that some forums seem to suffer from), evening out as much as possible the chance of victory for all. It also allows for the development of strategies such as to who’s going to paint what, under the coordination of moderators or other active members of your sub-forum. Even a last minute hero might tip the balance!!!THE RULES 1. ELIGIBLE FORUMS: This challenge involves all the sub-forums that are associated with a Codex officially released by GW. See eligible forums in the “Important Stuff” section below.2. VOWS: Each participant MUST declare the sub-forum (and hence the Codex to be used) in his/her vow. That’s how his/her allegiance will be defined. You cannot pledge for the Blood Angels sub-forum for example and use Codex: Space Wolves units as your vow. One has to make a choice. This is different from the LPC where people can paint whatever they like and pledge it for whichever forum they like. Here it’s about faction loyalty! So make your choice and support your preferred faction to the bitter end! 3. LEGAL ENTRIES: Each vow should be a legal unit from the chosen Codex. It can be upgraded with any legal upgrades but WYSIWYG is required. An exception is made for dedicated transports that can be entered individually as if they were standalone entries in any Codex. Furthermore Special Characters that are used as squad upgrades can also be entered individually and are worth the “upgrade” points. If in doubt of whether your vow is legal or not, feel free to raise the question (publicly or through PMs) and you will receive the ruling of the Inner Circle before you commit. 4. THE TWIST: EXPANDING THE VOWS: Here is the twist: once the vow is complete, a new vow with additional units can be added but they should also be legal entries from chosen Codex as described above. This new vow must be clearly made according to the same format of the original vow. It should be stressed that the participant is liable for all the vows he makes. Failing one is failing all. So think carefully before stepping-up your commitment, if you fail on the second or subsequent vows all is lost! 5. THE WINNER: The sub-forum with the most points (as per relevant Codex) in the end of the event wins. As simple as that. Those that complete their vows successfully will get an amazing banner declaring their success in the Dark Angels Challenge while those that vowed for the winning forum will get the “Dark Angels Challenge Champions” banner that can wear with pride until the end of their days! Those that fail will be branded with the banner of shame until the year-end!IMPORTANT STUFF Timing of the event: E TENEBRAE LUX opening: May 15th Vow submission period: May 15th until June 15th at 22:00 GMTE TENEBRAE LUX ending: August 15 at 22:00 GMT. The format of the vow should be:“I [insert name here] answer the challenge of the Unforgiven and vow to complete [insert unit name here] from Codex: [insert Codex name here] of total value [insert point value here] on or before August 15. Success will bring eternal glory to [insert Chapter/Legion/Warband] and failure will doom me to bear the sign of damnation until the year-end” Eligible Forums:• Black Templars – Codex: Black Templars• Blood Angels – Codex: Blood Angels• Dark Angels – Codex: Dark Angels• Index Astartes – Codex: Space Marines• Liber Astartes – Codex: Space Marines• Space Wolves – Codex: Space Wolves• Ultramarines – Codex: Space Marines• ALL Chaos sub-forums – Codex: Chaos Space Marines OR Codex: Chaos Daemons• Ordos Inquisition – Codex: Grey Knights OR SoBs PDF.• Adeptus Mechanichus – IMPERIAL TITANS ONLY! (more on that in the Forgeworld section below)Forgeworld: Forgeworld entries are legal provided it is clearly stated that the unit can be used in the chosen Codex in the 40k context. They worth the points as depicted in the relevant Forgeworld publication. The only exception here is Imperial Titans. For people that want to have a go with Imperial Titans they can legitimately do so if the vow is pledged for Adeptus Mechanicus. That’s the only non-Codex entries that are legal in this Challenge and the only vows that can be pledged on behalf of the Adeptus Mechanicus.Only two pictures are required – one in the beginning (minis unpainted or primed or in very early stages of painting) and one for the finished vow. You are of course welcome to post as many pictures as you like in your WIP thread – but just two (one at the start and one at the finish) will suffice! This thread is the “Chapter House” for this event. All vows of this sub-forum should be posted in this very thread in order to be valid. This is also the place to declare vow completions and/or vow renewals. Finally posting your WIP thread links in your vow post will be tremendously helpful! This is a big event guys, so making life easier for me, will help avoid confusion and backs ‘n forths…You can also use this thread to gauge the progress of your forum (I’ll update often) and compare it with other forums in their respective threads. It will also be a good place to talk to each other as how to go about it, and organize your forum effort. I am Captain Semper and the Inner Circle has given me command of this event. I’ll be glad to answer any questions as we go along and I will keep track of all forums’ efforts. So I’m the person you need to talk to for anything regarding the procedures of this competition but Moderators still have full control of the Meltas, Flamers and Blades of Reason. And they will gladly use all of them given half a chance...May the best forum win! Dark Angels Painting Challenge/Black Templars sub-forum First Vows Anthraxus 1 Dreadnought with MultiMelta, 1 Master of Sanctity in Terminator Armor and master crafted storm bolter, and 1 5 man Sword Brethren Terminator Command Squad 460 COMPLETE Arthanor a marshal with thunder hammer and storm shield, terminator honors, artificer armor, holy orb of Antioch, meltabombs and adamantine mantle and one Emperor’s Champion 300 COMPLETE Black_Templar85 Heavy Flamer, TLLC, Tank Hunting Venerable Dreadnought 165 Incomplete Brother Cristopher 2 Rhino transports (both w. smoke launchers) and one Razorback transport (smoke launchers ,SB, h/K missile) 204 COMPLETE Brother Darklight One 10-Man Sword Brethren Terminator Assault Squad; 5 Paired Lightning Claws and 5 Thunder Hammer/Storm Shields, all 10 with Crusader Seals and all 10 with Furious Charge 420 COMPLETE Brother Montressor one Land speeder Typhoon 70 COMPLETE Brother Richard one Master of Sanctity on a Bike, One bike squad (plus goodies) with Assualt Bike, one Predator, two Land Raiders, and two Crusaders 1,642 COMPLETE Brother Sellsword 2 Rhino Transport Tanks with extra armour and smoke launchers, 1 Emperor's Champion and one 3 Initiate Bike Squad with 2x Meltaguns and 1 x Plasma gun 332 COMPLETE Brother Ulkesh 10 Sword Bretheren Assault Terminators 400 COMPLETE Brother Uriel Sanguis One Master of Sanctity (With a Master-crafted Powerfist, Terminator Honours, Jump-pack, and Holy Orb of Antioch), 5-man Squad of Assault Initiates (One PF, Two Plasma Pistols), and three Biker Initiates (One PW, Two Meltas) 454 Incomplete Brother-Captain Sicarius Emperor's Champion 90 COMPLETE Castellan Alaric one crusader squad of 8 initiates (1 melta and 1 power fist) along with their rhino transport with extra armor and smoke launchers 211 COMPLETE ChaplainCliff a Land Raider Crusader 265 COMPLETE Civsmitty a Venerable Dreadnought 165 COMPLETE Commendator Arn Master of Sanctity in terminator armour, armed with crozius arcanum and stormbolter 140 COMPLETE DarkScipio a Command squad with a Veteran Sergeant with mastercrafted powerweapon and mastercrafted armour, shield and Plasmapistol, Apothecarius, Champion, Plasmagunner, Laser cannon and Frag grenades 245 COMPLETE DasPanzerIstUber 1 Land Raider Crusader 265 COMPLETE Eberious Marshal (Thunderhammer, Combat shield, Jump pack, Terminator honours), 3 Typhoons, 2 Rhino (1 with H/K missiile), 10 Initiates (Power fist, Meltagun, Frag/krak, seals), 10 Assualt initiates (Power fist, Flamer) 1016 COMPLETE Ginger Avenger a 5-man tactical Terminator squad with an assault cannon, a cyclone missile launcher and a chainfist plus an Emperor's Champion 340 COMPLETE Grey Knight Purifier A Black Templar Command Squad, with Apothecary with Power Weapon, and Terminator Honours, a Fighting Company Champion, A Sergeant with Terminator Honours and Power Weapon, a Marine with a Flamer and Terminator Honours, and a Marine with a Melta and Terminator Honours. In addition, each unit has the Furious Charge Special Rule, all marines also have frag grenades. I will also paint a Drop Pod with Storm Bolter 246 COMPLETE Gunrunr a 5 man squad of Sword Brethren Assault Terminators with thunder hammers, storm shields and crusader seals, 1- Typhoon land speeder and a techmarine 350 COMPLETE hart3856 One Land Raider Crusader, to further complete One Master of Sancitiy w/ jump pack and One squad of 10 Initiates, 1w/ML Two OOP Vindicators which will be completely refitted/reborn to our colors, updated with DB, SmL, SL, SB , Chaplin Grimaldus with Retinue, One Sword Brethern Squad 5 strong w/ TH, CmS, CS, LC, PW, One Emperor's Champion 1,349 COMPLETE Head Mook (1) Marshal, (1) Sword Brethren Terminator Squad, (2) Crusader Squads, (1) Land Speeder Typhoon, (2) Predator Destructors, and (1) Rhino 1,147 Incomplete Honda one dreadnought with DCCW/Hvy flamer and Multi-melta and and one land raider crusader (with Redeemer cannons, "counts as" Hurricane bolters) 390 COMPLETE Khornehunter57x one Marshal with Power Weapon, Storm Shield, Terminator Honors, and Artificer Armor 145 COMPLETE Larden Marshal (LC, SS, artif. armour, Frags, termie honors, melta bombs), Castellan (master-crafted PW, PP, Iron Halo, termi honours, orb of antioch), 7 initiates (Pf, Flamer, Frags, crusader seals), Dreadnought (Lascannon, Missile Launcher) 610 COMPLETE Lord Exedore 7 Sword Brethren Terminators with 2 cyclone ml, crusader seals, 2x7 SB Terminator assault squads with Crusader Seals (4xLC, 3xTH/SS) and their respective LRC transports (3) , each with an additional stom bolter and smoke launcher, as well as 1x Marshal in TD armor with LC and combi Melter, 1 Castellan TDA with LC and combi Melter and 1x MoS with TDA, energy weapon and stormbolter 2,196 COMPLETE Lysere 6 Sword Brethern Assault Terminators, (3 lightning claws, 3 thunder hammer storm shields, all with crusader seals) and a Reclusiarch with Crozius, Storm Bolter, and Terminator Armor 377 COMPLETE Marine one Land Raider Crusader 1x marshal with PW and master-crafted bolt pistol, 1x master of sanctity with plasma pistol 500 COMPLETE Marshal Hadrarius a Dreadnought armed with an assault cannon and heavy flamer with smoke launchers 118 Incomplete Marshal Veyross One Castellan (terminator armour, duel lightning claws, Iron halo) 5x Sword brethren assault terminators (3 lightning claws, 2 Storm shields and thunder hammers, 5 furious charge veteran skills) and one land raider crusader 625 COMPLETE Marshal2Crusaders 2 Crusader Squads (Squad 1 w. meltagun + PW + 8x (bp+cs), Squad 2 w.meltagun +PF+ 8xbg) 365 Incomplete Marshall Dovian 1x Vindicator - DozerBlade ExArm Search Light Pintle Mount Storm Bolter Smoke Launcher Hunter Killer Missile, 1x Terminator Unit - 2x LC 3x TH Crusader Seals, 1x Terminator Unit - 2x Cyc 3x ChainFists Crusader Seals 674 Incomplete MERC3065 6x Razorbacks with Twin Linked Lascannons and smoke launchers, 2x Predator destructors with Lascannon side sponsons and smoke launchers, 2x 2 squadrons of Land Speeder Typhoons 1,094 Incomplete my_face a reclusiarch led command squad with apothecary, company champion, standard bearer carrying a holy relic and a sergeant 240 Incomplete Mystech1 1 Marshal with Artificer Armor, Adamantium Mantle, Terminator Honors, Holy Orb of Antioch, melta bobmbs Master Crafted Combi-Plasma, and Power weapon and 1 Emperor's Champion, Master of Sanctity Chaplain with Jump Pack, Terminator Honors, Artificer Armor, Melta Bombs, and Master Crafted Plasma Pistol 500 COMPLETE Nards08 High Marshal Helbrecht 175 COMPLETE Psykic_scribe one Razorback with tl lascannon, dozer blade pintle s/b, h/k missile, smoke and POMS 153 COMPLETE Ray_K one crusader squad (PF & Meltagun) and rhino w/smoke launchers 238 Incomplete reckoning34 1 Marshall with PW and SS, T.Honors and HOoA, Frag and Krak Grenades 133 COMPLETE Raeven 5 Sword Brethern Assault Terminators, (All lightning claws, all with crusader seals), Chaplain Grimauldus and Cenobyte Retinue, Dreadnaught (AoBR) with MultiMelta, Smoke Launchers, and Searchlight, 2 Crusader Squads with 7 BP/CCW Initiates, 1 Meltagun, and 1 BW/PF each all with Crusader Seals, Frag, and Krak Grenades, and 2 Rhino's with smoke launchers 1,058 COMPLETE redmapa One Venerable dreadnaught with Twinlinked Lascannon and CCW 145 COMPLETE Reinhard 5 assault initiates, 2 armed with plasma pistols and one with a power weapon, 10 Sword Brethren Terminators organized into two squads: one with 2 Assault Cannons and one with 2 Cyclone Missile Launchers 630 COMPLETE Roesor a ten man squad of terminators 400 COMPLETE Ryld one Marshall with Power Weapon and Storm Shield, one Master of Sanctity with Jump Pack and Thunder Hammer and one Marshall in Terminator Armour with Thunder Hammer and Storm Shield 420 COMPLETE ScottishSmurf96 One dreadnaught with CCW/LASCANNON/HEAVY FLAMER/VENERABLE/TANK HUNTER 165 Incomplete Shades93 a Crusader squad of 10 initiates, one with a powerfist and one with a meltagun; One venerable dreadnought with a lascannon and DCCW; And One Vindicator with smoke launchers, storm bolter and hunter killer 483 COMPLETE Silver Wind Dragon One Master of Sanctity equipped with Terminator Honors, Bionics, Single Lighting Claw, and Artifice Armor, 9 Sword Brethren Assault Terminators, 5 with Lighting Claws, 4 with Thunder Hammers and Storm Shields, all with Crusader Seals and a Caestus Assault Ram 868 Incomplete Sir_Isenhar Land Raider Crusader 265 COMPLETE Smirnov Chaplain Grimaldus 195 COMPLETE Tolek 1 Land Raider Crusader, 1 Chaplain Dreadnought w/ 2x DCCW a storm bolter and heavy flamer from Imperial Armour Apocalypse, 1 Dreadnought w/ Assault Cannon and DCCW and heavy flammer and 2x Land Speeder Typhoon's 720 COMPLETE Trask A Crusader Squad of 7 initiates, and 2 neophytes, with a meltagun and a powerfist, and a rhino with smoke launchers and extra armor 215 COMPLETE watanabe2k 10 initiate squad (with plasma), 10 Initiate Squad (with flamer), Venerable Dreadnaught, Terminator Chaplin (Master of Sanctity), Jump pack Chaplin (Master of Sanctity), High Marshal Helbrech 883 COMPLETE Dark Angels Painting Challenge/Black Templars sub-forum Second Vows Brother Darklight 1 Marshall in Terminator Armour with a Lightning Claw and Storm Shield 140 COMPLETE Brother Christopher Crusader Squad (10 Initiates, 3 Neophytes, Power Weapon, Melta Gun, Frag, Krak, Crusader Seals), Terminator Squad (2x Chainfist, Assault Cannon), Dreadnought, Multi-Melta 605 COMPLETE Brother Richard One ten troop Sword Brethren Terminator Squad (Shooty) with two chainfists, one assualt cannon, and one missile laucher, and ten crusader seals, AND one ten troop Sword Brethren Terminator Squad (Shooty - from Space Crusade era) with ten Crusader seals, and one flamer, AND one five troop Sword Brethren Terminator Assualt Squad with five Crusade seals 1,115 COMPLETE Brother Ulkesh 1 Land Raider Crusader 265 COMPLETE Brother-Captain Sicarius marshal with master-crafted power sword, Storm Shield, Artificier armour, bionics, Adamantine Mantle, terminator honours, frag and krak grenades 198 COMPLETE ChaplainCliff venerable dreadnought with win linked las cannon, extra armour, a master of sanctity with plasma pistol, and artificer armour, and the holy orb of Antioch, a techmarine with servo harness and artificer armour 450 COMPLETE Civsmitty Emperor’s Champion 90 COMPLETE DarkScipio a Dreadnought (Venerable, Lasercannons, Misslelauncher, add. Armour) 160 COMPLETE Eberius Terminator MOS Chaplain (Pair LC, tele homer [represented by the skull with laurel crown on top of torso section], Adman mantle), 10 CC Terminators, 5 shooty Terminators (2 cyclone missile 4 chainfists, crusader seals), landraider (TL lassconnons, Hbolter, HK missile, storm bolter, smokes) 1,163 COMPLETE Ginger Avenger one Marshal with power fist, combi-plasma, artificer armour, iron halo, adamantine mantle and a holy orb of Antioch 210 COMPLETE Grey Knight Purifier a Squad of five Black Templar Initiates, armed with three bolters, a Plasma Gun, and a Missile Launcher 96 COMPLETE Gunrunr Marshal equipped with a pair of lightning claws, terminator honours, adamantine mantle, frag and krak grenades and a teleport homer 168 COMPLETE Honda Marshal (Terminator armor, Thunder hammer, Storm shield, Teleport homer) and a 4 Sword Brethren command squad (4 x Terminators, 2 x Cyclone Missile Launchers, 4 x Crusader seals) 368 COMPLETE Larden Emperors Champion, Assault squad -5 initiates (melta bombs, pf, 2-plasma pistol), 5x Crusader squad (5 bolters 2bp&cc, frags, missle launcher, plasma gun), Rhino (smoke launchers) 406 COMPLETE Lysere One Land Raider Crusader with Blessed Hull, Dozer Blade, Pintle-Mounted Storm Bolter, Searchlight, and Smoke Launchers, as well as One Emperor's Champion 399 COMPLETE Marshall Veyross One Vindicator with smoke launchers and Dozer blade 133 COMPLETE Mystech1 1 Marshal in Terminator Armor w/Adamantium Mantle, Master Crafted Storm Bolter and Master Crafted Power Fist and one 6 man Terminator Command Squad w/ CML, Heavy Flamer and Bionics on the Sergeant 480 COMPLETE Nards08 a Land Raider with smoke launchers, hunter-killer missile, and searchlight 269 COMPLETE Psykic_scribe one Venerable Dreadnought with TL lascannon and missile and smoke launchers 158 COMPLETE redmapa One Terminator Sword Bretheren Squad of five men equipped with two Cyclone Missile Launchers 250 COMPLETE Reinhard Swordbrethren Terminator Command Squad, armed with a Heavy Flamer and Chainfist 175 COMPLETE Roesor 10 man Terminator Command Squad with two assault cannons and two chainfists, Sgt; with additional Teleport Homer and Bionics 460 COMPLETE Ryld High Marshall Helbrecht 175 COMPLETE Shades93 a Master of Sanctity w/ Artificer Armor, Terminator Honors, Master Crafted Crozius and Master Crafted Plasma pistol: And a Marshall with artificer armour, master crafted power fist, storm shield and terminator honours 355 COMPLETE Smirnov Sword Brethren Assault Terminators squad of six brethren, two with thunder hammers and four with lightning claws, with Crusader Seals 250 COMPLETE Tolek 3x Initiate Biker's w/flamers, 1 Drop Pod w/storm bolter, 1 Razorback w/TWLC, 9x Initiate's w/bolters, 8x Initiate's w/bp and ccw, 5x Neophyte's w/bp and ccw, and 1 Techmarine w/2xTech Servitor's and 2x Gun Servitor's/heavy bolters 722 COMPLETE watanabe2k 5 LC Terminators 200 COMPLETE Dark Angels Painting Challenge/Black Templars sub-forum Third Vows Brother Darklight 1 Master of Sanctity with Terminator Armour and a Thunder Hammer 165 COMPLETE Brother Cristopher one Vindicator with PoTMsS, Extra Armour and HK Missile 175 COMPLETE Brother Ulkesh 1 Land Speeder Typhoon 70 COMPLETE Brother-Captain Sicarius Crusader squad with 5 initiates: frag and krak grenades, crusader seals 1 melta gun and a powerfist 130 COMPLETE ChaplainCliff a single land speeder typhoon w/ a multi melta 5 man terminator squad w/ 2x cyclone missile launchers and 5x chainfists and 5x crusader seals 370 COMPLETE Civsmitty Land Raider Crusader 265 COMPLETE DarkScipio Command squad (4 x Terminators w/ 2 Cyclone MLs, sergeant upgrade, 1 power weapon, 1 Thunder Hammer, auspex, Master Crafted Weapon) 257 COMPLETE Eberius Emperor’s Champion (ltd edition) 90 COMPLETE Ginger Avenger a Predator Annihilator with heavy bolter sponsons, searchlight, smoke launcher and pintle mounted storm bolter 144 COMPLETE Gunrunr a new Emperor's Champion 90 COMPLETE Honda 1 Master of Sanctity (Plasma pistol, Artificier armor, Holy Orb of Antioch, Iron Halo) 155 COMPLETE Marshall Veyross one Marshal with tactical dreadnought armour, Master crafted thunder hammer, storm shield, holy orb of antioch and adamantine mantle 210 COMPLETE Mystech1 a Master of Sanctity w/ Artificer Armor, Terminator Honors, Jump Pack, Bionics, Holy Orb of Antioch, Master Crafted Crozius and Master Crafted Power Fist 235 COMPLETE Nards08 1 Marshal with Master-crafted Lightning Claw, Storm Shield, Artificer Armour, Holy Orb of Antioch, Terminator Honours, and Adamantine Mantle 215 COMPLETE redmapa One Venerable dreadnaught with Multi-Melta and Heavy Flamer 145 COMPLETE Reinhard 1 Emperor's champion and 1 Reclusiarch with a Crozium, Terminator armor and Stormbolter 215 COMPLETE Roesor one 10 man crusader squad with meltagun and powerfist 185 Incomplete Ryld one Emperor’s Champion 90 COMPLETE Smirnov Land Raider Crusader with smokes, searchlight, storm bolter and blessed hull and Emperors Champion 394 COMPLETE watanabe2k a 5 man Command Squad with standard bearer, missile launcher, bolter, powersword and shield and plasma gun 155 COMPLETE Dark Angels Painting Challenge/Black Templars sub-forum Fourth Vows Brother Darklight one 9 man Assault Initiate Squad w/ 2x Plasma pistols, 1x Combat Shield, 1x Power Fist 238 COMPLETE Brother Cristopher one Master of Sanctity (Artificer armour, Bionics [WYSWIG: respirator], Frag Granades, Holy Orb, Master-crafted Plasma Pistol) 176 COMPLETE Brother Ulkesh one Crusader Squad of five initiates (with Frag & krak grenades, Flamer and Plasma Cannon) 121 COMPLETE Brother-Captain Sicarius a Master of sanctinty with bolt pistol, artificer armour, adamantine matle, mastercraftet crozius arcanum, frag grenades and terminator honours 197 COMPLETE ChaplainCliff Master of sanctity, w/ a bolt pistol, and artificer armour, Marshal, w/ termi armour, a master crafted thunder hammer and a storm shield, Marshal, w/ termi armour master crafted pair of lightning claws, an adamantine mantle, and melta bombs 481 COMPLETE Civsmitty a Sword Brethren Terminator Squad with two Cyclone Missile Launchers and a chain fist 255 COMPLETE DarkScipio a Landspeeder Typhoon 70 COMPLETE Eberius Two Marshals (storm shield, single L-claw and termie armour & artificer armour(represented by the larger bulk), terminator honours, frag/krak nades, storm shield, thunder maul) 308 COMPLETE Ginger Avenger a Master of Sanctity with Crozius, plasma pistol and frag grenades 126 COMPLETE Honda 1 Landraider Crusader and Landraider standard (both with smoke launchers) 525 COMPLETE Marshall Veyross One master of Sanctity with Artificer armour, Holy orb, power fist, terminator honours and artificer armour 180 COMPLETE Mystech1 10 man Crusade Squad w/ Crusader Seals, BP&CC, Meltagun and Power Fist 205 COMPLETE Nards08 1 Predator Annihilator with sponson lascannons and dozerblade 150 COMPLETE redmapa a Marshall with terminator armour, power weapon, storm shield and iron halo with a terminator command squad of four with two cyclone missile launchers,crusader seals and a storm shield 383 COMPLETE Reinhard one Marshal in Terminator armor with Combi-melta, Chainfist and Admantite Mantle and One Spartan Assault Tank with pintle mounted heavy bolter 495 COMPLETE Dark Angels Painting Challenge/Black Templars sub-forum Fifth Vows Brother Darklight Emperor’s Champion 90 COMPLETE ChaplainCliff terminator command squad one; 4 terminators w/ 1x cyclone missile launcher, 1x assault cannon, 1x chain fist, 4x crusader seals; terminator command squad two; 4 terminators w/ 2x assault cannons, 1x chainfist, and 4x crusader seals; terminator command squad three; 4 terminators w/ 2x assault cannons and 4x crusader seals 629 COMPLETE Civsmitty two Predator Annihilators with sponson-mounted lascannons 290 COMPLETE DarkScipio Castellan with German equipment 125 COMPLETE Eberius 1 Tri las-cannon Predator Annihilator 145 COMPLETE Ginger Avenger a 5-man Assault Marine squad with power fist, storm shield and two plasma pistols 138 COMPLETE Honda five initiates, one with bolt pistol and power weapon, one with a plasma gun, three with bolters, with crusader seals 106 COMPLETE Mystech1 a 10 man Crusade Squad w/ Crusader Seals, 7x Bolters, 1x BP&CC, Flamer and Missile Launcher 196 COMPLETE Nards08 one Techmarine with full servo-harness, master-crafted thunder hammer, storm shield, holy orb, bionics, melta bomb, terminator honours, teleport homer, and iron halo 230 COMPLETE redmapa One Venerable dreadnaught with Twinlinked Lascannon and Heavy Flamer 155 COMPLETE Reinhard one Techmarine with servo-harness, storm-bolter and Terminator honours 125 COMPLETE Dark Angels Painting Challenge/Black Templars sub-forum Sixth Vows Brother Darklight A Predator Destructor w/ LasCannon sponsons 125 COMPLETE ChaplainCliff Marshal (artificer armour, storm shield, master crafted thunder hammer, and terminator honours), Chaplain Grimauldus , Command squad x9 (standard bearer holding the chapter banner, a fighting company champion, a sergaent with a powerfist, 2x plasma guns, all with terminator honours, crusader seals, and frag grenades) 741 COMPLETE Civsmitty 5 Sword Brethren Assault Terminators (3 TH/SS, 2 LC) 200 COMPLETE Mystech1 a Land Speeder Tornado and an Emperor's Champion 170 COMPLETE Nards08 one Master of Sanctity with power axe, bolt pistol, jump pack, terminator honours, krak grenades and one Master of Sanctity with master-crafted powerfist, bolt pistol, terminator honours 329 COMPLETE redmapa a Master of Sanctity with Bolt Pistol, Bionics, Artificer Armour, Terminator Honours, Jump Pack and Adamantine Mantle 206 COMPLETE Dark Angels Painting Challenge/Black Templars sub-forum Seventh Vows Brother Darklight Command Squad - 6 man: Sergeant: Power Weapon, Terminator Honours, Apothecary: Power Weapon, Terminator Honours, Standard Bearer: Power Weapon, Terminator Honours, Company Champion: Terminator Honours, Initiate: Plasma Gun, Terminator Honours, Initiate: Plasma Gun, Terminator Honours; Crusaders: 34x Crusaders, 5x Neophytes. Initiate with Power Weapon 865 COMPLETE ChaplainCliff one Marshal w/ POLC, artificer armour, holy hand grenade, and t-honours 155 COMPLETE Mystech1 a 10 man Assault Squad w/ Power Weapon and 2x Plasma Pistols 240 COMPLETE Nards08 one Predator Destructor with sponson heavy bolters and dozer blade 115 COMPLETE redmapa a Master of Sanctity with Bolt Pistol,Combi-Melta, Bionics, Artificer Armour, Terminator Honours, Jump Pack and Adamantine Mantle 221 COMPLETE Dark Angels Painting Challenge/Black Templars sub-forum Eighth Vows Brother Darklight High Marshal Helbrecht, a Land Raider Crusader, a Vindicator w/ Dozer Blade, a Rhino, a Dreadnought with twinlinked Lascannons, a Dreadnought fist, and a heavy flamer, a Marshal with a power weapon, a storm bolter, an Iron Halo and a Holy Orb of Antioch, and a Marshal with a pair of Lightning Claws and an Iron Halo 1,028 COMPLETE ChaplainCliff a Marshal with master crafted power weapon, plasma pistol, and artificer armour 145 COMPLETE Mystech1 Two 5 man Crusade Squads w/ Missile Launcher and plasmagun; a 5 man Command Squad w/ Multimela, Plasma Cannon and Srgt w/ Terminator Honors, Combi-Melta and Power Fist; and a 5 man Command Squad w/ 2x Heavy Bolters and Srgt w/ Terminator Honors, Power Fist and Storm Shield; all models with Crusader Seals 562 COMPLETE Nards08 one Sword Brethern Terminator Squad with Assault Cannon, Cyclone Missle Launcher, Chainfist, and Crusader Seals 260 COMPLETE redmapa a Marshall with a Master Crafted Bolter, Artificer Armour, Terminator Honours, Adamantine Mantle,Power Weapon, Bionics and Jump Pack 206 COMPLETE Dark Angels Painting Challenge/Black Templars sub-forum Ninth Vows Brother Darklight 5 man Sword Brethren Terminator Squad (2x Assault Cannons, 2x Chainfists) 250 COMPLETE ChaplainCliff one 5-man crusader squad with las cannon and plasma gun 101 COMPLETE Mystech1 MkI version of my namesake Marshal w/ Iron Halo, Artificer Armor, Teleport Homer, Terminator Honors, Bolt Pistol and Master Crafted Plasma Pistol accompanied by a 6 man Command Squad w/ 2x Lascannons and Srgt w/ Terminator Honors and Bionics; all models with Crusader Seals 374 COMPLETE Nards08 a Vindicator with dozer blade, hunter-killer missle, and extra armour 150 COMPLETE redmapa a Marshall with a Holy orb of antioch, artificer armour, krak grenades and iron halo 137 COMPLETE Dark Angels Painting Challenge/Black Templars sub-forum Tenth Vows Brother Darklight 1 Master of Sanctity, Mastercrafted Plasma Pistol, Terminator Honours 155 COMPLETE ChaplainCliff one 5-man crusader squad with las cannon and plasma gun 101 COMPLETE Nards08 a Marshal with Thunder Hammer, Storm Shield, Frag Grenades 121 COMPLETE Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/ Share on other sites More sharing options...
Brother Richard Posted May 14, 2012 Share Posted May 14, 2012 Brothers! Last night I received a vision to expand my pledge...after much contemplation I have brought forth from the armory the strenght of my arsenal to meet the Angels challenge. Though it will require much dusting, repair, and replacement. These hollowed machines desire only to serve in just such a challenge. I Brother Richard of the Black Templar answer the challenge of the Unforgiven and vow to complete one Master of Sanctity on a Bike, One bike squad (plus goodies) with Assualt Bike, one Predator, two Land Raiders, and two Crusaders from Codex: Black Templar of a total value 1642 pts on or before August 15. Success will bring eternal glory to the Black Templar and failure will doom me to bear the sign of damnation until the year-end. Brothers! Seek through the niches of your armories and see if you can find such treasures to offer all of these subforums a real challege. They seek the true might of our crusades...let us hide no longer! In this challenge...every warrior and every codex worthy warmachine counts! Edit: add to my pledge and update photo Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3061033 Share on other sites More sharing options...
ScottishSmurf96 Posted May 14, 2012 Share Posted May 14, 2012 “I ScottishSmurf96 answer the challenge of the Unforgiven and vow to complete One dreadnaught with CCW/LASCANNON/HEAVY FLAMER/VENERABLE/TANK HUNTER from Codex: Black Templars of total value 165pts on or before August 15. Success will bring eternal glory to the Black Templars and failure will doom me to bear the sign of damnation until the year-end” Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3061075 Share on other sites More sharing options...
redmapa Posted May 14, 2012 Share Posted May 14, 2012 “I redmapa answer the challenge of the Unforgiven and vow to complete One Venerable Tank-Hunting dreadnaught with Twinlinked Lascannon and CCW from Codex: Black Templars of value 155pts on or before August 15. Success will bring eternal glory to the Black Templars and failure will doom me to bear the sign of damnation until the year-end” Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3061097 Share on other sites More sharing options...
hart3856 Posted May 14, 2012 Share Posted May 14, 2012 “I hart3856 answer the challenge of the Unforgiven and vow to complete One Land Raider Crusader from Codex: Black Templars of value 265pts on or before August 15. Success will bring eternal glory to the Black Templars and failure will doom me to bear the sign of damnation until the year-end” Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3061123 Share on other sites More sharing options...
Brother Sellsword Posted May 14, 2012 Share Posted May 14, 2012 I, Brother Sellsword, answer the challenge of the Unforgiven and vow to complete 2 Rhino Transport Tanks with extra armour and smoke launchers from Codex: Black Templars of value 116pts on or before August 15. Success will bring eternal glory to the Black Templars and failure will doom me to bear the sign of damnation until the year end. http://i932.photobucket.com/albums/ad169/wookiesnot/th_006-5.jpg Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3061145 Share on other sites More sharing options...
Grey Knight Purifier Posted May 15, 2012 Share Posted May 15, 2012 I, Grey Knight Purifier answer the challenge of the Unforgiven and vow to complete A Black Templar Command Squad, with Apothecary with Power Weapon, and Terminator Honours, a Fighting Company Champion, A Sergeant with Terminator Honours and Power Weapon, a Marine with a Flamer and Terminator Honours, and a Marine with a Melta and Terminator Honours. In addition, each unit has the Furious Charge Special Rule, all marines also have frag grenades. I will also paint a Drop Pod with Storm Bolter. from Codex: Black Templar of total value 261 points. on or before August 15. Success will bring eternal glory to Black Templars, and failure will doom me to bear the sign of damnation until the year-end” Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3061310 Share on other sites More sharing options...
chaplaincliff Posted May 15, 2012 Share Posted May 15, 2012 “I ChaplainCliff answer the challenge of the Unforgiven and vow to complete a Land Raider Crusader from Codex: Black Templar of total value 265 on or before August 15. Success will bring eternal glory to the Black Templar Chapter and failure will doom me to bear the sign of damnation until the year-end” Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3061375 Share on other sites More sharing options...
Captain Semper Posted May 15, 2012 Author Share Posted May 15, 2012 I Brother Richard of the Black Templar answer the challenge of the Unforgiven and vow to complete one Chaplain from Codex: Black Templar on or before August 15. Success will bring eternal glory to the Black Templar and failure will doom me to bear the sign of damnation until the year-end. That's great Brother Richard! However let me suggest you go for a Master of Sanctity (110pts) and if you want to add wargear, be more explicit so you'll benefit from the extra points - WYSIWYG should be upheld however (within reason obviously). :D Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3061410 Share on other sites More sharing options...
T14 Posted May 15, 2012 Share Posted May 15, 2012 I guess this would be the venue for all those fully upgraded Helbrecht cmd squads :D Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3061430 Share on other sites More sharing options...
merc3065 Posted May 15, 2012 Share Posted May 15, 2012 I MERC3065 answer the challenge of the Unforgiven and vow to complete the following from Codex: Black Templar: 6x Razorbacks with Twin Linked Lascannons and smoke launchers 2x Predator destructors with Lascannon side sponsons and smoke launchers 2x 2 squadrons of Land Speeder Typhoons For a total value of 1094 on or before August 15. Success will bring eternal glory to the Black Templar Chapter and failure will doom me to bear the sign of damnation until the year-end Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3061638 Share on other sites More sharing options...
Captain Semper Posted May 15, 2012 Author Share Posted May 15, 2012 OK guys - in the first post there is now a table(!) that is a snapshot of the overall situation of the BT forum. Please check your vows and let me know if there is any mistakes so I can fix them - tables are a difficult bussiness to master. ;) EDIT: Names are in alphabetical order. Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3061963 Share on other sites More sharing options...
civsmitty Posted May 15, 2012 Share Posted May 15, 2012 I, Civsmitty, answer the challenge of the Unforgiven and vow to complete a Venerable Dreadnought from Codex: Black Templar, a total value of 165 points on or before August 15. Success will bring eternal glory to the Black Templar and failure will doom me to bear the sign of damnation until the year-end. EDIT: Added initial photo Here's the initial photo, in all of its sideways glory. Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3062116 Share on other sites More sharing options...
KhorneHunter57x Posted May 15, 2012 Share Posted May 15, 2012 I, Khornehunter57x, answer the challenge of the Unforgiven and vow to complete one Marshal with Power Weapon, Storm Shield, Terminator Honors, and Artificer Armor from Codex: Black Templars with a total value of 145 points on or before August 15. Success will bring eternal glory to the Black Templars and failure will doom me to bear the sign of damnation until the year-end. EDIT: Here's my WIP thread. Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3062186 Share on other sites More sharing options...
Tolek Posted May 16, 2012 Share Posted May 16, 2012 I, Tolek, answer the challenge of the Unforgiven and vow to complete a Land Raider Crusader from Codex: Black Templar, a total value of 265 points on or before August 15. Success will bring eternal glory to the Black Templars and failure will doom me to bear the sign of damnation until the year-end. Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3062271 Share on other sites More sharing options...
Captain Semper Posted May 16, 2012 Author Share Posted May 16, 2012 First post table updated up to this point. Keep the vows flowing-in, BAs, DAs and Chaos are putting up a fight! Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3062376 Share on other sites More sharing options...
Brother Ulkesh Posted May 16, 2012 Share Posted May 16, 2012 I, Brother Ulkesh, answer the challenge of the Unforgiven and vow to complete 10 Sword Bretheren Assault Terminators from Codex: Black Templars of total value 400pts on or before August 15. Success will bring eternal glory to The Black Templars and failure will doom me to bear the sign of damnation until the year-end. Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3062438 Share on other sites More sharing options...
civsmitty Posted May 16, 2012 Share Posted May 16, 2012 Semper, you need to add my vow to the table. Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3062610 Share on other sites More sharing options...
Captain Semper Posted May 16, 2012 Author Share Posted May 16, 2012 Yeap, sorry about that - its done now. Thanks for pointing it out. :) Updated Brother Richard's vow too! Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3062616 Share on other sites More sharing options...
Brother Darklight Posted May 16, 2012 Share Posted May 16, 2012 “I, Brother Darklight, answer the challenge of the Unforgiven and vow to complete One 10-Man Sword Brethren Terminator Assault Squad; 5 Paired Lightning Claws and 5 Thunder Hammer/Storm Shields, all 10 with Crusader Seals from Codex: Black Templar of total value 420 Points on or before August 15. Success will bring eternal glory to The Black Templar and failure will doom me to bear the sign of damnation until the year-end” http://i.imgur.com/6jxbU.jpg?1 EDIT: My apologies, Brothers. My Righteous Zeal got the best of me and I started the two front Assault Brethren before I remembered that I needed to take the picture! I'll add more vows upon completion to repent! EDIT: My bad, cannot show that a model has Veteran Skills. So I've corrected my point value to show this! Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3062673 Share on other sites More sharing options...
Lord Exedore Posted May 16, 2012 Share Posted May 16, 2012 “I, Lord Exedore, answer the challenge of the Unforgiven and vow to complete 7 Sword Brethren Terminators with 2 cyclone ml, crusader seals and tanks hunters, 2x7 SB Terminator assault squads with Crusader Seals (4xLC, 3xTH/SS) and their respective LRC transports (3) , each with an additional stom bolter and smoke launcher, as well as 1x Marshal in TD armor with LC and combi Melter, 1 Castellan with LC and combi Melter and 1x MoS with energy weapon and stormbolter from Codex: Black Templar of total value 2189 Points on or before August 15. Success will bring eternal glory to The Black Templar and failure will doom me to bear the sign of damnation until the year-end” P.S. BT are second on the second day... lets see where this road will lead to in the end... I may regret this... P.P.S. Captain Semper: You are "unfair" - I guess this has been discussed on the "rock" for quite a time... in some dark corner...? ;) edit P.P.P.S: No offense meant, it simply looked a bit strange having the angels put up the most points... ;) Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3062887 Share on other sites More sharing options...
Captain Semper Posted May 17, 2012 Author Share Posted May 17, 2012 P.P.S. Captain Semper: You are "unfair" - I guess this has been discussed on the "rock" for quite a time... in some dark corner...? :D Unfair? How so? :) I know this is a lighthearted comment but I'm making a big effort here to keep everybody on even ground and frankly "fairness" is all I have on my side. This is an unprecedented event and far more complicated than it looks on paper. However if you do have a complaint by all means bring it to my attention - transparency is what drives this forward. Hence the tables where all can see each others vows and also contribute to friendly competition. You are right about dark corners though (DAs are DAs after all), but those that were in those dark corners are not alllowed to participate. Me included. ;) Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3063054 Share on other sites More sharing options...
The Shadow Guard Posted May 17, 2012 Share Posted May 17, 2012 P.P.S. Captain Semper: You are "unfair" - I guess this has been discussed on the "rock" for quite a time... in some dark corner...? ;) Hello Lord Exedore, I will back up Captain Semper here. No one bar the members of the Inner Circle and some admins of the B+C (no choice there! ;) ) were privy to the nature and intent of the contest. All other forum members were made aware at the same time. If you are worried about the Dark Angels forum members preparing in secret... well, while we do like to do things in secret, we like it better when even our own chapter brothers are kept in the dark! ;) Remember circles within circles and secrets within secrets... ;) ;) SG Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3063140 Share on other sites More sharing options...
Captain Semper Posted May 17, 2012 Author Share Posted May 17, 2012 ... we like it better when even our own chapter brothers are kept in the dark! B) Hahahaha!!! True that! Just to point out that BTs are doing a terrific job coming up with vows and remain true to form! This is going to be closely fought brothers!!! :D Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3063202 Share on other sites More sharing options...
Black_Templar85 Posted May 17, 2012 Share Posted May 17, 2012 I Black_Templar85 answer the challenge of the Unforgiven and vow to complete Heavy Flamer, TLLC, Tank HUnting Venerable Dreadnought from Codex: Black Templars of total value 165 points on or before August 15. Success will bring eternal glory to The Black Templars and failure will doom me to bear the sign of damnation until the year-end” Link to comment https://bolterandchainsword.com/topic/252369-e-tenebrae-lux/#findComment-3063496 Share on other sites More sharing options...
