Blindhamster Posted June 16, 2020 Share Posted June 16, 2020 i didnt think that was a contradiction? i thought that was just standard lore since Guilliman returned. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5543212 Share on other sites More sharing options...
dread05 Posted June 17, 2020 Share Posted June 17, 2020 Ok these are huge news to me and I got questions. A normal company has 6 battleline, 2 close support and 2 heavy support squads right? If it goes up to 20 squads does it become 12-4-4? if its normal squads split into combat squads that means that if I have 20 devastators in a company, there will still be 8 heavy weapons and not 16 if they're split into 5 man squads. And if they're squads pulled from the reserves then I could have a company with 6 battleline, 2 heavy support 12 close support? And it sure is a contradiction cause the one paragraph says that a company has 100 marines split into 10 10 man squads or 20 5 man squads, but the other paragraph implies that a company can pull 10 10 man squads from a reserve company and go as high as 200 marines. Im guessing that the first paragraph is refering to an actual company i.e. the 4th company splitting into 20 5 man squads and the second paragraphs is refering to a strike force i.e. Deathstorm strike force consisting of a full battle company and 10 squads pulled from the reserves. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5543378 Share on other sites More sharing options...
Xenith Posted June 17, 2020 Share Posted June 17, 2020 And it sure is a contradiction cause the one paragraph says that a company has 100 marines split into 10 10 man squads or 20 5 man squads, but the other paragraph implies that a company can pull 10 10 man squads from a reserve company and go as high as 200 marines. It's not a contradiction. The company can do both. They're not mutually exclusive. Your company can be 100 marines in 2x 5 man squads, all from the 4th co, or 10x 10 man squads from the 4th co, reinforced with 3x3 man squads from reserve companies or whatever, or indeed, anything in between. The point is, that reserve companies then apply the contracting company iconography, so either of these options are functionally the same when they're on your models on the table, unless you choose to paint them otherwise. The Codex is giving you a set of guidelines, how you interpret and enforce them is, as ever, up to you. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5543466 Share on other sites More sharing options...
BluejayJunior Posted June 17, 2020 Share Posted June 17, 2020 And the new codexes don't say a company has 6 battleline squads. It says they have 60 battleline troops. So they can be organized however you want them to be. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5543481 Share on other sites More sharing options...
Dont-Be-Haten Posted June 17, 2020 Share Posted June 17, 2020 And the new codexes don't say a company has 6 battleline squads. It says they have 60 battleline troops. So they can be organized however you want them to be. I don't like those changes at all. Like yes it gives you more options, but for decades its been 6 tactical squads 2 assault 2 dev. Now even three years in the radical change throws me off. Because all of the specialist units are so diluted and in differing slots. Like why are aggressors helmets Blue? Fire support, but they -want- to be up close and in your face. That seems to me it would be yellow helmets, reivers unfortunately look awful with yellow in my opinion but make sense being an assault unit, however if you take the bolt weapons, should be red or blue as they are fire support. Then we have the overall change to veterans and command. In previous editions commanders have had Red helmets, now they can have gold too. Now back when I first started playing fire support and heavy support were two different things, and I painted my very first terminators with blue helmets, because I thought being heavy infantry it made sense. I'll post a picture of one as I still have that unit. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5543513 Share on other sites More sharing options...
Charlo Posted June 17, 2020 Share Posted June 17, 2020 Stormcast sure look good in red. I agree, but there's no stormcast here! Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5543921 Share on other sites More sharing options...
Blindhamster Posted June 18, 2020 Share Posted June 18, 2020 Appiah doesn't tend to like primaris stuff - which is fine. I agree they look no more like stormcast than any other marine. There is a small resemblence because stormcast look like marines (hence the "sigmarine" monacker... but these just look like veteran marines to me, no more or less blingy than other veteran models we have seen. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5544222 Share on other sites More sharing options...
Jolemai Posted June 18, 2020 Author Share Posted June 18, 2020 Moving on... Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5544246 Share on other sites More sharing options...
Loishy Posted June 18, 2020 Share Posted June 18, 2020 Like why are aggressors helmets Blue? Fire support, but they -want- to be up close and in your face. That seems to me it would be yellow helmets, reivers unfortunately look awful with yellow in my opinion but make sense being an assault unit, however if you take the bolt weapons, should be red or blue as they are fire support. "Close support" don't mean close combat squad. You can also find the Land speeder and the inceptors in this category. For me, the Close Support Squads are "fast" OR they are designed for close combat. Reivers with Bolt carbine and with Grapnel Launchers or Grav-chutes are "fast", so they fit in the Close support category. But I agree, aggressors are a strange unit. Lot of fire power but small range. Not fast but equipped for close combat. I'll put the dakka ones in Fire support and the flamer ones in close support. And there is another thing. "Battle line = troops", "Close support = Fast Attack", "Fire support = heavy support" are not true anymore. That's weird for some units (incursors). Panzer 1 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5544306 Share on other sites More sharing options...
Jolemai Posted June 24, 2020 Author Share Posted June 24, 2020 New Unit of the Week entry: Relic Typhon Heavy Siege Tank Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5547534 Share on other sites More sharing options...
Indefragable Posted June 24, 2020 Share Posted June 24, 2020 I'm in a painting lull for a moment. I went pretty hardcore with Mephiston for the LPC, but now I'm finding it hard to pick up a brush. I made myself get some wash on some models to at least try to break myself back into it. I tend to have an all-or-nothing personality with intense focus on something and then ignoring it for a bit, so it fits that patten. However, one of the silver linings of the Great Quarantine of 2020 was that I pretty consistently chipped away at painting a bit every day. Maybe I got too used to that. Does anyone have trouble getting the wheels spun up again after completing models? Karhedron and Majkhel 2 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5547581 Share on other sites More sharing options...
Karhedron Posted June 24, 2020 Share Posted June 24, 2020 Does anyone have trouble getting the wheels spun up again after completing models? Yeah, I know the feeling. I painted a Repulsor in under a week at the start of the challenge and have since struggled to paint for more than about 15 minutes at a time. Burnout is real! Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5547625 Share on other sites More sharing options...
Jolemai Posted June 24, 2020 Author Share Posted June 24, 2020 I've suffered from that. Most recent may well have been in last month trying to find something suitable for June's 12M Challenge entry as all I wanted was something simple and straightforward (I only seem to have stuff to complete now which requires magnetising/greenstuff/etc) - not entirely sure how the answer was the Space Hulk Terminators and Librarian given all their detail Before then it was probably after our defeat in last year's ETL. I think I got over that one by painting something else for a few months as I was doing last year's 12M Challenge too. I think it helps doing something else and having a goal/deadline still. Unfortunately the BA-centric events have been on hold of late but there's bound to be some other goal/deadline/achievement you can reach/unlock. Perhaps there's something you have a hankering for? With no ETL this summer it's actually a good opportunity to paint something non-BA or even try something different - I wouldn't have painted a marble base for the Space Hulk Librarian if the ETL was on, for example. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5547664 Share on other sites More sharing options...
Majkhel Posted June 24, 2020 Share Posted June 24, 2020 Yeah, I'm struggling too :P I did 2 Suppressors and the third is just sitting and staring at me for weeks now. I will complete him, no worries, just need some kind of soft reset. Maybe it's the weather (June tends to be rainy here) Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5547673 Share on other sites More sharing options...
Father Mapple Posted June 24, 2020 Share Posted June 24, 2020 If I can't or don't think I will play, it's near impossible for me to paint. Painting challenges help with that, but it's still the primary motivator. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5547683 Share on other sites More sharing options...
Indefragable Posted June 24, 2020 Share Posted June 24, 2020 If I can't or don't think I will play, it's near impossible for me to paint. Painting challenges help with that, but it's still the primary motivator. I absolutely know that feeling. I think quarantine has been a counterintuitive form of that for me: knowing I won't be able to play for a while actually gave me a shot to the arm to whittle down my insane backlog. Has worked pretty well, overall. It's kind of the prison workout syndrome: if you have nothing else to do, might as well do some pushups and crunches. I think painting also gave me my "fix" for 40k knowing that actually playing was impossible. I do feel a second wave coming on, so I need to find that spark and pour prometheum all over it. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5547738 Share on other sites More sharing options...
Midnightmare Posted June 26, 2020 Share Posted June 26, 2020 I did a paint! Well, it was over a few days, but I did a paint! Indefragable, Charlo, Leonaides and 9 others 12 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5549108 Share on other sites More sharing options...
Indefragable Posted June 26, 2020 Share Posted June 26, 2020 I did a paint! <snip> Well, it was over a few days, but I did a paint! That is one scary dude (well done). The blue skin is striking compared to the red armor. Not my personal taste/interpretation, but very well done. Midnightmare 1 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5549113 Share on other sites More sharing options...
Midnightmare Posted June 26, 2020 Share Posted June 26, 2020 Thanks :tu: They do polarise opinion, but I love ‘em! Planning on Primaris supported by first born Death Company as the main bulk of the force. The new box set has whetted my apetite for the 9th. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5549117 Share on other sites More sharing options...
Xenith Posted June 27, 2020 Share Posted June 27, 2020 I did a paint! Well, it was over a few days, but I did a paint! Looks awesome, any more Primaris on the paint station? Midnightmare 1 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5549345 Share on other sites More sharing options...
Midnightmare Posted June 27, 2020 Share Posted June 27, 2020 Thanks Xenith, glad you like :tu: These two so far, but they need a few little chalice/blood drop details yet. Not overly bling as it’s not the Flesh Eater way! Fajita Fan and Xenith 2 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5549423 Share on other sites More sharing options...
Majkhel Posted June 28, 2020 Share Posted June 28, 2020 I did a paint! Well, it was over a few days, but I did a paint! Now that's a proper Grimdark Space Vampire! Great job! Love what you did with the armour both in terms of sculpt and paintjob. Midnightmare 1 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5549814 Share on other sites More sharing options...
Xenith Posted June 29, 2020 Share Posted June 29, 2020 (edited) Painted up an Angel Sanguine last night for a laugh. Quick job and needs some touching up, but I'm pretty pleased with him. This is also my first time trying out contrasts as recess shades. Flesh Tearers red didnt contrast enough, Skeleton horde was too 'thin', and snakebite leather was too dark - Gore Grunta Fur was actually perfect, though, not too strong, with enough red to tie it into the armour. I'll probably be swapping this in for my usual Agrax+medium shade from now on. Edited June 29, 2020 by Xenith SnorriSnorrison, Leonaides, Midnightmare and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5550140 Share on other sites More sharing options...
SnorriSnorrison Posted June 29, 2020 Share Posted June 29, 2020 Nice work on the intercessor. Interesting discovery on the shade with Gore Grunta fur. I tend to use Khorne Red on the Mephiston/Pure Red base and add Incubi Darkness to it as per Darren Latham’s YT tutorial. Nice work anyways! Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5550288 Share on other sites More sharing options...
Fajita Fan Posted June 29, 2020 Share Posted June 29, 2020 Not everyone will probably like this but I ordered a bunch of bare Sisters heads to swap on my Primaris to make a female BA successor chapter. Most of my models are primed but I'll just whip out the ol' guillotine and save those heads as trophies for my Black Legion. Thanks Xenith, glad you like These two so far, but they need a few little chalice/blood drop details yet. Not overly bling as it’s not the Flesh Eater way! Awesome looking bayonet, that's a good idea to count as a CCW. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/431/#findComment-5550430 Share on other sites More sharing options...
