Ryltar Thamior Posted June 23, 2019 Share Posted June 23, 2019 very, very nice painting on those Iron Warriors; whereabouts is the head on that champion from? [who's got cool posing, by the way] I've seen a few takes on Mk.III torsos on Primaris legs elsewhere, it's an interesting approach Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5335949 Share on other sites More sharing options...
ShotgunFacelift Posted June 23, 2019 Share Posted June 23, 2019 Really like the squad Sergeant/aspiring champion. Great conversion! Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5336072 Share on other sites More sharing options...
Chewbacacabra Posted June 24, 2019 Share Posted June 24, 2019 Wow, thank you all. Given the caliber of stuff on here, sheesh! The head of the Champ is a Khorne AoS cultist. It originally had horns, but I shaved them off for a more streamlined look. Ryltar Thamior 1 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5336293 Share on other sites More sharing options...
Ryltar Thamior Posted June 30, 2019 Share Posted June 30, 2019 Space Wolf in Mk.III with heavy bolter:I decided that my ongoing efforts with building a Vlka Fenryka hunter-pack, might require some on-the-move fire support. A heavy bolter seemed the obvious choice, not least because I could easily imagine it having greater utility in close confines of ship's corridors and such; as well as, I think, some pretty great Space Wolf Long Fang art from many an edition ago. The running legs [grave warden terminators] added a very nice sense of motion to the miniature, to counterbalance what would otherwise be a static presumption of a heavy weapon, and keep the 'active hunter'/stalker/pursuer vibe-theme going. I'm genuinely very pleased with how well it's gone with the bulky heavy bolter - it gives the visual impression of , almost , a transhuman-dread 'sledgehammer-glacier' battering-ram-jogging-tank; particularly with that open-mouthed, bearded head on a slight tilt and orientation. *Exactly* what a VIth Marine should be!Something I'm rather taken with on this miniature, is the way that the Mk.III + Space Wolf aesthetic, means that he doesn't seem entirely restricted to the Heresy-era. I could see him turning up in later periods without too much squinting at all. It's also been very legit how the head goes with the rest of the miniature - I've been somewhat leery of bare-headed Astartes all up, and some of the Space Wolves sprue heads in particular, which have almost seemed 'cartoonish' in characterization. But with both the Haunting Harii of Hvergelmir, and some of my more recent Wolves, I've started branching out - and it's actually turned out pretty decent! Although I'm *still* yet to find a way to actually photograph the incredibly fine glowing-green eyes I keep adding!He's also in possession of a bit more of an 'ornate' look than a lot of the previous Wolves I've done [well, all three of them] for this project; utilizing actual gold rather than the more brassy, bronzy look ... but also, multiple different kinds of metallic ornamentation [including copper-and-steel on the Mk.III backpack, not that it's hugely obvious from these shots]. This means that he's in some ways quite visually different from the other three ... but if any Astartes force is going to have individual heroes who're equipped as exactly that, it'd have to be the VIth. Finally, what was holding up this miniature for *ages* [seriously, literally months], was that I couldn't quite work out where to place the grenades. I'm a general believer in putting everything onto a miniature which it 'should have', so to speak - and have always endeavoured to model my Truescale Astartes as if they really are capable of doing just about anything, each, regardless of their designated specialization. So heavy weapons Marines nevertheless have close combat weapons and sidearms; pretty much all have stowage [including, as we can see here, a pouch [cut-down Guard one, partially for reasons of space, partially because they're an interesting alternative to the Primaris etc. ones I've often otherwise used, and the large 'button'], and the heavy bolter additional ammunition mounted under the power-pack]; and very frequently, grenades are also pointedly equipped. Preferably in places that all of the above are 'realistically' accessible and utilizable by the Astartes in question. Which can create some 'interesting situations' - c.f the Salamander I previously did, with his thunder hammer. After trying out a number of different possibilities with various different sorts of grenades [i've been quite taken with Van Saar grenades of late, because they have an obvious maglock or something mechanism, as well as looking pretty high-tech, generally; however, I've also occasionally utilized those massive Goliath 'potato-masher' style stick-grenades, because they're honestly an *excellent* idea given a Marine's size, and the WWI elements for some of what I've been doing previously; and while the plastic Heresy era grenades remain great for Marines, because of the larger size and panelling, shortages relative to my output [also something-something Primaris kits not having grenades, and a shortage of sheathed combat blades!] has often meant i've been dipping into Guard kits to find grenades .. which hasn't always been ideal. ], I eventually settled on an Orlock selection - one each of frag, krak, and what I presume is a smoke-grenade or det-charge. Perfect for some spec-ops-ery. And then mounted it on webbing I built over the pistol holster [another gripe - one can never have too many Astartes-sized holstered sidearms! Also, the Primaris-sized ones are pleasingly *huge* ... looking like the bearer can probably cave in a skull just by hitting somebody with it, without even drawing it - which, given Astartes strength, is probably *exactly* the case], rather than my earlier experimentation wth the left thigh-plate [i uh .. i figured that incoming fire would most likely be hitting the Marine on the left-hand side - hence the mono-molecular studs and such on Mk.V and VI armours, etc. - so therefore would have had a chance of prematurely cooking off the grenades, if he got hit there ... so hence, mounted on the other side]. This is also, apropos of nothing in particular, the first time I've done a ginger-haired miniature, I think. Something about him just seemed to demand it. Very Germanic looking, as a result. I've traditionally tended much more towards dark hair colourations - for various reasons, including the arguable over-representation of Indian skin-tones in my output [although interesting fact, there's actually a not insignificant proportion of red hair naturally occurring in North(West) Indian Brahmin populations], and the frequent rather dark or stark colours of the Astartes plate armours in question [not sure, for instance, how well ginger hair would go with the gleaming steel of my Iron Warriors, for instance]. I've had varied success with blond hair colours more recently, as well - and, now that i think about it, the first [Heresy-era] Wolf we ever did was done blond; but ginger and red have been a lot harder to get right - there's a Haunting Harii of Hvergelmir destroyer who's been sitting half-finished himself for months, as a result. Anyway, I'm rambling now. Good to finally get this chap painted and posted! Isengrin, Bouargh, Gederas and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5339621 Share on other sites More sharing options...
Luna707 Posted July 24, 2019 Author Share Posted July 24, 2019 Took a couple cool shots of the boys, thought you all might like them: batu, Graymane, Grotsmasha and 9 others 12 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5352327 Share on other sites More sharing options...
Blissful Brushes Posted August 1, 2019 Share Posted August 1, 2019 These were my first successful attempts at Truescaling - the only ones that I felt were worthy of any paint at any rate. Isengrin, Doghouse and Chaplain Raeven 3 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5356104 Share on other sites More sharing options...
Sherrypie Posted August 1, 2019 Share Posted August 1, 2019 Well, since they're finally getting into army size: behold, the Echoes of Eisenstein (loyalist remnants of the XIV)! Normal fellas are a head taller than regular marines, terminators got a boost at the abdomen. Isengrin, Emurian, Chaplain Raeven and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5356342 Share on other sites More sharing options...
Bjorn Firewalker Posted August 2, 2019 Share Posted August 2, 2019 (edited) Excellent work, Sherrypie. Edited August 2, 2019 by Bjorn Firewalker Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5356418 Share on other sites More sharing options...
Jackalwolf Posted August 19, 2019 Share Posted August 19, 2019 (edited) All the building is done! Finished my Bjorn conversion, 10 true scale blood claws/deathsworn, the rework of my wulfen pack leader and finished 10 more torsos for a squad of grey hunters as soon as I procure 10 more pairs of true scale legs: And detail on the legs of the conversion: Primaris for scale: Edited August 19, 2019 by Jackalwolf Canardwc, mercbat, batu and 16 others 19 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5370325 Share on other sites More sharing options...
Sherrypie Posted August 19, 2019 Share Posted August 19, 2019 Those Deathsworn are damn tasty, Jackalwolf. Jackalwolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5370677 Share on other sites More sharing options...
Jackalwolf Posted August 20, 2019 Share Posted August 20, 2019 Thank you my friend! Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5371070 Share on other sites More sharing options...
Chewbacacabra Posted November 10, 2019 Share Posted November 10, 2019 Quick n dirty bash of Aos Khorne guys and the new CSM box has them slightly taller and beefier than a standard marine. Doghouse and Bjorn Firewalker 2 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5423292 Share on other sites More sharing options...
Bjorn Firewalker Posted November 10, 2019 Share Posted November 10, 2019 Good job on the Khorne worshippers, Chewbacacabra. Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5423478 Share on other sites More sharing options...
Dark Rage Posted February 25, 2020 Share Posted February 25, 2020 Upscaled Mk6 Doghouse, batu, Spaced Hulk and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5481649 Share on other sites More sharing options...
apologist Posted February 25, 2020 Share Posted February 25, 2020 (edited) Here're a few details of my contributions – some quite old!: 190th Company squad Remnants of the Word Bearers Astral Claws' Killteam Clawthorn 2nd ed. retrohammer Blood Angels, including Terminator Another approach to Blood Angels Novamarine Captain Last of the Scarlet Blades Gatebreaker White Scar Salamander Castigator ...a few more... Iron Warriors Sons of Horus Alpha Legion Iron Hands[/b Tithonus, May He Live Forever Young Holion, and a refugee Ultramarines Edited February 25, 2020 by apologist Brother Dallo, Graymane, Dosjetka and 17 others 20 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5481680 Share on other sites More sharing options...
apologist Posted February 25, 2020 Share Posted February 25, 2020 ...and the army shots: Praetors of Calth: 15th Chapter and 190th Company Officio Monstrosa, Iron Warriors Night Lords ...and some random scenics, for fun: An embiggened Guilliman and some of his Legion Word Bearers clash with Imperial Fists Captain Tycho's Blood Angels take on the infidious Eldar Zaricus Cjarn of the IVth takes on the Imperial Fists on Terra Officio Monstrosa on the march Lieutenant Holion Ultramarines on Crusade hushrong, mercbat, Freakshow668 and 18 others 21 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5481681 Share on other sites More sharing options...
Elzender Posted February 25, 2020 Share Posted February 25, 2020 Dang Apologist, I thought I had seen most of your works on the different threads around here, but I must have missed some. Top notch stuff all around, but that is no surprise at this stage. I hope some day you expand a bit more the Iron Hands project, I remember awaiting updates on it because I loved both the miniatures and the narrative. Then again, I'm sure whatever you come up next will be a joy to see and read anyways apologist 1 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5481775 Share on other sites More sharing options...
Sherrypie Posted March 2, 2020 Share Posted March 2, 2020 Oh my, those army shots are pure gold, Apologist. Quite a sight. I like the way you've used characterful details everywhere, like the Ultramarine protecting a civilian, Zaricus' face and so on... great work with exactly the type of flair that keeps inspiring. apologist 1 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5484922 Share on other sites More sharing options...
Ryltar Thamior Posted March 23, 2020 Share Posted March 23, 2020 First group of Adamanticores for this thread. The Unyielding Adamanticores can also be found (in greater numbers), in the original thread (still ongoing) focusing on their M37/M38 iteration at the height of their glory, as well as their post-41st millennium incarnation in the form of the Dead Stars initiative. I may also get around to doing a more .. cohesive and unified fluff writeup for this year's Liber challenge-series. We'll see what happens. There's also at least a dozen more that're painted (and in fact have been painted for some months or even years now) awaiting photography - however I thought I'd start with some of the most recent. The last two are in mostly Mk.X armour, but are indeed truescales [at least fluff-wise] rather than Primaris. Long story. Doghouse, Dark Rage, jeremy1391 and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5495305 Share on other sites More sharing options...
Chewbacacabra Posted April 19, 2020 Share Posted April 19, 2020 Here are some truescale World Eaters I've been working on for a Khorne themed killteam. Grim Dog Studios, Ryltar Thamior, apologist and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5509235 Share on other sites More sharing options...
Spinsanity Posted April 20, 2020 Share Posted April 20, 2020 Damn, the kits fit together so well! What do they say about plagiarism again? Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5509263 Share on other sites More sharing options...
Knight of the Raven Posted September 13, 2020 Share Posted September 13, 2020 Coincidental timing made this years-old kitbash hilarious in hindsight. body from discontinued Dark Imperium starter box helmet and chainsword from Mark III Space Marines jump pack and right hand from Blood Angels Death Company base from Sector Imperialis box Dosjetka 1 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5600662 Share on other sites More sharing options...
Ryltar Thamior Posted September 13, 2020 Share Posted September 13, 2020 The KalAdharastine Bhairava - Nemesis KapalikaAmidst the many specialized sects and warrior-fraternities of both the Adamanticores and Old Adamantine folk-religion alike (for one was suitably indistinguishable from the other), the exaltation of Law was a common fixation. Yet whilst the 'Iron Masks' pursued the maintenance of civic order, and the Heshrpandits upheld the genomic excellence required for the Realm of Adamantia's fated purpose as Astartes fortress-womb ... the KalAdharastines (occasionally Gothicized as 'Kal-Adrastines') were different. A grim-faced order of terrific killers, their name meant something akin to 'The Blade / Leading Edge / Hand of Kaal' - Kaal being an Old Adamantine theonym for a deity of both Time and Death and bearing the Black colouration of the Dark Night. With slight alteration of inflection, it could also be interpreted to mean 'The Skillful in the Craft', implicitly of Death; and when calqued into the Yavanite languages to Adamantia's West it became 'Kal-Adrastines': understood there as "The Inescapable Kal". Leaving aside that "Kal" could also mean 'Beauty' in those latter languages, the "Inescapable Kaal" conveyed the underlying sense to the KalAdharastas' self-designation. For just as with Time and Death, they were held to be implacable - seeming to be outright 'inevitable' in their pursuit and eventual taking of their prey. Whereas various of those other orders aforementioned focused upon combating generalized threats to the Order of Adamantia , the KalAdharastas took as their mission the targeting and elimination of specific and often highly individual opponents to same.Each particular sub-order specialized in a different form of approach - some favouring the subtlety of stealth or the far-reaching grasp of long-range precision-kills as their particular forms of tribute to the All-Enfolding Death-That-Is-Night. Particularly adroit KalAdharastas would eventually begin to combine to their taste disciplines drawn from multiple of these traditions, becoming truly terrifying masters of the deadly administration of Justice's Harsh Hand. Demarcated from their fellows by bearing an ever-lengthening series of sobriquets alluding to the ways and means with which they could cast their sacred sanction upon Adamantia's foes. The specialization of the Kapalika was, as the name implies, in 'Headtaking'; with the 'Bhairava' cognomen of this particular Adamantine avenger indicating a focus also upon terror. Justice, in other words, being seen to be done - and the psychological affect being generated by the coldly implacable manner of the Astartes stalking forward with the inavoidability of Dusk towards the end of life's day; the massive eviscerator chainblade sweeping down like Night's sudden twilight fall. The 'Kapalika' affiliation of the Astartes is also declared not only via the two partially-flensed skulls that he carries in his right hand, but also by the servo-skull units slaved to his armour, that assist with the operation of certain arcane devices mounted upon his back. Meanwhile, the Cog-Wheel device represents a not uncommon escutcheon for the KalAdharastas - as it is thought to symbolize the inexorable, regular expression of the Law : the central wheel about which all else turns in motion as a result. And hence, once again, the inevitable cycle via which Night follows Day - and the KalAdharasta pursues his quarry til its dissolution. Declaring to would-be usurpers that they shall be ground down between the indefatigable gear-teeth of Order in recompense for their having sought to defy and oppose Reality Itself. History does not record with any great certainty what became of many of the KalAdharastas following the Fall of Adamantia. It is generally presumed that they, along with their Adamanticore brethren, died fighting 'gainst the forces which, with their own seeming inevitability of entropy, sought to lay the stellar domain of Adamantia low. What few remained must have, in a fitting bout of irony, have faded away into the dark obscuring mists of time - or else disappeared into the blackness which lingers betwixt the stars. However, some suggest that their influence lingers still. Analysis of several of the Adamantine Old Faith cults in operation over recent millennia suggest that these have gradually developed features of increasing resemblance to those of known KalAdharasta denominations. It should not take an unreasonably paranoid mind to postulate that these sects may be being actively 'guided' by the embodied Spirits of Vengeance whom they strive to emulate. Perhaps the wheels remain in motion. And perhaps the return of Darkness is merely one bright day away. ---Now, I should note that I can't actually take credit for the conversion-work on this beauty - that was my longstanding collaborator, Umbral's handiwork. I should also get around to posting the rest of the Unyielding Adamanticores that I've done in this thread at some point.In the mean-time, you can check various them , and some sort of fluff / Indo-European mythology & linguistics overload , at Vox Stellarum: Hara Barazaiti. Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5600984 Share on other sites More sharing options...
jaxom Posted September 27, 2020 Share Posted September 27, 2020 Taller than a human, not quite as tall as a Primaris. Dr_Ruminahui and Magos Takatus 2 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5607599 Share on other sites More sharing options...
Jacobite Posted December 7, 2020 Share Posted December 7, 2020 Brother Temrik - The Wanderer Son of Caliban, Astartes, Dark Angel, Firewing, Fallen, Blackshield Loyal 984.M40. Last seen accompanying Ordo Malleus Inquisitor Icarus Var involved in conflict with the Ordo Hereticus Puritan Inquisitor Bartholemu Speare. Current location unknown. Ryltar Thamior, Bjorn Firewalker and Dr_Ruminahui 3 Back to top Link to comment https://bolterandchainsword.com/topic/354055-showcase-true-scale-astartes/page/2/#findComment-5641248 Share on other sites More sharing options...
