The Iron Chancellor Posted May 13, 2015 Share Posted May 13, 2015 So my army is just starting out I have 10 assault marines with two melta and power fist on the sergeant and I just got a sanguinary guard box I'm thinking about how to equip them. (there aren't enough infernus pistols for all of them) I think I'm going to use some extra power swords so that they all have glaive encarmines. Also I have a tactical squad that Im thinking about how to equip so give me your thoughts down below Link to comment Share on other sites More sharing options...
Just4uCupCake Posted May 13, 2015 Share Posted May 13, 2015 for SG go with Glaives or power fists def put death masks on them and have a mix of plasma pistols and inferno pistols. Never ever use axes lol they are terrible for what you get Link to comment Share on other sites More sharing options...
Golden Aegis Posted May 13, 2015 Share Posted May 13, 2015 PFs are REALLY cheap for SG so try to grab one per 5 members, also go for the banner if you're running more then 5, or have a priest with them which I highly recommend. Priests up their survivability a lot, and makes them hit more accurately. Pistols are pretty optional their AP 4 double tap pistols are usually fine, but a meltagun or plasma pistol won't hurt if you've got the points. The masks are pretty cool, but most units you want these guys fighting don't care about fear. Overall don't be afraid to put some points into these guys, they are amazing in combat, but don't overload them with equipment either. I run mine in a 10 man unit, 2 PF, 2 Axes, 6 Swords, and a banner, running with Dante, a priest, and a sanguinary librarian. Pray for shield of sang. Will add in 2 plasma, 2 melts pistols ONLY if I have a ton of points to fill. Link to comment Share on other sites More sharing options...
Karhedron Posted May 13, 2015 Share Posted May 13, 2015 I would normally add 1-2 power fists for the inevitable walkers and MCs. A couple of axes are worth taking larger squads for the extra AP2. If you have the points 2-3 melta pistols are great as you can crack open transports and then charge the contents. A lot of players like alpha-striking meltacide ASM squads but SG can carry their melta with them. I don't worry with plasma pistols as they are for taking out infantry or MCs which the SQ can do comfortably in combat anyway. If running anything bigger than a min-sized squad then a banner is worth considering. I like a Priest to lead them as 2+ & FNP is pretty resilient. Link to comment Share on other sites More sharing options...
BadDice0809 Posted May 13, 2015 Share Posted May 13, 2015 Agree with adding a banner and a fist or two. But don't spend points on the pistols. Adds uo and can even end up shorting your charge if you kill too many. And every turn they aren't safe in combat is bad- they have a huge shiny target on their nipple armor for every plasma weapon your enemies have. Link to comment Share on other sites More sharing options...
Sans Mercy Posted May 13, 2015 Share Posted May 13, 2015 I take the Banner, and up to 2 Infernus and 2 PF. The plasma pistol is pointless in that its only advantage over the melta pistol is range. Link to comment Share on other sites More sharing options...
The Iron Chancellor Posted May 13, 2015 Author Share Posted May 13, 2015 Okay so the consensus seems to be 2 infernus pistols with glaives and I guess storm bolters for the remaining three. If my assault squad has two meltas and power fist (I'm aiming to be good against non horde armies) How should I equip my tactical squad? Link to comment Share on other sites More sharing options...
Sans Mercy Posted May 13, 2015 Share Posted May 13, 2015 Okay so the consensus seems to be 2 infernus pistols with glaives and I guess storm bolters for the remaining three. If my assault squad has two meltas and power fist (I'm aiming to be good against non horde armies) How should I equip my tactical squad? Flamers are great if you need an answer for horde stuff. Link to comment Share on other sites More sharing options...
Helias_Tancred Posted May 14, 2015 Share Posted May 14, 2015 I've got a 10 man force. I run 2 axes, 2 powerfists, 3 inferno pistols and the rest are angelus bolters and swords. They've always performed well for almost any combat situation I tossed them in. Link to comment Share on other sites More sharing options...
Helias_Tancred Posted May 14, 2015 Share Posted May 14, 2015 With two attacks each if you're running 6+ angelus bolters they work great for hordes of infantry. The axes and powerfists will eat armor and strongly armored opponents, same for the inferno pistols. I've never had a problem with my config performing in battle. and yeah tossing in a sanguinary priest with a jump pack is just sweet! Link to comment Share on other sites More sharing options...
Oirghialla Posted May 14, 2015 Share Posted May 14, 2015 I agree with most people here. I run mine like so: 7 Sanguinary Guard - chapter banner, 5 glaive, 2 powerfist Sanguinary Priest - power spear (only because I primarily fight eldar so I get str 6 on the charge for instant death), bolt pistol This strikes a balance between being cheap and being survivalable I find. Link to comment Share on other sites More sharing options...
