Blackadder Posted August 3, 2015 Share Posted August 3, 2015 All this talk regarding the necessity of a base bring to mind the question: ''What is the size of each foot; length and breadth including the diagonal toes?'' My Warlord feet are 9.75 inches long and 8.5 inches wide each but the front and rear toes flex up so they do not add to the stability. The stabilizing toes are the diagonals and they are 9.25 inches tip to tip. http://i.imgur.com/CzdvNErl.jpg http://i.imgur.com/hhP8Cda.jpg http://i.imgur.com/hhP8Cdal.jpg Bottom line is if the feet in any way resemble these dimensions the model should be adequately stable. Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4136258 Share on other sites More sharing options...
Blackadder Posted August 3, 2015 Share Posted August 3, 2015 Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4136266 Share on other sites More sharing options...
depthcharge12 Posted August 3, 2015 Share Posted August 3, 2015 Lol the warlord is nudging that lancer like "Hold mah beer son, see how a man gets it done." Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4136273 Share on other sites More sharing options...
Andvarr A Posted August 3, 2015 Share Posted August 3, 2015 All this talk regarding the necessity of a base bring to mind the question: ''What is the size of each foot; length and breadth including the diagonal toes?'' My Warlord feet are 9.75 inches long and 8.5 inches wide each but the front and rear toes flex up so they do not add to the stability. The stabilizing toes are the diagonals and they are 9.25 inches tip to tip. Bottom line is if the feet in any way resemble these dimensions the model should be adequately stable. Some hefty shoes to fill. "i don't think they made Nike's in her size Ray" Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4136309 Share on other sites More sharing options...
Athrawes Posted August 4, 2015 Author Share Posted August 4, 2015 So I'm still contemplating the basing issue. I think If I do go the basing route that I would make the base removable. However, I'm not convinced Magnets or pinning would work in this situation. I'll give it some more thought as I have a while yet before I need to decide either way. In other fronts, I've finished a bit more detailing work: http://i1088.photobucket.com/albums/i327/nickfayette1/c4cc3dc7-caf1-455a-884e-5301fd2c619d.jpg http://i1088.photobucket.com/albums/i327/nickfayette1/090c1b99-82f8-4a8d-95af-2c786a523299.jpg I have finished two more sets of Prayer Scrits. I think that I am finished on that front, as I want to keep them as an accent, not a focus. The next step will be to add small wind chimes/ furin bells in on the ropes in between the scrits. http://i1088.photobucket.com/albums/i327/nickfayette1/004c8286-63e3-4bd4-a1e4-e98b31b36647.jpg Of course it needs a few lighting bolts too... http://i1088.photobucket.com/albums/i327/nickfayette1/54253e9a-025a-49ba-86de-c1874631574e.jpg http://i1088.photobucket.com/albums/i327/nickfayette1/4cfff2e9-7240-4f12-8491-6bfa0cf4d291.jpg I'm Particularly proud of this. I thought the back would look cool with guardian dragons on the entry port rail. +++++ As always, I'd love to hear what you think. Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4136788 Share on other sites More sharing options...
Brother-Chaplain Kage Posted August 4, 2015 Share Posted August 4, 2015 Those dragons are great! Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4136793 Share on other sites More sharing options...
librisrouge Posted August 4, 2015 Share Posted August 4, 2015 Those serpents are magnificent. Any other unique sculpts planned or more scripts and lightning? Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4136795 Share on other sites More sharing options...
Athrawes Posted August 4, 2015 Author Share Posted August 4, 2015 Edit: I forgot the most important picture! I've begun sculpting the Heraldry. This is the start of the Legio Symbol: http://i1088.photobucket.com/albums/i327/nickfayette1/a4c557c1-954e-4d6c-9311-958832f13ff3.jpg Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4136798 Share on other sites More sharing options...
Morningshadow Posted August 4, 2015 Share Posted August 4, 2015 Nice work on all the added details. Again I have no idea what the bottom of the feet look like but what about adding an anchor that you could use to bolt a base onto the feet? Similar to a drywall anchor but less crude and something you could drill a small pilot hole and then glue a sleeve into. Since it'll be at least 3 months before I order my Warlord I'll just have to keep spit balling till then, lol. Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4136825 Share on other sites More sharing options...
sheep Posted August 4, 2015 Share Posted August 4, 2015 Nice legion symbol mate, is it cannon? Or something you came up with? I ask, because replacing the horn on the unicorn with a lightning bolt might make the psychic titan theme a bit stronger. Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4136828 Share on other sites More sharing options...
Blackadder Posted August 4, 2015 Share Posted August 4, 2015 Love all the 'Greenstuff' add-ons; 'way to go in personalizing your model. When (?) I get my model I'll refer to to this thread religiously for inspiration. Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4137007 Share on other sites More sharing options...
Augustus b'Raass Posted August 4, 2015 Share Posted August 4, 2015 Wow, those serpents are fantastic. Great idea, great execution. I'm less enthused by the choice of a unicorn as a symbol, but that is a matter of taste. You certainly did a convincing job sculpting it! :tu: One nitpick though: the lower right lightning bolt is a little off angle compared to the bottom left. Should be simple enough to fix -especially considering your GS skills- and it will make a world of difference on such an important piece of the visual. :tu: Wow! :) Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4137076 Share on other sites More sharing options...
Andvarr A Posted August 4, 2015 Share Posted August 4, 2015 Nice sculpting work. I think the serpents are a nice touch on the guard rails Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4137239 Share on other sites More sharing options...
Daemon2027 Posted August 4, 2015 Share Posted August 4, 2015 Love the little details your adding. The dragons on the rails are fantastic. Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4137242 Share on other sites More sharing options...
Teetengee Posted August 4, 2015 Share Posted August 4, 2015 I love the sculpted details, although I also think some of the lightning bolts might be slightly better positions (on such an expensive model it seems like it would be worth the effort for minor details). However, I fully support the unicorn, any creature with the strength of a horse, a blade on its head, and magical powers is dangerous, and any unicorn one might find in the 40k30k universe would almost certainly kill you. Seems appropriate. Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4137305 Share on other sites More sharing options...
Athrawes Posted August 4, 2015 Author Share Posted August 4, 2015 Since the Unicorn thing seems a bit controversial perhaps I should explain my thoughts. I needed a Legio symbol which could represent the avatar of a Psychic Titan Legion. This immediately excluded anything mundane. When it came to choosing a creature, it seemed best to pick a mythological creature to represent one of 40k's "myths", the existence of the Psi-Titan. We know from lore and background that they do exist, but we know next to nothing about them. The Unicorn. When I need a creature to represent psychic might, the Unicorn just jumps to mind. It is a mythical, noble creature, rare and somewhat melancholic in legend. But it is the Unicorns horn which truly cinches it for me. The symbolism of the single horn is wonderful. It represents the psychic "3rd eye" weaponized. What better avatar could there be which embodies the mind as a weapon, like a sword springing from pure thought the Unicorn embodies magic, and it's single horn represents the turning of that magical (psychic) power towards violence. +++++ That's at least my thought process! Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4137319 Share on other sites More sharing options...
Machine God Posted August 4, 2015 Share Posted August 4, 2015 Reference the Unicorn. Is your Psi-Titan controlled by a women, if it is that is good. Unicorns would only let female virgins ride on them. Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4137332 Share on other sites More sharing options...
Teetengee Posted August 4, 2015 Share Posted August 4, 2015 Reference the Unicorn. Is your Psi-Titan controlled by a women, if it is that is good. Unicorns would only let female virgins ride on them. That is dependent on the myth you are referring to. Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4137339 Share on other sites More sharing options...
Andvarr A Posted August 4, 2015 Share Posted August 4, 2015 That's just it tho...nothing is definite, and in 40k, they'd use symbolism they feel it fits them or best adheres to their methods. The choice of unicorn comes from the fact they are magical creatures and psykers/psychics are just a futuristic versions of magicians and such...so yeah...I think Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4137374 Share on other sites More sharing options...
Augustus b'Raass Posted August 4, 2015 Share Posted August 4, 2015 The symbolism of the single horn is wonderful. It represents the psychic "3rd eye" weaponized. Just this alone already sold it for me. :tu: Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4137815 Share on other sites More sharing options...
Daemon2027 Posted August 5, 2015 Share Posted August 5, 2015 I think Unicorns fit the far East theme you have developed for the II legion to. Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4138228 Share on other sites More sharing options...
Rev. Tiberius Jackhammer Posted August 5, 2015 Share Posted August 5, 2015 Looking forward to watching this beast grow, fantastic seeing such a monolothic model being dedicated to an intricate DIY Legion. Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4138233 Share on other sites More sharing options...
Nomus Sardauk Posted August 5, 2015 Share Posted August 5, 2015 I say stick with the Unicorn for all the reasons you've stated and more, it's just so unique. Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4138433 Share on other sites More sharing options...
GhostMalone Posted August 5, 2015 Share Posted August 5, 2015 Dude have you looked at joining the titan owners club? http://titanownersclub.blogspot.co.uk/?m=1 Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4138660 Share on other sites More sharing options...
Athrawes Posted October 19, 2015 Author Share Posted October 19, 2015 So, i have taken a bit of an extended break from the Warlord (if you hadn't noticed). Now that it is built and the conversions are finished, I have honestly been a bit daunted by the prospect of painting it, it is such an expensive model, and such a centerpiece that i have been holding off and second guessing myself in reguards to the paint scheme for it's titan legion to accompany my Lightning Bearers. I plan to dive in over the holidays when work takes a back burner, but I just wanted to check in and say She will walk. I also was wondering if there are any members in the UK who might consider picking up a Mars-Beta head from the forgeworld store now that it is available? If so, shoot me a PM please and I'll add an honor scroll with your name on it to the titan's Carapace when she is finished. Link to comment https://bolterandchainsword.com/topic/310874-mars-pattern-warlord-psi-titan-the-red-comet-walks/page/3/#findComment-4200648 Share on other sites More sharing options...
