ChaosRising Posted May 12, 2015 Share Posted May 12, 2015 Following are a series of photos and notes/step-by-step guides tracking the construction of a Khorne Rhino. First....the bitz in their natural state http://i280.photobucket.com/albums/kk172/michaelburnham/100_0804_zpsc2ovybns.jpg I then clipped out the necessary bitz and sprayed them black. http://i280.photobucket.com/albums/kk172/michaelburnham/100_0805_zps7drkvqxf.jpg When I was doing the clipping I was still unsure about the dirge caster and extra armor trophy racks so those were not included. Everything else was done in one pass. I then pulled aside the pieces for the main hull. http://i280.photobucket.com/albums/kk172/michaelburnham/100_0808_zpsacfc8c1f.jpg The main hull was then sprayed red. http://i280.photobucket.com/albums/kk172/michaelburnham/100_0809_zpssp5gqgmb.jpg This is a sample of the right track guards. http://i280.photobucket.com/albums/kk172/michaelburnham/100_0810_zpshq3fr7xw.jpg I used Scorpion Brass over the black basecoat. The left track guards were already painted on glued onto the left half of the hull by the time I took this picture. As of this posting, the right track guards are already glued in place. Last update: 5/12/15 - 2133 EST Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/ Share on other sites More sharing options...
ChaosRising Posted May 15, 2015 Author Share Posted May 15, 2015 The access hatches have been glued in place. Main hull - left profile http://i280.photobucket.com/albums/kk172/michaelburnham/100_0812_zpsegomct9n.jpg Main hull - right profile http://i280.photobucket.com/albums/kk172/michaelburnham/100_0813_zpsypheqxkm.jpg Main hull - rear http://i280.photobucket.com/albums/kk172/michaelburnham/100_0814_zps7xbykmnz.jpg The combi bolter has been glued along its inner edges, allowing it to pivot in place. http://i280.photobucket.com/albums/kk172/michaelburnham/100_0811_zpspo98gx6f.jpg Brass trim: Scorpion Brass. Lighter brass detailing: Runelord Brass over Scorpion Brass. Silver areas (except bayonet): Leadbelcher Bayonet: Runefang Steel over Leadbelcher. Ammunition: Mephiston Red. Last update: 5/14/15 - 2245 EST Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4042742 Share on other sites More sharing options...
ChaosRising Posted May 17, 2015 Author Share Posted May 17, 2015 Spikey bitz ready for attachment as extra armor. http://i280.photobucket.com/albums/kk172/michaelburnham/100_0817_zps1jy8n925.jpg These are just the normal tropy racks from the left spikey sprue, closest to the two sets of chains (see the "natural state" pic), cut up into more manageable chunks. They were painted as follows: Leadbelcher Runefang steel (for the tip and the round base) Mephiston Red (slopped on the tip) 'Ardcoat over anyplace with Mephiston Red (to give the impression of fresh blood) This same method was used for painting the giant, razor-sharp dozer blade on the front of the hull. Completed Rhino - rear http://i280.photobucket.com/albums/kk172/michaelburnham/100_0827_zpsyx6jau43.jpg Completed Rhino - front http://i280.photobucket.com/albums/kk172/michaelburnham/100_0828_zpsnhvyzywo.jpg Completed Rhino - left profile http://i280.photobucket.com/albums/kk172/michaelburnham/100_0831_zps8cmecbvv.jpg Completed Rhino - right profile http://i280.photobucket.com/albums/kk172/michaelburnham/100_0833_zpscnqlgvbg.jpg Dirge caster (mounted just above the dozer blade) Brass Scorpion Runelord Brass detailing Mephiston Red cabling 'Ardcoat over the red Searclight and headlights: Golden Yellow Flash Gitz Yellow Skull-hurling havoc launcher Abaddon Black (touchup) over black primer (mostly because the primer was a haphazard spray job) Brass Scorpion (skulls) Leadbelcher, followed by Runefang Steel (tracks on the top) Leadbelcher (cradle and tracks on the bottom) Brass Scorpion, followed by Runelord Brass (the two missiles visible in the lower rack) There is only some mild pinning and filing involved in order to convert a standard havoc launcher into a more Khorne-friendly version, Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4045871 Share on other sites More sharing options...
KrautScientist Posted May 17, 2015 Share Posted May 17, 2015 Looking good so far -- If I may make one suggestion, I think you'd be getting more reactions if you were to actually post pictures in this thread instead of merely linking to pictures. Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4046059 Share on other sites More sharing options...
ChaosRising Posted May 20, 2015 Author Share Posted May 20, 2015 Vow # 2 - 5 Khorne Warp Talons Primed - http://i280.photobucket.com/albums/kk172/michaelburnham/100_0834_zpstrlcbcgl.jpg I preassemled the feet/legs, as well as the torsos and jump packs, since I was planning to use this squad for vow #2. Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4050301 Share on other sites More sharing options...
Augustus b'Raass Posted May 20, 2015 Share Posted May 20, 2015 Looking good so far -- If I may make one suggestion, I think you'd be getting more reactions if you were to actually post pictures in this thread instead of merely linking to pictures. I strongly second this! Perhaps postimage.org isn't the best service to use for this forum, as I've tried to write you up a how-to, but none of them worked... Photobucket gives you the correct codes for posting images in your comments. Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4050555 Share on other sites More sharing options...
ChaosRising Posted May 23, 2015 Author Share Posted May 23, 2015 Vow #2 - 5 Khorne Warp Talons Mephiston Red on the legs and torsos. http://i280.photobucket.com/albums/kk172/michaelburnham/100_0836_zpsdgoo8y7r.jpg Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4054582 Share on other sites More sharing options...
ChaosRising Posted June 10, 2015 Author Share Posted June 10, 2015 Vow #2 - 5 Khorne Warp Talons Completed unit - front view http://i280.photobucket.com/albums/kk172/michaelburnham/100_0845_zpshlcpehgh.jpg Completed unit - rear view http://i280.photobucket.com/albums/kk172/michaelburnham/100_0859_zpsxycmlgm7.jpg Completed unit - right side view http://i280.photobucket.com/albums/kk172/michaelburnham/100_0860_zpss0ispcnk.jpg At some point I will try to post some photos that are not quite as dark. For the moment I'm just happy to be done with this unit. Here's a quick rundown of the paint job: Red armor: Mephiston Red Main brass (shoulder trim, gauntlet trim, leg/foot trim, face detail): Brass Scorpion Brass detail (lightning pattern on legs, gauntlets, some torsos, wing lightning) : Runelord Brass over Brass Scorpion Wings: Brass Scorpion, washed with Nuln Oil, then washed with Agrax Earthshade. Wing spikey bitz: Leadbelcher, with Runefang Steel tips (four models), straight Runefang steel (one model) Claws: Runelord Brass over Brass Scorpion; Runelord was then followed by Bloodletter Glaze. That was then followed by 'Ardcoat Fleshy parts on the jump packs: Squig Orange, followed by Kislev Flesh, finished with Screaming Skull Debris scenery: Doombull, brushed with Leadbelcher, then washed with Agrax Earthshade. Bottom of the scenic stand was Mechanicus Standard brushed with Ulthuan Grey Slaaneshi helmet: Genestealer purple, followed by Emperor's Children Pink, highlighted with Changeling Pink Fiery patterns: Mephiston Red base, Blazing Orange over that, Golden Yellow, and then Flash Gitz Yellow (used this for areas on the marines as well as the for the basing design) Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4079925 Share on other sites More sharing options...
ChaosRising Posted June 20, 2015 Author Share Posted June 20, 2015 Vow # 3 - Herald of Khorne Herald - primed black http://i280.photobucket.com/albums/kk172/michaelburnham/100_0864_zpsznbap1dk.jpg Completed Herald - front http://i280.photobucket.com/albums/kk172/michaelburnham/100_0866_zps5utdjecd.jpg Completed Herald - rear http://i280.photobucket.com/albums/kk172/michaelburnham/100_0867_zpsxsknwsdi.jpg Completed Herald - right http://i280.photobucket.com/albums/kk172/michaelburnham/100_0868_zpshofdw2mu.jpg Completed Herald - right front (facial view) http://i280.photobucket.com/albums/kk172/michaelburnham/100_0886_zpsapjm9y2o.jpg Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4094369 Share on other sites More sharing options...
Augustus b'Raass Posted June 20, 2015 Share Posted June 20, 2015 Coolbeans! But dude why not post the pics in your thread itself. You'll get more visitors and more feedback that way, i guarantee it. :tu: Edit: oops, I see now this has already been said, including by me. It is up to you to follow the advice of course, just trying to help. :) Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4094587 Share on other sites More sharing options...
ChaosRising Posted June 20, 2015 Author Share Posted June 20, 2015 Yea, I know....I just find the gallery feature to be a pain the rear armour. If there was an easier way to drop the images in I would. Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4094927 Share on other sites More sharing options...
Augustus b'Raass Posted June 20, 2015 Share Posted June 20, 2015 That's because the gallery is a pain in the rear. It also takes up valuable server space for which we all have to pay voluntarily. There is also a free and easier option: photobucket. If you upload your pics to a free Photobucket account, and then copy paste the lowermost URL of the individual pics straight in the comment, they show up perfectly. Couldn't be easier. Now please go do that, so we can drool over your models in the greatest Space Marine forum on the web. ;) Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4095487 Share on other sites More sharing options...
ChaosRising Posted June 29, 2015 Author Share Posted June 29, 2015 Arighty...time for a 4th vow. Daemon Prince of Khorne with Combat Familiar (other upgrades are on the DP model). Daemon Prince - primed. http://i280.photobucket.com/albums/kk172/michaelburnham/100_0888_zpsjucmfvci.jpg Daemon Prince's combat familiar - primed http://i280.photobucket.com/albums/kk172/michaelburnham/100_0889_zpsfe71rx5o.jpg Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4106793 Share on other sites More sharing options...
ChaosRising Posted July 4, 2015 Author Share Posted July 4, 2015 Vow # 4 - Daemon Prince of Khorne with Combat Familiar (In Progress - nearly finished) Picture heavy. Completion pictures in subsequent post. Just a couple things I should mention before launching into picture madness. Due to the scale of this vow - both the physical size (relative to most other models) and the fact that I wanted it to be a quality piece - I was focused more on the painting end of things than on taking pictures in order to avoid losing momentum. Also, given that the combat familiar is ultimately a support piece, I felt that he/it did not deserve much in the way of WIP photos, for the reasons mentioned above. Some of the photos that follow have part of a sprue in them, which I was using to prop up the piece in question to get a better angle. Feel free to ignore the sprue leftover. Now then...without any further ado, here are the pre-completion WIP/nearly completed photos of the big nasty. Daemon Prince - main body - front http://i280.photobucket.com/albums/kk172/michaelburnham/100_0890_zps18jrbqbw.jpg Daemon Prince - main body - back http://i280.photobucket.com/albums/kk172/michaelburnham/100_0891_zps8ktrjsxr.jpg Daemon Prince - head http://i280.photobucket.com/albums/kk172/michaelburnham/100_0892_zpsurbm21my.jpg Daemon Prince - left arm http://i280.photobucket.com/albums/kk172/michaelburnham/100_0896_zpsap0i3df5.jpg Daemon Prince - left shoulder guard http://i280.photobucket.com/albums/kk172/michaelburnham/100_0900_zps0tt6z0tp.jpg Daemon Prince - right arm http://i280.photobucket.com/albums/kk172/michaelburnham/100_0901_zpsqofnxfls.jpg Daemon Prince - right shoulder guard http://i280.photobucket.com/albums/kk172/michaelburnham/100_0897_zpsscer8ogp.jpg Daemon Prince - axe [treat as Goredrinker] http://i280.photobucket.com/albums/kk172/michaelburnham/100_0893_zpsolwkex78.jpg Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4113118 Share on other sites More sharing options...
ChaosRising Posted July 4, 2015 Author Share Posted July 4, 2015 Vow # 4 - Daemon Prince of Khorne with Combat Familiar (Completed) And now, the moment of truth. Well seeing as you all know what the Daemon Prince (who I've decided to call The Reaper, until I think of something better) is probably going to look like (assuming you've been poking around here), I may as well start with him first. Daemon Prince - completed - front http://i280.photobucket.com/albums/kk172/michaelburnham/100_0909_zps0aamswaq.jpg Daemon Prince - completed - rear http://i280.photobucket.com/albums/kk172/michaelburnham/100_0912_zpst4trww5e.jpg Combat familiar (aka "Killa") Killla - completed - front http://i280.photobucket.com/albums/kk172/michaelburnham/100_0917_zpsaynygnzc.jpg Killa - completed - rear http://i280.photobucket.com/albums/kk172/michaelburnham/100_0920_zpskdxvqj1o.jpg The Reaper and Killa http://i280.photobucket.com/albums/kk172/michaelburnham/100_0934_zpsfhlxgrtv.jpg Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4113130 Share on other sites More sharing options...
Carrack Posted July 5, 2015 Share Posted July 5, 2015 Awesome Prince. I also really wished I had seen this blog before I started my first rhino, it might have prevented the abomination I made. :) Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4113604 Share on other sites More sharing options...
ChaosRising Posted July 5, 2015 Author Share Posted July 5, 2015 Thanks for the compliments, Carrack. As far as the Rhino goes....aren't abominations the heart and soul of Chaos? Seriously though, don't go too hard on yourself. In my experience, the least appealing units (visually) are the first ones of their kind to be painted - be it my first bloodletter, or first space marine. Anytime you paint something you've never worked on before it's bound to be less glorious than the rest because you have nothing in your collection as a point of reference. Once you get that first piece done, you can look at it and decide what colors need to be changed on future models. Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4114527 Share on other sites More sharing options...
ChaosRising Posted July 6, 2015 Author Share Posted July 6, 2015 Now that I've responded to almost every topic I can think of, I guess it's time that I got cracking on my final vow. So then.... Vow # 5 - Helbrute and (yes, another) Khorne Daemon Prince Helbrute http://i280.photobucket.com/albums/kk172/michaelburnham/100_0935_zpsddstjmdm.jpg Daemon Prince http://i280.photobucket.com/albums/kk172/michaelburnham/100_0936_zpsae0iklrd.jpg Not much to say about this one, except that it has wings and a one-handed axe. For the purposes of this vow, the axe is treated as Kor'lath. For gaming, however, I plan to use the axe as Kor'lath, Blade of Endless Bloodshed, or Axe of Blind Fury, depending on what kinds of shenanigans I'm in the mood for. Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4114851 Share on other sites More sharing options...
Scribe Posted July 6, 2015 Share Posted July 6, 2015 You know...I should get that Daemon. Your red's look good! Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4114900 Share on other sites More sharing options...
ChaosRising Posted July 6, 2015 Author Share Posted July 6, 2015 Thanks Scribe. It's actually not that hard to do. Given that this was my first shot at something of this scale and detail I decided to pick up a copy of White Dwarf #57 a little while before hand so that I could start deciding which color themes I wanted for armor, flesh, etc. As far as the reds, they're really not too hard. Basically I just followed Steps 1 - 4 of p. 24 in WD 57, with only a few minor changes (see below) I pretty much followed the first few steps for painting a red-skinned bloodthirster (as follows) - boldface indicates I deviated from the Studio method Step 0. Prime black - I use matte black primer from P3 Step 1. Mephiston Red - Drybrush with a small drybrush Step 2. Agrax Earthshade - apply w/ a wash brush Step 3. Mephiston Red - Carefully drybrush over the existing layer, using the small dryrush (I say carefully, because you run the risk of the red blurring together and becoming non-descript) Step 4. Evil Sunz Scarlet - the only change here is I used a brush from a company called Gyros. Not sure what size the brush is, as that layer of the brush's coating has actually come off, but I'll post a picture of it one of these days, as it's my go-to brush for almost every project. Steps 1-3 were used for pretty much all parts of the body. Step 4 was used selectively - muscles, bones, etc as well as serving as a kind of base layer for the veins. The veins were then picked out in Wild Rider Red. Only a couple red areas that are a bit different: Khorne rune on the gut: Evil Sunz Scarlet Layer of 'Ardcoat Khorne rune on the left butt cheek Steps 1 - 4 as normal Layer of 'Ardcoat Evil Sunz Scarlet Layer of Ardcoat Thin layer of Blood for the Blood God Final layer of 'Ardcoat Everything else is much simpler. I'll post more instructions here later. Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4114920 Share on other sites More sharing options...
ChaosRising Posted July 7, 2015 Author Share Posted July 7, 2015 Vow #5 - (Daemon Prince updates) Daemon Prince - thorougly coated in Mephiston Red http://i280.photobucket.com/albums/kk172/michaelburnham/100_0937_zpsxrnwhlgc.jpg Daemon Prince - covered in Agrax Earthsade (not so much a wash as a bath) http://i280.photobucket.com/albums/kk172/michaelburnham/100_0938_zpsygzefit3.jpg Daemon Prince - second coat of Mephiston Red http://i280.photobucket.com/albums/kk172/michaelburnham/100_0943_zpsnhch7m6e.jpg The tail is the only piece that did not get a second layer of Mephiston (by design), so I decided to put in the picture anyway for the sake of comparison. Daemon Prince - Evil Sunz Scarlet detailing http://i280.photobucket.com/albums/kk172/michaelburnham/100_0946_zpsk2d2hfn9.jpg (I know....I got carried away) Daemon Prince - Wild Rider Red detailing http://i280.photobucket.com/albums/kk172/michaelburnham/100_0950_zpsi7ebap6i.jpg Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4115911 Share on other sites More sharing options...
ChaosRising Posted July 12, 2015 Author Share Posted July 12, 2015 Vow # 5 (Daemon Prince portion) Daemon prince - completed - front http://i280.photobucket.com/albums/kk172/michaelburnham/100_0951_zps1uwda8qb.jpg Daemon prince - completed - left http://i280.photobucket.com/albums/kk172/michaelburnham/100_0962_zps2hlhyvbr.jpg Daemon prince - completed - rear http://i280.photobucket.com/albums/kk172/michaelburnham/100_0956_zps0ozrmeui.jpg Daemon prince - completed - right http://i280.photobucket.com/albums/kk172/michaelburnham/100_0960_zpslvfpqo2h.jpg Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4121725 Share on other sites More sharing options...
Augustus b'Raass Posted July 14, 2015 Share Posted July 14, 2015 Great work, buddy! Keep it up. :) Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4122963 Share on other sites More sharing options...
ChaosRising Posted July 25, 2015 Author Share Posted July 25, 2015 Vow #5 (Helbrute Portion) Helbrute - completed - front http://i280.photobucket.com/albums/kk172/michaelburnham/100_0971_zps6b9wxpu3.jpg Helbrute - completed - rear http://i280.photobucket.com/albums/kk172/michaelburnham/100_0973_zpsfspndshd.jpg Helbrute - completed - right http://i280.photobucket.com/albums/kk172/michaelburnham/100_0980_zps4iijirjy.jpg Link to comment https://bolterandchainsword.com/topic/307479-blood-for-the-blood-god-etl-iv-work-in-progress/#findComment-4127726 Share on other sites More sharing options...
