Headhunters, Transports and Infiltration
Emperor's Furor
The infiltrate gained through Mutable Tactics only affects units with the Legiones Astartes (Alpha Legion) special rule. Since the dedicated transport does not have the Legiones Astartes (Alpha Legion) special rule, the Headhunters would not be able to infiltrate.
~K
Yeah but wouldn't the Headhunters regain the ability to infiltrate from the army wide rule which would then be passed on to their dedicated transport?  or does the rule in the unit's entry which removes infiltrate when giving them a transport have priority of the second giving of infiltration from the army wide special rule?
It's not clear.
Firstly, Infiltrate. If you have the rule, you must Infiltrate.
Units that contain at least one model with this special rule are deployed last, after all other units (friend and foe) have been deployed. If both sides have Infiltrators, the players roll-off and the winner decides who goes first, then alternate deploying these units.
Infiltrators can be set up anywhere on the table that is more than 12" from any enemy unit, as long as no deployed enemy unit can draw line of sight to them.
Unlike previous editions, there's no "setting up normally" or "infiltrate"; in 7th edition, the Infiltrate rule just means you aren't constrained by your Deployment zone.
So, Headhunters; if you take a Transport, there's no rules support by what "no longer infiltrate" means.
We can take it one or two ways;
If it means "loses Infiltrate special rule"; then yes; mutable tactics does overwrite. This is the order of operations;
a) Choose an army and warlord (hence, choose transport, lose infiltrate rule)
cool.png Roll Warlord Trait and choose Mutable Tactic (Infiltrate)
c) deploy first unit
d) deploy units containing one or more model with Infiltrate special rule
If it means may not deploy using infiltrate special rule, then no, it doesn't overrite.
As the wording is more similar to the latter, then a) it's unclear exactly what that means in regards to 7th edition vernacular, and cool.png if it's more similar to earlier editions, then it's outright banning the use of the infiltrate style of deployment; meaning that you'd have to deploy normally (despite still having the Infiltrate special rule; because Codex > Rulebook).
However, if you cannot agree to how the rule should be apply, roll off as in "The Most Important Rule".
If you were to ask me, however, I'd personally let you Infiltrate via Mutable Tactics.
Can someone please sort out this ruddy quoting mechanism? Never been on a sight with something so ridiculous.
So the mutable tactics rule overwrites the passage in the unit entry that says giving them a transport means they may not infiltrate?
It's not as clear as that, I think it would do however if the exact wording is May not infiltrate when selecting a dedicated transport then no Mutable Tactcis has no effect.
however their only options for Dedicated transport are a rhino and a drop pod right? Why would anyone want to infiltrate a drop pod? And an infiltrating rhino is hardly game breaking.
They could use the Armoured Spearhead RoW -- then they could deploy in a land raider. And yeah, that is very close to the exact wording. It says that if they select a dedicated transport, they may no longer infiltrate. I doubt it was intended to counteract the Mutable Tactics special rule, though. That would mean that a Cataphractii squad in a spartan could infiltrate, but the Headhunters in a rhino could not. Doesn't make a whole lot of sense, but that is the way it is written.
~K
