Dantay's VI Legion. Hvarls Headtakers
Dantay VI
Lord Thorn, no need to be humble :)
You are a brother wolf, so be loud and proud!!
I do not ask for thoughts to get smoke blown up my bum. I actually like input, such as yours. It is from a fresh pair of eyes, that mistakes or sometimes improvements can be seen that the creator has missed.
http://i1206.photobucket.com/albums/bb456/dantay_xv/20160125_1206541.jpg
I was re-examining the claw and while I like it, something seems a little un-natural.
I think it is where the claws come from the fingers... Nobody bends their fingers back like that, certainly not the tips anyway.
Maybe go back a few millimetres and remove the finger so it is purely claw?
As always folks, let me know what you think?
I'd actually bend them back inwards, so that the main part of the claw is parallel to the arm, rather than the tip.
The problem isn't the bent tips, it's the bent back "fingers" : straight claws might, if anything, make it look weirder :unsure.:
I've done a quick photoshop of the two ideas, the quality is bad but you should get the idea.
What you seem to be proposing:
My idea:
Lord Thorn: Not 100% sure what you mean and I may have done the opposite. Are you suggesting to bring the claws closer?
I have ended up cutting the fingers close to the knuckle joint, which has helped get rid of the green stuff.
I also opened up the lower claw, so they mirror each other more
Before
http://i1206.photobucket.com/albums/bb456/dantay_xv/20160125_1303061.jpg
After
http://i1206.photobucket.com/albums/bb456/dantay_xv/20160125_1302461.jpg
http://i1206.photobucket.com/albums/bb456/dantay_xv/20160125_1302081.jpg
I want to grab you and hug you and call you George!!!
This is going to be a bit photo heavy, but today I am proud to have finished the conversion of my dreadnaught
http://i1206.photobucket.com/albums/bb456/dantay_xv/20160128_1953261.jpg
I finally managed to get his chopped up leg done :)
No longer is he named Hoppy-Stomp
Yah! Jazz-hand(s)
http://i1206.photobucket.com/albums/bb456/dantay_xv/20160128_2113591.jpg
I can't find his base, but I need to work out if I want him to have his foot planted
http://i1206.photobucket.com/albums/bb456/dantay_xv/20160128_2112271.jpg
Or stepping on something about to make a lunge for someone/something.
http://i1206.photobucket.com/albums/bb456/dantay_xv/20160128_2134381.jpg
I want to hug you & squeeze you & call you George!! :D
I also swapped out this guys sword for a mighty axe!!
http://i1206.photobucket.com/albums/bb456/dantay_xv/20160128_2114461.jpg
I didn't realise how Portly he looks with the shoulderguard-belt buckle. He is going to need a suitable name and back-story. Any ideas??
http://i1206.photobucket.com/albums/bb456/dantay_xv/20160128_2114541.jpg
Also onky put small pelts under the shoulderpads. Figured it would give a nice layered effect to the armour and alsohelps stop the armour plates rubbing n making excess noise. He may be big, but he is still a silent killer :D
He is not done. Working on a gorget  and some doodahs
Lastly Is Jorgmundr, the twin blades of Fenris
http://i1206.photobucket.com/albums/bb456/dantay_xv/20160128_2139531.jpg
Then I figured it out, his sword had no pommel, so a few snips later and
http://i1206.photobucket.com/albums/bb456/dantay_xv/20160128_2139441.jpg
Looks a bit better, again I think he needs something to make him a bit more Fenryka.
http://i1206.photobucket.com/albums/bb456/dantay_xv/20160128_2140031.jpg
He has a little potential to make a half decent Ragnar conversion/kitbash :)
So what do you think?
I am in something of a quandary. I am making seekers for my 30K army, but wihout too much reference to the rulebooks.
Probably a silly thing to do. I always imagine the Seekers as a unit sent in to take out a specific target, tracking them  and then dispatching them before sowing mayhem amongsth the nemy or disappearing like mist on a spring morning.
With this in mind, I had envisaged making them striding across the battlefield, sweeping their cloaks back behind them to reveal their presence before gunning down their target. I wanted to load them up with combat blades and the like to make it look like they had been on a hunt.
However to read the rules entry they get a bolter which can be upgraded and  a bolt pistol, but no close combat weapons of any kind.
So do I stick to my plan and go with them loaded up and looking aggressive, or do I go with the book and make them Fenryka, but with no axe by their side?
Also, to stop my dread falling over I have tacked the spare dread shoulder under his foot. I might replace it and have the base trophy-less just like the other marines. However if I keep it, should I make it a Thousand Son or Alpha Legion dread that got wrecked?!?
T-Son is the easy option because of Prospero, but I want to try out an Alpha Legion colour scheme and this could be an easy way to try it.
Run with rule of cool, best rule in the book, and suiting the wolves perfectly :P
Have you thought about giving them a boltgun in one hand and a close combat weapon in the other ? Harken back to the good old days of true grit, looks cool, and would represent the attack the model would have normally in any case.
Okay, thanks guys. So lets see what we can do with the rule of cool.
I do not have a massive amount of bits with me, so these will be quite basic, and when I get home I can get a bit more involved with them.
Started a very rough model mock up of the first 3 seekers. Sarge, comms and the knife guy.
20160131 225619
20160131 225653
20160131 225706
Not sure if I should maglock the combi plasma to his thigh and give him an open hand, as if he is about to spin round a corner grab & stab, or leave as-is. Love the destroyer helmets. Blooming intimidating!!
20160131 225744
20160131 225805
Sarge. Actually really not sure aout this one. Might move him to the veteran tactical sniper squad as he looks like a spotter.
20160131 225824
20160131 225840
Comms guy. Using the recon marine comms model. No aerials and the like. These gys sneak in, blow stuff up and leave.
Let me know what you think.
And Alphas to die at the feet of the might dread!!
I mean everything weve read about the legion sort of hints toward the idea of them commonly keeping blades I  dont see why you would have to compromise yer artistic vision just because they dont take CCW.  I  would say just make sure they have  the hardware to gun people down as well  and youll be fine.  The stuff ive seen so far doesn't lead me to believe they are any less seekers.
Portly Belly : Arnulf Kegslayer
Arnulf earned his title of Kegslayer by attempting to defeat his primarch in a drinking contest. That night, he had already drank under the table 3 of the primarch's Wolf Guard. He attempted to surpass the feat by challenging Russ himself, who laughed and promptly accepted. After 6 hours of non-stop Mjod consumption, Russ and to punch the challenger out cold for fear that the legionnary would drink himself to death before admitting defeat to the night invicible primarch constitution.
6 hours may be a bit much, even for a space marine, but I like the Kegslayer :) is that how he becomes a Wolf Guard ?
All space marines carry a combat dagger. A combat dagger being a 30cm short sword in this manner. So, yeah, why not?
That cuts just as effectively as a 4 odd foot chainsaw with a sword handle... Who knew?
Being fair, a Chainsword does grant ana additional attack when paired with a Bolt pistol etc.
I think blades all round of some sort will have to be done.
I wasn't really feeling the leader vibe from him so a bit of chopping took place.
http://i1206.photobucket.com/albums/bb456/dantay_xv/SAM_3069.jpg
He has aged a wee bit, plus lost the axe. He is now Nuncio vox for the as yet un-named veteran tactical squad, which will act as suppressor/sniper team. He lost the axe arm which was replaced with an augmetic.
http://i1206.photobucket.com/albums/bb456/dantay_xv/SAM_3071.jpg
The twins, who benefit from the nuncio vox's guidance :)
(Need names)
http://i1206.photobucket.com/albums/bb456/dantay_xv/SAM_3070.jpg
Sargeant for the assault based veteran tactical squad. Do I go with melta guns in the squad or volkite chargers, as I seem to have found 2 of them? :)
http://i1206.photobucket.com/albums/bb456/dantay_xv/SAM_3072.jpg
Kegslayer... I put a gorget on him, but his head didnt fit, so also a head swap. The shadow makes the join look really bad, but it is an almost perfect fit.
http://i1206.photobucket.com/albums/bb456/dantay_xv/SAM_3074.jpg
Trying to make some custom bolt guns for my veterans.. I like them except for the bottom right. Looks like a Dyson hand held vacuum. So much for a sniiper variant eh?
http://i1206.photobucket.com/albums/bb456/dantay_xv/SAM_3075.jpg
Lastly combi-meltas for the boys... Did a re-pose on the middle guy as he looked quite "startled" before. Unfortunately his head got badly damaged. I think the cataphract heda looks quite decent. Almost knightly.
Thoughts?!?
Personally I think they all look too "clean" to be Wolves. Maybe when I get home to the proper bits box I can dirty them up?
Borrow away Pallas. It was a lucky find from breaking a head :D
A bit more WIP.
Tried out the Big bolter. What do you think, does it work?
http://i1206.photobucket.com/albums/bb456/dantay_xv/SAM_3077.jpg
I might swap the head out for a mark5, a mark 3 or a bare head. I like this style of mark 4, but hate the stupid skull.OPinions?
Saving the destroyer helm for another model.
http://i1206.photobucket.com/albums/bb456/dantay_xv/SAM_3076.jpg
I am aware that there is still a way to go with filling etc. I also nibbled a little too much off of the rifle butt, which can be fixed.
http://i1206.photobucket.com/albums/bb456/dantay_xv/SAM_3078.jpg
Another thought was to see if a Heavy Bolter drum might fit this bad boy, and run it as a HB with suspensor web?
I'll do another one tonight to get a size comparison.
http://i1206.photobucket.com/albums/bb456/dantay_xv/SAM_3079.jpg
Still a very rough WIP, Thanks for looking and please any thoughts would be gratefully appreciated.
