Chaeron Posted January 20, 2020 Share Posted January 20, 2020 An incredible pledge Mendi - really looking forward to seeing the finished result during the event! Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5464848 Share on other sites More sharing options...
Fajita Fan Posted January 20, 2020 Share Posted January 20, 2020 Thanks guys! What’s the length of your hexagon? It looks excellent so I could 3D print something like that. Ask and you shall receive :D Have fun and show us the results! Gracias! I can use Tinkercad to lay down shapes of exact dimension because I can’t cut plastic straight like that for my life. Fun fact: not even my movement trays in WHFB were square and they had the damn lines premade. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5464869 Share on other sites More sharing options...
Mendi Warrior Posted January 20, 2020 Author Share Posted January 20, 2020 (edited) @Fajita Fan: de nada! Thanks guys! I sure hope to tackle the task. Thanks for sending those measurements. I’m thinking of doing something similar, though octagonal instead of hexagonal. Ask and you shall receive A long time ago in a galaxy very, very close, I learned some trigonometry concepts … since then it became long forgotten knowledge So, after some research on google, I came across this interesting formula that allows to compute the radius for any division of a circle: AM = rho * sin(Pi / n) <=> rho = AM / [sin(Pi / n)] where rho is the radius, sin the sinus, Pi the Pi constant (3,141592...), and n the number of parts in your circle. AM is half of AH, which, here, is the width of the civitas imperialis component of interest. AH = 29mm, so AM = 14.5mm. In the case of an octagon (n=8), solving the equation gives rho equal to 37.89mm. This demonstrates why trigonometry can be important to wargames Lol, I would never had thought of putting that in a post about Adeptus Titanicus. I might add another octagon later, I'll see. Edited January 20, 2020 by Mendi Warrior Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5464934 Share on other sites More sharing options...
Mendi Warrior Posted January 20, 2020 Author Share Posted January 20, 2020 Gracias! I can use Tinkercad to lay down shapes of exact dimension because I can’t cut plastic straight like that for my life. Fun fact: not even my movement trays in WHFB were square and they had the damn lines premade. I sometimes do it as well. Here is an example. I added a bit of cardboard (1mm large) to rectify the mistake and avoid problems later. Very small progress, starting a second floor: I'll likely combine with other components to save on the civitas imperialis components. Reinforcing the structure helps a lot Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5464946 Share on other sites More sharing options...
Fajita Fan Posted January 20, 2020 Share Posted January 20, 2020 (edited) I’ve 3D printed a bunch 2x2 squares for reinforcement but they’re kinda thin, I need to make them thicker but they’ll be hard to peel off our newer heated bed. Are you gluing all those levels together or making them stackable? Think that’s worth it? Edited January 20, 2020 by Fajita Fan Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5464980 Share on other sites More sharing options...
Mendi Warrior Posted January 20, 2020 Author Share Posted January 20, 2020 Thickness at the edges need to be about 1mm, max 1.5 mm. The slot in the walls is slightly beveled if you look very close. So far, they are stackable. They are easier to store that way and you retain some flexibility to combine them differently. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5465009 Share on other sites More sharing options...
Mendi Warrior Posted January 20, 2020 Author Share Posted January 20, 2020 A bit more progress, still wondering if I add more civitas imperialis components or if I go for something alternative to finish levels 2 and 3 of both towers … something alternative means more civitas imperialis components for more buildings Fajita Fan 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5465130 Share on other sites More sharing options...
Fajita Fan Posted January 20, 2020 Share Posted January 20, 2020 Looted. Those will be the towers for my cathedral. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5465136 Share on other sites More sharing options...
Mendi Warrior Posted January 20, 2020 Author Share Posted January 20, 2020 Sounds cool! I'll give a try to an alternate roof as well. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5465141 Share on other sites More sharing options...
Mendi Warrior Posted January 23, 2020 Author Share Posted January 23, 2020 Some progress to report I glued many of the spires components. One little piece of advice for those willing to have the arch nicely fit the main body of the building: remove the two round things on the back, it fits much nicer afterwards. Readying some components, here we go with some alternative stuff The parts with 3 arches are from very old vitamin boxes I took when I was a student. I liked the shape, so they ended in a bits box. They are about 25y old, I just regret not keeping more of these … More alternative stuff, this time packaging from something, I don't know what it was but well these ended in my (big) bits box Playing with textured plasticard and readying some civitas imperialis components for a large wall. I added 1mm thick plasticard on the back of these so as to increase the surface for gluing some kind of guide, hence obtaining a nice fit for a wall made of 3 panels One rule to ensure I get the precise measurement (width = 3 x 29mm) and one wooden block so the top is nicely aligned Removing some details of the floor/roof And you get stairs and roofs And finally, as I was busy with stairs, I did a bigger one and that is it for today I think, more later Captain Semper and General Zodd 2 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5466474 Share on other sites More sharing options...
Chaeron Posted January 27, 2020 Share Posted January 27, 2020 The textured plasticard works wonders for those small details, and adds so much. So good to see this continue to develop! Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5468390 Share on other sites More sharing options...
Fajita Fan Posted January 27, 2020 Share Posted January 27, 2020 What size square is that? I never thought to use those as a marker for stairs, is that like 2mm or so? Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5468392 Share on other sites More sharing options...
Mendi Warrior Posted January 27, 2020 Author Share Posted January 27, 2020 Some progress was made in the last few days The stairs now lead higher I transformed a messed up hexagon into a platform, not sure yet where I'll use it, most likely on some industrial building A bridge Supports Readying the foamboard to insert the supports And there you go … This leads to a proof of concept for a drawbridge that you can open and close of course (otherwise it is too easy) A view from the rear, before I came up with a more stable and efficient solution to be actually able to open and close it without needing to leave it open like that A bit of origami A terrace to enjoy the view The origami result put in place so it can support some tiles to give texture at the angled wall The entrails of the beast, because a bit of supporting structure helps a lot Brother Dallo and General Zodd 2 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5468396 Share on other sites More sharing options...
Mendi Warrior Posted January 27, 2020 Author Share Posted January 27, 2020 Let's add some height The drawbridge can be moved using the brass rod serving as flag pole (the "flag" can be removed). Combining with the stairs Continuing to build up, adding more height Now, that is cool but I forgot one little thing: gluing a civitas imperialis component to the foamboard increases the width of the building by about 5mm, hence my measurements were off … so I started again and did another similarly shaped building. Starting with the top More origami, to make the lateral roof Step-by-step, adjusting as you go A bit of an overview (still very much work-in-progress) General Zodd 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5468404 Share on other sites More sharing options...
Fajita Fan Posted January 27, 2020 Share Posted January 27, 2020 It’s like Helm’s Deep... Mendi Warrior 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5468412 Share on other sites More sharing options...
malika666 Posted January 27, 2020 Share Posted January 27, 2020 wow...just wow... Mendi Warrior 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5468413 Share on other sites More sharing options...
Mendi Warrior Posted January 27, 2020 Author Share Posted January 27, 2020 I'll add more stuff I think I'm a bit crazy Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5468436 Share on other sites More sharing options...
Captain Semper Posted January 27, 2020 Share Posted January 27, 2020 This is overwhelming... You are a bit crazy, but that’s the attribute required to get a project of this scale underway - let alone to complete it! Go for it champ! Mendi Warrior 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5468623 Share on other sites More sharing options...
Mendi Warrior Posted January 28, 2020 Author Share Posted January 28, 2020 In truth, that is the "complete it" part that scares me the most Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5468818 Share on other sites More sharing options...
Mendi Warrior Posted January 30, 2020 Author Share Posted January 30, 2020 Well, it seems I currently can't upload pics into my albums so pictures will have to wait a bit. I did cut some foamboard panels, quite a few actually as I am now out of foamboard. Planning to get some more in the coming days. I got glue sticks for my hot glue gun. A few more things are needed and then I can make more progress. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5470127 Share on other sites More sharing options...
Fajita Fan Posted January 30, 2020 Share Posted January 30, 2020 I had to create a new album, I couldn't upload to my AT album so I made one for terrain today. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5470162 Share on other sites More sharing options...
Mendi Warrior Posted January 31, 2020 Author Share Posted January 31, 2020 (edited) The album access problem was just a temporary issue, Brother Tyler fixed it So here are a few more pics Foamboard cut to the desired shapes Then glued with some plasticard I made 4 of these It allows for taller walls, without spending too many of the civitas imperialis components More foamboard and measurements, lots of measurements and lines, always Adding more plasticard and buttresses Checking by eye if the alignment is ok, it doesn't seem too bad Bird's eye view, ok-ish even if the one on the right could have been a little bit better aligned (there is some optical distorsion as well). Switching to something else: how can I incorporate this CoD component into AT scenery? Well, by turning it into a gigantic door of course Details to be added/removed of course. Fun fact: the rivets at the extreme left and right at the top are 87mm apart, which quite conveniently equals the width of 3 civitas imperialis components. I added some foamboard on the back so I can have more contact surface for gluing this to a skeleton structure. Before that I cut the skulls and the keypad as they can be reused for 28mm scenery. Edited January 31, 2020 by Mendi Warrior Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5470306 Share on other sites More sharing options...
Guest Posted January 31, 2020 Share Posted January 31, 2020 Man your scenery will look so good. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5470336 Share on other sites More sharing options...
Fajita Fan Posted January 31, 2020 Share Posted January 31, 2020 That’s amazing, just awesome. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5470394 Share on other sites More sharing options...
Rabenga Posted February 1, 2020 Share Posted February 1, 2020 I still can't get over the effin draw bridge!!! Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/17/#findComment-5470732 Share on other sites More sharing options...
