Spear of Achilles Posted January 27, 2016 Share Posted January 27, 2016 (edited) Ok, this is going to be a project that looks too good to pass up...want to do a Cindered Khorne Daemonkin army that uses this look... http://2.bp.blogspot.com/-qeuCAzZhNaw/VqhjyaVJb5I/AAAAAAAAB6g/pSTu6AOcHzo/s1600/Presentation_shot_Ahriman_01.jpg but I'm wondering if I should go light to dark or dark to light...(probably the former)...I'm seeing a lot of blues/greys/violets and of course umber burns to flame spectrum...nothing to show yet, as just a concept, but I'll try some test models and post on this thread. I'm thinking doing the flames in the various marine joints/eyes, etc, then filling them with liquid masking rubber and then going for the base colors...might be the best way to do 'veins' of flame.... Edited January 27, 2016 by Spear of Achilles Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/ Share on other sites More sharing options...
The_Chaplain Posted January 27, 2016 Share Posted January 27, 2016 Sounds like a great concept, looking forward to seeing it executed Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4286278 Share on other sites More sharing options...
Spear of Achilles Posted February 28, 2016 Author Share Posted February 28, 2016 (edited) I have 15 Puppetswar flesh hounds and I wanted to try this idea before I tackle them in the color scheme. Each pic has info about what steps i was on. Did it work? Meh, not as well as I'd liked...the mask liquid was quite hard to control;...either I'll have to use the brush-on, or add it in very small amounts, wait for it to dry, and add more. On the parts of the model it did work best, I really like the effect...I think these flame areas will look much better with a little brush touch up, and of course everything armor wise needs to be painted. I sued a synthetic cotton swab and on the old minitaire paints, it removed the paint as well as the dried rubber mask...as for how it turned out? Nothing ventured, nothing gained.... This is the stuff i used; This stuff has a needle in the cap as well to clear the applicator needle. Comes out as fluid as milk, so even with the needle you are somewhat at the mercy of the models contours (I suppose I could be VERY careful and build on to added, dried mask for greater control...would take an age...dries fairly fast, so I'll try the slower steps and just devote a day to masking. Maybe use of the airbrush would speed up the drying time? The mask was added before i painted him in soot ...pained the various areas I though would be flame seams first then masked. (over a ghastly old light blue original paint job...yes i know shoulda stripped/primed) Back after painting over mask fluid Stripping off the mask,,,,need more though in where my yellows/oranges are going to show... Some work with a normal brush is in order (Obviously) to clean up splotchy mask patches Stripped the mask...need to find a item, maybe a clay-shaper, that will move the mask off without scratching paint This is going to take a lot of touching up (and of course none of the items he wears/uses are painted yet) Edited April 26, 2017 by Spear of Achilles Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4320903 Share on other sites More sharing options...
Spear of Achilles Posted February 29, 2016 Author Share Posted February 29, 2016 (edited) Hmmm the 'Great Experiment' is pretty much over with using Masking Fluid through a needle tip. I find that it is just too uncontrollable to give fine detail results (especially on these small models). I'll save such for eye sockets and cockpit glass when airbrushing. Below are the steps I did tonight on 5 of fifteen flesh-hounds. I was very happy right up to the last step, removing the masking. Looks like it will be fine haired brushes for these burning areas from now on. It won't take much to fix them with the airbrush, so it was a worthy experiment. I've listed the steps and comments as I went through it. Yellow with patches of oranges added in horizontal bars...hopefully the yellow will appear at the top of the veins of fire/muscle edges... Spraying Ghost Tint Orange to make them pop when the masking is removed. Adding the masking...was a slow process as I had to wait for each side of the spine. Afterwards I thought I should have did the backbone spines in circles/dots, not a solid line like this Deep purple overcoat (you can see the lighter areas where the masking is on the spine.. Dark blue added in most pronounced areas... Blue-grey airbrushed on major muscles Gory red sprayed in varying thickness for a mauve blend. Better closeup...foreshadowing the mouth tints too Puppetswar is disturbing in its anatomical correctness Adding white socks (lol) to make the coming yellows/oranges brighter Medium yellow sprayed over white and gore red Orange sprayed over gore red and most of the yellow Final spray of Ghost-Tint orange. The gloss/shine will be faded with dull-coat later...this is about as good as I had the model before pulling up the masking.... Pulled up the masking...clay-shaper with pointed rubber tip did 'ok' but still not thrilled with the results....will repair later... experiment with masking: FAIL.. Edited April 26, 2017 by Spear of Achilles Brother Aiwass, Honda, Thousand Eyes and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4321828 Share on other sites More sharing options...
Brother-Chaplain Kage Posted February 29, 2016 Share Posted February 29, 2016 Even if they didn't turn out as well as you'd hoped, you're conducting some experiments that could very well impact the work of others. :) Spear of Achilles and Honda 2 Back to top Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4321858 Share on other sites More sharing options...
Magos Kasen Posted February 29, 2016 Share Posted February 29, 2016 That is a really unique and interesting look. Very cool. Spear of Achilles 1 Back to top Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4321903 Share on other sites More sharing options...
Spear of Achilles Posted March 1, 2016 Author Share Posted March 1, 2016 (edited) Finished them up without the masking...just need to decide on collar/chains tones... Edited April 26, 2017 by Spear of Achilles Chandrian and Honda 2 Back to top Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4323315 Share on other sites More sharing options...
The_Chaplain Posted March 1, 2016 Share Posted March 1, 2016 Visually, they look great. The gradient in the skin tone will really pop on the tabletop. I think you should do a conversion based off of Nagash or one of the Mortarch steeds to really showcase that "cindered" look. Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4323375 Share on other sites More sharing options...
Halandaar Posted March 1, 2016 Share Posted March 1, 2016 Visually, they look great. The gradient in the skin tone will really pop on the tabletop. I think you should do a conversion based off of Nagash or one of the Mortarch steeds to really showcase that "cindered" look. Agree there; things with prominent rib cages will allow that "internal fire" look to really shine. Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4323382 Share on other sites More sharing options...
Dragonlover Posted March 1, 2016 Share Posted March 1, 2016 *scribbles notes for when I get to my Bloodthirster* They look really cool and I think it's what my brain was trying to do with my Flesh Hounds. I'll be watching with interest. Dragonlover Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4323398 Share on other sites More sharing options...
Spear of Achilles Posted March 4, 2016 Author Share Posted March 4, 2016 My first attempt at lava bases. Working with these rather bland 50mm bases from Proxie Models (they were dirt cheap, if low-grade plastic), I used large-grain basing sand flock, and a ton of Elmer's Glue the night before I painted them. I waited for the first ground layer to dry before adding more sand layers. Coated everything in clear coat to seal them together, then primed them. Got home from work at 00:30 and spent an hour and a half painting them. They have a more red/orange hue than the camera will pick up under stark fluorescent light (they look lifeless yellow in some pics). I'll add cinder grey to the bigger lava chunks and a gloss coat to the yellow-orange areas before I base the dogs on them permanent. Space Truckin, Pearson73 and Luna707 3 Back to top Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4325892 Share on other sites More sharing options...
MikhalLeNoir Posted March 4, 2016 Share Posted March 4, 2016 Damn....they look so absolutely good Spear of Achilles 1 Back to top Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4325896 Share on other sites More sharing options...
Pearson73 Posted March 4, 2016 Share Posted March 4, 2016 These look great, really nice tones on the skin/muscle. Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4325901 Share on other sites More sharing options...
Spear of Achilles Posted March 4, 2016 Author Share Posted March 4, 2016 Thanks gents. :) Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4326172 Share on other sites More sharing options...
Dagoth Ur Posted March 4, 2016 Share Posted March 4, 2016 Wow, absolutely stunning work! Spear of Achilles 1 Back to top Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4326185 Share on other sites More sharing options...
Spear of Achilles Posted March 5, 2016 Author Share Posted March 5, 2016 (edited) Didn't have time to finish 'em up, need 'em based for today's 4,000pt game Edited April 26, 2017 by Spear of Achilles Argent aquila and Soric 2 Back to top Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4326844 Share on other sites More sharing options...
Spear of Achilles Posted March 6, 2016 Author Share Posted March 6, 2016 The battle report :) https://www.facebook.com/permalink.php?story_fbid=780418695435475&id=654447594699253 Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4327593 Share on other sites More sharing options...
Spear of Achilles Posted March 22, 2016 Author Share Posted March 22, 2016 Working on some spawn (using some 4 armed Minotaurs for them as well) and more dogs and a new Maulerfiend for The Cindered BrotherJim and Argent aquila 2 Back to top Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4342598 Share on other sites More sharing options...
Spear of Achilles Posted September 24, 2016 Author Share Posted September 24, 2016 Did some more work on my army; 2.5 hours logged tonight re-painting some bloodcrushers and a bunch of bloodletters with an airbrush I aint touched in months...they now match my fleshhounds and spawn...got a lot of work left to do on them but they are at least cohesive with the other units. Added an old Halloween plastic skull in there for tracking tithe... BrotherJim 1 Back to top Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4513240 Share on other sites More sharing options...
Spear of Achilles Posted September 30, 2016 Author Share Posted September 30, 2016 Decided to add a Cyclopia Cabal for tourney play. Also did up some bloodletter lava bases bluntblade 1 Back to top Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4516771 Share on other sites More sharing options...
Spear of Achilles Posted December 18, 2016 Author Share Posted December 18, 2016 Adding a butt-load of Chaos Termies to the ranks of The Cindered...need to figure a good way to do some good flaming crack lines across their bodies. Also working on a daemon prince and some of those female obliterator knock-offs from Space Crusade Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4596220 Share on other sites More sharing options...
Spear of Achilles Posted April 5, 2017 Author Share Posted April 5, 2017 Ugh Neck is sore from all the magma painting...got the ObTITinators done as well, except the basing... Azekai and deathspectersgt7 2 Back to top Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4703891 Share on other sites More sharing options...
Spear of Achilles Posted April 7, 2017 Author Share Posted April 7, 2017 Made some more lava bases...these are freehand blended, not sure I like 'em as not as smooth as airbursh...but why not give it i try :P...of course they were already glued on before I added sand/elmers... deathspectersgt7 1 Back to top Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4705840 Share on other sites More sharing options...
Draakur Posted April 7, 2017 Share Posted April 7, 2017 Looking soooo good. No real idea why you're not getting feedback, my honest guess is there's not a lot to say other than "Awesome!" Interesting choice with the female models, my first thought was it didn't come together, but I'm starting to think otherwise now :) Spear of Achilles 1 Back to top Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4706073 Share on other sites More sharing options...
Spear of Achilles Posted April 16, 2017 Author Share Posted April 16, 2017 thanx you sir. interkino 1 Back to top Link to comment https://bolterandchainsword.com/topic/318575-the-cindered/#findComment-4712211 Share on other sites More sharing options...
