+++E Tenebrae Lux+++
“I the TrueSonOfRuss answer the challenge of the Unforgiven and vow to complete 3 Lone Wolves two with Chain Fists and Storm Shields in TDA and one with x2 Wolf Claws in TDA for a total of 235 Pts per Codex: Space Wolves on or before August 15. Success will bring eternal glory to the Vlka Fenryka and failure will doom me to bear the sign of damnation until the year-end”
Way to go True Son of Russ! It's about time the Wolves regained some momentum...
@ Arez: No fortifications, no allies. Too late in the ETL to make such fundamental changes. It is also against the spirit of the ETL which is to pit Codex vs. Codex rathe than using generic fortifications or allies from othe SM codices. So remain true to your Codex and try to come on top... You have still some big guns that have yet to fire... :)
My vow is complete, proof can be found here: http://www.bolterandchainsword.com/index.p...p;#entry3136045.
the group pic will have to wait for a bit, my game/painting area is a bit cluttered at the moment.
WLK
“I Wolf Lord Kieran, again answer the challenge of the Unforgiven and vow to complete Logan Grimnar counts as, Bran Redmaw counts as, Njal Stormcaller in power armor, Lone Wolf in TDA with chainfist and storm bolter, a 5 strong Long Fang pack with 4 missile launchers and a Vindicator Tank with a siege sheild and extra armor from Codex: Space Wolves of total value 1045pts on or before August 15. Success will bring eternal glory to my brothers and sisters of the Fang and failure will doom me to bear the sign of damnation until the year-end”
WLK
“I Wolf Lord Kieran, again answer the challenge of the Unforgiven and vow to complete Bran Redmaw counts as
Is there rules for Bran or are you just using a WL?
Forge World released a set in the last Imperial Armor.
WLK
TO ALL SPACE WOLVES:
WLK just completed the largest single vow in the ETL worth 4k pts! Congratulations WLK - this is no mean feat! You are a true Champion of the Fang and an valuable asset in the Emperor's arsenal. AND to add to his glorious performance WLK also made a new vow in excess ok 1k pts! Wow, just wow!!!
So the new vow is in (Bran is a legal entry) and the table updated. The Wolves are currently third at 15.5k pts with DAs second with 16.2k pts and the BTs leading with 21.8k pts. In my view the most strategic completions now are not only the biggest ones but the ones that are second and third vows because they'll carry the waight of the previous ones too...
Good luck everybody! :P
E TENEBRAE LUX – 11th WEEK UPDATE
Week 11 is over. This has been the most productive week so far (and by far) with total completions at almost 18k pts! Total completion rate increased to 42.5% vs. 35.6% last week and total completions reached 94k pts! Predictably the new vows stood at 6k which means that risk appetite is diminishing as the ETL approaches its conclusion. The total pledged points reached the 220k level!
I would like to draw everybody’s attention to WLKs 4k pts completion – the largest single vow in the ETL! And on top of that he re-vowed for another 1k+ pts! Way to go WLK – well done!
Only two weeks remaining until the conclusion. There will be another update on August 7th but I will not make an update on August 14th as it will be only one day before the end of the event. I will strive to give you guys the final results as soon as possible after the 15th but, just to play it safe, I would like to set a self-imposed deadline on Sunday August 19th. It will probably be sooner.
Now a few points I’d like to make:
- On August 15th @ 22:00 GMT is the official end of the ETL. Please, PLEASE do not let things run to the last minute if possible. Missing the deadline for a minute will be a big let down and could leave a bitter taste to the participant in question – which will be a pity. Make no mistake I will enforce a strict deadline on the event. Completions reported at 22:01 GMT WILL NOT COUNT. In case of doubt the clock that matters is the B&C clock set to GMT time.
- The concluding report that will follow the completion of the ETL will have a lot of data and statistics for the event in total and per forum. It will also have detailed lists of all the participants, the completed vows and points completed per participant! I also am willing to give out other information that might be requested on a case by case basis. One of the major aims of the ETL was transparency, and I intend to serve this aim to the end!
- In case you fail to fulfill a vow, even if it is your last in a series of successful completions, you should wear the Badge of Shame until year-end (or more if you feel the penitence period should be extended). So behold the Badge of Shame:
http://www.fortressoftheunforgiven.com/ETL_02_Oathbreaker.jpg
So if you feel you can do without this banner in your signature, get cracking! If on the other hand you are sure you won’t make it, be my guest and put it on right away…
- Now I can also reveal some details regarding the banners for the victors. These are the banners to be worn by those that completed successfully ALL their vows. Why am I using plural for the “banners”? Because the banners will have an indication that will correspond to the number of completed vows for each participant! This would be subtle but clearly visible feature! I believe it will make for a great account of the ETL and people will wear it with pride!
- Also the winning faction will be getting an “add-on” banner commemorating their victory that will be designed to be placed next to the victory banner with no space between them so it will look as one. So the participants of the winning forum will retain their “victory” banner along with the vow-count feature (like everybody else) but will also get another banner to commemorate their dominance in the ETL!
- Lastly, you may have noticed the new banner in my signature. This is my personal banner in relation to the ETL – It has nothing to do with the Winning or the Champion banners – so don’t get any ideas! :)
So here’s how things look at the end of Week 11 in more detail:
E TENEBRAE LUX – 11TH WEEK UPDATE
Black Templars 113 45,254 400 22,984 51%
Blood Angels 65 31,953 492 9,861 31%
Dark Angels 91 43,877 482 16,365 37%
Codex Space Marines 58 34,082 588 10,935 32%
Space Wolves 50 33,917 678 15,459 46%
Chaos 57 24,504 430 13,941 57%
Ordos Inquisition 22 6,196 282 4,548 73%
Total 456 219,783 482 94,093 43%
Index Astartes 31 16,695 539 8,355 50%
Liber Astartes 15 9,818 655 1,695 17%
Ultramarines 12 7,569 631 885 12%
Comments:
The Dark Angels are getting their actr together and have managed to complete the most points compared to any other forum this week. This momentum that started building up since the previous week certainly delivers results as completion rate jumped to 37% from 25% the previous week. However, as the opposition was not idle either, the average completion rate of the ETL also increased leaving the DAs again to below average levels. That also can be interpreted that the DAs could more easily repeat this week’s performance compared to other forums that are gradually reaching their limits. The key to the DAs plan for victory now is for the big tickets to weigh in. There are a few mega-vows that are running for 11 weeks now – undoubtedly some of them are nearing completion. The momentum has been regained – all that’s left now is carry one and complete the vows!
The Wolves managed to get back in the game dynamically with a large number of completed points including the largest single vow in the ETL: WLK’s 4k Mega Vow. But he was not alone. After a sluggish Wek 10, the wolves are back in business having the second largest amount of completions this week. But now the situation is dire! Given the weight of the average vow the burden now falls on those 2nd and subsequent vows, the completions of which serve two purposes: 1) validating the previous precious completions (losing them would mean defeat) and 2) adding the new point-rich vows (that are necessary for victory). So the subsequent vows are especially important to the Wolves both as a shield to previous completions but also in their own right as they carry the weight necessary to win!
Blood Angels had a very timid week, adding a meagre 850 pts to their total. Things look grim for them as time is running out as they need not only to flood the ETL with completions but also to proceed to second and subsequent vows to raise their total points pledged and bring their required completion rate closer to a more normal 50% rather than the demanding 70%+ that is currently required. So remember: it’s not over until it’s over – keep delivering on your vows and everything is possible! For Sanguinius! For the Emperor!
Black Templars continue to deliver on their oaths in true BT style! Despite having a comfortable lead they added 4.7k pts maintaining their difference to the DAs at a sizeable 6.6k pts! And, being BTs, they pledged another 3.4k pts so most of the completions have been re-filled. Here I need to mention there are already two BTs in their 8th vow already (and there are bound to be others too) but be careful guys, the stakes are now very high! Just as a side note, 57% of all new vows (point-wise) in Week 11 were made by the BTs. Fanatics? Damn right!
Codex Forums are in three distinct speeds. First we have Index Astartes that are delivering 50% completion rates (above the ETL average) and contribute 76% of the total points of the Codex bloc. Alone they are threatening the BAs (!) and I believe they still have some aces up their sleeve! Then we have the Liber Astartes that they contribute 16% of the total points of the faction. With completion rate of 17% way below the average of the ETL they have the potential to really make the difference for the Codex bloc! In fact I believe this is the Codex best chance to leap forward and challenge the first positions! Then we have the Ultramarines. The lowest contribution to the Codex total of only 8% and total completions of less than 1k. Hmmm… here there must be some progress as we reach the deadline because although the Ums are not many, they have some hefty vows there… And with completion rate of only 12% there is only one way to go! Honor & Courage – you have the power to turn the tables and give the opposition a run for their money!
Chaos after some fantastic performance in Week 10 has slipped from second position to fourth as 1) their smaller numbers begin to show and 2) other forums have mobilized their resources gaining momentum. BUT Chaos still has a few rounds of heavy artillery in its arsenal and their position, although 4th, is not that distant from the rest of the forums in terms of points. Chaos is determined enough to see this through – they have proven it already with a completion rate approaching 60% - by far the highest (excluding the Ordos)!!!
Ordos Inquisition had a second week in a row with no completions to report. Frankly with a completion rate in the 70s it looks as they have won the Dedication to the Emperor award … I woul urge the three participants that have 2nd and third vows unfinished to make the effort to complete them in time – just by tying the loose ends your completion rate will jump to the 80s!!!
Until the next and last weekly update, farewell and good luck to all!
As noted - I have the shame of having failed and thus tried to wear the Badge of Shame... it wouldn't link it, said the B&C doesn't allow links from there which I found rather odd.
@WLK Incredible there chap ;) keep it up!
@All other Brothers, we may be few and our vowes low in number - but we SHALL prevail, after all did Russ flee when surrounded by foes? NO! Would Lord Grimnar baulk at the site of an entire traitor legion? NO! and so you must honour our great brothers, fathers and fore-fathers with GLORY and VICTORY!!
Try the following: Make a "quote"reply to my post an copy the code of the banner. Then paste it to your signature and it should work. You know it works because you can see it in my post so, well, it works! :D
Try the following: Make a "quote"reply to my post an copy the code of the banner. Then paste it to your signature and it should work. You know it works because you can see it in my post so, well, it works! :)
I did - turns out I was being daft and putting the [/img] into the actual code :/ <- silly wolf
Still my brothers and sister/s shall beat your dress wearing kindred! :rolleyes:
My vow is done,pictures are crappier than usual since i took these pictures just to show that they are done(pics will be in my thread).soon as my parents guests leave i will look for batteries for the families digital camera and take better pictures for this and my entire vow.I will try to get the tank im currently working on put together so i can vow it.
" I Mactire of the vlka fenryka answer the challenge of the unforgiven and vow to complete 2 x lone wolfs [both in TDA, 1 x TH & stormshield, 1 x TH & chainfist] from Code : Space Wolves of total value 170 points on or before august 15th 2012. Success will bring eternal glory to the Sixth Legion and failure will doom me to bear the sign of damnation until year end."
sorry for the crappy points total guys but i might as well be realistic about completion chances ;)
Also i hearby call for any jarls in the fang to promote Arez, Rayray & WLK to wolf asap. awesome work guys :tu: the only way to describe is :eek :) :wub:
here is my first wip pic
Ok, so I'm making it official. I have completed my vow.
My Rune Priest in TDA.
Two of my three Wolf Guard retinue. (Note that they now have pack markings in the first image above.)
And finally, my Arjac Rockfist to meet the WG minimum requirement.
All progress shots and musings regarding this vow can be found in this painting blog.
In all honesty, I want to make another vow, but still need to consider my schedule currently. I've finally moved, but the constant job searching is keeping me from getting much done. I wish I could have vowed more than what I have so far, and if this is all I end up contributing, I hope it was enough to make some difference.
Congratrulations to Arez, Mactire and of course Wulfebane for completing their vows! I see Mactire made another one too! Things look good for you guys, as with the recent completions you are marginally ahea of the DAs and in second position overall (yes Mactire tipped the balance)!
So stay focused, avoid unnecessary risks, and everything's possible. The strategy should now be to complete existing vows - overall you have less points than the BTs and therefre you require a higher completion rate. As it stands now your completion rate is 50% and the BTs have 54%... So you realise that if they have more points AND higher completion rates... well, you cannot allow this to happen! :)
So focus on completing existing vows.
TO ALL THE SONS OF RUSS THAT PARTICIPATE IN THE ETL AND HAVE YET TO COMPLETE: NOW IS THE TIME TO STEP IN AND MAKE THE DIFFERENCE!!!
Good luck to all!
I the True Son of Russ have completed my final Vow. Sadly I don't have the time with work and family to Vow again. It has been an honour to struggle with you brothers and I am sure we will stand above the Unforgiven in the end. The proof of my deed is here and I would like to thank everyone who gave me advice since my first post. While my work has eons to go to stand amongst the ranks of some of you I feel my work is improving from what I started at NS IA t least home game table top worthy at this point. Work hard brothers 12 days remain and the filthy skirts will try to push us but we are wolves and as a pack we will always defeat their kind.
“I the TrueSonOfRuss answer the challenge of the Unforgiven and vow to complete 1 Lone Wolf in TDA with Thunder Hammer and Storm shield worth 85 Pts per Codex: Space Wolves on or before August 15. Success will bring eternal glory to the Vlka Fenryka and failure will doom me to bear the sign of damnation until the year-end”
My Wyrd is upon me and I feel I must push to complete more... If this one turns out as fast as I think it can since I am feeling the power within me there may be one more before the 15th but I will not risk the total for the minor boost.
Second vow.
Wolf Lord - 220pts
-TDA
-Combi-plasma
-Powerfist
-Wolftooth necklace
-Belt of Russ
-Saga of the Bear
Hmmm... Sorry Wulfebane, there was a ruling early on, that given the nature of the Sagas, they cannot be effectively represented on the miniatures (how can you represent word of mouth? ;)) and therefore will not count towards your total points. Now given your skill I'm sure you could probably work something out but let's keep this level... The ruling stands so I'd say your Wolf Lord will be worth 185pts (minus the saga and keeping all the rest). I will not update as yet just in case you want to alter the load-out. Let me know either way.
