Huggtand Posted February 6, 2018 Share Posted February 6, 2018 Why are the front of the bolter/bolt pistols upside down in the second upgrade pack https://www.forgeworld.co.uk/en-CA/Space-Wolves-Legion-Grey-Slayers-Upgrade-Pack-2-2018 Why has nobody caught this in the quality control? Compare this to resent miniatures like the custodes shield-captain or the necromunda stuff and I starting to wonder if it's only the wolves where choddy sculpting and bad quality appears. Brofist 1 Back to top Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/ Share on other sites More sharing options...
Charlo Posted February 6, 2018 Share Posted February 6, 2018 I quite like the design overall, I want to know if there was a conscious decision for this and it's something we are missing... Before we start throwing things to QA control :P Fire Golem 1 Back to top Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5004581 Share on other sites More sharing options...
Huggtand Posted February 6, 2018 Author Share Posted February 6, 2018 (edited) You see that it's the same design-asset, iron sight and all, just turned upside down? No modification made. Edited February 6, 2018 by Huggtand Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5004583 Share on other sites More sharing options...
1ncarnadine Posted February 6, 2018 Share Posted February 6, 2018 Looks like a hand stop. So probably a deliberate decision to make them compact assault bolters for mostly one-handing, otherwise putting the non-firing hand between the mag and stop. LIke, a deliberate nod to the old True Grit rule. Iron sights are stupid on bolters anyway. Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5004589 Share on other sites More sharing options...
m_r_parker Posted February 6, 2018 Share Posted February 6, 2018 Yeah, I'm going to have to go with the fact that I thought those 'sticky-up' bits by the barrel were the iron sights of the weapon, for manual aiming (of a bolter). So how is that supposed to work when it's underneath the body of the gun, and the upgrade kit has no helmets to provide camera feeds through the eye lenses? It is literally the bolter asset chapped in half and rotated by 180 degrees, down to the flat bit underneath the barrel. I literally held my hand over the grip, the hand, and the ammo feed and said to myself "it's upside down". My head hurts... Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5004600 Share on other sites More sharing options...
1ncarnadine Posted February 6, 2018 Share Posted February 6, 2018 the upgrade kit has no helmets to provide camera feeds through the eye lenses? The same kit where almost half of the bare heads seem to have targeters or bionic eyes? Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5004622 Share on other sites More sharing options...
Huggtand Posted February 6, 2018 Author Share Posted February 6, 2018 Looks like a hand stop. So probably a deliberate decision to make them compact assault bolters for mostly one-handing, otherwise putting the non-firing hand between the mag and stop. LIke, a deliberate nod to the old True Grit rule. Iron sights are stupid on bolters anyway. If they wanted a hand guard with stop why not model a handguard with stop? I like the idé of a compact assault bolter but anybody who has seen a normal bolter will just see that the front on these are upside down Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5004625 Share on other sites More sharing options...
SkimaskMohawk Posted February 6, 2018 Share Posted February 6, 2018 It's alright, their axes still use wooden handles too Khornestar, Noctus Cornix and hushrong 3 Back to top Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5004628 Share on other sites More sharing options...
Brother Styphus Posted February 6, 2018 Share Posted February 6, 2018 If it wasn't an error, it's just such an odd design decision. Seeing as how every other marine typically holds the weapon with two hands, you'd think there would be a benefit to having a grip on the bottom. Instead they have this super clunky underside, and what appears to be a backwards pistol grip. Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5004651 Share on other sites More sharing options...
1ncarnadine Posted February 6, 2018 Share Posted February 6, 2018 If they wanted a hand guard with stop why not model a handguard with stop? I like the idé of a compact assault bolter but anybody who has seen a normal bolter will just see that the front on these are upside down I mean, they kind of did, if it's a hand stop in this style. Or this one. I'm not going to argue your point that the execution is still pretty odd, because hand stops usually aren't positioned like that. They can be, but it's definitely not normal. And it was lazy as hell to copy, flip and paste the CAD of the "sight" to do this. I'm just trying to argue that it strongly looks like it was a deliberate design choice, not a mistake. It's alright, their axes still use wooden handles too Yeah... another odd choice. Gotta leave it to our imaginations. Maybe the axes are the heartwood of some kind of insane Fenrisian tree and are actually incredibly strong. Or they're just molded to look like wood, or there's a metal core in the handle. Huggtand and Fire Golem 2 Back to top Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5004653 Share on other sites More sharing options...
Luna707 Posted February 6, 2018 Share Posted February 6, 2018 ooooooooooohhhhhhh my throne that is hilarious, it's literally just flipped. I really don't understand the rational there. Man I feel bad for Wolf players :/ Aside from Russ, FW did some really poor design work with your line Arminius_Warbringer 1 Back to top Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5004897 Share on other sites More sharing options...
Noserenda Posted February 6, 2018 Share Posted February 6, 2018 Yeah its a screw up, the rear iron sight is still on the top and the bayonet lug is upside down too...Plus what possible use is a hand stop on a bolter intended to be fired one handed anyway? Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5004929 Share on other sites More sharing options...
D3L Posted February 7, 2018 Share Posted February 7, 2018 (edited) A bit like praetor, the learneans at the moment FW seem to have given the latest design choices to the work experience kids Edited February 7, 2018 by D3L Lucerne 1 Back to top Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5004970 Share on other sites More sharing options...
Brofist Posted February 7, 2018 Share Posted February 7, 2018 A legion so special That mars issued them with padded helmets and upside down dummy bolters Yeah its a screw up, the rear iron sight is still on the top and the bayonet lug is upside down too... Plus what possible use is a hand stop on a bolter intended to be fired one handed anyway? Word. The upside down bayonet lug really nails it. I thought us IWs had it bad with those random stars, but between the padded helmets and upside down bolters it feels like somebody is trolling the SWs players hard. Arminius_Warbringer, Rolltonotdie and Lord Marshal 3 Back to top Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5004976 Share on other sites More sharing options...
Withershadow Posted February 7, 2018 Share Posted February 7, 2018 Wooden handles and upside down iron sights... and here I thought the gimp masks and sausage fur were the worst of their problems. Arminius_Warbringer 1 Back to top Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5004979 Share on other sites More sharing options...
Brofist Posted February 7, 2018 Share Posted February 7, 2018 Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5004988 Share on other sites More sharing options...
carlisimo Posted February 7, 2018 Share Posted February 7, 2018 There's a rumor that the sculptor quit. If true, I'd feel bad about that. The Varagyr's heads didn't all look like they were placed logically in that armor, but I thought they were well sculpted, and would've liked that guy to do heads for the White Scars. There've been other models that looked fine except for oversized heads, like that Blood Ravens guy or the new shield-captain. But yeah, these bolters and the Varagyr/praetor's issues seem rushed. Which is probably what happened. Huggtand and Lord Marshal 2 Back to top Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5005086 Share on other sites More sharing options...
Corswain Posted February 7, 2018 Share Posted February 7, 2018 Maybe FW is just trolling us? I hope..... I’m sure now that it’s been pointed out it’ll be fixed, it’s not like it’s a unique bit. They’ll probably just use ones out of other kits. Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5005117 Share on other sites More sharing options...
Huggtand Posted February 7, 2018 Author Share Posted February 7, 2018 There's a rumor that the sculptor quit. If true, I'd feel bad about that. The Varagyr's heads didn't all look like they were placed logically in that armor, but I thought they were well sculpted, and would've liked that guy to do heads for the White Scars. There've been other models that looked fine except for oversized heads, like that Blood Ravens guy or the new shield-captain. But yeah, these bolters and the Varagyr/praetor's issues seem rushed. Which is probably what happened. That would be bad news. There are elements that is nice in the wolves range so it was not totally bad. I have no problem with new sculptors that is not fully learned. We all have to start from scratch. But that where quality control comes in to the picture so stuff like this get stopped early and a new sculptor can learn and improve. Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5005127 Share on other sites More sharing options...
Guest Posted February 7, 2018 Share Posted February 7, 2018 (edited) If the rumor is true and he quit, I wonder if he quit after the release or before and had to finish the SW stuff first. I don't know how GW and UK quitting policies work, but I do know some places require you to finish a project before you are released. This often causes rapid finish of a project with shoddy quality. If he quit after and due to the SW stuff, the blame isn't on him alone but QA also. Either way I hope him the best. ooooooooooohhhhhhh my throne that is hilarious, it's literally just flipped. I really don't understand the rational there. Man I feel bad for Wolf players :/ Aside from Russ, FW did some really poor design work with your line Let's just hope that we (SWs) took the brute of this and FW will do the other legions justice. Edited February 7, 2018 by Jarl Caldersson Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5005156 Share on other sites More sharing options...
helterskelter Posted February 7, 2018 Share Posted February 7, 2018 He quit because of the abuse over the models, I've seen someone post somewhere. All the backlash can't be good for the soul. But that's just someone's post on the internet so it could be wrong Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5005164 Share on other sites More sharing options...
Jackalwolf Posted February 7, 2018 Share Posted February 7, 2018 I have no idea if the sculptor quit but I spoke with him in august and he had finished all Varagyr and grey slayers by then. A couple thoughts: - Yes I am overall disenchanted with SW - there are strong positives though (heads, torsos, Varagyr legs) I feel he had the right ideas in terms of going Celtic and Viking but some things were poorly executed like fur, proportions and details like the hand stop or the lack of grip in Praetor bolter. That said it could all have been easily fixed if someone had cared to point it out since proportions are very easy to change in cad and the fur could have been manually sculpted which always gives better results than in computer. Runefyre, Lord Marshal and Huggtand 3 Back to top Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5005244 Share on other sites More sharing options...
ChildofFang Posted February 7, 2018 Share Posted February 7, 2018 Alas the responses he probably saw the most were about how terrible a sculptor he was and that everyone can do better rather than the more measured type response like, I am not a fan of the fur or I don't like the direction they have chosen to go down.Words have power, 'we' should remember that occasionally. choppyred 1 Back to top Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5005286 Share on other sites More sharing options...
Noserenda Posted February 7, 2018 Share Posted February 7, 2018 I think the blame here should really go to whoever approved the sculpts, noone is perfect and i always imagined theres should be some back and forth in the process. Like, "dude, the bolters are upside down", "whoops! ill fix that boss" etc etc. I mean Aesthetics are one thing but there are a LOT of obvious mistakes recently :( Lord Marshal and infyrana 2 Back to top Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5005323 Share on other sites More sharing options...
ChildofFang Posted February 7, 2018 Share Posted February 7, 2018 Are there a lot though or are there a few that are highlighted and talked about constantly?I see a lot of people complaining about many things but the vast majority are personal preference, actual mistakes/errors/whatever is a very different thing. Link to comment https://bolterandchainsword.com/topic/344171-upside-down-bolter-on-the-grey-hunter-upgrade-pack-2/#findComment-5005329 Share on other sites More sharing options...
