Jorre Posted August 19, 2012 Share Posted August 19, 2012 (edited) Hi guys, a few people after seeing my WIP thread have been asking me to make a how to for attaching the Sanguinary Guard chest peaces to a Terminator body.I have taken a whole bunch of pictures and hopefully you guys will be able to use them to work out how I did it. I'm not really much for writing guides on this kind of thing, but I'll do my best to explain as we go.First up this is a completed one I built earlierStep 1The first thing you need is this peaceYou will need to cut the front of the chest plate. I use hobby knife with a fresh blade and rock it back and forth until it cuts through. The flatter and straighter you get this step the easier the rest of the job will be. When you are done it should look like this.Next just glue the modified peace into the normal Terminator back like this.Step 2Next you need to prepare the Sanguinary guard chest peace.You need to cut the chest peace as flat as possible so that it will easily fit onto the first peace you prepared.Here is the Before and after shotsBeforeAfter.... Note that I have also cut out the domed part inside the bottom of the chest peace. You need to do this so that you can squeeze terminator legs into the torso later.I also cut out a little of the top section where you would usually glue the head.This is important because it can be really hard to fit a head in later. Once you glue the chest on its really hard to cut away the insides unless you have a dremel.Step 3Next just glue the 2 peaces togetherThe flatter you manage to cut the two peaces the easier this stage will be. Also positioning here is really important, Place the chest to high and the head wont fit in the hole. Place it to low and the 2 bottoms won't line up very well. I usually make the chest peace hang just a little lower than the back.You should allow a little time for your glue to set before a quick clean up to finish the chest off.Step 4A quick clean up to make sure all the uneven edges are even will make all the differenceIf you didn't cut the 2 peaces really well you may have to use some green stuff to fill in gaps, on this model it wasn't needed as I got the cut really good. A little bit of a trim with the hobby knife has everything lined up nicely. You don't have to be to pro with this part as most of this part will be hidden by the arms and weapons.Thats all you need to do to make the chest! Building the rest of the Terminator is pretty straight forward so I wont bore you with that!Hope this is helpful to you all and check out my WIP hopefully I will get around to painting this squad! http://www.bolterandchainsword.com/index.p...howtopic=189585Skip to page 4 if your only interested in the Terminators! Edited August 31, 2020 by Jolemai Tags Jolemai 1 Back to top Link to comment https://bolterandchainsword.com/topic/259236-sanguinary-terminators/ Share on other sites More sharing options...
Evicerator Posted August 19, 2012 Share Posted August 19, 2012 Thanks for the tutorial! It was similar to what I thought was involved, but a little different way of going about it. As for the kneepads, are they a straight up fit or is tweaking needed? Link to comment https://bolterandchainsword.com/topic/259236-sanguinary-terminators/#findComment-3152856 Share on other sites More sharing options...
Jønke Posted August 19, 2012 Share Posted August 19, 2012 Thank you for this. Now im confident to go try that myself. Will prolly also use it with some bt chests. Link to comment https://bolterandchainsword.com/topic/259236-sanguinary-terminators/#findComment-3152934 Share on other sites More sharing options...
Jorre Posted August 19, 2012 Author Share Posted August 19, 2012 There is a little circular knob on the outside of the terminator legs that needs to be shaved down before the shoulder pads will fit on the knees. Aside from that it's a straight fit Link to comment https://bolterandchainsword.com/topic/259236-sanguinary-terminators/#findComment-3153142 Share on other sites More sharing options...
Nomus Sardauk Posted August 20, 2012 Share Posted August 20, 2012 A thousand thanks Brother Jorre, your sharing of this knowledge will strengthen the chapter and your brothers greatly! Link to comment https://bolterandchainsword.com/topic/259236-sanguinary-terminators/#findComment-3153197 Share on other sites More sharing options...
Ushtarador Posted August 21, 2012 Share Posted August 21, 2012 Those look awesome, especially the shoulder pads on their knees! I know how I'm gonna build mine thats for sure ;) Link to comment https://bolterandchainsword.com/topic/259236-sanguinary-terminators/#findComment-3154307 Share on other sites More sharing options...
MadMek83 Posted August 21, 2012 Share Posted August 21, 2012 Wow, that is nice. I almost can see Sang.Guard wings to be used as Stormshields for Sang. Guard Hammernators... Very nice looking and thank you for showing! Link to comment https://bolterandchainsword.com/topic/259236-sanguinary-terminators/#findComment-3154817 Share on other sites More sharing options...
Abraxes Posted August 22, 2012 Share Posted August 22, 2012 Thanks for the how-to. That first image of the unpainted termy looks really great. Can't wait to see it with paint. Link to comment https://bolterandchainsword.com/topic/259236-sanguinary-terminators/#findComment-3154895 Share on other sites More sharing options...
Gray Knights Posted August 22, 2012 Share Posted August 22, 2012 I like the look of this the will look good painted. Link to comment https://bolterandchainsword.com/topic/259236-sanguinary-terminators/#findComment-3154924 Share on other sites More sharing options...
Brother Ambroz Posted August 22, 2012 Share Posted August 22, 2012 Wow, I don't play Blood Angels and I'm still tempted to make some sanguinary termis with this tutorial. Very nice! Link to comment https://bolterandchainsword.com/topic/259236-sanguinary-terminators/#findComment-3154929 Share on other sites More sharing options...
Jorre Posted August 22, 2012 Author Share Posted August 22, 2012 Might be a while before they are painted.... I am an extrodinarily slow painter! If you want to see painted check out DaemonPrinceDargor's WIP thread http://www.bolterandchainsword.com/index.p...howtopic=236706 The original inspiration for my Terminators and an outstanding painter! Link to comment https://bolterandchainsword.com/topic/259236-sanguinary-terminators/#findComment-3155231 Share on other sites More sharing options...
nagashnee Posted August 25, 2012 Share Posted August 25, 2012 Brilliant work mate! Link to comment https://bolterandchainsword.com/topic/259236-sanguinary-terminators/#findComment-3157850 Share on other sites More sharing options...
Killax Posted August 26, 2012 Share Posted August 26, 2012 Nice! Can you get those shoulderpads somewhere seperate or are they from a (Warmachine?) other model? Link to comment https://bolterandchainsword.com/topic/259236-sanguinary-terminators/#findComment-3158616 Share on other sites More sharing options...
Jorre Posted August 27, 2012 Author Share Posted August 27, 2012 The shoulder pads are from chapter house studios. You can also use dreadnaught shin guards. Link to comment https://bolterandchainsword.com/topic/259236-sanguinary-terminators/#findComment-3158832 Share on other sites More sharing options...
Brother Nihm Posted August 27, 2012 Share Posted August 27, 2012 Excellent Nipple-nators, Thank you for sharing. Link to comment https://bolterandchainsword.com/topic/259236-sanguinary-terminators/#findComment-3158941 Share on other sites More sharing options...
