Anamnesis Posted February 24, 2017 Share Posted February 24, 2017 (edited) Hey they!This is mostly a repost i've done on another forum but with infero landing, hopefully you can find some use for it! You could probably do a few base and just cast them but i'm way too lazy for that http://heresy30k.invisionzone.com/public/style_emoticons/default/sleep.png you'll need: some milliput a cutter clipper ruler pencile rolling pin cork sheet vallejo dark earth (or something similar) super glue and white glue Optionnal: some juweela bricks (i'm using size 1/35 and 1/48) some sands, differents size some bits and pieces from your favorite enemy (*ies) Some leftover from milliput tiles tamiya scrapper 1. you need to mix the milliput and flatten it quickly with your hand. Now put it between to sheets of baking paper to avoid having it stick to your workplace and flatten it to the thickness you like with a rolling pine, to have smoother finish (i use two plastic guide on each side to have the thickness i want). http://i.imgur.com/rIEdyzQ.jpg2. Then it's time to mark your tiles with a ruler and a pencil, i'm doing 1cm tiles. Then with the backside of your cutter (mind your finger!), mark the line, if you use the normal side you'll just cut through. Don't push to hard, it's better to go a few time lightly than marking it to much or cutting through. http://i.imgur.com/OyXDPyh.jpg3. Now take a piece of cork, and rip it to the size of your mini (or the size you like), in this case, a tartaros termite. When your satisfied with the placing, just glue it down with superglue (or white glue but it will take longer). http://i.imgur.com/LNvGJWW.jpg4. Take your milliput tiles and with your clipper cut it roughly to the size of your cork, don't forget to choose the orientation of your tile to go with your mini!. (if you break with your finger, there's a strong chance the crack will follow your tiles markings). When your happy with it glue it down with milliput. http://i.imgur.com/BNR1p3O.jpg5. Now it's time for wear and tear the tiles to properly fit the cork. With a clipper, a pince and cutter clip some piece, or just tear them away until you have something your satisfied with, you can use the cutter to cut properly some piece of just cut away the first layer of the milliput. You can also draw some cracks in the middle with a cutter or a metal pointer.http://i.imgur.com/ztvTMnR.jpg6. Use the vallejo dark earth to fill the all base, you can create some volume with this paste to make it more interesting, otherwise you can just use sand but you'll have finish a bit flat. http://i.imgur.com/dxI0tiO.jpg7. When you dark earth is still wet, push in some broken bricks, broken tiles, somes bits and pieces from your favorite enemy to break the monoty of the sand and make it more interesting. You don't have to do this step but i add quite a lot of depth to your mini and represent well the idea of a battlefield.http://i.imgur.com/NJXvK4Y.jpg 8. Optionnal: To finish it, i put some white glue on a few spot around the dark earth on the base and sprinkle some differents sized sands (the dark earth is to uniform for my taste).Second part on how to paint it http://i.imgur.com/bp9Mlwj.jpg1. Primer black, light white primer on top, to go faster since i had a few bases layings around, i've done the tiles with an airbrush with an off white, in this case Scalecolor Nacar http://i.imgur.com/Ep8Nim4.jpg2. I then black the line between the tiles with Armypainter strong tone, and i make a heavy wash with gw Rhinox hide on the soil http://i.imgur.com/H9TYhlz.jpg3. I blackened some more the lines between tiles with rhinox hide mixed with black (still quite diluted), then drybrush the soil with a lighter brown (Sc Dubai brown) http://i.imgur.com/gLi36L4.jpg4. I've made three more drybrush on the soil with Sc Walnut first then Sc Thar brown to finish with Sc White sand, going lighter and lighter (you could probably have less color i'm not sure the first on is really needed..)http://i.imgur.com/DweWVY0.jpg5. Then i start defining the tiles, to do this i shade the back of the tiles with AP strong tone diluted (agrax earthshade), you don't need to blend everything we'll come back on that latter, i've also blackened the rime in a few diluted coat. http://i.imgur.com/6DsDVUf.jpg6. I do the same with my previous mix of rhinox hide and black but very lightly http://i.imgur.com/QMy0GXj.jpg7. I drawning the marbles effect with Vallejo dark sea blue (amazeball color!) heavily diluted, since i have some dark sea blue, i also add a few "patch" of this mix on random spot on the soil to make it more interesting and tie it with my mini (same colour i use for the black). http://i.imgur.com/X9PJUvN.jpg8.It's time to tie everything together! I glaze my base color which is Nacar on the tile to blend the shade and the marble effect and make it lighter and more subtle. I've also continued making some "spot" on the soil with the red is use on the eye, Sc mayhem red and some with violet ink. http://i.imgur.com/8E2e407.jpg9. I lighten the tiles with nacar and primacryl titanium white as glaze just on the front part of the tiles, and still make some spot on the soil with Sc kalamari orange which is my rust colour. I also redefine the cracks and separation on the tiles with my black and rhinox hide mix. http://i.imgur.com/JZbf5nd.jpg10. I finish the finish the tiles by edge highlightint the front part with pure white and the bottom part of the cracks. Sometimes i also really lightly drybrush some white sand on the sand to retrieve the top highlight if i've been to heavy on the glaze Enjoy! Edited July 19, 2017 by Anamnesis Tags edited Paland, Prot, Brother Dallo and 18 others 21 Back to top Link to comment https://bolterandchainsword.com/topic/331342-how-to-make-prospero-tiles-marbles-bases-and-paint-them/ Share on other sites More sharing options...
Brother Dallo Posted February 24, 2017 Share Posted February 24, 2017 Looks awesome. Excellent tutorial. Thanks for that Anamnesis. What thickness for the "tiles" and the cork would you recommend? Do you think you'd get similar results using the basing paints from GW, or is Vallejo Dark Earth the way to go? Keep up the good work. Dallo Link to comment https://bolterandchainsword.com/topic/331342-how-to-make-prospero-tiles-marbles-bases-and-paint-them/#findComment-4665525 Share on other sites More sharing options...
DistroyA Posted February 24, 2017 Share Posted February 24, 2017 That is a fantastic way of making tiles. Dunno why I didn't think of doing that beforehand. :) Link to comment https://bolterandchainsword.com/topic/331342-how-to-make-prospero-tiles-marbles-bases-and-paint-them/#findComment-4665834 Share on other sites More sharing options...
Anamnesis Posted February 27, 2017 Author Share Posted February 27, 2017 Thanks brothers, glad you like it ! Looks awesome. Excellent tutorial. Thanks for that Anamnesis. What thickness for the "tiles" and the cork would you recommend? Do you think you'd get similar results using the basing paints from GW, or is Vallejo Dark Earth the way to go? Keep up the good work. Dallo I have 3mm cork sheet but honestly it's a matter of taste or of what's easily available to you For the tiles, i generally make them 1.5mm-2mm thick, i use the old modular tray as a guide. I think you can use the textured paint from GW, should be mostly the same, i just like dark earth cause it's a big pot and cheaper than gw Cheers! Anamnesis Brother Dallo 1 Back to top Link to comment https://bolterandchainsword.com/topic/331342-how-to-make-prospero-tiles-marbles-bases-and-paint-them/#findComment-4667209 Share on other sites More sharing options...
steamius Posted February 27, 2017 Share Posted February 27, 2017 Very good tutorial. I might use it for my eldar ^^) Link to comment https://bolterandchainsword.com/topic/331342-how-to-make-prospero-tiles-marbles-bases-and-paint-them/#findComment-4667251 Share on other sites More sharing options...
Brother Dallo Posted February 27, 2017 Share Posted February 27, 2017 Could we get some shots of the base from table level? I'm curious to see how the tiles look on top of the cork. Cheers. Dallo Link to comment https://bolterandchainsword.com/topic/331342-how-to-make-prospero-tiles-marbles-bases-and-paint-them/#findComment-4668001 Share on other sites More sharing options...
Anamnesis Posted February 28, 2017 Author Share Posted February 28, 2017 Hey thanks guys, here is a pic from farther away with 3 marines side by side to give you an idea Borther Dallo http://i1175.photobucket.com/albums/r630/Anamnesis_corp/20170227_233112_zpsobx7jw4y.jpg Brother Dallo, Prot, Dosjetka and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/331342-how-to-make-prospero-tiles-marbles-bases-and-paint-them/#findComment-4668424 Share on other sites More sharing options...
Brother Dallo Posted March 1, 2017 Share Posted March 1, 2017 Looking great. You have some amazing space pups there. Sorry if I wasn't specific enough though. Essentially, I'd like to see what the bases look like from the back, with the camera a little lower so I can see how the milliput looks on top of the cork. Essentially turn the marines around 180 degrees and you're onto a winner. Cheers. Dallo Link to comment https://bolterandchainsword.com/topic/331342-how-to-make-prospero-tiles-marbles-bases-and-paint-them/#findComment-4669299 Share on other sites More sharing options...
Anamnesis Posted March 3, 2017 Author Share Posted March 3, 2017 (edited) ah! my bad, here's the picture from behing, it's roughly twice the size of a basic base http://i.imgur.com/QAkxk9b.jpg Edited July 19, 2017 by Anamnesis Dosjetka and Brother Dallo 2 Back to top Link to comment https://bolterandchainsword.com/topic/331342-how-to-make-prospero-tiles-marbles-bases-and-paint-them/#findComment-4671528 Share on other sites More sharing options...
ixzion Posted July 8, 2017 Share Posted July 8, 2017 This was a great tutorial! Do you think that you could upload the pictures again? They seem to be under ransom by Photobucket... Link to comment https://bolterandchainsword.com/topic/331342-how-to-make-prospero-tiles-marbles-bases-and-paint-them/#findComment-4812529 Share on other sites More sharing options...
Brother Aiwass Posted July 9, 2017 Share Posted July 9, 2017 I can't see anything because photobucked is possessed by Guilliman :( Link to comment https://bolterandchainsword.com/topic/331342-how-to-make-prospero-tiles-marbles-bases-and-paint-them/#findComment-4813224 Share on other sites More sharing options...
Anamnesis Posted July 18, 2017 Author Share Posted July 18, 2017 (edited) I sorry guys for the photobucket problem, i shall update them soon to imgur you photobucket though Edited July 19, 2017 by WarriorFish Don't dodge the swear filter Brother Aiwass 1 Back to top Link to comment https://bolterandchainsword.com/topic/331342-how-to-make-prospero-tiles-marbles-bases-and-paint-them/#findComment-4823448 Share on other sites More sharing options...
Anamnesis Posted July 19, 2017 Author Share Posted July 19, 2017 and everything should be good now ixzion and NiceGuyAdi 2 Back to top Link to comment https://bolterandchainsword.com/topic/331342-how-to-make-prospero-tiles-marbles-bases-and-paint-them/#findComment-4824649 Share on other sites More sharing options...
Wolf_Lord_Hardrada Posted December 31, 2017 Share Posted December 31, 2017 These look great...just ordered the materials to make some! Anamnesis 1 Back to top Link to comment https://bolterandchainsword.com/topic/331342-how-to-make-prospero-tiles-marbles-bases-and-paint-them/#findComment-4971359 Share on other sites More sharing options...
