the jeske Posted August 20, 2013 Share Posted August 20, 2013 Is it 2k or 1999? Lord, MoS, Brand, PW, SoC doesn't the upgrade gear , even the torrent flamer has a too short range . your not runing a bike or a unit for him to run around . he is a tax to get NM as troops and should be kept cheap. Sorcerer, ML+2, Spell Familiar, SoC Same SoC too slow in melee and your not going to use a +3sv+/+4inv to tank . SoC should be removed. Noise Marines w/Doom Siren & 2x Blastmasters Noise Marines w/Doom Siren & 2x Blastmasters 15 Cultsts w/flamer 15 Cultsts w/flamer cut to 10 man . troops should be cut in half if this is a 2k pts army one with the MoS lord and the other with cultists and Sorc. Baledrake Baledrake nothing to comment on Havocs w/Autocannon x 4 + 3 bodies Havocs w/Autocannon x 4 + 3 bodies cut the extra 3 bodies . if your runing a 2kpts army and not a 1999 one run 1 extra unit of havocks as ally use the points from droped upgrades to buy autocannons for the third squad. units hsould be 5/5/5 with 3 autocannons each .if there are enough points start buying 4th AC before starting to buy a 6th havock in any unit . Obliterators w/MoN x 3 Aegis w/Quad .If your playing 2k t s you could be runing 2 of those instead of the 3 havock unit . But in general if your realy having problems with flyers in your enviroment switch to runing Demons with csm ally or CSM with tau/IG ally. Link to comment Share on other sites More sharing options...
Dallas Drake Posted August 20, 2013 Author Share Posted August 20, 2013 Jeske, thanks for the pointers. What do you think of adding in 2 Forgefiends? Or running a AoBF Khorne Lord with bikers? Both are options I'm considering tbh. D Link to comment Share on other sites More sharing options...
the jeske Posted August 20, 2013 Share Posted August 20, 2013 Take the lord with the bikes it is a solid option . I mentioned the lord and the spawn , because a high cost melee character that moves slow in 6th ed is bad. Bikers both give him a quasi ID immunity [due to T5] and speed , melta bikers are also an ok unit to have anyway. If you want to take a Forge Fiend you have to ask yourself , how efficient do you want your hvy support to be . Oblits are generaly better , being more flexible and all . With 2 FoC you could take 2 oblits and 2 havocks and that would be very good. If your taking fiends take them with cannon head and dakka arms , supported by Oblits Link to comment Share on other sites More sharing options...
nurglez Posted August 20, 2013 Share Posted August 20, 2013 I quite like my hadesfiend, but you have to accept that they are over costed. I currently run daemon allies for 3 rolls on divination and the grimmore, which helps the fiend out (as well as others). At 1500 points I used my hadesfiend, autocannon havocs and heldrake as anti air, and I've had awesome games with the fiend and terrible games, quite hit and miss in fact :D Link to comment Share on other sites More sharing options...
Dallas Drake Posted August 22, 2013 Author Share Posted August 22, 2013 Well I've had loads of advice & most of it will be used. I have a re-match next Thursday, plan is to not get tabled by turn 4. For the record I've added IG allies as I have plenty of FW traitor IG kits. By cutting toys on the Lord/Sorcerer & losing 1 Oblit & 6 Havoc body bags I've added the following; Lord Commissar Platoon Command Squad - Autocannon - Plasma gun Infantry Squad - Sabre Defence Platform (Lascannon) Infantry Squad - Sabre Defence Platform (Lascannon) Aegis w/coms I'll let you all know how I get on! Dallas Link to comment Share on other sites More sharing options...
the jeske Posted August 23, 2013 Share Posted August 23, 2013 The horror , the horror. Link to comment Share on other sites More sharing options...
