Panzer Posted September 16, 2018 Share Posted September 16, 2018 People always consider that in a vacuum. If you don't need the AGL guy up close, why wouldn't you give him a powerful long range rifle? He may not always be the one you want using a grenade - one of your fighters up close may want to toss one into an area they're moving into, in which case the guy with that Stalker can still do some good while shooting. If you're going to give him some other gun that has to shoot at half range to avoid penalties, why bother with an AGL at all when you'll probably be close enough to just throw a grenade? I did consider that but the Bolt rifle is only 6" less than the Stalker bolt rifle and gives you a way bigger advantage at 15" or less while still letting you move&shoot without penalty. It's simply the more versatile weapon, especially on such a small board. Also it's rather unlikely that you want to use the grenade with someone without AGL since at that range you're also in short range for any of your Bolter weapons while the AGL carry with his 30" range often is the one last ending up in short range his Bolter weapons (even with the Stalker bolt rifle). Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5167772 Share on other sites More sharing options...
Mutanthybrid Posted September 16, 2018 Share Posted September 16, 2018 If you choose to run a primaris only KT then your best weapon for taking care of those better saves at range is going to be the stalker pattern. As knight stated above the AGL doesn't always need to be used as other guys may be closer. If you're using Reivers then their grenades offer some really tactical options and will potentially be used in lieu of the AGL. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5167791 Share on other sites More sharing options...
thewarriorhunter Posted September 16, 2018 Share Posted September 16, 2018 I'm building a Primaris only KT. I have two AGLs for some flexibility on where they can be used. One has the stalker because He'll be hanging back, the other has the bolt rifle since he'll probably be moving and up a little closer so I want him to be able to have rapid fire. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5167824 Share on other sites More sharing options...
Stoic Raptor Posted September 17, 2018 Share Posted September 17, 2018 I did consider that but the Bolt rifle is only 6" less than the Stalker bolt rifle and gives you a way bigger advantage at 15" or less while still letting you move&shoot without penalty. It's simply the more versatile weapon, especially on such a small board. Also it's rather unlikely that you want to use the grenade with someone without AGL since at that range you're also in short range for any of your Bolter weapons while the AGL carry with his 30" range often is the one last ending up in short range his Bolter weapons (even with the Stalker bolt rifle). 6" shorter range means a -1 at a lot closer range than it does for the Stalker. And you may have completely missed my point about the grenades, but it seems like you're operating on the premise that the guy with the AGL can target the entire board at any time. Sometimes your close-up troops may need to throw a grenade - and if the only guys that are ever doing that are the one or two troopers with an AGL, what's the point of everyone having grenades? You have to ask yourself what the role is of the guy with an AGL. Is he a shock trooper, designed for close assault? Probably not - why would you need a 30" range for his grenades? Clearly the AGL is a tool designed to lob grenades from a distance - and since it has no range penalty, it makes no difference at all if it's from 12" or 30". That was my point. Considering that, might as well put it on the guy who can do something useful in the event that someone else might want to use a grenade (you know, like your Reivers when they want to shock the troops they're assaulting?) Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5167906 Share on other sites More sharing options...
Panzer Posted September 17, 2018 Share Posted September 17, 2018 I did consider that but the Bolt rifle is only 6" less than the Stalker bolt rifle and gives you a way bigger advantage at 15" or less while still letting you move&shoot without penalty. It's simply the more versatile weapon, especially on such a small board. Also it's rather unlikely that you want to use the grenade with someone without AGL since at that range you're also in short range for any of your Bolter weapons while the AGL carry with his 30" range often is the one last ending up in short range his Bolter weapons (even with the Stalker bolt rifle). 6" shorter range means a -1 at a lot closer range than it does for the Stalker. And you may have completely missed my point about the grenades, but it seems like you're operating on the premise that the guy with the AGL can target the entire board at any time. Sometimes your close-up troops may need to throw a grenade - and if the only guys that are ever doing that are the one or two troopers with an AGL, what's the point of everyone having grenades? You have to ask yourself what the role is of the guy with an AGL. Is he a shock trooper, designed for close assault? Probably not - why would you need a 30" range for his grenades? Clearly the AGL is a tool designed to lob grenades from a distance - and since it has no range penalty, it makes no difference at all if it's from 12" or 30". That was my point. Considering that, might as well put it on the guy who can do something useful in the event that someone else might want to use a grenade (you know, like your Reivers when they want to shock the troops they're assaulting?) "a lot closer range" is pretty exagerated, The difference is exactly 3" for short range between both weapons and in Kill Team you get really quickly within the 15" required for the Bolt rifle. At that point you have two AP-1 shots vs one AP-2 shot. I for one know what I prefer. And no I didn't miss that point of yours, I just prefer to keep my team more or less together so they can support eachother and the AGL is mobile enough to always have LoS to at least something so if I get this close enough to throw a grenade to the enemy with one of my front line guys then that front line guy is also within short range for his Bolt rifle etc. and doesn't really need to throw a grenade anyway while the AGL guy can still shoot with the superior AGL from further away without having to rely on the worse Stalker bolt rifle. He doesn't have to see everything, it's enough if he can see ANYTHING because at short range Bolt rifles aren't that much worse than Krak or Frag grenades while at long range the AGL is simply better than any basic Bolter variant. I know my AGL carrys role pretty well. He's my long range fire support and for long range he uses the AGL so he wouldn't use the Stalker bolt rifle anyway. In the unlikely case he can't use his AGL the Bolt rifle is still good enough at long range at 30" while being better than the Stalker at short range which is barely shorter at 3" difference. Really, it never happened in any of my games so far except for that one time where he had a bunch of to hit penalties and I prefered having more shots with the Bolt rifle over the better strength and damage of the Krak grenade and the unreliable amount of shots of the Frag grenade with worse S and AP. Your whole point seems to be about what you do when :cuss hits the fan and you assuming the Bolt rifle being not long range capable. Don't forget that the Bolt rifle is almost the same as the Stalker bolt rifle. 30" on such a tiny board is huge and since you can move&shoot without penalty you can position yourself much better. The only real drawback is having AP-1 instead of AP-2 but on the other hand you get an additional shot at short range which you end up in pretty much every game anyway at 15" unless it's some sniper fest where everybody tries to stay as far away as possible (what are objectives anyway lol). Literally the only real reason to take a Stalker bolt rifle is the Masterful Marksmanship Tactic and only if you don't move because otherwise it doesn't give you an advantage at all and only serves to balance out one of the disadvantages. Hence why I'll put one Stalker botl rifle guy in my Primaris list on top of my AGL specialist. What you could do of course is giving the Stalker botl rfile guy an AGL as well if you have the point but he shouldn't be the first guy to fall back on to use the AGL, that's what you have the actual AGL carry for. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5167930 Share on other sites More sharing options...
Fobzter Posted September 17, 2018 Share Posted September 17, 2018 I only field an intercessor gunner as comms specialist and it has stalker bolt rifle and AGL. In the rare case of shock grenade from my reiver sergeant I like the -2 ap and the option for the masterful marksman.. My comms hangs back with my scout ML&cloak, HB demolitions specialist and my tactical sergeant with auspex & grav pistol. They form my long range Gunners while my reiver and intercessor sergeants meet the enemy in duel. Have to say that reiver sergeant should have an option to take a power sword, those 4 attacks S4 ap 0 have done literally nothing in my games, but 2 wounds is the biggest reason I haven't ditched him.. yet.. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5167949 Share on other sites More sharing options...
Mutanthybrid Posted September 17, 2018 Share Posted September 17, 2018 I only field an intercessor gunner as comms specialist and it has stalker bolt rifle and AGL. In the rare case of shock grenade from my reiver sergeant I like the -2 ap and the option for the masterful marksman.. My comms hangs back with my scout ML&cloak, HB demolitions specialist and my tactical sergeant with auspex & grav pistol. They form my long range Gunners while my reiver and intercessor sergeants meet the enemy in duel. Have to say that reiver sergeant should have an option to take a power sword, those 4 attacks S4 ap 0 have done literally nothing in my games, but 2 wounds is the biggest reason I haven't ditched him.. yet.. I have the same problem with the reiver sergeant. 2 turns of combat against a grey Knight and I didn't even scratch him thanks to the 3+ save even though I forced 5 wounds over two combats. To make matters worse he killed me over two turns with his psychic power. The intercessor sergeant however is the true saviour with the power sword and 3 attacks. I intend to run both together as a sort of double team in future to make use of the shock grenades and then power sword attacks up close. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5168238 Share on other sites More sharing options...
Disruptor_fe404 Posted September 17, 2018 Author Share Posted September 17, 2018 Astartes teams should absolutely be taking Combat-cessor sergeants against other power armoured teams. Assuming you're expecting any Fight phase action at all, that is. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5168281 Share on other sites More sharing options...
Disruptor_fe404 Posted October 12, 2018 Author Share Posted October 12, 2018 What are everyone's thoughts regarding wider access to the auspex as well as the Medic specialty now being available to us? And the auxilliary grenade launcher nerf? Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5173047 Share on other sites More sharing options...
Panzer Posted October 13, 2018 Share Posted October 13, 2018 I'm extremely pleased with it. That's something that should've been there all along (obviously since it's an Errata and not a supplement). I'm thinking about buying an apothecary to use as medic even. The AGL nerf is sad but was to be expected I guess. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5173160 Share on other sites More sharing options...
UnkyHamHam Posted November 6, 2018 Share Posted November 6, 2018 I played my first game on Friday. Against Death Guard with 6 plague marines. I used 6 marines: Intercessor Sarge w/ BR and PS - Leader Tac Sarge w/ auspex and PP - Comms Scout w/ sniper & cloak - Demo Tac Gunner w/ ML - Heavy Reiver Sarge w/ Carbine, blade, chute, and grapnel Intercessor Gunner w/ BR and AGL As this was my first time playing I can attribute much here to my lack of xp and many mistakes. But how do people with marine KTs deal with plague marines? They are sooo tough! Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5186285 Share on other sites More sharing options...
JasonfromFW Posted November 6, 2018 Share Posted November 6, 2018 I usually go with something like: Intercessor Sarge w/ BR, PS, auspex - Leader Tac Sarge w/ PF and PP Tac Gunner w/ HB - Heavy Tac Gunner w/ PG - Sniper Scout w/ sniper & cloak - Comms Scout gunner w/ ML & cloak Shoot the hell out of them with ML / PG / HB mortal wounds with the help of Comms / auspex. When they're too close, tac sarge with PF / PP and Intercessor sarge usually are enough. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5186449 Share on other sites More sharing options...
brother Vorn_GarDos Posted November 10, 2018 Share Posted November 10, 2018 @unkyHamHam the agl will not help against nurgle. the save and disgusting resilient just make it tough. the reliable PG and ML against nurgle will help more in your KT games Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5189044 Share on other sites More sharing options...
UnkyHamHam Posted December 9, 2018 Share Posted December 9, 2018 @unkyHamHam the agl will not help against nurgle. the save and disgusting resilient just make it tough. the reliable PG and ML against nurgle will help more in your KT games Just got stomped and wiped to the man again by my friend's Plague Marines. I managed to only kill his pox walkers. He won initiative and focused down my plasma gun and missile launcher right away. Then i had more or less just Intercessors and my Reiver Sarge. Which they could do absolutely nothing against him. Reiver with ALL the attacks and strats stacked on, STILL could not break a single plague marine. I think I'm going to have to bring Plasma/Combi-Plasma and 3 MLs just to have a shot at beating him. But it feels like power gaming :( Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5210785 Share on other sites More sharing options...
brother Vorn_GarDos Posted December 10, 2018 Share Posted December 10, 2018 @unkyhamham, ouch, it seems you need more bodies to absorb loss. bringing all ML might help, but having a dedicated cc beast (other than Reiver) will also help. Reivers are terrible against MEQ as they do not cause any AP. What type of mission were you playing? If you find it tough to beat the nurgle marines then avoid going against them and concentrate on objective of mission. Throw in some expendable fire teams to distract the plague marines as you concentrate on the objective of the mission. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5211549 Share on other sites More sharing options...
InAction Posted December 29, 2018 Share Posted December 29, 2018 Recently got a hold of the core manual and am looking to jump back into 40K with a kill team focused on a custom chapter of marines, but I'm not certain how to go about it. Specifically, how I should go about making a team that reflects my chapter's unique fluff, (tldr; cowboy marines). From where I stand I think that ought to mean a team utilizing hit-and-run tactics and those I've asked around have suggested utilizing auto rifles and Reivers, but I'd appreciate getting thoughts from people here on the forums. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5224490 Share on other sites More sharing options...
Berzul Posted April 5, 2019 Share Posted April 5, 2019 Hey guys. Ive been looking for a new team configuration to change my usual plas a and missiles focused set up a bit. Anyone have tried something like: Scout Sgt w/Bolter, Leader Tactical Marine w/Bolter, Medic lv3 (Field Medic, Trauma Specialist) Tactical Sergeant w/Combi Grav, Sniper lv2 (Assassin) Tactical Gunner w/Grav Gun, Veteran lv2 (Practiced) Scout Fire Team of 3 Scouts w/Bolters The idea is to pack the scouts together to pick at lighter targets while providing cover to the Sergeant. Then, move the three specialists together. Their guns should hurt most anything at a 3+, with rerrolls on wound rolls for both gunner and sergeant. The medic gives them a FnP6+ and reduces chances of them getting take. Out of action, while remaining in cover himself behind the other specialists. I wonder if this could be a viable team. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5291876 Share on other sites More sharing options...
Tordeck Posted April 5, 2019 Share Posted April 5, 2019 Unless your meta actually plays open play the only way to get that team would be via campaign. Matched play (which every pick up game I've ever played has been) maxes lvl for Specialists at 1. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5291894 Share on other sites More sharing options...
Berzul Posted April 5, 2019 Share Posted April 5, 2019 Oh yeah, I should have clarified that we do. Sorry! Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5291904 Share on other sites More sharing options...
kravi Posted May 3, 2019 Share Posted May 3, 2019 This is my preferred list, though usually I try (and don't always succeed) to focus on rosters, and customize each list depending on the scenario and opponent. Most of my lists end up being a variant of this (one way or another) if I'm going up against MEQs. If I'm going against hordes, I'll probably drop the plasma and one of the missiles, and throw down some more bolters (yay bodies). I love sniper on the plasma for the rerolling of 1s in particular. Pretty safe to overcharge that way. + Leader + Intercessor Sergeant: Bolt rifle, Leader, Power sword + Specialists + Reiver Sergeant: Bolt carbine, Combat knife, Veteran Tactical Marine Gunner: Plasma gun, Sniper Tactical Marine Gunner: Demolitions, Missile launcher + Non-specialists + Scout Gunner: Camo Cloak, Missile launcher Scout Gunner: Heavy bolter Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5306269 Share on other sites More sharing options...
Othniel's Blade Posted May 6, 2019 Share Posted May 6, 2019 I'll share my list- it has been holding its own quite well recently + Leader + Intercessor Sergeant: Leader, Bolt, pistol Power sword + Specialists + Intercessor: Comms, Bolt Rifle, Auspex Scout Gunner: Heavy, Heavy bolter Scout: Sniper, Sniper rifle, Camo cloak + Non-specialists + Intercessor: Bolt Rifle Intercessor: Bolt Rifle Scout: Bolter I might try switching out the sniper as he's been little more than a deterrent in the last few games with only 1 shot vs everyone else in the team typically. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5308249 Share on other sites More sharing options...
Dosjetka Posted May 6, 2019 Share Posted May 6, 2019 I'm assuming you don't play using the Matched Play rules since you have 4 specialists? Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5308272 Share on other sites More sharing options...
thewarriorhunter Posted May 6, 2019 Share Posted May 6, 2019 I've been running an all-Primaris list. It hurts not having a Heavy Bolter but I am trying my best to make it work since I'm making my own chapter. + Leader + Reiver Sergeant: Bolt carbine, Combat knife, Leader + Specialists + Intercessor: Auspex, Bolt rifle, Comms Intercessor Gunner: Bolt rifle, Demolitions Intercessor Sergeant: Auto bolt rifle, Power sword, Combat + Non-specialists + Intercessor: Bolt rifle Reiver: Bolt carbine ++ Total: [98pts] ++ I can add/remove Grapnel Launcher's to my Reivers as I need too. Not having them actually won me a match last week. We tied for points so the list with the lower force (points) won. My opponent was at an even 100 and I was at 98 so I took the victory. I tend to run my demo and comms together. The comms ability combined with the auspex lets my demo specialist hit and wound on 2's against obscured targets. It gives me a higher str shot if I need it or if we're in range I can opt for rapid fire. My combat sgt has the assault rifle so he can advance and fire to get into charge range. The power sword is the only way to get any AP modified CC attacks. When he does get into combat he does pretty well, but getting him there has been a challenge. The rest is pretty straightforward. 6 models is rough but the 2W definitely help them have some survivability on the field. Really the one trick my list has is the comms/demo combo and I hope I can out maneuver/strategize my opponent. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5308301 Share on other sites More sharing options...
Disruptor_fe404 Posted May 8, 2019 Author Share Posted May 8, 2019 So, as a fan of 'slippery'/evasive Leaders, I'm really looking forward to Elites. Why? Eliminator Sergeants and Suppressor Sergeants. While they will both cost double what a Scout Sergeant with camo cloak does, they also both have two Wounds with a 3+ save and still bring other options to the table which I'm keen to try out. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5309271 Share on other sites More sharing options...
Othniel's Blade Posted May 8, 2019 Share Posted May 8, 2019 I'm assuming you don't play using the Matched Play rules since you have 4 specialists? Post edited. I copied and edited a kravi's post on here to show my list and left an extra guy. Link to comment https://bolterandchainsword.com/topic/349280-kill-team-tactica-adeptus-astartes/page/10/#findComment-5309327 Share on other sites More sharing options...
