Kiltpa_of_the_Iron_Will Posted August 1, 2016 Share Posted August 1, 2016 Okay so here is the second try (with a Spartan this time) Angron-400pts Primus Medicae-105pts RF Troops Legion Tactical Squad-285pts x19 marines, True Grit, Vexilla, Sergeant w/ AA, Legion Terminator Squad-185pts x5 Cataphractii, HF Legion Veteran Tactical Squad-229pts x1 marines, x7 PS, x1 Heavy Chainsword, Sergeant w/ AA, PF, PP Elites Apothecarion Detachment-100 x1 apothecaries, AA Contemptor-Mortis Dreadnought-180 Kheres Assault Cannons Heavy Support Legion Land Raider Squadron-210 x1 Legion Proteus w/ twin linked lascannon Spartan Assault Tank-305pts Added the Contemptor-Mortis to give the list some Anti-Air. Please give feedback! Link to comment Share on other sites More sharing options...
Supe robot gangster #1 Posted August 1, 2016 Share Posted August 1, 2016 Apoth with the foot slogging tacs? Only thing I notice is a severe lack of AP 2 on your infantry. Most people in 30k give their sarges artificer armour and an AP 2 weapon of some variety (axe, fist etc) so you may find yourself a bit outmatched in that regard. It's mainly a problem if you come across a termie heavy list. Besides angron and your vet sarge you don't have anything that can reliably deal with them in combat. If you can make up 25 points and chuck some fists on your termies that should help! AT at 2k points, you should be alright with the Spartan and angron, but angron would be wasted on tanks (unless that's how you want to use him?) a chainfist or two on the termies and melta bombs on the sarges would again help (dependant on points of course!) Link to comment Share on other sites More sharing options...
Kiltpa_of_the_Iron_Will Posted August 2, 2016 Author Share Posted August 2, 2016 Apoth with the foot slogging tacs? Only thing I notice is a severe lack of AP 2 on your infantry. Most people in 30k give their sarges artificer armour and an AP 2 weapon of some variety (axe, fist etc) so you may find yourself a bit outmatched in that regard. It's mainly a problem if you come across a termie heavy list. Besides angron and your vet sarge you don't have anything that can reliably deal with them in combat. If you can make up 25 points and chuck some fists on your termies that should help! AT at 2k points, you should be alright with the Spartan and angron, but angron would be wasted on tanks (unless that's how you want to use him?) a chainfist or two on the termies and melta bombs on the sarges would again help (dependant on points of course!) The apoth would foot slog and the Primus Medicae would hop in the Land Raider with the Vets. I think I might drop the Contemptor or switch out his autocannon in favor of the stock Multi Meltas, and then upgrade another sergeant with a PF or Power Axe. I may also consider power axes on the Vets (or at least a few of them). Is the HH meta in favor of fliers, or do I not really need to worry about them? Link to comment Share on other sites More sharing options...
Supe robot gangster #1 Posted August 2, 2016 Share Posted August 2, 2016 With fliers it depends on your local group. Mine uses a few but not many. I usually like to cover all gaps anyway, because there are quite a lot of fliers in the heresy, wether they get used or not Link to comment Share on other sites More sharing options...
Kiltpa_of_the_Iron_Will Posted August 2, 2016 Author Share Posted August 2, 2016 With fliers it depends on your local group. Mine uses a few but not many. I usually like to cover all gaps anyway, because there are quite a lot of fliers in the heresy, wether they get used or not Is Primarch's Chosen/Angron worth it in a 2k game? Link to comment Share on other sites More sharing options...
Supe robot gangster #1 Posted August 3, 2016 Share Posted August 3, 2016 I'm not too sure to be honest, never having played at that low a points myself, although it seems alright for edging primarchs into smaller games, so if you are dead set on having angron at 2k points it's probably your best bet Link to comment Share on other sites More sharing options...
Nightmare84 Posted August 3, 2016 Share Posted August 3, 2016 Primarchs chosen at 2k is fine 2.5 to 3k is ok as well above that it gets dicey cause of the draw back if you lose your primarch. 2k there will be less heavy guns pointing at him Link to comment Share on other sites More sharing options...
