Gibbous Posted November 3, 2017 Share Posted November 3, 2017 I have been wanting a LR punisher for a while, but didn't want to buy the full kit. I had a used Vanquisher turret and purchased a Punisher cannon bit off eBay. Please see picture for detail. Step 1: Remove Vanquisher Cannon leaving enough to connect the punisher cannon. Try to get the cut as straight and flush as possible or your new cannon will be all wonky. Step 2: Remove connecting point on Punisher cannon (you could also bore out the remaining Vanquisher for the Punisher bit to fit, I didn't have a drill bit that was large enough handy. I feel this would have been better for stability) Step 3: Clean up the pieces then glue everything together. Step 4: Prime and paint. The entire process took me about 15 mins. WingCommander 1 Back to top Link to comment https://bolterandchainsword.com/topic/341020-leman-russ-vanquisher-to-punisher-cannon/ Share on other sites More sharing options...
Chaplain Killmer Posted November 6, 2017 Share Posted November 6, 2017 (edited) Thank you for the tutorial - thats something that even I could do and I should not use something with an edge (says my wife ) Edited November 6, 2017 by Chaplain Killmer Link to comment https://bolterandchainsword.com/topic/341020-leman-russ-vanquisher-to-punisher-cannon/#findComment-4925567 Share on other sites More sharing options...
Gibbous Posted November 15, 2017 Author Share Posted November 15, 2017 Lol, yeah it was easy and more importantly... I didn't cut myself! Link to comment https://bolterandchainsword.com/topic/341020-leman-russ-vanquisher-to-punisher-cannon/#findComment-4931944 Share on other sites More sharing options...
