Silly Lasgun/Laspistol question
Hi guys, just curious, do you drill the barrels of your lasguns/pistols? I've managed to find some pretty small drill bits for bolter barrels (and the smaller ports on the side), but I'm wondering if doing it for lasguns and whatnot would be going a little silly.
Do you think it would make more sense that it would have a lens on the end, so you'd leave the barrel end un-drilled and say put red on the end and 'ard coat (or another gloss varnish). For my las cannons i have drilled out the barrels, but those were huge and it looked like it needed the holes (and you could say the lenses are in-set inside the barrel maybe).
Just putting the idea/question out there, I have a thing for drilling all my gun barrels (little ocd with it, it becomes really noticeable when i see un-drilled barrels lol), seeing what everyone else does.
https://bolterandchainsword.com/topic/318581-silly-lasgunlaspistol-question/
No, the barrels are very small and arguably lasguns don't technically have one as they fire their space future lasers rather than bullets. Mostly it's a modelling thing though, that's a lot of tiny barrels to drill out :P
After working on my mordians Ive been wondering the same thing
On my lascannons yes because they look odd not to
But on my lasguns/pistols no because I think it would look equally odd.
On my scions I have gone through the extra step of giving the tips a glow similar to plasma guns I found that a good compromise. Your lens idea isn't a bad idea either.
I drill them.  I normally take an xacto and cut that little 'lens' piece off.  Then I score the center with the xacto tip.  I use the citadel drill to make the hole... think I use smallest bit, but I can't remember at the moment.
I drill everything.  Not sure if Melta is supposed to be drilled but I drill that too.
I drill the Chimera lasgun ports too.
I just started playing around by drilling flamers, meltas, and grenade launchers with a drillbit, by hand. Unless I come into a windfall and get the fancy Citadel drill, I don't think I'll ever drill out my lasgun barrels, since they are far too small to do freehand.
I don't think I ever saw a lascannon with a hole in the end of the barrel until maybe 5th edition...and not at the beginning of that era, either. I think in my entire collection, I have 1-3 models with that style...and I have dozens with flat tips. The idea that the lens is recessed to protect against environmental hazards makes sense...but I'm not moved to modify any of mine...and I've grown obsessive about drilling my boltguns, I have the technology and plenty of practice. The un-drilled lascannons just don't seem wrong to me, drilled flashlights would have me scratching my head, and censored.gif about multilasers?!?
Er...I have that fancy tool, and the bits that it includes...the lasgun barrels are too small for even that kit, you'd need an even smaller bit from a third party, and even then you'd ruin half of the barrels you drilled.
I do happen to have .45 and .75mm drill bits but you would have to be as crazy as a sporran full of claustrophobic ferrets to drill barrels to that size... ;) wacko.pngblink.png
I have mine for a fibre-optic project I did once
I always saw (and believe I read somewhere in a Gaunt's Ghosts novel) that the end of the barrel was a focussing lens but I could be wrong :(
I am with WarriorFish on this one... now where is my bolt pistol??
I do happen to have .45 and .75mm drill bits but you would have to be as crazy as a sporran full of claustrophobic ferrets to drill barrels to that size... msn-wink.gifwacko.pngblink.png
I must be worse than that then... I shorten, drill and pin all of my lasguns :D :
http://i35.photobucket.com/albums/d161/Inso/GW%20Squats/Squat%20How%20To/HTG6_zpsxbevrbnf.jpg
The B stands for Baneblade tongue.png If you lunatics really are painting and/or drilling your lasguns I want to see a model. No, in fact I want to see models - I want proof that you have indeed drilled/painted the ends of every lasgun in your army. For brevity's sake I will accept pictures of a couple of squads and trust that the rest of the army is the same... msn-wink.gif
As I feared, the madness is spreading. Not only that but seems to be getting more severe... I fear bolt pistols may not be enough elmo. We need Plan B - to go to the Commissar mobile!
Virus bomb as you leave orbit?
LOL you guys are... KILLING MEcool.png *badumm-ts*
So far, i didn't drill the barrels on my lasgun equipped troops and i don't plan on doing so; I don't mind not-drilled-out barrels on the trusty flashlight. The mighty bolter however... that's literally a whole different caliberrolleyes.gif Bolters and similarly sized guns just look better with drilled out barrels in my opinion... of course i do drill mine (god, that sounds wrong in my head right now). I guess i fall somewhere in the moderate spectrum, there's certainly no need to execute mebiggrin.png
In the interest of full disclosure, I must confess that I picked up the drilling habit relatively late, at least half of my DA are not (yet?) drilled, but all of my LEGIOXX are, since I just started them a month or two ago (hey, I've drilled 30 bolters for them so far!)
http://www.itsacon.net/wp-content/gallery/necromunda-van-saar/Juves-1-Front.JPG
More pictures here
Hell, I even drill all six barrels on assault cannons:
http://www.itsacon.net/portentimage/40k_da_dw_terminators_misc1.jpg
Drilling bolters and assault cannons and the like is fine, that's good and normal. Lasguns on the other hand... tongue.png
Laspistol and Plasmagun. Cannot see Lasgun barrel, but it is drilled I promise! :p
Lasgun:
I have about 30 partially painted in-progress troops on my table, they are all drilled. I'll get a pic of those tonight :p
I'm gonna have to call shenanigans. you didn't drill a hole into the barrel tip, you drilled a hole into the flash hider (odd thing to have on a gun that doesn't have flaming gasses following a projectile out the barrel, but that's another issue), removing the tip of the barrel! The holes you drilled are bigger than the holes in boltgun barrels, so we've really been talking past one another here, lol...your solution is perfectly fine, but it's not at all what the rest of us were talking about (not to speak for the others, lol)
Look at these pics of a lasgun and a multilaser...I'm sure that like me, everyone else thought that "drilling out the barrels" of las weapons meant drilling a hole into the tip of the bit that protrudes from the suppressor thingie (the blue bit on the tip of my lasgun below), not drilling the end of the barrel away entirely and drilling a recess into the suppressor thingie!
Obviously, the plastic lasguns are slightly different on the tip, but they do have that rounded nub sticking out of the suppressor thingie, drilling a hole into that, not obliterating it and drilling a much larger diameter hole in the suppressor thingie...that's what we were thinking...hence, our amazement at the idea of drilling out lasgun tips...what you're doing, again, perfectly acceptable, is actually less and easier work than drilling out a bolter, not more and impossibly small work!
/edit/ I just noticed that you said you cut the rouded nub off, it makes sense now!
/edit againt/ What itsacon did with his green suited guys is what I was thinking of...doing what he did to the guy in the middle across an entire guard army!
Well i did not. And will do only if i must
