Mandragola Posted February 1, 2020 Share Posted February 1, 2020 This is a truly epic construction project. Looking forward to seeing what you do next. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5470733 Share on other sites More sharing options...
Mendi Warrior Posted February 1, 2020 Author Share Posted February 1, 2020 Thanks guys! I replenished my stock of foamboard today: 50x70cm sheets, 2 x 3mm thick and 3 x 5mm thick. I also retrieved an insulation panel from my remaining stock in the garage. I did a quick & dirty mock up for the hilltop accessed via the drawbridge Then I tackled some walls for an inclined roof, quite a lot of cutting as I need to take into account specific shapes of the adjacent part. And here is the gigantic door these walls will be glued to. I started by gluing the skulls I had removed from the back of the door to the two lamps left and right of the door. I then added bits to encase the stairs. Then I ensured I could get a good fit for the adjacent walls. There is a beam on the left of the pic, not on the right, so I took that element into account for the two sides. The lower part of the wall comes forward so I also took that into account. Different views of the adjacent parts These connectors are useful to mask the imperfections, so you get this. The keypads will be masked, I need to find a good way to do it. More to follow 1ncarnadine and Dosjetka 2 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5470948 Share on other sites More sharing options...
Fajita Fan Posted February 1, 2020 Share Posted February 1, 2020 I love the little columns on the edge of those stairs, it’s a tiny detail I really like. Mendi Warrior 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5470957 Share on other sites More sharing options...
Mendi Warrior Posted February 4, 2020 Author Share Posted February 4, 2020 Some more progress in building scenery Adding roofs to the left and right parts by first building a structure (foamboard for the walls, cardboard for the floor) and then cutting some cardboard to shape for the actual roof and also adding some textured plasticard to act as terrace, this requested some fine-tuning to get to the exact height I needed to be able to extend the row of civitas imperialis panels above the gigantic door Switching to other roofs for my hexagonal towers. By dividing the circle into 24 equal parts, I could theoretically get 4 hexagonal roofs but the cardboard only allowed for 3 as its width was not sufficient. and a first result using one of the hexagonal tops from the spires box trying the other one, its base is thicker so it seems a bit weird, some adjustments are needed The first 3 More drawings and measurements, this time adding another circle At the basis, the width is 28-29mm, at the truncated top it is 12mm. Once ready always check it fits into the hexagonal tower. This fits better One little thing to add: another tiny hexagon so as to give more contact surface for the top, always checking it is parallel to the ground (aka my desk) Adding L-shaped plasticard (2mm width) to hide the angles. This is more aesthetically pleasing and also ensures the roof doesn't lean too much to the left or to the right. noigrim, CaptainFrederickson and Dosjetka 3 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5472112 Share on other sites More sharing options...
Guest Posted February 4, 2020 Share Posted February 4, 2020 I can't wait to see this painted :) Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5472168 Share on other sites More sharing options...
Fajita Fan Posted February 4, 2020 Share Posted February 4, 2020 That looks like a lot of effort and it really pays off, it looks brilliant. I wish I had your patience... Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5472185 Share on other sites More sharing options...
Mendi Warrior Posted February 4, 2020 Author Share Posted February 4, 2020 Thanks! Well, patience is one thing, good preparation and some chain work definitely help as well. I currently don't have a job so I have plenty of time and that is, for me at least, a good way to try keeping some sanity, even though morale can sometimes be on a "slow motion" rollercoaster. Or, maybe I have completely lost it already  Anyway, I did some more work on hexagonal towers. They eat civitas imperialis panels quite fast ... Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5472244 Share on other sites More sharing options...
Mendi Warrior Posted February 5, 2020 Author Share Posted February 5, 2020 Roof terrace wip The question is how far above the ground are we? Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5472587 Share on other sites More sharing options...
Mendi Warrior Posted February 5, 2020 Author Share Posted February 5, 2020 I went for a tall one: about 23.5 cm at the top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5472955 Share on other sites More sharing options...
Fajita Fan Posted February 5, 2020 Share Posted February 5, 2020 The funny part is that you're probably faster with foam core board than I am with 3d printing.  Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5472965 Share on other sites More sharing options...
Mendi Warrior Posted February 6, 2020 Author Share Posted February 6, 2020 3D printing can allow for some nice components to add and "pimp" a blank wall made of foamboard. The day I have a new job (the sooner the better), I think a resin 3D printer is my first "big" purchase. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5473118 Share on other sites More sharing options...
Mendi Warrior Posted February 7, 2020 Author Share Posted February 7, 2020 Various stuff, including some additions to previous partial builds A roof terrace A higher hexagonal tower, with details to be added later Industrial building getting some additional details, like stairs, flooring, ... An extended loading bay. The ground level was done previously, I added a terrace and an upper floor. Chaeron, CaptainFrederickson and Fajita Fan 3 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5473953 Share on other sites More sharing options...
Guest Posted February 7, 2020 Share Posted February 7, 2020 More painting :P Man this looks great. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5473961 Share on other sites More sharing options...
Fajita Fan Posted February 7, 2020 Share Posted February 7, 2020 LOL where do you store all this? Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5473973 Share on other sites More sharing options...
Sherrypie Posted February 8, 2020 Share Posted February 8, 2020 That loading bay is a great concept, totally stealing for my next big terrain push. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5473988 Share on other sites More sharing options...
Rabenga Posted February 8, 2020 Share Posted February 8, 2020 You sir,should consider a career in grim dark architecture. Brilliant. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5474038 Share on other sites More sharing options...
malika666 Posted February 8, 2020 Share Posted February 8, 2020 Will there be trucks or aquatic ships docking at the loading bay? Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5474052 Share on other sites More sharing options...
Mendi Warrior Posted February 8, 2020 Author Share Posted February 8, 2020 Thanks guys!   More painting Man this looks great.  My aim is to round up this bout of building by end of Feb, then paint a lot. I still have a few surprises in store. And painting is definitely required if I want to succeed my vow  LOL where do you store all this?  Let's just say we had a dressing room  That loading bay is a great concept, totally stealing for my next big terrain push.  Please do. Simply using 5mm thick foamboard, 2 panels glued together, one to support the terrace, the other to act as upper wall. I need to add lateral walls, flat ones, then I can use this in combination with other buildings. Always trying to be as modular as possible.  You sir,should consider a career in grim dark architecture. Brilliant.  Well, if I don't succeed in getting back into my specialty, I might.  Will there be trucks or aquatic ships docking at the loading bay?  Sweet suggestion, I especially like the idea of ships docking! Could be an interesting set up: shoreline docks with shallow water drilling rigs and titans fighting in between Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5474078 Share on other sites More sharing options...
Chaeron Posted February 8, 2020 Share Posted February 8, 2020 Amazing stuff Mendi - love the thought of loading bays, manufactoria, and the thought of the scenarios you could play from there... Mendi Warrior 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5474127 Share on other sites More sharing options...
malika666 Posted February 8, 2020 Share Posted February 8, 2020 Grimdark aquatic ships could be a cool modelling project. Very curious to see what you'd come up with! Mendi Warrior 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5474190 Share on other sites More sharing options...
Captain Semper Posted February 9, 2020 Share Posted February 9, 2020 This is truly a staggering amount of work! I'm in awe... :o Mendi Warrior 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5474635 Share on other sites More sharing options...
Mendi Warrior Posted February 9, 2020 Author Share Posted February 9, 2020 Thanks guys! Taking a break for a few days, I have an interview to prepare. Expect more soon.  I'll be ordering some more stuff as well, still undecided as to what exactly as there is so much … I also asked FW if an upgrade kit for the psi-titan might be coming, hopefully they'll answer positively (not holding my breath though). Captain Semper and malika666 2 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5474664 Share on other sites More sharing options...
Rabenga Posted February 10, 2020 Share Posted February 10, 2020 Good luck with the interview Mendi Warrior 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5475272 Share on other sites More sharing options...
Fajita Fan Posted February 11, 2020 Share Posted February 11, 2020 Thanks guys! Taking a break for a few days, I have an interview to prepare. Expect more soon.  I'll be ordering some more stuff as well, still undecided as to what exactly as there is so much … I also asked FW if an upgrade kit for the psi-titan might be coming, hopefully they'll answer positively (not holding my breath though). At least gun if not the head.  May bring the Emperor’s light in your interview. Mendi Warrior 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5475351 Share on other sites More sharing options...
schoon Posted February 11, 2020 Share Posted February 11, 2020 If you're looking for trucks for your loading bay: https://kore.ecwid.com/Epically-scaled-6-8mm-Vehicles-c33153403 Mendi Warrior and malika666 2 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/18/#findComment-5475594 Share on other sites More sharing options...
