sbarnby71 Posted January 15, 2018 Author Share Posted January 15, 2018 I still really like the light blue of the 40k... About 20 years ago I went to the Fox Glacier in New Zealand and saw a ice tunnel that was the blue of the Wolves (light blue into dark) and it's always stuck with me, the landscape and colours made me think this would be their home. Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-4983222 Share on other sites More sharing options...
Stoic Raptor Posted January 16, 2018 Share Posted January 16, 2018 So not a fan of the new GW colours for Space Wolves, The Fang is too blue. It's not meant to be the main color for the model. It's intended to be totally layered over with Russ Grey. Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-4984521 Share on other sites More sharing options...
sbarnby71 Posted January 18, 2018 Author Share Posted January 18, 2018 Big thanks to Triszin for sending me some moulds of the knot-work from the Stormfang, hoping to add these to the leg armour: The cast I've done may end up being too fragile when it comes out of the mould, if so I'll try a different method of keeping more greenstuff as a thin base for the symbols. Thanks again Triszin Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-4986247 Share on other sites More sharing options...
Sagentus Posted January 18, 2018 Share Posted January 18, 2018 Maybe do a 50:50 mix of GS:milliput ... might give you a stronger mould Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-4986333 Share on other sites More sharing options...
sbarnby71 Posted January 19, 2018 Author Share Posted January 19, 2018 First cast of the knot-work has worked well: Was going to use these on the leg armour, but I like this idea too: And a quick test on the leg: Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-4987458 Share on other sites More sharing options...
Panzer Posted January 19, 2018 Share Posted January 19, 2018 This guy will look so good with all the knot-work. Who needs FW anyway lol Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-4987487 Share on other sites More sharing options...
Bjorn Firewalker Posted January 20, 2018 Share Posted January 20, 2018 Great job on the knot work! Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-4988215 Share on other sites More sharing options...
Graymane Posted January 20, 2018 Share Posted January 20, 2018 that is looking shiny Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-4988785 Share on other sites More sharing options...
sbarnby71 Posted January 24, 2018 Author Share Posted January 24, 2018 Tried out the casts of the knot-work, the one on the left side of picture worked better as it had a very thin layer between each part of the knot-work so it held its structure, one on the right is more delicate but warped as I applied it. Going to try again with the right hand side: Also added some extra detail to the legs: Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-4991879 Share on other sites More sharing options...
Guest Triszin Posted January 24, 2018 Share Posted January 24, 2018 That looks great, never thought of using the knot work as greaves. Ideas you give me... Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-4992219 Share on other sites More sharing options...
sbarnby71 Posted January 26, 2018 Author Share Posted January 26, 2018 Another attempt with the knot-work, looks a bit trashed in this picture, but after a bit more clean-up and a first layer of paint it does look better: Will get some updated picture once both sides are done. Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-4993995 Share on other sites More sharing options...
sbarnby71 Posted January 29, 2018 Author Share Posted January 29, 2018 Got better results with leaving a thicker base layer of green stuff under the cast and then trimming: Leg knot-work with first layer of RuneLord Brass applied: And knot-work applied to the left & right top plates, with an additional piece at the front: Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-4996254 Share on other sites More sharing options...
Sagentus Posted January 29, 2018 Share Posted January 29, 2018 Dam that knot work looks great! GW could learn from this :D Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-4996328 Share on other sites More sharing options...
Guest Triszin Posted January 29, 2018 Share Posted January 29, 2018 Dam that knot work looks great! GW could learn from this strangely enough, it is GW knot work! Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-4996604 Share on other sites More sharing options...
sbarnby71 Posted February 7, 2018 Author Share Posted February 7, 2018 Finally finished the base colours now. Never had so much hassle with paint just rubbing off when I handle a model, but then I've not worked on a dread or vehicle with the newer GW paints. Anyway here he is and I'm happy with the colour scheme: I know the crazy blue of the wolf head on the shoulder armour looks odd, but I want it to look like ice - so keep watching. Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-5005145 Share on other sites More sharing options...
Panzer Posted February 7, 2018 Share Posted February 7, 2018 Yeah paint rubbing off is a real problem. Better fix it to something where you hold it rather than touching the model directly while painting. Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-5005159 Share on other sites More sharing options...
sbarnby71 Posted February 7, 2018 Author Share Posted February 7, 2018 Yeah tried fixing bits so I'm not holding the model directly but also find it rubs off just by it being placed on a sponge that I use to stop it resting directly on the work table. I've started adding a coat of Lahmian Medium over the offending colours once I've done a layer, it does help a bit. I get that the layer paints are thinner so more likely to rub away, but I even get it on Mephiston Red which is a base. Ah well. Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-5005182 Share on other sites More sharing options...
Panzer Posted February 7, 2018 Share Posted February 7, 2018 Mh maybe your primer didn't work correctly? Can happen if it's too humid when priming etc. Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-5005188 Share on other sites More sharing options...
sbarnby71 Posted February 7, 2018 Author Share Posted February 7, 2018 I think the primer did work, what I'm seeing is the layer paint rubbing off and I'm setting the base coat come through. Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-5005270 Share on other sites More sharing options...
Bjorn Firewalker Posted February 7, 2018 Share Posted February 7, 2018 The parts are beautifully painted. I hope to see the Dreadnought assembled and posed soon. Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-5005490 Share on other sites More sharing options...
sbarnby71 Posted April 5, 2018 Author Share Posted April 5, 2018 Finally.........done! May I present Triszin of the VI Legion It's been fun building him, but as you can see I'm the worlds slowest painter (started this whole project back in August last year). Going to try and get some better pics with my SLR as the colour looks a little washed out in these. Hope you like. Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-5048632 Share on other sites More sharing options...
Sagentus Posted April 5, 2018 Share Posted April 5, 2018 Looks epic! This project was worth taking your time over. Youve made a 1/2 decent model into something great! Tones and tones of character, i just wish gw would see models like this and see potential in making better upgrade sprues for the redemptor. Whats next? Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-5048759 Share on other sites More sharing options...
Bjorn Firewalker Posted April 5, 2018 Share Posted April 5, 2018 The Redemptor looks AWESOME. If anyone tells you otherwise, feel free to bury an ax in their skulls, the way a Fenrisian would answer an insult. Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-5048854 Share on other sites More sharing options...
sbarnby71 Posted April 10, 2018 Author Share Posted April 10, 2018 Looks epic! This project was worth taking your time over. Youve made a 1/2 decent model into something great! Tones and tones of character, i just wish gw would see models like this and see potential in making better upgrade sprues for the redemptor. Whats next? Thanks for the praise. :-) I am really happy how this turned out. As for what's next. hmmmmmmmmmm... So I bought 2 Redemptors and had planned this to be a prototype for the 2nd one, but I like this one just fine. But my plan for the next one is a totally wrecked Dred down on one knee, missing main weapon arm, just fending off an attacker with a half broken Power Fist. I've made a single Primaris Reiver out of the box of 10, so that's an option. There is a Land Raider been sat half painted for 15+ years that could do with some Wolf skull on it. I had a crazy idea when the Beastclaw Riders Stonehorn came out to make that with a Terminator Lord on it's back. but this is the next project... I was lucky enough to get this before GW forced this miniature of production, he is the Chapter Master from the Blood Ravens (Dawn of War video game). As soon as I saw the running pose I knew I wanted to convert him. So watch this space. Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-5052471 Share on other sites More sharing options...
sbarnby71 Posted April 10, 2018 Author Share Posted April 10, 2018 Some (hopefully) better finished pictures: Ok, how do I make my pictures appear full sized in my posts? Link to comment https://bolterandchainsword.com/topic/337794-space-wolves-primaris-redemptor-dreadnought-wip/page/4/#findComment-5052512 Share on other sites More sharing options...
