The Iron Chancellor Posted May 28, 2014 Share Posted May 28, 2014 Hey guys, so I'm building a squad of tactical marines and to finish it off I need some heavy weapons- in my codex it says i can use a lascannon, multi-melta, or heavy bolted. I'm pretty sure I want the multi-melta, however I don't see the point in buying a single marine with multi-melta for $14, when a devastor squad costs $35. Any alternative sets that contain multi-meltas? Link to comment Share on other sites More sharing options...
maverike_prime Posted May 28, 2014 Share Posted May 28, 2014 Hey guys, so I'm building a squad of tactical marines and to finish it off I need some heavy weapons- in my codex it says i can use a lascannon, multi-melta, or heavy bolted. I'm pretty sure I want the multi-melta, however I don't see the point in buying a single marine with multi-melta for $14, when a devastor squad costs $35. Any alternative sets that contain multi-meltas? Sadly not as far as kits go no. Best option I can offer is hit up Ebay and check oh Hoard 'o Bits, or Bits World. They usually have the Devastator Multimelta sets for about $5 each. Link to comment Share on other sites More sharing options...
Forté Posted May 28, 2014 Share Posted May 28, 2014 Bits sites. Multi Meltas are not too often used due to the range. Link to comment Share on other sites More sharing options...
The Iron Chancellor Posted May 28, 2014 Author Share Posted May 28, 2014 hmmm. okay do you think the plasma cannon is a better choice? Link to comment Share on other sites More sharing options...
The_Chaplain Posted May 28, 2014 Share Posted May 28, 2014 It depends entirely on the battlefield role you want the squad to specialize in really. If it's a mobile squad, a multi-melta provides tank busting at shorter ranges. At longer range, lascannons and missile launchers shine. Plasma cannons are good for rear/light armor, or dealing with 2+ saves-- but the chance to blow up makes them a risky investment for some. Have you considered magnets so you can swap out the heavy weapons as needed? Link to comment Share on other sites More sharing options...
Dedlok Posted May 29, 2014 Share Posted May 29, 2014 Landspeeders come with multimeltas that are the right size for a marine to hold, but require some converting to add the power cables and backpack which it does not include. Of course this all depends on if you want a landspeeder for your army. Link to comment Share on other sites More sharing options...
NovemberIX Posted May 29, 2014 Share Posted May 29, 2014 I would say unless you're really set against the idea, just go buy a dev box. Not only do you get that Multi-melta, but you get a full squad (plus 1 if you have an extra torso, say from the assault squad kit) a bunch of heavy weps, and bitz you'd otherwise not really have access to. Link to comment Share on other sites More sharing options...
averykess Posted June 4, 2014 Share Posted June 4, 2014 You could buy the various MM bits off ebay (horde'obits, blackdagger games, etc) and do some converting. I prefer the Missile Launcher in Tac squads. You can snap fire the krak missile when you move, and tac squads seem to move a lot Link to comment Share on other sites More sharing options...
Urauloth Posted June 4, 2014 Share Posted June 4, 2014 Yeah, most bitz sites should have a MM somewhere. Then again, they're usually about £5 in the UK, and the devastator kit is £20, so there's very little point in buying single MMs. Unless you can find a really well-priced one, honestly, your best bet is to go for a devastator kit and either stockpile the other heavy weapons, build a dev squad, or make extra heavy weapon marines to swap into your tac squads if you feel like running something different. Link to comment Share on other sites More sharing options...
Jeff Newton Posted June 4, 2014 Share Posted June 4, 2014 http://www.forgeworld.co.uk/The_Horus_Heresy/Legiones_Astartes/Space_Marine_Legion_Army_List/LEGION_HEAVY_SUPPORT/Legion_Heavy_Support_Squad/LEGION_MULTI_MELTA_SET.html This is the route I went for more multimeltas. Link to comment Share on other sites More sharing options...
