Banjoboy Posted September 2, 2016 Share Posted September 2, 2016 If we're avoiding combat why are we stomping around in Power Armor, depending on the sentence, I can survey from a distance to examine patrols Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4488262 Share on other sites More sharing options...
Slips Posted September 2, 2016 Share Posted September 2, 2016 Well, we don't have any negative mods to using stealth in power armour thanks to our Black Carapace AND we can get Cameleolines and Stummers to make us visually and audibly invisible, which is what I did :p Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4488278 Share on other sites More sharing options...
Banjoboy Posted September 2, 2016 Share Posted September 2, 2016 Then should I'll go for the cloak and a Bolter silencer just in case Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4488284 Share on other sites More sharing options...
Servant of Dante Posted September 2, 2016 Share Posted September 2, 2016 Well, we don't have any negative mods to using stealth in power armour thanks to our Black Carapace AND we can get Cameleolines and Stummers to make us visually and audibly invisible, which is what I did Hum . . . Inellia could get a stummer, but I don't know if the 20min use is worth all the ammo I would have to leave behind. I want to be prepared for an extended deployment, since I don't know how long this will take. Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4488289 Share on other sites More sharing options...
Slips Posted September 2, 2016 Share Posted September 2, 2016 Well, we don't have any negative mods to using stealth in power armour thanks to our Black Carapace AND we can get Cameleolines and Stummers to make us visually and audibly invisible, which is what I did Hum . . . Inellia could get a stummer, but I don't know if the 20min use is worth all the ammo I would have to leave behind. I want to be prepared for an extended deployment, since I don't know how long this will take. Well, you have 20 min run time with 1 hour recharge n between each use. Should be fine for extended deployments just have to use them smartly Also, I called you an inquisitor because thats what I've known you to be playing up to this point. Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4488375 Share on other sites More sharing options...
Servant of Dante Posted September 2, 2016 Share Posted September 2, 2016 Well, we don't have any negative mods to using stealth in power armour thanks to our Black Carapace AND we can get Cameleolines and Stummers to make us visually and audibly invisible, which is what I did Hum . . . Inellia could get a stummer, but I don't know if the 20min use is worth all the ammo I would have to leave behind. I want to be prepared for an extended deployment, since I don't know how long this will take.Well, you have 20 min run time with 1 hour recharge n between each use. Should be fine for extended deployments just have to use them smartlyAlso, I called you an inquisitor because thats what I've known you to be playing up to this point. That's fine! I'm not upset, but neither I nor Inellia want to be an Inquisitor. The Inquisitor is a separate guy, and he's not even Inellia's actual Inquisitorial boss, since he would be Ordo Xenos. Inellia is on loan from her (Ordo Hereticus) inquisitor to this Ordo Xenos Inquisitor so she can keep an eye on your kill team, if that makes any sense. I'll look at the stummner again later. Can it be recharged easily during a mission? Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4488408 Share on other sites More sharing options...
Slips Posted September 2, 2016 Share Posted September 2, 2016 I dunno, you can probably hook it up to a power armour's supply to recharge easy-peasy. Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4488418 Share on other sites More sharing options...
Cryptix Posted September 4, 2016 Author Share Posted September 4, 2016 So is that everyone? Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4489788 Share on other sites More sharing options...
Servant of Dante Posted September 4, 2016 Share Posted September 4, 2016 What is the Iron Hand taking? And I think Inellia wants to take a Stummer as well. It fits in her Requisition (18+5=23) edit: Character Sheet updated Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4489791 Share on other sites More sharing options...
SinnerBeta Posted September 4, 2016 Share Posted September 4, 2016 Still waiting for replies to some questions so I can start working on the sheet. Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4489894 Share on other sites More sharing options...
Morovir Posted September 4, 2016 Share Posted September 4, 2016 Could you theoretically wear a cameleoline tarpaulin? Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4489907 Share on other sites More sharing options...
Slips Posted September 4, 2016 Share Posted September 4, 2016 I..mean...yeah? Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4489908 Share on other sites More sharing options...
Morovir Posted September 4, 2016 Share Posted September 4, 2016 Now I'm imagining an Astartes shuffling forward under a 5x5m sheet of cameleoline, just because its only 5 requisition points. I will take a Diagnostor Helmet, a stummer and a clip of Kraken rounds. Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4489911 Share on other sites More sharing options...
Slips Posted September 4, 2016 Share Posted September 4, 2016 Well, yeah, you could do that and get the +30 Concealment but you wouldn't get the Camo-Cloaks "1 Range Bracket Further" Bit if stationary. Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4489915 Share on other sites More sharing options...
Morovir Posted September 4, 2016 Share Posted September 4, 2016 It was mainly designed as a joke, because the diagnostor helmet renders me unable to take the cameoline cloak. Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4489918 Share on other sites More sharing options...
Slips Posted September 4, 2016 Share Posted September 4, 2016 I mean, I certainly wouldn't stop you from taking one LOL but the giant sheet over your head might make your life a bit harder in other respects. That said, you could use it to also cover our Target when we're trying to get out of wherever we're getting them from. Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4489921 Share on other sites More sharing options...
Morovir Posted September 4, 2016 Share Posted September 4, 2016 It might be enough to cover us all... Now imagine an entire Kill Team w/Sister of Battle and Xenos Filth sneaking out of a heavily guarded Tau base under a massive sheet of cameleoline. I dare you. Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4489923 Share on other sites More sharing options...
Banjoboy Posted September 4, 2016 Share Posted September 4, 2016 Still waiting for replies to some questions so I can start working on the sheet. What are your questions? Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4489971 Share on other sites More sharing options...
Servant of Dante Posted September 4, 2016 Share Posted September 4, 2016 It might be enough to cover us all... Now imagine an entire Kill Team w/Sister of Battle and Xenos Filth sneaking out of a heavily guarded Tau base under a massive sheet of cameleoline. I dare you. I'ma drop this here. Not only is it true, it's funny to imagine getting that response from a group of Astartes walking around with a tarp over their heads. Mostly, It's an awesome reference that had me laughing for five minutes straight. http://img02.deviantart.net/ac5a/i/2011/216/f/9/we__re_on_a_mission_by_a6a7-d44yyst.jpg I want a poster print of this. Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4490012 Share on other sites More sharing options...
Morovir Posted September 4, 2016 Share Posted September 4, 2016 Soooo...let's have a vote. Should I take the Kraken rounds, or the cameleoline tarpaulin? Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4490013 Share on other sites More sharing options...
Banjoboy Posted September 4, 2016 Share Posted September 4, 2016 Cameleoline Tarpaulin, this is a stealh mission, and I like the idea of knocking the ethereal out with a pistol whip, and bagging him/her up in the 5x5 tarp Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4490024 Share on other sites More sharing options...
SinnerBeta Posted September 4, 2016 Share Posted September 4, 2016 Still waiting for replies to some questions so I can start working on the sheet. What are your questions? Just the stuff that I directed to the GM in my previous posts. Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4490049 Share on other sites More sharing options...
Servant of Dante Posted September 4, 2016 Share Posted September 4, 2016 Q: What books are allowed ? A: And Sinner, at the moment we're using Dark Heresy (1st Edition), Dark Heresy: Ascension, Deathwatch rulebook, Living Errata, Deathwatch: The First Founding, Deathwatch: Mark of the Xenos, Deathwatch: Honour the Chapter, Deathwatch: Rites of Battle, Deathwatch: the Emperor's Chosen, and Deathwatch: the Outer Reaches. Also, the Inquisitor's Handbook from DH1E Q: I think I will go with my old Dark Angel Techmarine, Brother Kamael. Is that fine? A: Yes actually, the gang's missing a Techmarine. Also, Dante, forgot to mention, your SB counts as half of it's value (rounding up) for grenade purposes - IE the range and adding to non-explosive grenade damage. Q: If I may make a suggestion Cryptix - could you edit your first post in this thread and update it with some information ? Short plot summary for new players, a list current players, which books do we use, what is allowed, where/how do we roll for stats, what beside stats do we roll for, what is allowed and what not, etc. I'm sifting through the pages for the information and I think it would be better if you gathered it in one place. Also, would taking both Omnissiah's Calling and Price of Victory deeds be fine ? A: ? I just went through all your posts in this thread, and gathered any that had questions in them. Unless I missed one (which is entirely possible), the only one that is unanwsered is the last one about Onmisiah's Calling and Price of Victory. Cryptix? Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4490174 Share on other sites More sharing options...
Cryptix Posted September 4, 2016 Author Share Posted September 4, 2016 Gotta choose one brother. Says so on page 74, Rites of Battle. Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4490205 Share on other sites More sharing options...
SinnerBeta Posted September 5, 2016 Share Posted September 5, 2016 I think I also asked if we roll for marks of armor, pick them or all get mk7. Also, we roll at this page http://orokos.com/ but I seem to have missed how many times, how many dices etc. Link to comment https://bolterandchainsword.com/topic/324309-the-black-reaches-dw-ooc/page/9/#findComment-4490475 Share on other sites More sharing options...
