Jackalwolf Posted September 7, 2018 Author Share Posted September 7, 2018 Bought all the plague marines there are, a couple of each. Needed around 15 models to manage to kit bash 5 pairs of legs. Torsos I'll use the two models shown above, the ornate one for sergeants and the one with spikes for the troops. It really matches well the visual style of the Varagyr where that same kind of spikes is prominent. Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5163072 Share on other sites More sharing options...
Vairocanum Posted September 8, 2018 Share Posted September 8, 2018 Such impressive conversion work with the DG bits, the different bits work so well together! Definitely looking forward to seeing them painted up! Jackalwolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5163528 Share on other sites More sharing options...
Jackalwolf Posted September 9, 2018 Author Share Posted September 9, 2018 Such impressive conversion work with the DG bits, the different bits work so well together! Definitely looking forward to seeing them painted up! Thanks mate! I've already finished cleaning 5 pairs and am almost done repairing the damaged bits with green stuff. I bought a 0.3mm lead pencil to finish off the riveting and hopefully next weekend I'll try casting molds and printing 30 legs so I've got enough for 3 squads! Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5163691 Share on other sites More sharing options...
hushrong Posted September 10, 2018 Share Posted September 10, 2018 Late to the party but the removal of the extra armor on the thigh does wonders for a PA conversion! Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5164471 Share on other sites More sharing options...
Jackalwolf Posted September 11, 2018 Author Share Posted September 11, 2018 (edited) Thanks man. Need some help guys. Already finished cleaning and repairing 5 pairs of legs but riveting is a nightmare since they're so small in the plague marine kit. What do you think of this result? They need to be cleaned now in the surroundings of each rivet but you get the idea: Trying to make them all the same size and simetric over a curved irregular surface is driving me crazy to the point where I'm considering just shaving all rivets off and leave the mkiii clean of them. What do you think? Shall I try a different method? Leave as it is? Just make smooth armour? Edited September 11, 2018 by Grieux Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5165250 Share on other sites More sharing options...
Guest Triszin Posted September 11, 2018 Share Posted September 11, 2018 Thanks man. Need some help guys. Already finished cleaning and repairing 5 pairs of legs but riveting is a nightmare since they're so small in the plague marine kit. What do you think of this result? They need to be cleaned now in the surroundings of each rivet but you get the idea: Trying to make them all the same size and simetric over a curved irregular surface is driving me crazy to the point where I'm considering just shaving all rivets off and leave the mkiii clean of them. What do you think? Shall I try a different method? Leave as it is? Just make smooth armour? GS rivets. *thumbs up* Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5165254 Share on other sites More sharing options...
Marshal Rohr Posted September 12, 2018 Share Posted September 12, 2018 Grieux, are you using a press mold for those rivets? If I remember correctly the rivets the FW sculptors use are brita filter beads, so it wont match the plastic ones, but itll look like the resin ones. Alternatively, drilling a rivet size into a brass rod and filing the outer edges can create a nifty little DIY tool Ive seen people use on larger models to make tiny, tiny rivets. Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5165289 Share on other sites More sharing options...
Jackalwolf Posted September 12, 2018 Author Share Posted September 12, 2018 I'm sculpting them with a 0.35mm mechanical pencil :p Do you know how large these filter beads are? Also what's the best way to ensure they're equidistant when the surface is so irregular? Just checked the GW plastic mkiii and not even these seem to be perfectly equidistant! Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5165363 Share on other sites More sharing options...
hushrong Posted September 12, 2018 Share Posted September 12, 2018 You GS'd some rivets? You are a madman but a talented one! Your GS rivets seem to match the plastic ones on the mini just fine. And seeing as some of the converted DG armor has gouges and rends maybe have some empty sockets where a rivet would have been could be in order. Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5165518 Share on other sites More sharing options...
Marshal Rohr Posted September 12, 2018 Share Posted September 12, 2018 I'm sculpting them with a 0.35mm mechanical pencil Do you know how large these filter beads are? Also what's the best way to ensure they're equidistant when the surface is so irregular? Just checked the GW plastic mkiii and not even these seem to be perfectly equidistant! I use microbeads, personally, but they are much bigger than the Mark 3 rivets. I didn't find out about the britta filter thing until a few months ago, actually. I was looking through the guy who sculpted the Reavers Instagram and it was in one of the comments. Youtube Video of disassembly As for ensuring they are equidistant, when I do make rivets I eyeball it . Not the most exact science. I've got digital callipers but I rarely break them out. Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5165538 Share on other sites More sharing options...
Jackalwolf Posted September 17, 2018 Author Share Posted September 17, 2018 (edited) So I took a small break after all the stress of the rivets. They're now with a crack sculptor in Sweden to finish riveting and then I'll cast molds when they're back. On the meantime I'm 99% done with Arjac who with some magnetisation doubles up as Hvarl Red blade in 30k! Only waiting for some belt feed bullets to put into the heavy bolter mag well. Edited September 17, 2018 by Grieux hushrong, Dantay VI, Doghouse and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5168354 Share on other sites More sharing options...
Doghouse Posted September 17, 2018 Share Posted September 17, 2018 Those death guard/pre-heresy space wolves conversions are superb mate, really impressed by those and may have to try it myself some time, :tu: Jackalwolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5168378 Share on other sites More sharing options...
Dantay VI Posted September 18, 2018 Share Posted September 18, 2018 Looks great :tu: Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5168485 Share on other sites More sharing options...
hushrong Posted September 18, 2018 Share Posted September 18, 2018 That fella is the bee's knee! You keep rolling out these sweet conversions and making me wish I had some SW! Jackalwolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5168680 Share on other sites More sharing options...
Dantay VI Posted September 18, 2018 Share Posted September 18, 2018 Doesnt Hvarl wear tartaros armour? Jackalwolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5168797 Share on other sites More sharing options...
Marshal Rohr Posted September 18, 2018 Share Posted September 18, 2018 So I took a small break after all the stress of the rivets. They're now with a crack sculptor in Sweden to finish riveting and then I'll cast molds when they're back. On the meantime I'm 99% done with Arjac who with some magnetisation doubles up as Hvarl Red blade in 30k! Only waiting for some belt feed bullets to put into the heavy bolter mag well. When you make your molds what do you use in lieu of super sculpey to avoid melting the plastic components? Jackalwolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5168832 Share on other sites More sharing options...
Jackalwolf Posted September 18, 2018 Author Share Posted September 18, 2018 (edited) Thank you so much guys! Hey Dantay yes indeed he's in tartaros but I decided to just use Hvarl since I have him already built and since all my attempts at tartaros terminators don't marry the design identity of the Varagyr or Russ. My last attempt wasted 45 pounds in deathsroud who look like dwarves by the Varagyr!! Also since Hvarl has a 4++ due to iron halo noone should kick a fuss saying I confused them. And Marshall I've never done molds I'm afraid! I'm going to ask a friend for the legs. Edited September 18, 2018 by Grieux Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5168877 Share on other sites More sharing options...
Jackalwolf Posted September 18, 2018 Author Share Posted September 18, 2018 And Njal is almost finished, only the spell effect sculpt into ravens and the base remaining. He's full of details but I think it works for the chief rune priest of the 6th plus I want him to rival Russ himself in level of elaborate. Vairocanum and Deadass 2 Back to top Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5168978 Share on other sites More sharing options...
Dantay VI Posted September 19, 2018 Share Posted September 19, 2018 Marshal Rohr I have used this stuff pretty successfully for making moulds http://www.greenstuffworld.com/en/reusable-blue-stuff/8-blue-stuff-mold-8-bars.html?search_query=Blue+Stuff+Mold+8+bars&results=2 Youtube videos further down show pretty well how the stuff works Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5169115 Share on other sites More sharing options...
Marshal Rohr Posted September 19, 2018 Share Posted September 19, 2018 I use Smooth On Mold Max series, personally. When you do a two part mold with that, you’re supposed to use a polymer clay base to hold the master which is fine for resin, but the plasticizers in the clay will ‘melt’ GW plastic parts. If he’s gonna cast up the legs I was just wondering if he had an alternative so they don’t get ruined (and also shameless so I could steal thenodea for my own molds). Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5169186 Share on other sites More sharing options...
Dantay VI Posted September 19, 2018 Share Posted September 19, 2018 I have used the bluestuff on plastic and resin and it has not damaged either of them, I used it on Horus's cloak. I have even used it on painted models and it has not affected the paint Marshal Rohr 1 Back to top Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5169197 Share on other sites More sharing options...
Vairocanum Posted September 19, 2018 Share Posted September 19, 2018 Super impressive work on everything, but man that Njall is a really nice looking conversion! Just a random idea but instead of the demon face psyker flame, maybe a wolf instead? Definitely looking forward to seeing him painted up though! Jackalwolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5169306 Share on other sites More sharing options...
Jackalwolf Posted September 19, 2018 Author Share Posted September 19, 2018 Super impressive work on everything, but man that Njall is a really nice looking conversion! Just a random idea but instead of the demon face psyker flame, maybe a wolf instead? Definitely looking forward to seeing him painted up though! Thanks man I actually pre-ordered the endless spells from beasts of chaos and will graft in there a flock of ravens to represent Huginn and Muninn! Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5169331 Share on other sites More sharing options...
Jackalwolf Posted September 19, 2018 Author Share Posted September 19, 2018 And Arjac's version of the conversion: Marshal Rohr and malcharion 2 Back to top Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5169552 Share on other sites More sharing options...
malcharion Posted September 19, 2018 Share Posted September 19, 2018 Man ! All your wolves look awesome !! Great work all over the thread ! (the use of Sevatar and Khârn !!) I'm impressed ! Those are some real big bad wolves. I'm following . Keep on the good job ! Malchy Link to comment https://bolterandchainsword.com/topic/349558-a-skjald%C2%B4s-tale-of-the-days-of-darkness/page/5/#findComment-5169560 Share on other sites More sharing options...
